DSR error 0094 when I try to use COPY directive in E/A II
77 replies to this topic
#26 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 212 posts
Posted Tue Dec 11, 2018 11:42 AM
I think your memory map is in error, but I can't seem to locate the document where I read about this.  I know that a copy of the File Descriptor Record(FDR) is copied into the VDP memory space.  I'm a little bit shaky on what the copy is called, but I'm calling it the FCB here.  Doesn't there have to be a 256 byte space in there for the FCB for each open file?  It is possible for the buffers to be shared, even if it is a bit messy, but I'm reasonably certain that the TI99 reserves 512 bytes in VDP for each file.
Does anyone know where to find an authoritative source of information on this?
Thank you,
HH
There is a VDP stack area that is allocated downwards from top of VDP. The stack pointer is at >8370.
The disk controller allocates file buffers up there before any other use of the stack.
There is a buffer for sector 0.
Each file buffer contains a 256 byte sector buffer, its first sector FDR (attributes and list of sector clusters) and some file control info.
in Basic for example you invoke CALL FILES(1) then NEW. NEW then rebuilds the stack with just 1 file buffer.
The default number is 3 but Tursi said E/A allocates 4 when it starts.
You need a VDP memory map to show the details. I always relied on the Miller Graphics Smart Programmer issue with an XB VDP memory map.
Here is a good one:
see "TI floppy disk controller card"
I don't know if a program can do some serious damage if it clobbers the top of VDP, where sector 0 VIB is buffered, then tries to write into a new file. Sector 0 has the sector allocation bitmap. Maybe the buffer is reloaded before the next write.
Edited by FarmerPotato, Tue Dec 11, 2018 11:42 AM.
#27 Lee Stewart OFFLINE
Lee Stewart
  • 3,870 posts
Posted Tue Dec 11, 2018 3:18 PM
TI’s Software Specifications for the 99/4 Disk Peripheral is the document from which Thierry Nouspikel (Erik’s [ FarmerPotato ’s] reference above) likely derived his information.  I agree with Erik that Thierry’s chart is a good one.  You can see from it that each open file gets 518 bytes.  The FCB gets 6 bytes of control information in addition to the 256 bytes for the FDR.  In addition, 256 bytes are reserved for a sector’s worth of data—again, pretty much what Erik said.
I believe Harry ( senior_falcon ) has moved this buffer area elsewhere in VRAM by modifying the proper pointers, but you really do not want to mess with its innards at all—unless you wrote the DSR.  As Mark ( Willsy ) has often said, “Here, there be dragons!”
...lee
#28 hhos OFFLINE
hhos
    Space Invader
  • 38 posts
Posted Wed Dec 12, 2018 9:20 AM
Editor Assembler has buffers for use:
>1000 is for Assembler or Editor to be loaded and run
>1100 is for Source file input
>1200 is for Object file output
>1300 is for List file output
>1400 if for Printer or Wafer Tape or Tape output.
I found this excerpt in the documentation that FarmerPotato sent me to:
The cartridge also uses the VDP area to store PABs for file access, and to load the file
themselves.
PAB for Editor, Assembler, edited/printed file, assembly source file, loaded file: >1000-1018
PAB for assembly object file, printer: >1100-1118
PAB for assembly list file: >1200-1218
PAB for file copied during assembly (?): >1300
Assembly source file, edited/printed file: >1080-10CF
Assembly code file data, printer data: >1180-11CF
Assembly list file data: >1280-12CF
Program files (Editor, Assembler, user-defined): >1380-157F
It IDs RXB's addresses as PAB locations in VDP, all except the >1400 one.  I don't think the E/A II that I'm using will accept the cassette as a source or destination, so I'm calling that one invalid. The rest were just misidentified a buffers.  Perhaps the original E/A did accept the cassette, but my one attempt to use my copy of E/A didn't turn out so well, so I won't be trying that again too terribly soon. ;-)   I'll have to rebuild my disk based E/A disk A from an image file first before I do that.
From this it would seem that the >1300 location is the one that isn't working for me when I try to COPY in an external file.  There is also this:
>3580 +-------------------------+
      |        (free)           |
>35D2 +-------------------------+ <--- @>8370
      | File buffers (4 files)  |
>37D8 +-------------------------+ <--- @>8370
      | File buffers (3 files)  |
>3FFF +-------------------------+ VR0=0, VR1=E0, VR7=F5
It looks like there is at least the possibility that E/A will only reserve 3 buffers.  All of which must be dedicated to a specific purpose, whether I use them or not?  Apparently so.  So how do I instruct the assembler to reserve 4 buffers?  Or, are there different versions of the E/A that only allocate 3 buffers?  I am using the E/A II that I downloaded for use with my FlashROM99, so I'm assuming it is a later version, but does it always only provide for 3 buffers?
Thanks to all for the help so far,
HH
#29 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 212 posts
Posted Wed Dec 12, 2018 10:58 AM
themselves.
      |        (free)           |
HH
To be clear,  there are PABs (25 bytes typically) and there are disk buffers (518 bytes each plus overhead).
The disk buffers are owned and manipulated by code in the disk DSR ROM and contain working copies of disk sectors and FDRs. User programs shouldn't need to read or write to them.
The PAB is the thing a program writes to  before calling DSRLNK, (plus it supplies an additional area in VDP to contain 1 record of input or output. (for the disk, the record has to be in VDP.. even though there is a bit flag feature to say if its in VDP or CPU RAM.) PABs (10 bytes structure, plus filename, those shown starting at >1000)  - E/A can have as many as it likes.
Disk buffers don't have a dedicated purpose, they are used and reused in the order that disk files are opened or closed.
The disk (sector) buffers in high VDP are allocated by the "FILES" subroutine on the disk controller, and only limit the number of  disk files that can be open.
You could open a LIST file to RS232 or PIO and it would not use one of the disk buffers. You would have a PAB with 10 bytes plus the  filename string like "RS232.BA=9600", plus one  record buffer (80 bytes ought to be enough.)
It sure sounds like E/A II is not making the "FILES(4)" call or assuming people only send LIST files to the printer.
#30 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Dec 12, 2018 1:11 PM
Thank you,
HH
LOL DOCUMENT?
How about GPL SOURCE CODE OF Editor Assembler Cartridge?
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0001
Version 2.0 (Weiand 1985)     Options : LCSFPF#########
[0001]               ***********************************************************
[0002]                      GROM >E000
[0003]                      AORG >0000
[0004]                      TITL  'Rich E/A GROM'
[0005]               ***********************************************************
[0006]               * CPU
[0007]               *
[0008] 8300          TMP    EQU   >8300
[0009] 8301          TMP1   EQU   >8301
[0010] 8302          TMP2   EQU   >8302
[0011] 8303          TMP3   EQU   >8303
[0012] 8304          TMP4   EQU   >8304
[0013] 8306          TMP6   EQU   >8306
[0014] 8307          TMP7   EQU   >8307
[0015] 8308          TMP8   EQU   >8308
[0016] 8310          SCADD  EQU   >8310
[0017] 8311          SCADE  EQU   >8311
[0018] 8316          TEMP   EQU   >8316
[0019] 8317          TEMP1  EQU   >8317
[0020] 8318          CHRCUR EQU   >8318
[0021] 831C          PABPTR EQU   >831C
[0022] 831E          COUNT  EQU   >831E            CATALOG COUNT FILES
[0023] 8320          CURADD EQU   >8320
[0024] 8322          CODE   EQU   >8322
[0025] 8324          STLN   EQU   >8324
[0026] 8326          ENDLN  EQU   >8326
[0027] 8342          XTOKEN EQU   >8342
[0028] 8347          LDFLAG EQU   >8347
[0029] 8348          FLAG   EQU   >8348
[0030] 8349          FLAG2  EQU   >8349
[0031] 834A          FAC    EQU   >834A
[0032] 834B          FAC1   EQU   >834B
[0033] 834C          FAC2   EQU   >834C
[0034] 834D          FAC3   EQU   >834D
[0035] 834E          FAC4   EQU   >834E
[0036] 834F          FAC5   EQU   >834F
[0037] 8350          FAC6   EQU   >8350
[0038] 8351          FAC7   EQU   >8351
[0039] 8352          FAC8   EQU   >8352
[0040] 8353          FAC9   EQU   >8353
[0041] 8354          ERCODE EQU   >8354
[0042] 8355          FAC11  EQU   >8355
[0043] 8356          FAC12  EQU   >8356
[0044] 8356          VPAB   EQU   >8356
[0045] 835C          ARG    EQU   >835C
[0046] 835D          ARG1   EQU   >835D
[0047] 835E          ARG2   EQU   >835E
[0048] 8360          ARG4   EQU   >8360
[0049] 8362          ARG6   EQU   >8362
[0050] 836E          VSTACK EQU   >836E
[0051] 8373          SUBSTK EQU   >8373
[0052] 8374          KBNO   EQU   >8374
[0053] 8375          KEY    EQU   >8375
[0054] 8379          ITIMER EQU   >8379
[0055] 837D          VCHAR  EQU   >837D
[0056]               ********************
[0057]               * GENERAL
[0058]               *
[0059] 0001          AID    EQU   1
[0060] 0002          CLEAR  EQU   2
[0061] 0006          REDO   EQU   6
[0062] 000C          PROCD  EQU   12
[0063] 000D          ENTER  EQU   13
[0064] 000E          BEGIN  EQU   14
[0065] 000F          BACK   EQU   15
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0002
Rich E/A GROM
[0066] 0020          SPACE  EQU   32
[0067]               * XML's ************
[0068]               *
[0069] 0002          ROUND  EQU   >02
[0070] 0023          CIF    EQU   >23
[0071]               * VDP **************
[0072]               *
[0073] 077F          COLOR  EQU   >077F
[0074]               * GROM *************
[0075]               *
[0076] 0010          DSRLNK EQU   >0010
[0077] 0012          DSRRET EQU   >0012
[0078] 001C          BERR   EQU   >001C
[0079] 0038          BGETSS EQU   >0038
[0080] 6372          RXB    EQU   >6372
[0081]               ***********************************************************
[0082]               * GROM Header
[0083] E000 AA              BYTE  >AA              * Header byte
[0084] E001 0B              BYTE  11               * Version #
[0085] E002 01              BYTE  1                * # programs
[0086] E003 00              BYTE  0                * Reserved
[0087] E004 00,00           DATA >0000             * POWER UP
[0088] E006 E0,10           DATA  MENU             * Cartridge menu
[0089] E008 F6,F2           DATA  EADSR            * DSRs
[0090] E00A 00,00           DATA  >0000            * Subroutines
[0091] E00C 00,00           DATA  >0000            * Interupts
[0092] E00E 00,00           DATA  >0000            * TI BASIC
[0093] E010 00,00    MENU   DATA  >0000
[0094] E012 E0,25           DATA  SETUP
[0095] E014 10,52,45        STRI  'REA VERSION 2015'
       E017 41,20,56
       E01A 45,52,53
       E01D 49,4F,4E
       E020 20,32,30
       E023 31,35
[0096]               *********************************************************
[0097]               * Set up configure paths
[0098] E025 D6,AE,FF SETUP  CEQ   >99,V@>0EFF      PREVIOUS RUN FLAG SET?
       E028 99
[0099] E029 60,6C           BS    SOLDEA           Yes
[0100] E02B BE,AE,FF        ST    >99,V@>0EFF      No, SET PREVIOUS RUN FLAG
       E02E 99
[0101] E02F 86,AF,0F        CLR   V@>0F00
       E032 00
[0102] E033 35,00,FF        MOVE  >FF,V@>0F00,V@>0F01
       E036 AF,0F,01
       E039 AF,0F,00
[0103] E03C 31,00,0B        MOVE  11,G@C1,V@>0F00  DSK1.EDIT1
       E03F AF,0F,00
       E042 F7,22
[0104] E044 31,00,0B        MOVE  11,G@C2,V@>0F28  DSK1.ASSM1
       E047 AF,0F,28
       E04A F7,2D
[0105] E04C 31,00,0C        MOVE  12,G@C3,V@>0F50  DSK1.SOURCE
       E04F AF,0F,50
       E052 F7,38
[0106] E054 31,00,0C        MOVE  12,G@C4,V@>0F78  DSK1.OBJECT
       E057 AF,0F,78
       E05A F7,44
[0107] E05C 31,00,0A        MOVE  10,G@C5,V@>0FA0  DSK1.LIST
       E05F AF,0F,A0
       E062 F7,50
[0108] E064 31,00,02        MOVE  2,G@C6,V@>0FC8   L
       E067 AF,0F,C8
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0003
Rich E/A GROM
       E06A F7,5A
[0109]               * NORMAL RXB START OF EA MODULE
[0110] E06C 06,E8,14 SOLDEA CALL  NESCRN
[0111] E06F CA,42,38 OLDEA  CHE   >38,@XTOKEN      Flag to high?
[0112] E072 60,79           BS    CLREA            Yes
[0113] E074 CA,42,31        CHE   >31,@XTOKEN      Flag set?
