Atari 1200XL needs help
12 replies to this topic
#1 hueyjones70 OFFLINE
hueyjones70
    Moonsweeper
  • 316 posts
Posted Wed Dec 5, 2018 8:06 PM
I have a 1200XL that doesn't boot. I get an audio click at power on but nothing on the screen. The power light does not come on but there is power through the switch and power at various places on the board. I have another working 1200XL and I used it to check every chip on the MB. All checked out. I guess that leaves resistors, capacitors, and broken traces. Does any one have any advice based on experience.
#2 DrVenkman OFFLINE
DrVenkman
  • 4,080 posts
  • Back off, man! I'm a scientist.
Posted Wed Dec 5, 2018 8:20 PM
I went through this process a year and a half ago with one of my 1200XL’s, so I feel your pain.
Even though the screen is dark, if you boot with START pressed, do you get the cassette boot sound? If so, you may have a video issue. If you boot with a drive or drive-emulator device attached to the SIO port, do you get any sounds? Have you tried booting STAR RAIDERS, which ID’s itself to the system as a “diagnostic” cart and thus will sometimes boot when the rest of the OS can’t or won’t.
If all the chips on the non-booting machine work in another machine, then there’s the possibility (likelihood?) of either a faulty socket (or three!). Did your swap tests include the OS ROMS and all the support logic as well? On my 1200XL’s, all of those are socketed except the Delay Line chip, which is soldered.
My suggestion is to get the Sam’s 800XL Computerfacts PDF from AtariMania and a cheap logic probe and start seeing if all the chips are producing the expected results when you try to boot the troublesome machine. Even though the schematics aren’t quite accurate for the 1200XL, they are illustrative and you can figure out what you need to by comparing the 800XL stuff with the physical traces on the board in front of you.
Anyway, if the chips are all good, but you’re not getting the expected activity on each pin, the process is then to basically trace backwards along the circuit until you find the problem. It can be time-consuming but this effort will definitely ID what’s working right and what’s not on the board.
#3 hueyjones70 OFFLINE
hueyjones70
    Moonsweeper
  • 316 posts
Posted Wed Dec 5, 2018 10:00 PM
I tried the Star Raiders thing and got nothing. I don't get any kind of reaction on the screen, it is exactly the same as if the monitor is turned off. I had to replace one of the ICs because corrosion had caused two pins to break off. I think I will start checking voltages from the top and bottom of each IC so I can find out if any of the sockets need replacing. Thanks for the input. I read your account of your travails with your two 1200XLs
#4 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,930 posts
Posted Wed Dec 5, 2018 10:42 PM
corroded pins usually match up with corroded socket swipes/wipes. de-oxit the socket, if they are weak or discolored you end up with issues. might as well check them all with de oxit and a magnifying glass
Edited by _The Doctor__, Wed Dec 5, 2018 10:43 PM.
#5 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 390 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Thu Dec 6, 2018 10:51 AM
try the easy things first - have you reseated all the chips? check for corrosion / dry joints on the PCB etc
It would be helpful if you can test your chips in another, known working atari
here is the FSM etc:
#6 _The Doctor__ OFFLINE
_The Doctor__
  • 6,930 posts
Posted Thu Dec 6, 2018 10:56 AM
he already noted he swapped chips between the two 1200's so it was mentioned the chips worked on the known good 1200...
So after socket inspection/ solder joint trace inspection, it might be time to check that last soldered in chip...
what kind of cord or method are you using for monitor/tv connection?
Edited by _The Doctor__, Thu Dec 6, 2018 10:58 AM.
#7 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 390 posts
Posted Thu Dec 6, 2018 11:19 AM
ah, apologies - i shouldve read it fully...
#8 bob1200xl OFFLINE
bob1200xl
  • 2,624 posts
Posted Thu Dec 6, 2018 11:59 AM
You need to try the delay line at some point.
Bob
#9 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 855 posts
Posted Fri Dec 7, 2018 6:51 PM
I've run across two 1200XL's that had weak connections in the sockets.  One was on a RAM socket, and the other was on
one of the ROM sockets.  I've also had a delay chip go bad too.  You might want to look for 5V DC on all the sockets first
and then follow up with the logic probe.  Look for discolored or burned components and also make sure you don't feel any
hot components.  One other thing... Are you using the same power supply on both the good and bad computer?
DavidMil
#10 hueyjones70 OFFLINE
hueyjones70
    Moonsweeper
  • 316 posts
Posted Fri Dec 7, 2018 10:09 PM
Yes to the power supply. I put in a new delay chip because the original was not pocketed and I cut it out, installed a socket and a new chip.
#11 hueyjones70 OFFLINE
hueyjones70
    Moonsweeper
  • 316 posts
Posted Wed Jan 16, 2019 8:30 PM
After testing ever IF on the board, I started on the trouble shooting guide. The problem was one of the 5 volt voltage regulators.
#12 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 390 posts
Posted Thu Jan 17, 2019 9:19 AM
this little baby is a direct drop-in replacement for the 7805:
https://www.ebay.com...bD5TT:rk:1:pf:0
they are switching type so they run ultra-cool. i used a pair in one of my 1050s and its fine. just v.unusual to have a cold 1050 that is powered up!!
#13 hueyjones70 OFFLINE
hueyjones70
    Moonsweeper
  • 316 posts
Posted Thu Jan 17, 2019 7:09 PM
Auto correct got me again, that should have said "every IC".