[0114] E077 60,82           BS    NEWEA            yes
[0115] E079 06,ED,67 CLREA  CALL  CLRREA
[0116] E07C 86,42           CLR   @XTOKEN          Reset RXB flag
[0117] E07E 86,AF,3E        CLR   V@>3EF0   Clear RXB MENU Flag
       E081 F0
[0118] E082 87,8F,9D NEWEA  DCLR  @>2000
       E085 00
[0119] E086 06,E8,1A GE029  CALL  EASCRN
[0120] E089 86,44           CLR   @>8344           * Disk SEARCH FLAG
[0121] E08B BF,4A,0B        DST   >0B00,@FAC
       E08E 00
[0122] E08F 06,00,4A        CALL  UPCASE
[0123] E092 BE,74,05 GE056  ST    5,@KBNO
[0124] E095 BF,4A,09        DST   >0900,@FAC
       E098 00
[0125] E099 06,00,18        CALL  LOCASE
[0126] E09C 86,A8,00        CLR   V@>0800
[0127] E09F 35,00,FF        MOVE  >00FF,V@>0800,V@>0801
       E0A2 A8,01,A8
       E0A5 00
[0128] E0A6 39,00,06        MOVE  6,G@VREGS,#1
       E0A9 01,F8,BE
[0129] E0AC 86,AF,10        CLR   V@>1000          * CLEAR PAB AREAS
       E0AF 00
[0130] E0B0 35,03,80        MOVE  >0380,V@>1000,V@>1001
       E0B3 AF,10,01
       E0B6 AF,10,00
[0131] E0B9 B2,80,C2        AND   >EF,@>83C2
       E0BC EF
[0132] E0BD 31,00,10        MOVE  16,G@CURPAT,V@>08F0
       E0C0 A8,F0,F8
       E0C3 9E
[0133] E0C4 31,00,10        MOVE  16,G@DARROW,V@>0C10
       E0C7 AC,10,F8
       E0CA AE
[0134]               *
[0135]               *  Display Main Menu
[0136]               *
[0137] E0CB BE,73,7E MMENU  ST    >7E,@SUBSTK       * Set SUBSTACK
[0138] E0CE 87,22           DCLR  @CODE
[0139] E0D0 87,48           DCLR  @FLAG
[0140] E0D2 86,47           CLR   @LDFLAG
[0141] E0D4 07,20           ALL   SPACE
[0142] E0D6 CA,42,38 GE116  CHE   >38,@XTOKEN
[0143] E0D9 60,E0           BS    MSCRN
[0144] E0DB CA,42,31        CHE   >31,@XTOKEN
[0145] E0DE 61,AA           BS    MYEAXB
[0146] E0E0 87,7E    MSCRN  HOME
[0147] E0E2 08              FMT
[0148] E0E3 FF,01           COL   1
[0149] E0E5 1D,52,69        HTEX  'Rich Editor & Assembler V=2015'
       E0E8 63,68,20
       E0EB 45,64,69
       E0EE 74,6F,72
       E0F1 20,26,20
       E0F4 41,73,73
       E0F7 65,6D,62
       E0FA 6C,65,72
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0004
Rich E/A GROM
       E0FD 20,56,3D
       E100 32,30,31
       E103 35
[0150] E104 A0              ROW+  1
[0151] E105 FF,00           COL   0
[0152] E107 5F,5F           HCHA  32,95
[0153] E109 A1              ROW+  2
[0154] E10A FF,06           COL   6
[0155] E10C 12,53,20        HTEX  'S    SET PATH NAMES'
       E10F 20,20,20
       E112 53,45,54
       E115 20,50,41
       E118 54,48,20
       E11B 4E,41,4D
       E11E 45,53
[0156] E120 A3              ROW+  4
[0157] E121 FF,06           COL   6
[0158] E123 0D,44,20        HTEX  'D    DIRECTORY'
       E126 20,20,20
       E129 44,49,52
       E12C 45,43,54
       E12F 4F,52,59
[0159] E132 A2              ROW+  3
[0160] E133 FF,06           COL   6
[0161] E135 0D,41,20        HTEX  'A    ASSEMBLER'
       E138 20,20,20
       E13B 41,53,53
       E13E 45,4D,42
       E141 4C,45,52
[0162] E144 A1              ROW+  2
[0163] E145 FF,06           COL   6
[0164] E147 0A,45,20        HTEX  'E    EDITOR'
       E14A 20,20,20
       E14D 45,44,49
       E150 54,4F,52
[0165] E153 A1              ROW+  2
[0166] E154 FF,06           COL   6
[0167] E156 0E,58,20        HTEX  'X    XB PROGRAM'
       E159 20,20,20
       E15C 58,42,20
       E15F 50,52,4F
       E162 47,52,41
       E165 4D
[0168] E166 A1              ROW+  2
[0169] E167 FF,06           COL   6
[0170] E169 10,4C,20        HTEX  'L    LOAD and RUN'
       E16C 20,20,20
       E16F 4C,4F,41
       E172 44,20,61
       E175 6E,64,20
       E178 52,55,4E
[0171] E17B A1              ROW+  2
[0172] E17C FF,06           COL   6
[0173] E17E 10,50,20        HTEX  'P    PROGRAM FILE'
       E181 20,20,20
       E184 50,52,4F
       E187 47,52,41
       E18A 4D,20,46
       E18D 49,4C,45
[0174] E190 A3              ROW+  4
[0175] E191 FF,06           COL   6
[0176] E193 09,2E,20        HTEX  '.    R X B'
       E196 20,20,20
       E199 52,20,58
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0005
Rich E/A GROM
       E19C 20,42
[0177] E19E FB              FEND
[0178] E19F 03       NEWSCN SCAN
[0179] E1A0 41,9F           BR    NEWSCN
[0180] E1A2 D6,75,2E        CEQ   >2E,@KEY         * .?
[0181] E1A5 41,B4           BR    NSCAN            * Yes
[0182] E1A7 05,63,72 RTRXB  B     RXB              * Go RXB
[0183] E1AA 87,AF,22 MYEAXB DCLR  V@>2250          * Clear Pass flag
       E1AD 50
[0184] E1AE BC,75,42        ST    @XTOKEN,@KEY
[0185] E1B1 BE,42,EA        ST    >EA,@XTOKEN      * Load Flag
[0186] E1B4 D6,75,4C NSCAN  CEQ   'L',@KEY         * L?
[0187] E1B7 61,C3           BS    NSCAN1
[0188] E1B9 D6,75,6C        CEQ   'l',@KEY         * l?
[0189] E1BC 61,C3           BS    NSCAN1
[0190] E1BE D6,75,33        CEQ   '3',@KEY         * 3?
[0191] E1C1 41,CB           BR    NSCAN2
[0192] E1C3 BE,75,33 NSCAN1 ST    >33,@KEY         * Set LOAD & RUN
[0193] E1C6 D6,75,33        CEQ   >33,@KEY         * LOAD AND RUN?
[0194] E1C9 6A,0F           BS    LANDR
[0195] E1CB D6,75,50 NSCAN2 CEQ   'P',@KEY         * P?
[0196] E1CE 61,DA           BS    NSCAN3
[0197] E1D0 D6,75,70        CEQ   'p',@KEY         * p?
[0198] E1D3 61,DA           BS    NSCAN3
[0199] E1D5 D6,75,35        CEQ   '5',@KEY         * 5
[0200] E1D8 41,E2           BR    NSCAN4
[0201] E1DA BE,75,35 NSCAN3 ST    >35,@KEY         * SET RUN PROGRAM
[0202] E1DD D6,75,35        CEQ   >35,@KEY         * PROGRAM?
[0203] E1E0 6B,E8           BS    PRGRM
[0204] E1E2 D6,75,41 NSCAN4 CEQ   'A',@KEY         * A?
[0205] E1E5 61,F1           BS    NSCAN5
[0206] E1E7 D6,75,61        CEQ   'a',@KEY         * a?
[0207] E1EA 61,F1           BS    NSCAN5
[0208] E1EC D6,75,32        CEQ   '2',@KEY         * 2?
[0209] E1EF 41,F9           BR    NSCAN6
[0210] E1F1 BE,75,32 NSCAN5 ST    >32,@KEY         * SET ASSEMBLER
[0211] E1F4 D6,75,32        CEQ   >32,@KEY         * ASSEMBLER?
[0212] E1F7 68,4F           BS    ASSEM
[0213] E1F9 D6,75,45 NSCAN6 CEQ   'E',@KEY         * E?
[0214] E1FC 62,08           BS    NSCAN7
[0215] E1FE D6,75,65        CEQ   'e',@KEY         * e?
[0216] E201 62,08           BS    NSCAN7
[0217] E203 D6,75,31        CEQ   '1',@KEY         * 1?
[0218] E206 42,10           BR    NSCAN8
[0219] E208 BE,75,31 NSCAN7 ST    >31,@KEY         * SET EDITOR
[0220] E20B D6,75,31        CEQ   >31,@KEY         * EDITOR?
[0221] E20E 63,8D           BS    EDITOR
[0222] E210 D6,75,44 NSCAN8 CEQ   'D',@KEY         * D?
[0223] E213 6D,C9           BS    DIRECT
[0224] E215 D6,75,64        CEQ   'd',@KEY         * d?
[0225] E218 6D,C9           BS    DIRECT
[0226] E21A D6,75,58        CEQ   'X',@KEY         * X?
[0227] E21D 6C,DB           BS    XBINP
[0228] E21F D6,75,78        CEQ   'x',@KEY         * x?
[0229] E222 6C,DB           BS    XBINP
[0230] E224 D6,75,53        CEQ   'S',@KEY         * S?
[0231] E227 62,2E           BS    CONFIG
[0232] E229 D6,75,73        CEQ   's',@KEY         * s?
[0233] E22C 41,9F           BR    NEWSCN
[0234]               ******************************************************
[0235]               * CONFIGURE PATHS
[0236]               *
[0237] E22E 06,E8,1A CONFIG CALL  EASCRN
[0238] E231 86,42           CLR   @XTOKEN
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0006
Rich E/A GROM
[0239] E233 06,ED,67        CALL  CLRREA
[0240] E236 07,20           ALL   SPACE
[0241] E238 87,7E           HOME
[0242] E23A 08              FMT
[0243] E23B FF,06           COL   6
[0244] E23D 12,2A,20        HTEX  '* CONFIGURE PATHS *'
       E240 43,4F,4E
       E243 46,49,47
       E246 55,52,45
       E249 20,50,41
       E24C 54,48,53
       E24F 20,2A
[0245] E251 FB              FEND
[0246] E252 BE,A0,41        ST    49,V@65            1
       E255 31
[0247] E256 35,00,28        MOVE  40,V@>0F00,V@67    DSK1.EDIT1
       E259 A0,43,AF
       E25C 0F,00
[0248] E25E BE,A0,A1        ST    50,V@161           2
       E261 32
[0249] E262 35,00,28        MOVE  40,V@>0F28,V@163   DSK1.ASSM1
       E265 A0,A3,AF
       E268 0F,28
[0250] E26A BE,A1,01        ST    51,V@257           3
       E26D 33
[0251] E26E 35,00,28        MOVE  40,V@>0F50,V@259   DSK1.SOURCE
       E271 A1,03,AF
       E274 0F,50
[0252] E276 BE,A1,61        ST    52,V@353
       E279 34
[0253] E27A 35,00,28        MOVE  40,V@>0F78,V@355   DSK1.OBJECT
       E27D A1,63,AF
       E280 0F,78
[0254] E282 BE,A1,C1        ST    53,V@449           5
       E285 35
[0255] E286 35,00,28        MOVE  40,V@>0FA0,V@451   DSK1.LIST
       E289 A1,C3,AF
       E28C 0F,A0
[0256] E28E 08              FMT
[0257] E28F FE,11           ROW   17
[0258] E291 FF,01           COL   1
[0259] E293 0A,36,20        HTEX  '6  OPTIONS:'
       E296 20,4F,50
       E299 54,49,4F
       E29C 4E,53,3A
[0260] E29F FE,15           ROW   21
[0261] E2A1 FF,04           COL   4
[0262] E2A3 19,43,54        HTEX  'CTRL 1 - 5 DRIVE SELECTION'
       E2A6 52,4C,20
       E2A9 31,20,2D
       E2AC 20,35,20
       E2AF 44,52,49
       E2B2 56,45,20
       E2B5 53,45,4C
       E2B8 45,43,54
       E2BB 49,4F,4E
[0263] E2BE FE,17           ROW   23
[0264] E2C0 FF,04           COL   4
[0265] E2C2 19,41,4E        HTEX  'ANY OTHER KEY TO MAIN MENU'
       E2C5 59,20,4F
       E2C8 54,48,45
       E2CB 52,20,4B
       E2CE 45,59,20
       E2D1 54,4F,20
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0007
Rich E/A GROM
       E2D4 4D,41,49
       E2D7 4E,20,4D
       E2DA 45,4E,55
[0266] E2DD FB              FEND
[0267] E2DE 35,00,28        MOVE  40,V@>0FC8,V@556   OPTIONS: L
       E2E1 A2,2C,AF
       E2E4 0F,C8
[0268] E2E6 03       CONFIH SCAN
[0269] E2E7 42,E6           BR    CONFIH
[0270] E2E9 CA,75,37        CHE   '7',@KEY        <7?
[0271] E2EC 63,42           BS    CONFIL          Exit out
[0272] E2EE CA,75,31        CHE   '1',@KEY        1 to 6 only valid
[0273] E2F1 40,79           BR    CLREA           Exit out
[0274] E2F3 BF,20,00        DST   65,@CURADD      Cursor Location
       E2F6 41
[0275] E2F7 CA,75,30        CHE   >30,@KEY        KEY>48?
[0276] E2FA 42,E6           BR    CONFIH
[0277] E2FC A6,75,30        SUB   >30,@KEY        KEY-48
[0278] E2FF BC,00,75        ST    @KEY,@TMP       Save key 0-5
[0279] E302 BC,08,75        ST    @KEY,@TMP8      Save key 1-6
[0280] E305 92,00           DEC   @TMP            -1
[0281] E307 AA,00,60        MUL   96,@TMP         Add 64 Cursor Address
[0282] E30A A1,20,00        DADD  @TMP,@CURADD    Cursor address
[0283] E30D BE,B0,20        ST    130,V*CURADD    Left Arrow
       E310 82
[0284] E311 A3,20,00        DADD  35,@CURADD      Cursor
       E314 23
[0285] E315 BD,04,20        DST   @CURADD,@TMP4   Save address
[0286] E318 06,E6,C4 CONFIJ CALL  GETINP          Get input
[0287] E31B 8F,50           DCZ   @FAC6           Length 0?
[0288] E31D 62,2E           BS    CONFIG
[0289] E31F CA,4A,27        CHE   39,@FAC         <39?
[0290] E322 62,2E           BS    CONFIG
[0291] E324 87,06           DCLR  @TMP6           Index
[0292] E326 A3,06,00 CONFIK DADD  40,@TMP6        Index+40
       E329 28
[0293] E32A 92,08           DEC   @TMP8           Copy of KEY
[0294] E32C 43,26           BR    CONFIK
[0295] E32E BC,EE,D8        ST    @FAC7,V@>0ED8(@TMP6)  Length
       E331 06,51
[0296] E333 35,00,27        MOVE  39,V*TMP4,V@>0ED9(@TMP6) String
       E336 EE,D9,06
       E339 B0,04
[0297] E33B 42,2E           BR    CONFIG
[0298] E33D BE,42,EA MMMENU ST    >EA,@XTOKEN     Set flag
[0299] E340 40,CB           BR    MMENU           Exit
[0300]               * CTRL keys ***************************************
[0301] E342 CA,75,B6 CONFIL CHE   182,@KEY        CTRL 5?
[0302] E345 62,2E           BS    CONFIG
[0303] E347 CA,75,B1        CHE   177,@KEY
[0304] E34A 42,2E           BR    CONFIG
[0305] E34C 06,00,34        CALL  ACCTON          ACCEPT TONE
[0306] E34F BC,04,75        ST    @KEY,@TMP4      SAVE KEY
[0307] E352 A6,04,B0        SUB   176,@TMP4       CTRL=1 to 5
[0308] E355 87,5C           DCLR  @ARG
[0309] E357 BF,00,FF        DST   -25,@TMP        SCREEN ADDRESS
       E35A E7
[0310] E35B BF,5C,0E        DST   >0EDC,@ARG      MEMORY ADDRESS
       E35E DC
[0311] E35F A3,5C,00 CONFLP DADD  40,@ARG         40*VALUE
       E362 28
[0312] E363 A3,00,00        DADD  96,@TMP         96*VALUE
       E366 60
[0313] E367 92,04           DEC   @TMP4
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0008
Rich E/A GROM
[0314] E369 43,5F           BR    CONFLP
[0315] E36B BE,06,1E        ST    30,@TMP6
[0316] E36E BF,02,01 CONDEU DST   >0160,@TMP2     COUNTER
       E371 60
[0317] E372 03       CONDEV SCAN
[0318] E373 63,80           BS    CONDST
[0319] E375 93,02           DDEC  @TMP2           COUNTER-1
[0320] E377 43,72           BR    CONDEV
[0321] E379 C0,06,B0        EX    V*TMP,@TMP6     SWAP
       E37C 00
[0322] E37D 05,E3,6E        B     CONDEU
[0323] E380 06,00,34 CONDST CALL  ACCTON
[0324] E383 BC,B0,00        ST    @KEY,V*TMP      SCREEN ADDRESS #
       E386 75
[0325] E387 BC,B0,5C        ST    @KEY,V*ARG      MEMORY ADDRESS #
       E38A 75
[0326] E38B 42,2E           BR    CONFIG
[0327]               **************************************************
[0328]               *  Main Menu Option 1: EDIT
[0329]               *
[0330] E38D 06,E8,1A EDITOR CALL  EASCRN
[0331] E390 87,48           DCLR  @FLAG
[0332] E392 86,47           CLR   @LDFLAG
[0333] E394 BE,42,EA        ST    >EA,@XTOKEN
[0334] E397 08              FMT
[0335] E398 FF,0B           COL   >0B
[0336] E39A FE,01           ROW   1
[0337] E39C 09,2A,20        HTEX  '* EDITOR *'
       E39F 45,44,49
       E3A2 54,4F,52
       E3A5 20,2A
[0338] E3A7 A2              ROW+  3
[0339] E3A8 FF,03           COL   3
[0340] E3AA 08,31,20        HTEX  '1    LOAD'
       E3AD 20,20,20
       E3B0 4C,4F,41
       E3B3 44
[0341] E3B4 A0              ROW+  1
[0342] E3B5 96              COL+  23
[0343] E3B6 08,32,20        HTEX  '2    EDIT'
       E3B9 20,20,20
       E3BC 45,44,49
       E3BF 54
[0344] E3C0 A0              ROW+  1
[0345] E3C1 96              COL+  23
[0346] E3C2 08,33,20        HTEX  '3    SAVE'
       E3C5 20,20,20
       E3C8 53,41,56
       E3CB 45
[0347] E3CC A0              ROW+  1
[0348] E3CD 96              COL+  23
[0349] E3CE 09,34,20        HTEX  '4    PRINT'
       E3D1 20,20,20
       E3D4 50,52,49
       E3D7 4E,54
[0350] E3D9 A0              ROW+  1
[0351] E3DA 95              COL+  22
[0352] E3DB 09,35,20        HTEX  '5    PURGE'
       E3DE 20,20,20
       E3E1 50,55,52
       E3E4 47,45
[0353] E3E6 A0              ROW+  1
[0354] E3E7 95              COL+  22
[0355] E3E8 FB              FEND
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0009
Rich E/A GROM
[0356] E3E9 03       GE19B  SCAN
[0357] E3EA 43,E9           BR    GE19B
[0358] E3EC D6,75,0F        CEQ   BACK,@KEY       * BACK KEY
[0359] E3EF 60,79           BS    CLREA
[0360] E3F1 A6,75,31        SUB   >31,@KEY
[0361] E3F4 CA,75,06        CHE   >06,@KEY
[0362] E3F7 63,E9           BS    GE19B
[0363] E3F9 87,48           DCLR  @FLAG
[0364] E3FB BE,73,7E        ST    >7E,@SUBSTK
[0365] E3FE BC,00,75        ST    @KEY,@TMP       * Save KEY
[0366] E401 AA,00,40        MUL   >40,@TMP
[0367] E404 BF,20,00        DST   >0082,@CURADD
       E407 82
[0368] E408 A1,20,00        DADD  @TMP,@CURADD
[0369] E40B BE,B0,20        ST    130,V*CURADD    * SHOW ARROW
       E40E 82
[0370] E40F BC,04,75        ST    @KEY,@TMP4
[0371] E412 D6,75,04        CEQ   4,@KEY          * PURGE?
[0372] E415 44,3C           BR    GE1E4           * No, next check
[0373]               *  Edit Menu Option 5: PURGE
[0374] E417 08              FMT
[0375] E418 A1              ROW+  2
[0376] E419 13,41,72        HTEX  'Are you sure (Y/N)? '
       E41C 65,20,79
       E41F 6F,75,20
       E422 73,75,72
       E425 65,20,28
       E428 59,2F,4E
       E42B 29,3F,20
[0377] E42E FB              FEND
[0378] E42F 06,E9,E8        CALL  YESNO
[0379] E432 D6,75,59        CEQ   >59,@KEY
[0380] E435 43,8D           BR    EDITOR
[0381] E437 06,E8,41        CALL  CLRXOP
[0382] E43A 43,8D    GE1E2  BR    EDITOR
[0383] E43C D6,75,03 GE1E4  CEQ   >03,@KEY         * PRINT?
[0384] E43F 64,C3           BS    GE237            * YES!
[0385] E441 D7,8F,9D        DCEQ  >55AA,@>2000     * EDIT1 loaded?
       E444 00,55,AA
[0386] E447 64,85           BS    GE1FC            * Yes
[0387] E449 35,00,63        MOVE  99,V@>2250,@>EA00
       E44C 8F,67,00
       E44F AF,22,50
[0388] E452 BC,8F,7C        ST    @XTOKEN,@>FFFB
       E455 FB,42
[0389] E457 06,F6,55        CALL  P1000
[0390] E45A 06,ED,96        CALL  NPAB
[0391] E45D 35,00,28        MOVE  40,V@>0F00,V@>1009  Get configured path EDIT1
       E460 AF,10,09
       E463 AF,0F,00
[0392] E466 BE,47,01        ST    1,@LDFLAG           Set Editor flag
[0393] E469 06,EC,9B GE1F6  CALL  PGMLOD
[0394] E46C D7,8F,9D        DCEQ  >55AA,@>2000
       E46F 00,55,AA
[0395] E472 43,8D           BR    EDITOR
[0396] E474 06,E8,41        CALL  CLRXOP
[0397] E477 35,00,63        MOVE  99,@>EA00,V@>2250
       E47A AF,22,50
       E47D 8F,67,00
[0398] E480 BC,42,8F        ST    @>FFFB,@XTOKEN
       E483 7C,FB
[0399] E485 D6,04,01 GE1FC  CEQ   >01,@TMP4       * Edit?
[0400] E488 65,1D           BS    EMOPT2          * Yes
[0401] E48A D6,04,02        CEQ   >02,@TMP4       * Save?
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0010
Rich E/A GROM
[0402] E48D 44,C3           BR    GE237           * No
[0403]               *  Edit Menu Option 3: SAVE
[0404] E48F 86,42           CLR   @XTOKEN
[0405] E491 08              FMT
[0406] E492 FF,02           COL   2
[0407] E494 FE,10           ROW   16
[0408] E496 12,44,56        HTEX  'DV80 Format (Y/N)? '
       E499 38,30,20
       E49C 46,6F,72
       E49F 6D,61,74
       E4A2 20,28,59
       E4A5 2F,4E,29
       E4A8 3F,20
[0409] E4AA FB              FEND
[0410] E4AB 06,E9,E8        CALL  YESNO
[0411] E4AE D6,75,59        CEQ   >59,@KEY
[0412] E4B1 44,B6           BR    GE22C
[0413] E4B3 B6,49,02        OR    >02,@FLAG2
[0414] E4B6 D6,75,0F GE22C  CEQ   BACK,@KEY
[0415] E4B9 63,8D           BS    EDITOR
[0416] E4BB BF,20,02        DST   >0262,@CURADD
       E4BE 62
[0417] E4BF 44,CE           BR    GE23B
[0418] E4C1 86,42    GE235  CLR   @XTOKEN          * CLEAR XTOKEN FLAG
[0419] E4C3 BF,20,02 GE237  DST   >0202,@CURADD    * Print or Load
       E4C6 02
[0420] E4C7 35,00,FF        MOVE  255,V@>0200,V@>201
       E4CA A2,01,A2
       E4CD 00
[0421] E4CE 31,00,0A GE23B  MOVE  10,G@FPATH,V*CURADD
       E4D1 B0,20,F8
       E4D4 80
[0422] E4D5 A3,20,00        DADD  >0040,@CURADD
       E4D8 40
[0423]               * CONFIGURE PATH SOURCE *********************************
[0424] E4D9 87,16           DCLR @TEMP
[0425] E4DB BC,17,AF        ST   V@>0F50,@TEMP1
       E4DE 0F,50
[0426] E4E0 BD,AF,22        DST  @TEMP,V@>2255
       E4E3 55,16
[0427] E4E5 34,16,AF        MOVE @TEMP,V@>0F51,V@>2257 Save as SOURCE
       E4E8 22,57,AF
       E4EB 0F,51
[0428] E4ED BE,EF,22        ST   >0D,V@>2258(@TEMP)
       E4F0 58,16,0D
[0429]
[0430] E4F3 CA,04,02        CHE   >02,@TMP4       SAVE, PRINT ?
[0431] E4F6 65,07           BS    EINPUT
[0432] E4F8 D6,42,EA        CEQ   >EA,@XTOKEN
[0433] E4FB 65,07           BS    EINPUT
[0434] E4FD 45,07           BR    EINPUT
[0435] E4FF 06,E6,8A        CALL  BLNKBU
[0436] E502 06,E6,59        CALL  BLDPAB
[0437] E505 45,0A           BR    EMOPT1
[0438] E507 06,E6,56 EINPUT CALL  GETALL
[0439] E50A D6,75,0F EMOPT1 CEQ   BACK,@KEY       * BACK?
[0440] E50D 60,79           BS    CLREA
[0441] E50F D6,04,02        CEQ   >02,@TMP4       * Save?
[0442] E512 65,6C           BS    GE2B5
[0443] E514 D6,04,03        CEQ   >03,@TMP4       * Print?
[0444] E517 65,90           BS    GE2D9
[0445] E519 8E,04           CZ    @TMP4           * Load?
[0446] E51B 65,26           BS    GE272
[0447]               *  Edit Menu Option 2: EDIT
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0011
Rich E/A GROM
[0448] E51D 0F,23    EMOPT2 XML   >23
[0449] E51F 74,60           BS    GE8B0
[0450] E521 06,F4,B2        CALL  GE8FC
[0451] E524 43,8D           BR    EDITOR
[0452] E526 BE,42,EA GE272  ST    >EA,@XTOKEN     SET XTOKEN
[0453] E529 06,E5,32        CALL  GE27B
[0454] E52C 0F,21           XML   >21
[0455] E52E 74,63           BS    GE8B3
[0456] E530 43,8D           BR    EDITOR
[0457]               *********************************************
[0458] E532 BE,E0,01 GE27B  ST    >04,V@1(@PABPTR)
       E535 1C,04
[0459] E537 B2,49,FD        AND   >FD,@FLAG2
[0460] E53A BD,56,1C GE283  DST   @PABPTR,@VPAB
[0461] E53D A3,56,00        DADD  >0009,@VPAB
       E540 09
[0462] E541 06,00,10        CALL  DSRLNK
[0463] E544 08              BYTE  >08
[0464] E545 75,0E           BS    CHKERR
[0465] E547 DA,E0,01        CLOG  >E0,V@1(@PABPTR)
       E54A 1C,E0
[0466] E54C 45,53           BR    GE29C
[0467] E54E BE,B0,1C        ST    >02,V*PABPTR
       E551 02
[0468] E552 00              RTN
[0469]               **********************************************
[0470] E553 BC,00,E0 GE29C  ST    V@1(@PABPTR),@TMP
       E556 01,1C
[0471] E558 B2,00,1F        AND   >1F,@TMP
[0472] E55B D6,00,04        CEQ   >04,@TMP
[0473] E55E 45,6A           BR    GE2B3
[0474] E560 BE,E0,01        ST    >14,V@1(@PABPTR)
       E563 1C,14
[0475] E565 B6,49,02        OR    >02,@FLAG2
[0476] E568 45,3A           BR    GE283
[0477] E56A 55,0E    GE2B3  BR    CHKERR
[0478] E56C BE,E0,01 GE2B5  ST    >02,V@1(@PABPTR)
       E56F 1C,02
[0479] E571 DA,49,02        CLOG  >02,@FLAG2
[0480] E574 65,7B           BS    GE2C4
[0481] E576 BE,E0,01        ST    >12,V@1(@PABPTR)
       E579 1C,12
[0482] E57B 06,E6,A3 GE2C4  CALL  DOIO
[0483] E57E BE,B0,1C        ST    >03,V*PABPTR
       E581 03
[0484] E582 BE,E0,05        ST    >50,V@5(@PABPTR)
       E585 1C,50
[0485] E587 0F,22           XML   >22
[0486] E589 74,63           BS    GE8B3
[0487] E58B 06,E6,9F        CALL  CLOSE
[0488] E58E 43,8D           BR    EDITOR
[0489]               * Edit Menu Option 4 : PRINT output
[0490] E590 06,E5,32 GE2D9  CALL  GE27B
[0491] E593 08              FMT
[0492] E594 FF,02           COL   2
[0493] E596 FE,14           ROW   20
[0494] E598 0B,44,45        HTEX  'DEVICE NAME?'
       E59B 56,49,43
       E59E 45,20,4E
       E5A1 41,4D,45
       E5A4 3F
[0495] E5A5 FB              FEND
[0496] E5A6 BF,20,02        DST   >02C2,@CURADD   * Cursor Address
       E5A9 C2
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0012
Rich E/A GROM
[0497] E5AA BF,1C,11        DST   >1100,@PABPTR   * PAB address
       E5AD 00
[0498] E5AE D6,04,04        CEQ   >04,@TMP4       * VIEW?
[0499] E5B1 65,B8           BS    VFILE           * No
[0500] E5B3 86,42           CLR   @XTOKEN
[0501] E5B5 06,ED,67        CALL  CLRREA
[0502] E5B8 06,E6,56 VFILE  CALL  GETALL
[0503] E5BB 86,42           CLR   @XTOKEN
[0504] E5BD BE,E0,05        ST    >50,V@5(@PABPTR)
       E5C0 1C,50
[0505] E5C2 BE,E0,01 GE30A  ST    >12,V@1(@PABPTR)
       E5C5 1C,12
[0506] E5C7 BF,E0,02        DST   >1080,V@2(@PABPTR)
       E5CA 1C,10,80
[0507] E5CD 06,E6,A3        CALL  DOIO
[0508] E5D0 D6,E0,04        CEQ   >20,V@4(@PABPTR)
       E5D3 1C,20
[0509] E5D5 45,DA           BR    GE322
[0510] E5D7 B6,48,02        OR    >02,@FLAG
[0511] E5DA BE,B0,1C GE322  ST    >03,V*PABPTR
       E5DD 03
[0512] E5DE DA,48,02        CLOG  >02,@FLAG
[0513] E5E1 66,44           BS    GE38D
[0514] E5E3 06,F6,55 GE32B  CALL  P1000
[0515] E5E6 06,E6,8A        CALL  BLNKBU
[0516] E5E9 06,E6,A3        CALL  DOIO
[0517] E5EC BF,1C,11        DST   >1100,@PABPTR
       E5EF 00
[0518] E5F0 BF,00,10        DST   >1080,@TMP
       E5F3 80
[0519] E5F4 A3,00,00        DADD  >004F,@TMP
       E5F7 4F
[0520] E5F8 BE,02,50        ST    >50,@TMP2
[0521] E5FB BC,03,B0 GE344  ST    V*TMP,@TMP3
       E5FE 00
[0522] E5FF D6,03,20        CEQ   >20,@TMP3
[0523] E602 66,18           BS    GE361
[0524] E604 D6,03,0C        CEQ   >0C,@TMP3
[0525] E607 46,16           BR    GE35F
[0526] E609 BE,B0,00        ST    >20,V*TMP
       E60C 20
[0527] E60D 06,E6,A3        CALL  DOIO
[0528] E610 06,E6,A3        CALL  DOIO
[0529] E613 06,E6,A3        CALL  DOIO
[0530] E616 46,1E    GE35F  BR    GE367
[0531] E618 93,00    GE361  DDEC  @TMP
[0532] E61A 92,02           DEC   @TMP2
[0533] E61C 45,FB           BR    GE344
[0534] E61E 06,E6,A3 GE367  CALL  DOIO
[0535] E621 A6,02,20        SUB   >20,@TMP2
[0536] E624 CE,02,00        CGT   >00,@TMP2
[0537] E627 46,37           BR    GE380
[0538] E629 A3,E0,02        DADD  >0020,V@2(@PABPTR)
       E62C 1C,00,20
[0539] E62F BC,E0,05        ST    @TMP2,V@5(@PABPTR)
       E632 1C,02
[0540] E634 05,E6,1E        B     GE367
[0541] E637 BF,E0,02 GE380  DST   >1080,V@2(@PABPTR)
       E63A 1C,10,80
[0542] E63D BE,E0,05        ST    >20,V@5(@PABPTR)
       E640 1C,20
[0543] E642 45,E3           BR    GE32B
[0544] E644 06,F6,55 GE38D  CALL  P1000
[0545] E647 06,E6,8A        CALL  BLNKBU
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0013
Rich E/A GROM
[0546] E64A 06,E6,A3        CALL  DOIO
[0547] E64D BF,1C,11        DST   >1100,@PABPTR
       E650 00
[0548] E651 06,E6,A3        CALL  DOIO
[0549] E654 46,44           BR    GE38D
[0550] E656 06,E6,8A GETALL CALL  BLNKBU
[0551]               *  Build PAB with name
[0552] E659 06,E6,B8 BLDPAB CALL  VZERO
[0553] E65C BD,E0,02        DST   @PABPTR,V@2(@PABPTR)
       E65F 1C,1C
[0554] E661 A3,E0,02        DADD  >0080,V@2(@PABPTR)
       E664 1C,00,80
[0555] E667 BE,E0,08        ST    >00,V@8(@PABPTR)
       E66A 1C,00
[0556] E66C BF,E0,04        DST   >5000,V@4(@PABPTR)
       E66F 1C,50,00
[0557] E672 87,AF,22        DCLR  V@>2250
       E675 50
[0558] E676 06,E6,C4        CALL  GETINP
[0559] E679 8F,50           DCZ   @FAC6
[0560] E67B 66,89           BS    GE3CF
[0561] E67D 34,50,E0 PABNAM MOVE  @FAC6,V*FAC4,V@10(@PABPTR)
       E680 0A,1C,B0
       E683 4E
[0562] E684 BC,E0,09        ST    @FAC7,V@9(@PABPTR)
       E687 1C,51
[0563] E689 00       GE3CF  RTN
[0564] E68A A3,1C,00 BLNKBU DADD  >0080,@PABPTR
       E68D 80
[0565] E68E BE,B0,1C        ST    >20,V*PABPTR
       E691 20
[0566] E692 35,00,4F        MOVE  >004F,V*PABPTR,V@1(@PABPTR)
       E695 E0,01,1C
       E698 B0,1C
[0567] E69A A7,1C,00        DSUB  >0080,@PABPTR
       E69D 80
[0568] E69E 00              RTN
[0569] E69F BE,B0,1C CLOSE  ST    >01,V*PABPTR
       E6A2 01
[0570] E6A3 BD,56,1C DOIO   DST   @PABPTR,@VPAB
[0571] E6A6 A3,56,00        DADD  >0009,@VPAB
       E6A9 09
[0572] E6AA 06,00,10        CALL  DSRLNK
[0573] E6AD 08              BYTE  >08
[0574] E6AE 75,0E           BS    CHKERR
[0575] E6B0 DA,E0,01        CLOG  >E0,V@1(@PABPTR)
       E6B3 1C,E0
[0576] E6B5 55,0E           BR    CHKERR
[0577] E6B7 00              RTN
[0578] E6B8 86,B0,1C VZERO  CLR   V*PABPTR
[0579] E6BB 35,00,45        MOVE  >0045,V*PABPTR,V@1(@PABPTR)
       E6BE E0,01,1C
       E6C1 B0,1C
[0580] E6C3 00              RTN
[0581] E6C4 06,E6,F7 GETINP CALL  GETKEY
[0582] E6C7 BD,20,24        DST   @STLN,@CURADD
[0583] E6CA BE,00,3C        ST    >3C,@TMP
[0584] E6CD 87,50           DCLR  @FAC6
[0585] E6CF D6,B0,20 GE415  CEQ   SPACE,V*CURADD
       E6D2 20
[0586] E6D3 46,E5           BR    GE42B
[0587] E6D5 91,20           DINC  @CURADD
[0588] E6D7 92,00           DEC   @TMP
[0589] E6D9 46,CF           BR    GE415
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0014
Rich E/A GROM
[0590] E6DB BD,20,24        DST   @STLN,@CURADD
[0591] E6DE DA,48,04        CLOG  >04,@FLAG
[0592] E6E1 46,F6           BR    GE43C
[0593] E6E3 46,C4           BR    GETINP
[0594] E6E5 BD,4E,20 GE42B  DST   @CURADD,@FAC4
[0595] E6E8 D6,B0,20 GE42E  CEQ   SPACE,V*CURADD
       E6EB 20
[0596] E6EC 66,F6           BS    GE43C
[0597] E6EE 91,50           DINC  @FAC6
[0598] E6F0 91,20           DINC  @CURADD
[0599] E6F2 92,00           DEC   @TMP
[0600] E6F4 46,E8           BR    GE42E
[0601] E6F6 00       GE43C  RTN
[0602]               *  Key input routine
[0603] E6F7 BE,18,1F GETKEY ST    >1F,@CHRCUR
[0604] E6FA BD,26,20        DST   @CURADD,@ENDLN
[0605] E6FD BD,24,20        DST   @CURADD,@STLN
[0606] E700 86,79    GE446  CLR   @ITIMER
[0607] E702 C0,18,B0        EX    V*CURADD,@CHRCUR
       E705 20
[0608]               *  REPEAT KEYS
[0609] E706 03       GE44C  SCAN
[0610] E707 67,2F           BS    GE456
[0611] E709 CA,79,07        CHE   7,@ITIMER
[0612] E70C 47,06           BR    GE44C
[0613] E70E D6,42,EA        CEQ   >EA,@XTOKEN      * ANYTHING
[0614] E711 47,00           BR    GE446
[0615] E713 BD,76,AF PSCANX DST   V@>2250,@>8376
       E716 22,50
[0616] E718 BC,75,EF        ST    V@>2257(@>8376),@KEY
       E71B 22,57,76
[0617] E71E 91,76           DINC  @>8376
[0618] E720 BD,AF,22        DST   @>8376,V@>2250
       E723 50,76
[0619] E725 D4,AF,22        CEQ   @>8376,V@>2256
       E728 56,76
[0620] E72A 47,2F           BR    GE456
[0621] E72C BE,75,0D        ST    >0D,@KEY         * Store ENTER
[0622] E72F D6,B0,20 GE456  CEQ   >1F,V*CURADD
       E732 1F
[0623] E733 47,39           BR    GE460
[0624] E735 C0,18,B0        EX    V*CURADD,@CHRCUR
       E738 20
[0625] E739 BD,00,20 GE460  DST   @CURADD,@TMP
[0626] E73C A5,00,24        DSUB  @STLN,@TMP
[0627] E73F C6,75,19        CH    >19,@KEY         * SPACE key and higher?
[0628] E742 67,5A           BS    GE46B
[0629] E744 D6,75,07        CEQ   7,@KEY           * FCTN 3?
[0630] E747 47,74           BR    GE485
[0631] E749 BE,B0,24        ST    SPACE,V*STLN
       E74C 20
[0632] E74D 35,00,3F        MOVE  >003F,V*STLN,V@1(@STLN)
       E750 E0,01,24
       E753 B0,24
[0633] E755 BD,20,24        DST   @STLN,@CURADD
[0634] E758 46,F7           BR    GETKEY
[0635] E75A DA,48,01 GE46B  CLOG  >01,@FLAG
[0636] E75D 47,CC           BR    GE4DD
[0637] E75F BC,B0,20 GE470  ST    @KEY,V*CURADD
       E762 75
[0638] E763 C5,20,26        DCH   @ENDLN,@CURADD
[0639] E766 47,6B           BR    GE47C
[0640] E768 BD,26,20        DST   @CURADD,@ENDLN
[0641] E76B C6,01,3F GE47C  CH    >3F,@TMP1
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0015
Rich E/A GROM
[0642] E76E 67,00           BS    GE446
[0643] E770 91,20           DINC  @CURADD
[0644] E772 47,00           BR    GE446
[0645] E774 B2,48,FE GE485  AND   >FE,@FLAG
[0646] E777 D6,75,0F        CEQ   BACK,@KEY
[0647] E77A 47,88           BR    GE499
[0648] E77C DA,48,20        CLOG  >20,@FLAG
[0649] E77F 40,79           BR    CLREA            * GE97F
[0650] E781 DA,48,04        CLOG  >04,@FLAG
[0651] E784 40,79           BR    CLREA
[0652] E786 43,8D           BR    EDITOR
[0653] E788 D6,75,09 GE499  CEQ   >09,@KEY
[0654] E78B 67,6B           BS    GE47C
[0655] E78D D6,75,08        CEQ   >08,@KEY
[0656] E790 47,9A           BR    GE4AB
[0657] E792 8E,01           CZ    @TMP1
[0658] E794 67,00           BS    GE446
[0659] E796 93,20           DDEC  @CURADD
[0660] E798 47,00           BR    GE446
[0661] E79A D6,75,0D GE4AB  CEQ   >0D,@KEY
[0662] E79D 67,F2           BS    GE503
[0663] E79F D6,75,03        CEQ   >03,@KEY
[0664] E7A2 47,C2           BR    GE4D3
[0665] E7A4 BE,B0,20        ST    SPACE,V*CURADD
       E7A7 20
[0666] E7A8 BD,00,26        DST   @ENDLN,@TMP
[0667] E7AB A5,00,20        DSUB  @CURADD,@TMP
[0668] E7AE CE,01,00        CGT   >00,@TMP1
[0669] E7B1 47,00           BR    GE446
[0670] E7B3 34,00,B0        MOVE  @TMP,V@1(@CURADD),V*CURADD
       E7B6 20,E0,01
       E7B9 20
[0671] E7BA BE,B0,26        ST    SPACE,V*ENDLN
       E7BD 20
[0672] E7BE 93,26           DDEC  @ENDLN
[0673] E7C0 47,00           BR    GE446
[0674] E7C2 D6,75,04 GE4D3  CEQ   >04,@KEY
[0675] E7C5 47,F0           BR    GE501
[0676] E7C7 B6,48,01        OR    >01,@FLAG
[0677] E7CA 47,00           BR    GE446
[0678] E7CC BD,00,26 GE4DD  DST   @ENDLN,@TMP
[0679] E7CF A5,00,24        DSUB  @STLN,@TMP
[0680] E7D2 C6,01,3F        CH    >3F,@TMP1
[0681] E7D5 67,00           BS    GE446
[0682] E7D7 BD,00,26        DST   @ENDLN,@TMP
[0683] E7DA A5,00,20        DSUB  @CURADD,@TMP
[0684] E7DD 91,00           DINC  @TMP
[0685] E7DF 34,00,A3        MOVE  @TMP,V*CURADD,V@>03C0
       E7E2 C0,B0,20
[0686] E7E5 34,00,E0        MOVE  @TMP,V@>03C0,V@1(@CURADD)
       E7E8 01,20,A3
       E7EB C0
[0687] E7EC 91,26           DINC  @ENDLN
[0688] E7EE 47,5F           BR    GE470
[0689] E7F0 47,00    GE501  BR    GE446
[0690] E7F2 00       GE503  RTN
[0691]               *  Check for Expansion Memory
[0692] E7F3 BC,00,8F EXPMEM ST    @>2000,@TMP
       E7F6 9D,00
[0693] E7F8 BE,8F,9D        ST    >FF,@>2000
       E7FB 00,FF
[0694] E7FD D6,8F,9D        CEQ   >FF,@>2000
       E800 00,FF
[0695] E802 54,CE           BR    GE91D
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0016
Rich E/A GROM
[0696] E804 86,8F,9D        CLR   @>2000
       E807 00
[0697] E808 8E,8F,9D        CZ    @>2000
       E80B 00
[0698] E80C 54,CE           BR    GE91D
[0699] E80E BC,8F,9D        ST    @TMP,@>2000
       E811 00,00
[0700] E813 00              RTN
[0701] E814 04,F4    NESCRN BACK  >F4
[0702] E816 BE,A7,7F        ST    >F4,V@COLOR
       E819 F4
[0703] E81A BE,A3,00 EASCRN ST    >D0,V@>0300
       E81D D0
[0704] E81E BC,A3,80        ST    V@COLOR,V@>0380
       E821 A7,7F
[0705] E823 35,00,1F        MOVE  31,V@>0380,V@>0381
       E826 A3,81,A3
       E829 80
[0706] E82A 07,20           ALL   SPACE
[0707] E82C 3D,00,01        MOVE  1,V@COLOR,#7
       E82F 07,A7,7F
[0708] E832 00              RTN
[0709] E833 BE,A3,80 USSCRN ST    >13,V@>0380
       E836 13
[0710] E837 35,00,1F        MOVE  31,V@>0380,V@>0381
       E83A A3,81,A3
       E83D 80
[0711] E83E 07,20           ALL   SPACE
[0712] E840 00              RTN
[0713] E841 86,8F,7C CLRXOP CLR   @>FFD8
       E844 D8
[0714] E845 35,00,05        MOVE  5,@>FFD8,@>FFD9
       E848 8F,7C,D9
       E84B 8F,7C,D8
[0715] E84E 00              RTN
[0716]               ***********************************************************
[0717]               *
[0718]               * Main Menu Option 2: ASSEMBLER
[0719]               *
[0720] E84F 07,20    ASSEM  ALL   SPACE
[0721] E851 08              FMT
[0722] E852 FF,0A       COL   10
[0723] E854 FE,01       ROW   1
[0724] E856 0C,2A,20    HTEX  '* ASSEMBLER *'
       E859 41,53,53
       E85C 45,4D,42
       E85F 4C,45,52
       E862 20,2A
[0725] E864 FB          FEND
[0726] E865 87,48           DCLR  @FLAG
[0727] E867 86,47           CLR   @LDFLAG
[0728] E869 BE,73,7E        ST    >7E,@SUBSTK
[0729] E86C B6,48,20        OR    >20,@FLAG
[0730] E86F D7,8F,9D        DCEQ  >AA55,@>2000
       E872 00,AA,55
[0731] E875 68,A8           BS    GE687
[0732] E877 35,00,63        MOVE  99,V@>2250,@>EA00
       E87A 8F,67,00
       E87D AF,22,50
[0733] E880 BC,8F,7C        ST    @XTOKEN,@>FFFB
       E883 FB,42
[0734] E885 86,42           CLR   @XTOKEN
[0735]               * Replacement for LODPGM
[0736]               *       CALL  LODPGM
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0017
Rich E/A GROM
[0737]               *       DATA  DASSM1
[0738]               *       CALL  DEVICE
[0739]               *       CEQ   BACK,@KEY
[0740]               *       BS    CLREA
[0741] E887 06,F6,55        CALL  P1000
[0742] E88A 31,00,0F        MOVE  15,G@PAB,V*PABPTR
       E88D B0,1C,F7
       E890 5C
[0743] E891 35,00,28        MOVE  40,V@>0F28,V@>1009  Get configured path ASSM1
       E894 AF,10,09
       E897 AF,0F,28
[0744]
[0745] E89A BE,47,02        ST    2,@LDFLAG
[0746] E89D 06,EC,9B GE654  CALL  PGMLOD
[0747] E8A0 D7,8F,9D        DCEQ  >AA55,@>2000
       E8A3 00,AA,55
[0748] E8A6 48,4F           BR    ASSEM
[0749]               *  CALL FILES (4)
[0750] E8A8 BF,AF,13 GE687  DST   >0116,V@>1380
       E8AB 80,01,16
[0751] E8AE BF,56,13        DST   >1380,@VPAB
       E8B1 80
[0752] E8B2 BE,4C,04        ST    >04,@FAC2
[0753] E8B5 06,00,10        CALL  DSRLNK
[0754] E8B8 0A              BYTE  >0A
[0755] E8B9 35,00,63        MOVE  99,@>EA00,V@>2250
       E8BC AF,22,50
       E8BF 8F,67,00
[0756] E8C2 BC,42,8F        ST    @>FFFB,@XTOKEN
       E8C5 7C,FB
[0757] E8C7 07,20           ALL   32
[0758] E8C9 08              FMT
[0759] E8CA FF,0A           COL   10
[0760] E8CC FE,01           ROW   1
[0761] E8CE 0C,2A,20        HTEX  '* ASSEMBLER *'
       E8D1 41,53,53
       E8D4 45,4D,42
       E8D7 4C,45,52
       E8DA 20,2A
[0762] E8DC FB              FEND
[0763] E8DD 06,F6,55        CALL  P1000
[0764]               ** CONFIGURE PATH SOURCE ************************
[0765] E8E0 06,E6,B8        CALL  VZERO
[0766] E8E3 06,ED,9E        CALL  LPAB
[0767] E8E6 BF,E0,02        DST   >1080,V@2(@PABPTR)
       E8E9 1C,10,80
[0768] E8EC BE,E0,08        ST    >00,V@8(@PABPTR)
       E8EF 1C,00
[0769] E8F1 BF,E0,04        DST   >5000,V@4(@PABPTR)
       E8F4 1C,50,00
[0770] E8F7 87,AF,22        DCLR  V@>2250
       E8FA 50
[0771] E8FB 35,00,28        MOVE  40,V@>0F50,V@9(@PABPTR)
       E8FE E0,09,1C
       E901 AF,0F,50
[0772] E904 BF,E0,02        DST   >1080,V@2(@PABPTR)
       E907 1C,10,80
[0773] E90A 06,E5,32        CALL  GE27B
[0774] E90D 86,42           CLR   @XTOKEN
[0775] E90F BF,1C,11        DST   >1100,@PABPTR
       E912 00
[0776] E913 BF,20,01        DST   >0142,@CURADD
       E916 42
[0777]               ** CONFIGURE PATH OBJECT *************************
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0018
Rich E/A GROM
[0778] E917 06,E6,B8        CALL  VZERO
[0779] E91A 06,ED,9E        CALL  LPAB
[0780] E91D BE,E0,01        ST    >00,V@1(@PABPTR)
       E920 1C,00
[0781] E922 BF,E0,02        DST   >1180,V@2(@PABPTR)
       E925 1C,11,80
[0782] E928 BE,E0,08        ST    >00,V@8(@PABPTR)
       E92B 1C,00
[0783] E92D BF,E0,04        DST   >5000,V@4(@PABPTR)
       E930 1C,50,00
[0784] E933 87,AF,22        DCLR  V@>2250
       E936 50
[0785] E937 35,00,28        MOVE  40,V@>0F78,V@9(@PABPTR)
       E93A E0,09,1C
       E93D AF,0F,78
[0786] E940 BF,E0,02        DST   >1180,V@2(@PABPTR)
       E943 1C,11,80
[0787] E946 06,E6,A3        CALL  DOIO
[0788] E949 B6,48,40        OR    >40,@FLAG
[0789] E94C BF,1C,12        DST   >1200,@PABPTR
       E94F 00
[0790] E950 B6,48,04        OR    >04,@FLAG
[0791]               ** CONFIGURE PATH LIST **************************
[0792] E953 06,E6,B8        CALL  VZERO
[0793] E956 06,ED,9E        CALL  LPAB
[0794] E959 BE,E0,01        ST    >12,V@1(@PABPTR)
       E95C 1C,12
[0795] E95E BF,E0,02        DST  >1280,V@2(@PABPTR)
       E961 1C,12,80
[0796] E964 BE,E0,08        ST    >00,V@8(@PABPTR)
       E967 1C,00
[0797] E969 BF,E0,04        DST   >5000,V@4(@PABPTR)
       E96C 1C,50,00
[0798] E96F 87,AF,22        DCLR  V@>2250
       E972 50
[0799] E973 35,00,28        MOVE  40,V@>0FA0,V@9(@PABPTR)
       E976 E0,09,1C
       E979 AF,0F,A0
[0800] E97C 8F,50           DCZ   @FAC6
[0801] E97E 69,91           BS    GE736
[0802] E980 BE,E0,01        ST    >12,V@1(@PABPTR)
       E983 1C,12
[0803] E985 BF,E0,02        DST   >1280,V@2(@PABPTR)
       E988 1C,12,80
[0804] E98B 06,E6,A3        CALL  DOIO
[0805] E98E B6,48,80        OR    >80,@FLAG
[0806] E991 08       GE736  FMT
[0807] E992 FF,02           COL   2
[0808] E994 FE,10           ROW   16
[0809] E996 07,4F,70        HTEX  'Options?'
       E999 74,69,6F
       E99C 6E,73,3F
[0810] E99F FB              FEND
[0811] E9A0 BF,20,02        DST   >0242,@CURADD
       E9A3 42
[0812]               ** CONFIGURE PATH OPTIONS ********************
[0813] E9A4 35,00,14        MOVE  20,V@>0FC9,V@>03C0
       E9A7 A3,C0,AF
       E9AA 0F,C9
[0814] E9AC B2,48,FB        AND   >FB,@FLAG
[0815] E9AF 8F,50           DCZ   @FAC6
[0816] E9B1 49,B3           BR    GE756
[0817] E9B3 35,00,0F GE756  MOVE  15,V@>0FC9,@>20D2
       E9B6 8F,9D,D2
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0019
Rich E/A GROM
       E9B9 AF,0F,C9
[0818] E9BC 06,E8,41        CALL  CLRXOP
[0819] E9BF 07,20           ALL   SPACE
[0820] E9C1 0F,21           XML   >21
[0821] E9C3 74,63           BS    GE8B3
[0822] E9C5 06,E8,41 GE767  CALL  CLRXOP
[0823] E9C8 06,F6,55        CALL  P1000
[0824] E9CB 06,E6,9F        CALL  CLOSE
[0825] E9CE BF,1C,11        DST   >1100,@PABPTR
       E9D1 00
[0826] E9D2 06,E6,9F        CALL  CLOSE
[0827] E9D5 DA,48,80        CLOG  >80,@FLAG
[0828] E9D8 69,E1           BS    GE784
[0829] E9DA BF,1C,12        DST   >1200,@PABPTR
       E9DD 00
[0830] E9DE 06,E6,9F        CALL  CLOSE
[0831] E9E1 86,48    GE784  CLR   @FLAG
[0832] E9E3 06,F5,F4        CALL  WENTER
[0833] E9E6 40,6F           BR    OLDEA
[0834]               *  Get Yes/No reply
[0835] E9E8 BE,18,1F YESNO  ST    >1F,@CHRCUR
[0836] E9EB 86,79    GE7A2  CLR   @ITIMER
[0837] E9ED C0,18,7D        EX    @VCHAR,@CHRCUR
[0838] E9F0 03       GE7A7  SCAN
[0839] E9F1 69,FA           BS    GE7B1
[0840] E9F3 CA,79,06        CHE   >06,@ITIMER
[0841] E9F6 49,F0           BR    GE7A7
[0842] E9F8 49,EB           BR    GE7A2
[0843] E9FA D6,75,0F GE7B1  CEQ   BACK,@KEY
[0844] E9FD 6A,09           BS    GE7C0
[0845] E9FF D6,75,59        CEQ   >59,@KEY
[0846] EA02 6A,09           BS    GE7C0
[0847] EA04 D6,75,4E        CEQ   >4E,@KEY
[0848] EA07 49,EB           BR    GE7A2
[0849] EA09 BC,7D,75 GE7C0  ST    @KEY,@VCHAR
[0850] EA0C 86,42           CLR   @XTOKEN
[0851] EA0E 00              RTN
[0852]               ***************************************************
[0853]               *  Main Menu Option 3: LOAD AND RUN
[0854]               *
[0855] EA0F 87,48    LANDR  DCLR  @FLAG
[0856] EA11 B6,49,01        OR    >01,@FLAG2
[0857] EA14 07,20           ALL   SPACE
[0858] EA16 08              FMT
[0859] EA17 FF,08           COL   8
[0860] EA19 FE,00           ROW   0
[0861] EA1B 0F,2A,20        HTEX  '* LOAD and RUN *'
       EA1E 4C,4F,41
       EA21 44,20,61
       EA24 6E,64,20
       EA27 52,55,4E
       EA2A 20,2A
[0862] EA2C 89              COL+  10
[0863] EA2D A1              ROW+  2
[0864] EA2E 09,50,41        HTEX  'PATH.NAME?'
       EA31 54,48,2E
       EA34 4E,41,4D
       EA37 45,3F
[0865] EA39 FB              FEND
[0866] EA3A 06,E7,F3        CALL  EXPMEM
[0867] EA3D B6,49,40        OR    >40,@FLAG2
[0868] EA40 BE,A0,A2 GE7F2  ST    SPACE,V@162
       EA43 20
[0869] EA44 35,00,3B        MOVE  >003B,V@162,V@163
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0020
Rich E/A GROM
       EA47 A0,A3,A0
       EA4A A2
[0870] EA4B BF,20,00        DST   162,@CURADD
       EA4E A2
[0871] EA4F B6,48,04        OR    >04,@FLAG
[0872] EA52 06,F6,55        CALL  P1000
[0873] EA55 06,E6,56        CALL  GETALL
[0874] EA58 86,42           CLR   @XTOKEN
[0875] EA5A 8F,50           DCZ   @FAC6
[0876] EA5C 4A,65           BR    GE816
[0877] EA5E 06,F6,12        CALL  BINIT2
[0878] EA61 4A,83           BR    RUN
[0879] EA63 4A,70           BR    GE821
[0880] EA65 DA,49,40 GE816  CLOG  >40,@FLAG2
[0881] EA68 6A,70           BS    GE821
[0882] EA6A 06,F6,1A        CALL  BINIT3
[0883] EA6D B2,49,BF        AND   >BF,@FLAG2
[0884] EA70 BE,E0,01 GE821  ST    >04,V@1(@PABPTR)
       EA73 1C,04
[0885] EA75 BD,56,1C GE826  DST   @PABPTR,@VPAB
[0886] EA78 A3,56,00        DADD  >0009,@VPAB
       EA7B 09
[0887] EA7C 0F,22           XML   >22
[0888] EA7E 74,63           BS    GE8B3
[0889] EA80 05,EA,40        B     GE7F2
[0890]               ***************************************************
[0891]               *  Main Menu Option 4: RUN
[0892]               *
[0893] EA83 07,20    RUN    ALL   SPACE
[0894] EA85 BE,73,7E GE848  ST    >7E,@SUBSTK
[0895] EA88 08              FMT
[0896] EA89 FE,00           ROW   0
[0897] EA8B FF,01           COL   1
[0898] EA8D 06,2A,20        HTEX  '* RUN *'
       EA90 52,55,4E
       EA93 20,2A
[0899] EA95 A1              ROW+  2
[0900] EA96 FF,01           COL   1
[0901] EA98 13,53,45        HTEX  'SELECT PROGRAM NAME:'
       EA9B 4C,45,43
       EA9E 54,20,50
       EAA1 52,4F,47
       EAA4 52,41,4D
       EAA7 20,4E,41
       EAAA 4D,45,3A
[0902] EAAD FB              FEND
[0903] EAAE 06,E7,F3        CALL  EXPMEM
[0904] EAB1 86,42           CLR   @XTOKEN       SET XTOKEN=0
[0905] EAB3 BF,06,00        DST   129,@TMP6     * Screen location LOCATION
       EAB6 81
[0906] EAB7 BF,08,3F        DST   >3FF8,@TMP8   * Locataion of LINK TABLE
       EABA F8
[0907] EABB BD,02,08 FNDLNK DST   @TMP8,@TMP2   * Copy it.
[0908] EABE BE,04,06        ST    6,@TMP4       * MAX Length of each name.
[0909] EAC1 CA,CF,7D FNDLP  CHE   128,@0(@TMP2) * ~?
       EAC4 00,02,80
[0910] EAC7 6B,0B           BS    FNDDON        * Yes, done.
[0911] EAC9 CA,CF,7D        CHE   32,@0(@TMP2)  * Space or higher?
       EACC 00,02,20
[0912] EACF 4B,0B           BR    FNDDON        * No, done.
[0913] EAD1 D6,CF,7D        CEQ   32,@0(@TMP2)  * Space?
       EAD4 00,02,20
[0914] EAD7 4A,DE           BR    FNDSHO        * No.
[0915] EAD9 D6,04,06        CEQ   6,@TMP4       * 6?
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0021
Rich E/A GROM
[0916] EADC 6B,0B           BS    FNDDON        * Yes.
[0917] EADE BC,E0,00 FNDSHO ST    @0(@TMP2),V@0(@TMP6)
       EAE1 06,CF,7D
       EAE4 00,02
[0918] EAE6 91,06           DINC  @TMP6         * COL+1
[0919] EAE8 CB,06,03        DCHE  768,@TMP6     * End of screen?
       EAEB 00
[0920] EAEC 4A,FA           BR    MORSCN
[0921] EAEE 31,00,14        MOVE  20,G@OUTSCN,V@>8
       EAF1 A0,08,F7
       EAF4 93
[0922] EAF5 06,00,36        CALL  BADTON
[0923] EAF8 4B,0B           BR    FNDDON
[0924]               *
[0925] EAFA 91,02    MORSCN DINC  @TMP2         * Next character.
[0926] EAFC 92,04           DEC   @TMP4         * Length-1
[0927] EAFE 4A,C1           BR    FNDLP         * No, keep looping.
[0928] EB00 95,06           DINCT @TMP6         * Reset next column
[0929] EB02 A7,08,00        DSUB  8,@TMP8       * Link Table Address+8
       EB05 08
[0930] EB06 D6,08,00        CEQ   >2600,@TMP8   * Last Table name?
[0931] EB09 4A,BB           BR    FNDLNK        * No
[0932]               * Get the name by using arrow keys
[0933] EB0B B6,48,04 FNDDON OR    >04,@FLAG
[0934] EB0E BF,10,00        DST   >0080,@SCADD  ARROW LOCATION
       EB11 80
[0935] EB12 BE,B0,10 RUN00  ST    130,V*SCADD   LEFT ARROW
       EB15 82
[0936] EB16 BE,E0,07        ST    131,V@7(@SCADD)  RIGHT ARROW
       EB19 10,83
[0937] EB1B 03              SCAN
[0938] EB1C 4B,12           BR    RUN00
[0939] EB1E BE,B0,10        ST    32,V*SCADD    NO LEFT ARROW
       EB21 20
[0940] EB22 BE,E0,07        ST    32,V@7(@SCADD) NO RIGHT ARROW
       EB25 10,20
[0941] EB27 D6,75,0F        CEQ   BACK,@KEY     BACK?
[0942] EB2A 6A,0F           BS    LANDR
[0943] EB2C D6,75,0B        CEQ   11,@KEY       FCTN UP?
[0944] EB2F 6B,36           BS    RUNUP
[0945] EB31 D6,75,45        CEQ   'E',@KEY      UP (E)?
[0946] EB34 4B,40           BR    RUN01
[0947] EB36 A7,10,00 RUNUP  DSUB  32,@SCADD     ARROW-8
       EB39 20
[0948] EB3A CB,10,00        DCHE  >007F,@SCADD  TOP LINE LEFT?
       EB3D 7F
[0949] EB3E 4B,0B           BR    FNDDON
[0950] EB40 D6,75,0A RUN01  CEQ   10,@KEY       FCTN DOWN?
[0951] EB43 6B,4A           BS    RUNDN
[0952] EB45 D6,75,58        CEQ   'X',@KEY      DOWN (X)?
[0953] EB48 4B,60           BR    RUN02
[0954] EB4A A3,10,00 RUNDN  DADD  32,@SCADD     ARROW+8
       EB4D 20
[0955] EB4E CB,10,02        DCHE  767,@SCADD    BOTTON LINE RIGHT?
       EB51 FF
[0956] EB52 6B,0B           BS    FNDDON
[0957] EB54 D7,E0,01        DCEQ  >2020,V@1(@SCADD) SPACE SPACE?
       EB57 10,20,20
[0958] EB5A 4B,60           BR    RUN02
[0959] EB5C A7,10,00        DSUB  32,@SCADD     ARROW-8
       EB5F 20
[0960] EB60 D6,75,08 RUN02  CEQ   8,@KEY        FCTN LEFT?
[0961] EB63 6B,6A           BS    RUNLT
[0962] EB65 D6,75,53        CEQ   83,@KEY       LEFT (S)?
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0022
Rich E/A GROM
[0963] EB68 4B,74           BR    RUN03
[0964] EB6A A7,10,00 RUNLT  DSUB  8,@SCADD      ARROW-32
       EB6D 08
[0965] EB6E CB,10,00        DCHE  >007F,@SCADD  TOP LINE LEFT?
       EB71 7F
[0966] EB72 4B,0B           BR    FNDDON
[0967] EB74 D6,75,09 RUN03  CEQ   9,@KEY        FCTN RIGHT?
[0968] EB77 6B,7E           BS    RUNRT
[0969] EB79 D6,75,44        CEQ   68,@KEY       RIGHT (D)?
[0970] EB7C 4B,94           BR    RUN04
[0971] EB7E A3,10,00 RUNRT  DADD  8,@SCADD      ARROW+8
       EB81 08
[0972] EB82 CB,10,02        DCHE  767,@SCADD    BOTTOM LINE RIGHT?
       EB85 FF
[0973] EB86 6B,0B           BS    FNDDON
[0974] EB88 D7,E0,01        DCEQ  >2020,V@1(@SCADD) SPACE SPACE?
       EB8B 10,20,20
[0975] EB8E 4B,94           BR    RUN04
[0976] EB90 A7,10,00        DSUB  8,@SCADD      ARROW-8
       EB93 08
[0977] EB94 D6,75,0D RUN04  CEQ   ENTER,@KEY    ENTER?
[0978] EB97 6B,9B           BS    RUN05
[0979] EB99 4B,12           BR    RUN00
[0980]               * Fetch the name match and address
[0981] EB9B 35,00,06 RUN05  MOVE  6,V@1(@SCADD),@FAC
       EB9E 4A,E0,01
       EBA1 10
[0982] EBA2 BF,16,40        DST   >4000,@TEMP   * Locataion of LINK TABLE
       EBA5 00
[0983] EBA6 A7,16,00 RUN06  DSUB  8,@TEMP       * MINUS offset
       EBA9 08
[0984] EBAA 35,00,08        MOVE  8,@0(@TEMP),@ARG * Copy it.
       EBAD 5C,CF,7D
       EBB0 00,16
[0985] EBB2 D5,5C,4A        DCEQ  @FAC,@ARG     * First two characters?
[0986] EBB5 4B,A6           BR    RUN06
[0987] EBB7 D5,5E,4C        DCEQ  @FAC2,@ARG2   * Secod two characters?
[0988] EBBA 4B,A6           BR    RUN06
[0989] EBBC D5,60,4E        DCEQ  @FAC4,@ARG4   * Third two characters?
[0990] EBBF 4B,A6           BR    RUN06
[0991] EBC1 35,00,02        MOVE  2,@ARG6,@>2022
       EBC4 8F,9D,22
       EBC7 62
[0992]               * Normal EA 3 start up
[0993] EBC8 D7,8F,9D GE883  DCEQ  >A55A,@>2000
       EBCB 00,A5,5A
[0994] EBCE 54,C7           BR    GE916
[0995] EBD0 06,E8,33        CALL  USSCRN
[0996] EBD3 87,22    GE88E  DCLR  @CODE
[0997] EBD5 0F,21           XML   >21
[0998] EBD7 74,93           BS    GE8E3
[0999] EBD9 DA,49,20        CLOG  >20,@FLAG2
[1000] EBDC 74,58           BS    GE8A8
[1001] EBDE 94,73           INCT  @SUBSTK
[1002] EBE0 BF,90,73        DST   GE88E,*SUBSTK
       EBE3 EB,D3
[1003] EBE5 94,73           INCT  @SUBSTK
[1004] EBE7 00              RTN
[1005]               ***************************************************
[1006]               *
[1007]               *  Main Menu Option 5: RUN PROGRAM FILE
[1008]               *
[1009] EBE8 07,20    PRGRM  ALL   SPACE
[1010] EBEA 08              FMT
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0023
Rich E/A GROM
[1011] EBEB FF,06           COL   6
[1012] EBED FE,01           ROW   1
[1013] EBEF 13,2A,20        HTEX  '* RUN PROGRAM FILE *'
       EBF2 52,55,4E
       EBF5 20,50,52
       EBF8 4F,47,52
       EBFB 41,4D,20
       EBFE 46,49,4C
       EC01 45,20,2A
[1014] EC04 FB              FEND
[1015] EC05 D6,42,FF        CEQ   >FF,@XTOKEN         RXB flag set?
[1016] EC08 4C,16           BR    NOEABF              No
[1017] EC0A 35,00,40        MOVE  64,V@>2400,V@>2255  Get RXB buffer
       EC0D AF,22,55
       EC10 AF,24,00
[1018] EC13 BE,42,EA        ST    >EA,@XTOKEN         Set RXB flag
[1019] EC16 06,F6,12 NOEABF CALL  BINIT2              * INITILIZE LOW8K
[1020] EC19 B6,49,08        OR    >08,@FLAG2          Set flag
[1021] EC1C BF,20,01        DST   >0102,@CURADD       Cursor address
       EC1F 02
[1022] EC20 31,00,0A        MOVE  10,G@FPATH,V*CURADD * FILE NAME?
       EC23 B0,20,F8
       EC26 80
[1023] EC27 A3,20,00        DADD  >0040,@CURADD       Cursor address+64
       EC2A 40
[1024] EC2B B6,48,04        OR    >04,@FLAG           Set flag
[1025] EC2E 06,E6,C4        CALL  GETINP              Get path.file
[1026] EC31 D6,51,01        CEQ   1,@FAC7             Length=1?
[1027] EC34 4C,4C           BR    NO1KEY              No
[1028] EC36 BF,AF,24        DST   >000B,V@>2400       Length
       EC39 00,00,0B
[1029] EC3C 06,ED,A6        CALL  GDDSK               Load DSK1. Address
[1030] EC3F 31,00,06        MOVE  6,G@DUTIL1,V@>2407  Load UTIL1
       EC42 AF,24,07
       EC45 F7,75
[1031] EC47 BE,42,FF        ST    >FF,@XTOKEN         Set RXB flag
[1032] EC4A 4B,E8           BR    PRGRM               Restart
[1033] EC4C 8F,50    NO1KEY DCZ   @FAC6               * ENTER?
[1034] EC4E 4C,5A           BR    GE597               * No
[1035] EC50 BE,44,31        ST    '1',@>8344          * Search flag
[1036] EC53 06,EC,75 MYSRCH CALL  LODPGM              * Load DATA
[1037] EC56 F7,75           DATA  DUTIL1              * DSK1.UTIL1
[1038] EC58 4C,69           BR    GE5A6
[1039] EC5A 06,EC,82 GE597  CALL  LODUSR
[1040] EC5D 06,E6,7D        CALL  PABNAM
[1041] EC60 D7,B0,4E        DCEQ  >4353,V*FAC4        * CS ??
       EC63 43,53
[1042] EC65 4C,69           BR    GE5A6               * No
[1043] EC67 07,20           ALL   SPACE
[1044] EC69 06,EC,9B GE5A6  CALL  PGMLOD
[1045] EC6C 06,E8,33        CALL  USSCRN
[1046] EC6F 0F,F0           XML   >F0
[1047] EC71 74,93           BS    GE8E3
[1048] EC73 54,58           BR    GE8A8
[1049] EC75 88,10    LODPGM FETCH @SCADD
[1050] EC77 88,11           FETCH @SCADE
[1051] EC79 33,00,05        MOVE  5,G@0(@SCADD),V@>100F
       EC7C AF,10,0F
       EC7F 00,00,10
[1052] EC82 87,00    LODUSR DCLR  @TMP
[1053] EC84 06,F6,55        CALL  P1000
[1054] EC87 06,ED,96        CALL  NPAB
[1055] EC8A 8E,44           CZ    @>8344               * Check Search flag
[1056] EC8C 6C,93           BS    PMSG                 * No, go on
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0024
Rich E/A GROM
[1057] EC8E BC,E0,0D        ST    @>8344,V@13(@PABPTR) * Yes, store next drive #
       EC91 1C,44
[1058] EC93 31,00,0F PMSG   MOVE  15,G@PLEASE,V@>02A2
       EC96 A2,A2,F8
       EC99 8A
[1059] EC9A 00              RTN
[1060]               *  Load Program
[1061] EC9B 06,E6,A3 PGMLOD CALL  DOIO
[1062] EC9E 35,00,06        MOVE  6,V@>1380,@SCADD
       ECA1 10,AF,13
       ECA4 80
[1063] ECA5 8F,00           DCZ   @TMP
[1064] ECA7 4C,AC           BR    GE5E5
[1065] ECA9 BD,00,14        DST   @>8314,@TMP
[1066] ECAC A7,14,83 GE5E5  DSUB  TMP,@>8314
       ECAF 00
[1067] ECB0 34,12,C0        MOVE  @>8312,V@>1386,@TMP(@>8314)
       ECB3 00,14,AF
       ECB6 13,86
[1068] ECB8 8F,10           DCZ   @SCADD
[1069] ECBA 6C,CC           BS    GE605
[1070] ECBC 87,02           DCLR  @TMP2
[1071] ECBE BC,03,AF        ST    V@>1009,@TMP3
       ECC1 10,09
[1072] ECC3 A3,02,10        DADD  >1009,@TMP2
       ECC6 09
[1073] ECC7 90,B0,02        INC   V*TMP2
[1074] ECCA 4C,9B           BR    PGMLOD
[1075] ECCC BE,A2,A2 GE605  ST    SPACE,V@>02A2
       ECCF 20
[1076] ECD0 35,00,13        MOVE  19,V@>02A2,V@>02A3
       ECD3 A2,A3,A2
       ECD6 A2
[1077] ECD7 06,E6,B8        CALL  VZERO
[1078] ECDA 00              RTN
[1079]               ********************************************************
[1080]               * RXB Loader
[1081] ECDB 07,20    XBINP  ALL   SPACE
[1082] ECDD BE,4A,01        ST    1,@FAC
[1083] ECE0 08       XBAGN  FMT
[1084] ECE1 FF,08           COL   8
[1085] ECE3 FE,01           ROW   1
[1086] ECE5 08,2A,20        HTEX  '* R X B *'
       ECE8 52,20,58
       ECEB 20,42,20
       ECEE 2A
[1087] ECEF A3              ROW+  4
[1088] ECF0 FF,02           COL   2
[1089] ECF2 09,50,41        HTEX  'PATH.NAME?'
       ECF5 54,48,2E
       ECF8 4E,41,4D
       ECFB 45,3F
[1090] ECFD FB              FEND
[1091] ECFE 92,4A           DEC   @FAC
[1092] ED00 4C,E0           BR    XBAGN
[1093] ED02 D6,42,FF        CEQ   >FF,@XTOKEN       XTOKEN=>EA?
[1094] ED05 4D,13           BR    XBINP1
[1095] ED07 35,00,40        MOVE  64,V@>2400,V@>2255
       ED0A AF,22,55
       ED0D AF,24,00
[1096] ED10 BE,42,EA        ST    >EA,@XTOKEN       SET XTOKEN=>EA
[1097] ED13 BF,20,01 XBINP1 DST   >0102,@CURADD
       ED16 02
[1098] ED17 BF,1C,10        DST   >1000,@PABPTR
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0025
Rich E/A GROM
       ED1A 00
[1099] ED1B B6,48,20        OR    >20,@FLAG
[1100] ED1E 06,E6,56        CALL  GETALL
[1101] ED21 8F,50           DCZ   @FAC6
[1102] ED23 6D,5D           BS    XBINP3
[1103] ED25 D6,51,01        CEQ   1,@FAC7
[1104] ED28 4D,4B           BR    XBINP2
[1105] ED2A BF,AF,24        DST   >000A,V@>2400
       ED2D 00,00,0A
[1106] ED30 31,00,05        MOVE  5,G@DDSK1,V@>2402
       ED33 AF,24,02
       ED36 F7,66
[1107] ED38 BC,AF,24        ST    V*STLN,V@>2405
       ED3B 05,B0,24
[1108] ED3E 31,00,05        MOVE  5,G@DLOAD,V@>2407
       ED41 AF,24,07
       ED44 F7,7B
[1109] ED46 BE,42,FF        ST    >FF,@XTOKEN      SET XTOKEN=>FF
[1110] ED49 4C,DB           BR    XBINP
[1111] ED4B 06,ED,67 XBINP2 CALL  CLRREA
[1112] ED4E BF,AF,22        DST   >994A,V@>2254
       ED51 54,99,4A
[1113] ED54 35,00,50        MOVE  80,V@9(@PABPTR),V@>2256
       ED57 AF,22,56
       ED5A E0,09,1C
[1114] ED5D 86,00    XBINP3 CLR   @TMP
[1115] ED5F 35,00,6E        MOVE  >006E,@TMP,@TMP1
       ED62 01,00
[1116] ED64 05,63,72        B     RXB
[1117]               ***********************************************************
[1118] ED67 86,AF,22 CLRREA CLR   V@>2250                Clear RXB buffer
       ED6A 50
[1119] ED6B 35,00,50        MOVE 80,V@>2250,V@>2251      Ripple
       ED6E AF,22,51
       ED71 AF,22,50
[1120] ED74 00              RTN
[1121] ED75 D6,E0,09 ONEKEY CEQ  1,V@9(@PABPTR)    One character for drive#?
       ED78 1C,01
[1122] ED7A 4D,95           BR   TWOKEY            No, normal continue
[1123] ED7C BC,80,C0        ST   V@10(@PABPTR),@>83C0    Yes, save # character
       ED7F E0,0A,1C
[1124] ED82 31,00,05        MOVE 5,G@DDSK1,V@10(@PABPTR) DSK1. loaded into pab
       ED85 E0,0A,1C
       ED88 F7,66
[1125] ED8A BE,E0,09        ST   >05,V@9(@PABPTR)        DSK1. has 5 characters
       ED8D 1C,05
[1126] ED8F BC,E0,0D        ST   @>83C0,V@13(@PABPTR)    Load charcter drive#/le
       ED92 1C,80,C0
[1127] ED95 00       TWOKEY RTN
[1128]               *
[1129] ED96 31,00,14 NPAB   MOVE  20,G@PAB,V*PABPTR
       ED99 B0,1C,F7
       ED9C 5C
[1130] ED9D 00              RTN
[1131]               *
[1132] ED9E 31,00,0A LPAB   MOVE  10,G@PAB80,V*PABPTR
       EDA1 B0,1C,F7
       EDA4 80
[1133] EDA5 00              RTN
[1134]               *
[1135] EDA6 D6,A1,42 GDDSK  CEQ   '0',V@>0142
       EDA9 30
[1136] EDAA 4D,BA           BR    GDDSKN
[1137] EDAC 31,00,05        MOVE  5,G@WDS1,V@>2402
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0026
Rich E/A GROM
       EDAF AF,24,02
       EDB2 F8,99
[1138] EDB4 BE,A1,42        ST    '1',V@>0142
       EDB7 31
[1139] EDB8 4D,C2           BR    GDWDS
[1140] EDBA 31,00,05 GDDSKN MOVE  5,G@DDSK1,V@>2402
       EDBD AF,24,02
       EDC0 F7,66
[1141] EDC2 BC,AF,24 GDWDS  ST    V*STLN,V@>2405
       EDC5 05,B0,24
[1142] EDC8 00              RTN
[1143]               ***********************************************************
[1144]               *
[1145]               * CATALOG HARD/DISK
[1146]               *
[1147] EDC9 06,ED,CE DIRECT CALL DMENU
[1148] EDCC 4E,B4           BR   DIREC2
[1149] EDCE 07,20    DMENU  ALL  SPACE             Clear screen
[1150] EDD0 08              FMT
[1151] EDD1 FF,09           COL 9
[1152] EDD3 FE,00           ROW 0
[1153] EDD5 0E,2A,20        HTEX '* DIRECTORY *  '
       EDD8 44,49,52
       EDDB 45,43,54
       EDDE 4F,52,59
       EDE1 20,2A,20
       EDE4 20
[1154] EDE5 A3              ROW+ 4
[1155] EDE6 89              COL+ 10
[1156] EDE7 12,44,65        HTEX 'Device? (# or path)'
       EDEA 76,69,63
       EDED 65,3F,20
       EDF0 28,23,20
       EDF3 6F,72,20
       EDF6 70,61,74
       EDF9 68,29
[1157] EDFB A6              ROW+ 7
[1158] EDFC FF,02           COL  2
[1159] EDFE 19,41,43        HTEX 'ACTIVE KEYS: CLEAR, BEGIN,'
       EE01 54,49,56
       EE04 45,20,4B
       EE07 45,59,53
       EE0A 3A,20,43
       EE0D 4C,45,41
       EE10 52,2C,20
       EE13 42,45,47
       EE16 49,4E,2C
[1160] EE19 A1              ROW+ 2
[1161] EE1A FF,02           COL  2
[1162] EE1C 18,42,41        HTEX 'BACK, PROCEED, REDO, AID,'
       EE1F 43,4B,2C
       EE22 20,50,52
       EE25 4F,43,45
       EE28 45,44,2C
       EE2B 20,52,45
       EE2E 44,4F,2C
       EE31 20,41,49
       EE34 44,2C
[1163] EE36 A1              ROW+ 2
[1164] EE37 FF,02           COL  2
[1165] EE39 19,28,41        HTEX '(Arrows), E,e,X,x,S,s,D,d,'
       EE3C 72,72,6F
       EE3F 77,73,29
       EE42 2C,20,45
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0027
Rich E/A GROM
       EE45 2C,65,2C
       EE48 58,2C,78
       EE4B 2C,53,2C
       EE4E 73,2C,44
       EE51 2C,64,2C
[1166] EE54 A1              ROW+ 2
[1167] EE55 FF,02           COL  2
[1168] EE57 18,41,20        HTEX 'A (Assembler), 1 (Editor)'
       EE5A 28,41,73
       EE5D 73,65,6D
       EE60 62,6C,65
       EE63 72,29,2C
       EE66 20,31,20
       EE69 28,45,64
       EE6C 69,74,6F
       EE6F 72,29
[1169] EE71 A1              ROW+ 2
[1170] EE72 FF,02           COL  2
[1171] EE74 1B,45,4E        HTEX 'ENTER (Tag file to autorun),'
       EE77 54,45,52
       EE7A 20,28,54
       EE7D 61,67,20
       EE80 66,69,6C
       EE83 65,20,74
       EE86 6F,20,61
       EE89 75,74,6F
       EE8C 72,75,6E
       EE8F 29,2C
[1172] EE91 A1              ROW+ 2
[1173] EE92 FF,02           COL  2
[1174] EE94 1C,53,50        HTEX 'SPACE BAR (XB programs only).'
       EE97 41,43,45
       EE9A 20,42,41
       EE9D 52,20,28
       EEA0 58,42,20
       EEA3 70,72,6F
       EEA6 67,72,61
       EEA9 6D,73,20
       EEAC 6F,6E,6C
       EEAF 79,29,2E
[1175] EEB2 FB              FEND
[1176] EEB3 00              RTN
[1177] EEB4 BF,20,01 DIREC2 DST  >0102,@CURADD     Prompt location
       EEB7 02
[1178] EEB8 BF,1C,10        DST  >1000,@PABPTR     Use first PAB area
       EEBB 00
[1179] EEBC B6,48,20        OR   >20,@FLAG         Set return bit for error
[1180] EEBF 06,E6,56        CALL GETALL            Input the filename
[1181] EEC2 86,42    DIREC3 CLR  @XTOKEN
[1182] EEC4 06,ED,67        CALL CLRREA
[1183] EEC7 31,00,09        MOVE 9,G@CATDAT,V*PABPTR Prepare PAB
       EECA B0,1C,F2
       EECD 44
[1184] EECE 06,ED,75        CALL ONEKEY
[1185] EED1 06,E6,A3        CALL DOIO              Open the file
[1186] EED4 BF,B0,1C        DST  >020D,V*PABPTR    Read opcode to PAB
       EED7 02,0D
[1187] EED9 06,E6,A3        CALL DOIO              Read first record
[1188] EEDC 07,20           ALL  SPACE             Clear screen again
[1189] EEDE 06,F2,55        CALL SCREEN            Set up header
[1190] EEE1 BE,AF,25        ST   >20,V@>2500
       EEE4 00,20
[1191] EEE6 35,11,00        MOVE >1100,V@>2500,V@>2501
       EEE9 AF,25,01
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0028
Rich E/A GROM
       EEEC AF,25,00
[1192] EEEF BF,40,25        DST  >2580,@>8340
       EEF2 80
[1193] EEF3 BE,02,59        ST   >59,@TMP2         Y
[1194] EEF6 03       TSTKEY SCAN                   Scan the keyboard
[1195] EEF7 4F,11           BR   TSTKE5            Any key?
[1196] EEF9 D6,75,20        CEQ  SPACE,@KEY        SPACE KEY?
[1197] EEFC 6F,0E           BS   TSTKE4            Yes, wait.
[1198] EEFE D6,75,0F        CEQ  BACK,@KEY         BACK key?
[1199] EF01 4F,0A           BR   TSTKE3            No
[1200] EF03 86,42    TSTKE2 CLR  @XTOKEN           Yes, so restart
[1201] EF05 06,E6,9F        CALL CLOSE             Close disk
[1202] EF08 4D,C9           BR   DIRECT            Start Catalog again
[1203] EF0A 86,42    TSTKE3 CLR  @XTOKEN           Clear flag
[1204] EF0C 4F,1B           BR   ARROWS
[1205] EF0E 03       TSTKE4 SCAN                   Wait for any key.
[1206] EF0F 4F,0E           BR   TSTKE4            Loop
[1207] EF11 06,E6,A3 TSTKE5 CALL DOIO              Read file info
[1208] EF14 06,F3,40        CALL FILNAM            Put it on screen
[1209] EF17 4E,F6           BR   TSTKEY            Loop till done
[1210] EF19 92,1E           DEC  @COUNT            COUNT-1
[1211] EF1B 06,F6,4D ARROWS CALL CLRFAC
[1212] EF1E BC,4B,1E        ST   @COUNT,@FAC1
[1213] EF21 CB,4A,00        DCHE 100,@FAC
       EF24 64
[1214] EF25 4F,2F           BR   ARROW1
[1215] EF27 A7,4A,00        DSUB 100,@FAC
       EF2A 64
[1216] EF2B BE,A0,1C        ST   49,V@28           Show it 1__
       EF2E 31
[1217] EF2F CB,4A,00 ARROW1 DCHE 9,@FAC
       EF32 09
[1218] EF33 4F,48           BR   ARROW2
[1219] EF35 AE,4A,0A        DIV  10,@FAC
[1220] EF38 A2,4A,30        ADD  >30,@FAC
[1221] EF3B BC,A0,1D        ST   @FAC,V@29         Show it _#_
       EF3E 4A
[1222] EF3F A2,4B,30        ADD  >30,@FAC1
[1223] EF42 BC,A0,1E        ST   @FAC1,V@30        Show it __#
       EF45 4B
[1224] EF46 4F,4F           BR   ARROW3
[1225] EF48 A2,4B,30 ARROW2 ADD  >30,@FAC1
[1226] EF4B BC,A0,1E        ST   @FAC1,V@30
       EF4E 4B
[1227] EF4F BF,10,00 ARROW3 DST  >0081,@SCADD      Arrows location
       EF52 81
[1228] EF53 BF,04,25        DST  >2580,@TMP4       Recall buffer
       EF56 80
[1229] EF57 35,02,60 OKKEY  MOVE >0260,V*TMP4,V@>0080 Fill screen
       EF5A A0,80,B0
       EF5D 04
[1230] EF5E BE,B0,10 NOKEY  ST   130,V*SCADD       Left arrow
       EF61 82
[1231] EF62 BE,E0,0B        ST   131,V@11(@SCADD)  Right arrow
       EF65 10,83
[1232] EF67 03              SCAN
[1233] EF68 D6,75,01        CEQ  AID,@KEY          AID
[1234] EF6B 4F,86           BR   NAID
[1235] EF6D 35,03,00        MOVE 768,V@0,V@>2000   Save screen
       EF70 AF,20,00
       EF73 A0,00
[1236] EF75 06,ED,CE        CALL DMENU
[1237] EF78 03       YAID   SCAN                   Any key?
[1238] EF79 4F,78           BR   YAID              No.
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0029
Rich E/A GROM
[1239] EF7B 35,03,00        MOVE 768,V@>2000,V@0   Restore screen
       EF7E A0,00,AF
       EF81 20,00
[1240] EF83 03       WAID   SCAN                   Any key?
[1241] EF84 4F,83           BR   WAID
[1242] EF86 D6,75,02 NAID   CEQ  CLEAR,@KEY        CLEAR
[1243] EF89 6F,03           BS   TSTKE2
[1244] EF8B D6,75,0C        CEQ  PROCD,@KEY        PROCEED
[1245] EF8E 70,7D           BS   ENTER0
[1246] EF90 D6,75,06        CEQ  REDO,@KEY         REDO
[1247] EF93 6F,03           BS   TSTKE2
[1248] EF95 D6,75,0F BACK0  CEQ  BACK,@KEY         BACK
[1249] EF98 4F,D1           BR   BEGIN0
[1250] EF9A D7,AF,10        DCEQ 'DS',V@>100A      DS?   DISK ONLY?
       EF9D 0A,44,53
[1251] EFA0 6F,03           BS   TSTKE2
[1252] EFA2 06,F2,29        CALL CLRBUF            Clear buffers and FAC
[1253] EFA5 BD,4A,AF        DST  V@>1008,@FAC      Get length
       EFA8 10,08
[1254] EFAA D7,4A,00        DCEQ 5,@FAC            DSK#. or SCS#. or WDS#.
       EFAD 05
[1255] EFAE 6F,FF           BS   BEGIN3
[1256] EFB0 CB,4A,00        DCHE 4,@FAC
       EFB3 04
[1257] EFB4 4F,FF           BR   BEGIN3
[1258] EFB6 06,F2,29        CALL CLRBUF            Clear buffers and FAC
[1259] EFB9 BD,4A,AF        DST  V@>1008,@FAC      Get length
       EFBC 10,08
[1260] EFBE 93,4A    BACK1  DDEC @FAC              Length -1
[1261] EFC0 D6,EF,10        CEQ  >2E,V@>1009(@FAC) .?
       EFC3 09,4A,2E
[1262] EFC6 4F,BE           BR   BACK1             No, keep searching
[1263] EFC8 CB,4A,00        DCHE 5,@FAC            DSK. or SCS. or WDS. or DSK#.
       EFCB 05
[1264] EFCC 6F,FF           BS   BEGIN3
[1265] EFCE BE,75,0E BACK3  ST   BEGIN,@KEY
[1266] EFD1 D6,75,0E BEGIN0 CEQ  BEGIN,@KEY        BEGIN
[1267] EFD4 50,1E           BR   FCTNUP
[1268] EFD6 06,F6,4D        CALL CLRFAC            Clear buffers and FAC
[1269] EFD9 BD,4A,AF        DST  V@>1008,@FAC      Get length
       EFDC 10,08
[1270] EFDE D7,4A,00        DCEQ 5,@FAC            DSK#. or SCS#. or WDS#.
       EFE1 05
[1271] EFE2 6F,F6           BS   BEGIN2
[1272] EFE4 87,4A           DCLR @FAC              Clear FAC
[1273] EFE6 91,4A    BEGIN1 DINC @FAC              COUNT +1
[1274] EFE8 D6,EF,10        CEQ  >2E,V@>1009(@FAC) .?
       EFEB 09,4A,2E
[1275] EFEE 4F,E6           BR   BEGIN1            No, keep searching
[1276] EFF0 D7,4A,00        DCEQ 4,@FAC            DSK. Length?
       EFF3 04
[1277] EFF4 6F,E6           BS   BEGIN1            Yes, look for Volume.
[1278] EFF6 91,4A    BEGIN2 DINC @FAC              LENGTH+1
[1279] EFF8 BF,EF,10        DST  >0D0D,V@>1009(@FAC)
       EFFB 09,4A,0D
       EFFE 0D
[1280] EFFF BD,AF,10 BEGIN3 DST  @FAC,V@>1008
       F002 08,4A
[1281] F004 A3,4A,00        DADD 2,@FAC
       F007 02
[1282] F008 34,4A,AF        MOVE @FAC,V@>1008,V@>2255
       F00B 22,55,AF
       F00E 10,08
[1283] F010 34,4A,AF        MOVE @FAC,V@>1008,V@>2400
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0030
Rich E/A GROM
       F013 24,00,AF
       F016 10,08
[1284] F018 BE,42,37        ST   >37,@XTOKEN
[1285] F01B 05,E0,6F        B    OLDEA
[1286] F01E D6,75,0B FCTNUP CEQ  11,@KEY           FCTN UP?
[1287] F021 71,86           BS   UPKEY
[1288] F023 D6,75,45        CEQ  'E',@KEY          E?
[1289] F026 71,86           BS   UPKEY
[1290] F028 D6,75,65        CEQ  'e',@KEY          e?
[1291] F02B 71,86           BS   UPKEY
[1292] F02D D6,75,0A        CEQ  10,@KEY           FCTN DOWN?
[1293] F030 71,9E           BS   DKEY
[1294] F032 D6,75,58        CEQ  'X',@KEY          X?
[1295] F035 71,9E           BS   DKEY
[1296] F037 D6,75,78        CEQ  'x',@KEY          x?
[1297] F03A 71,9E           BS   DKEY
[1298] F03C D6,75,08        CEQ  8,@KEY            FCTN LEFT?
[1299] F03F 71,C2           BS   LKEY
[1300] F041 D6,75,53        CEQ  'S',@KEY          S?
[1301] F044 71,C2           BS   LKEY
[1302] F046 D6,75,73        CEQ  's',@KEY          s?
[1303] F049 71,C2           BS   LKEY
[1304] F04B D6,75,09        CEQ  9,@KEY            FCTN RIGHT?
[1305] F04E 71,E7           BS   RKEY
[1306] F050 D6,75,44        CEQ  'D',@KEY          D?
[1307] F053 71,E7           BS   RKEY
[1308] F055 D6,75,64        CEQ  'd',@KEY          d?
[1309] F058 71,E7           BS   RKEY
[1310] F05A D6,75,20        CEQ  ' ',@KEY          SPACE BAR
[1311] F05D 70,7D           BS   ENTER0
[1312] F05F D6,75,41        CEQ  'A',@KEY          A?
[1313] F062 70,7D           BS   ENTER0
[1314] F064 D6,75,61        CEQ  'a',@KEY          a?
[1315] F067 70,7D           BS   ENTER0
[1316] F069 D6,75,47        CEQ  'G',@KEY          G?
[1317] F06C 70,7D           BS   ENTER0
[1318] F06E D6,75,67        CEQ  'g',@KEY          g?
[1319] F071 70,7D           BS   ENTER0
[1320] F073 D6,75,0D        CEQ  ENTER,@KEY        ENTER
[1321] F076 70,7D           BS   ENTER0
[1322] F078 D6,75,31        CEQ  '1',@KEY          1=EDITOR
[1323] F07B 4F,5E           BR   NOKEY
[1324] F07D 06,F2,29 ENTER0 CALL CLRBUF
[1325] F080 BD,06,AF ENTR   DST  V@>1008,@TMP6    Get length of device
       F083 10,08
[1326] F085 BE,EF,10        ST   >2E,V@>1009(@TMP6)
       F088 09,06,2E
[1327] F08B 34,06,AF        MOVE @TMP6,V@>100A,V@>2402
       F08E 24,02,AF
       F091 10,0A
[1328] F093 BD,4C,10        DST  @SCADD,@FAC2
[1329] F096 90,11           INC  @SCADE
[1330] F098 90,4D    ENTER1 INC  @FAC3             Index+1
[1331] F09A 90,4B           INC  @FAC1             Count+1
[1332] F09C D6,B0,4C        CEQ  SPACE,V*FAC2      Space?
       F09F 20
[1333] F0A0 70,A7           BS   ENTER2            Yes
[1334] F0A2 D6,4B,0B        CEQ  11,@FAC1          To long?
[1335] F0A5 50,98           BR   ENTER1
[1336] F0A7 BE,B0,4C ENTER2 ST   ENTER,V*FAC2      cr
       F0AA 0D
[1337] F0AB D7,E0,10        DCEQ 'Di',V@16(@SCADD) Directory?
       F0AE 10,44,69
[1338] F0B1 50,C1           BR   NODIR             No
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0031
Rich E/A GROM
[1339] F0B3 D6,E0,12        CEQ  'r',V@18(@SCADD)
       F0B6 10,72
[1340] F0B8 50,C1           BR   NODIR
[1341] F0BA BF,B0,4C        DST  >2E0D,V*FAC2      .cr
       F0BD 2E,0D
[1342] F0BF 90,4A           INC  @FAC              Count+1
[1343] F0C1 34,4A,EF NODIR  MOVE @FAC,V*SCADD,V@>100A(@TMP6)
       F0C4 10,0A,06
       F0C7 B0,10
[1344] F0C9 A1,4A,06        DADD @TMP6,@FAC
[1345] F0CC 34,4A,AF        MOVE @FAC,V@>100A,V@>2257
       F0CF 22,57,AF
       F0D2 10,0A
[1346] F0D4 BD,AF,22        DST  @FAC,V@>2255
       F0D7 55,4A
[1347] F0D9 90,07           INC  @TMP7
[1348] F0DB BD,AF,24        DST  @TMP6,V@>2400
       F0DE 00,06
[1349] F0E0 06,E6,9F        CALL CLOSE
[1350] F0E3 BE,42,EA        ST   >EA,@XTOKEN       Set flag
[1351] F0E6 D6,75,20        CEQ  32,@KEY           SPACE BAR
[1352] F0E9 71,60           BS   XBPGM
[1353] F0EB D7,E0,10        DCEQ 'Di',V@16(@SCADD) Directory?
       F0EE 10,44,69
[1354] F0F1 50,FA           BR   PORVI
[1355] F0F3 D6,E0,12        CEQ  'r',V@18(@SCADD)
       F0F6 10,72
[1356] F0F8 6D,C9           BS   DIRECT
[1357] F0FA D6,E0,10 PORVI  CEQ  'P',V@16(@SCADD)  Program?
       F0FD 10,50
[1358] F0FF 6B,E8           BS   PRGRM
[1359] F101 D6,E0,14        CEQ  'V',V@20(@SCADD)  Variable?
       F104 10,56
[1360] F106 51,1E           BR   DORF80
[1361] F108 D6,E0,10        CEQ  'I',V@16(@SCADD)  Internal?
       F10B 10,49
[1362] F10D 51,1E           BR   DORF80
[1363] F10F D7,E0,18        DCEQ '25',V@24(@SCADD) Length 25_?
       F112 10,32,35
[1364] F115 51,1E           BR   DORF80
[1365] F117 D6,E0,1A        CEQ  '4',V@26(@SCADD)  Length 254?
       F11A 10,34
[1366] F11C 6C,DB           BS   XBINP
[1367] F11E D7,E0,19 DORF80 DCEQ '80',V@25(@SCADD) Length 80?
       F121 10,38,30
[1368] F124 51,4D           BR   DF80
[1369]               ************************** Save as SOURCE *******
[1370] F126 87,16           DCLR @TEMP
[1371] F128 BC,AF,0F        ST   @TEMP,V@>0F50      clear byte at setup
       F12B 50,16
[1372] F12D 35,00,27        MOVE 39,V@>0F50,V@>0F51 Ripple it
       F130 AF,0F,51
       F133 AF,0F,50
[1373] F136 BC,17,AF        ST   V@>2256,@TEMP1     Get length byte
       F139 22,56
[1374] F13B 92,17           DEC  @TEMP1             Length-1
[1375] F13D BC,AF,0F        ST   @TEMP1,V@>0F50     Get length byte
       F140 50,17
[1376] F142 34,16,AF        MOVE @TEMP,V@>2257,V@>0F51 Save as SOURCE
       F145 0F,51,AF
       F148 22,57
[1377] F14A 06,E8,41        CALL CLRXOP             CLEAR EDIT BUFFER
[1378]               ******************************
[1379] F14D D6,E0,14 DF80   CEQ  'F',V@20(@SCADD)  Fixed?
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0032
Rich E/A GROM
       F150 10,46
[1380] F152 6A,0F           BS   LANDR
[1381] F154 D6,75,41 LEAASM CEQ  'A',@KEY          Assemble file
[1382] F157 68,4F           BS   ASSEM
[1383] F159 D6,75,47        CEQ  'G',@KEY          GPL Assemble file
[1384] F15C 68,4F           BS   ASSEM
[1385] F15E 40,CB           BR   MMENU
[1386] F160 D6,E0,10 XBPGM  CEQ  'P',V@16(@SCADD)  Program?
       F163 10,50
[1387] F165 6C,DB           BS   XBINP
[1388] F167 D6,E0,14        CEQ  'V',V@20(@SCADD)  Variable?
       F16A 10,56
[1389] F16C 40,CB           BR   MMENU
[1390] F16E D6,E0,10        CEQ  'I',V@16(@SCADD)  Internal?
       F171 10,49
[1391] F173 40,CB           BR   MMENU
[1392] F175 D7,E0,18        DCEQ '25',V@24(@SCADD) Length 25_?
       F178 10,32,35
[1393] F17B 40,CB           BR   MMENU
[1394] F17D D6,E0,1A        CEQ  '4',V@26(@SCADD)  Length 254?
       F180 10,34
[1395] F182 6C,DB           BS   XBINP
[1396] F184 40,CB           BR   MMENU
[1397] F186 D7,10,00 UPKEY  DCEQ >0081,@SCADD      Top of screen?
       F189 81
[1398] F18A 71,92           BS   GLESS             So scroll screen down
[1399] F18C A7,10,00        DSUB 32,@SCADD         Up one.
       F18F 20
[1400] F190 51,9C           BR   GLESS2            Return
[1401] F192 D7,04,25 GLESS  DCEQ >2580,@TMP4      Start of buffer?
       F195 80
[1402] F196 6F,57           BS   OKKEY             Yes
[1403] F198 A7,04,00        DSUB >20,@TMP4         One more line down
       F19B 20
[1404] F19C 4F,57    GLESS2 BR   OKKEY
[1405] F19E D6,E0,01 DKEY   CEQ  >20,V@1(@SCADD)   Blank line?
       F1A1 10,20
[1406] F1A3 71,86           BS   UPKEY
[1407] F1A5 D7,10,02        DCEQ >02C1,@SCADD      Bottom of screen?
       F1A8 C1
[1408] F1A9 71,B1           BS   GMORE             So scroll screen up
[1409] F1AB A3,10,00        DADD 32,@SCADD         Down one.
       F1AE 20
[1410] F1AF 4F,57           BR   OKKEY             No
[1411] F1B1 D5,04,40 GMORE  DCEQ @>8340,@TMP4      End of buffer?
[1412] F1B4 6F,57           BS   OKKEY             Yes
[1413] F1B6 D6,A0,A2        CEQ  >20,V@>00A2       Last line in buffer?
       F1B9 20
[1414] F1BA 6F,57           BS   OKKEY             Yes
[1415] F1BC A3,04,00        DADD >20,@TMP4         One more line up
       F1BF 20
[1416] F1C0 4F,57           BR   OKKEY
[1417] F1C2 BE,76,12 LKEY   ST   18,@>8376         Line Counter
[1418] F1C5 D7,10,00 LUPKEY DCEQ >0081,@SCADD      Top of screen?
       F1C8 81
[1419] F1C9 71,D1           BS   LGLESS            So scroll screen down
[1420] F1CB A7,10,00        DSUB 32,@SCADD         Up one.
       F1CE 20
[1421] F1CF 51,DB           BR   LGLES2            Return
[1422] F1D1 D7,04,25 LGLESS DCEQ >2580,@TMP4       Start of buffer?
       F1D4 80
[1423] F1D5 71,DD           BS   LOKKEY            Yes
[1424] F1D7 A7,04,00        DSUB >20,@TMP4         One more line down
       F1DA 20
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0033
Rich E/A GROM
[1425] F1DB 51,DD    LGLES2 BR   LOKKEY
[1426] F1DD 06,F2,18 LOKKEY CALL FLSCR
[1427] F1E0 92,76           DEC  @>8376            Line counter -1
[1428] F1E2 51,C5           BR   LUPKEY            Continue Loop
[1429] F1E4 05,EF,5E        B    NOKEY             Done.
[1430] F1E7 BE,76,12 RKEY   ST   18,@>8376         Line Counter
[1431] F1EA D6,E0,01 RDKEY  CEQ  >20,V@1(@SCADD)   Blank line?
       F1ED 10,20
[1432] F1EF 71,86           BS   UPKEY
[1433] F1F1 D7,10,02        DCEQ >02C1,@SCADD      Bottom of screen?
       F1F4 C1
[1434] F1F5 71,FD           BS   RGMORE            So scroll screen up
[1435] F1F7 A3,10,00        DADD 32,@SCADD         Down one.
       F1FA 20
[1436] F1FB 52,0E           BR   ROKKEY            No
[1437] F1FD D5,04,40 RGMORE DCEQ @>8340,@TMP4      End of buffer?
[1438] F200 72,0E           BS   ROKKEY            Yes
[1439] F202 D6,A0,A2        CEQ  >20,V@>00A2       Last line in buffer?
       F205 20
[1440] F206 72,0E           BS   ROKKEY            Yes
[1441] F208 A3,04,00        DADD >20,@TMP4         One more line up
       F20B 20
[1442] F20C 52,0E           BR   ROKKEY
[1443] F20E 06,F2,18 ROKKEY CALL FLSCR
[1444] F211 92,76           DEC  @>8376            Line counter -1
[1445] F213 51,EA           BR   RDKEY             Continue Loop
[1446] F215 05,EF,5E        B    NOKEY             Done.
[1447] F218 35,02,60 FLSCR  MOVE >0260,V*TMP4,V@>0080 Fill screen
       F21B A0,80,B0
       F21E 04
[1448] F21F BE,B0,10        ST   130,V*SCADD       Left arrow
       F222 82
[1449] F223 BE,E0,0B        ST   131,V@11(@SCADD)  Right arrow
       F226 10,83
[1450] F228 00              RTN
[1451] F229 BE,AF,22 CLRBUF ST   ENTER,V@>2257     Clear buffer
       F22C 57,0D
[1452] F22E 35,00,3F        MOVE 63,V@>2257,V@>2258
       F231 AF,22,58
       F234 AF,22,57
[1453] F237 35,00,3F        MOVE 63,V@>2257,V@>2402
       F23A AF,24,02
       F23D AF,22,57
[1454] F240 06,F6,4D        CALL CLRFAC
[1455] F243 00              RTN
[1456]               *
[1457]               * PAB data
[1458]               *
[1459] F244 00,0D,08 CATDAT BYTE 0,>D,8,>36,0,0,0,0,0
       F247 36,00,00
       F24A 00,00,00
[1460]               *
[1461] F24D 40,02,00 HALVE  BYTE >40,>02,0,0,0,0,0,0
       F250 00,00,00
       F253 00,00
[1462]               *
[1463]               * Screen - prints initial screen and disk info
[1464]               *
[1465] F255 08       SCREEN FMT
[1466] F256 FE,00            ROW  0
[1467] F258 FF,02            COL  2
[1468] F25A 1C,44,69         HTEX 'Directory=           Files000'
       F25D 72,65,63
       F260 74,6F,72
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0034
Rich E/A GROM
       F263 79,3D,20
       F266 20,20,20
       F269 20,20,20
       F26C 20,20,20
       F26F 20,46,69
       F272 6C,65,73
       F275 30,30,30
[1469] F278 A0               ROW+ 1
[1470] F279 FF,02            COL  2
[1471] F27B 14,46,72         HTEX 'Free=           Used='
       F27E 65,65,3D
       F281 20,20,20
       F284 20,20,20
       F287 20,20,20
       F28A 20,20,55
       F28D 73,65,64
       F290 3D
[1472] F291 A0               ROW+ 1
[1473] F292 FF,02            COL  2
[1474] F294 1C,20,46         HTEX ' Filename  Size    Type     P'
       F297 69,6C,65
       F29A 6E,61,6D
       F29D 65,20,20
       F2A0 53,69,7A
       F2A3 65,20,20
       F2A6 20,20,54
       F2A9 79,70,65
       F2AC 20,20,20
       F2AF 20,20,50
[1475] F2B2 A0               ROW+ 1
[1476] F2B3 FF,02            COL  2
[1477] F2B5 1C,2D,2D         HTEX '---------- ---- ----------- -'
       F2B8 2D,2D,2D
       F2BB 2D,2D,2D
       F2BE 2D,2D,20
       F2C1 2D,2D,2D
       F2C4 2D,20,2D
       F2C7 2D,2D,2D
       F2CA 2D,2D,2D
       F2CD 2D,2D,2D
       F2D0 2D,20,2D
[1478] F2D3 FB              FEND
[1479] F2D4 86,1E           CLR  @COUNT            Clear file counter
[1480] F2D6 06,F4,3E        CALL DISSTR            Get string into FAC
[1481] F2D9 8E,4B           CZ   @FAC1             Skip if zero length
[1482] F2DB 72,E5           BS   CAT3
[1483] F2DD 08              FMT
[1484] F2DE FE,00            ROW 0
[1485] F2E0 FF,0C            COL 12
[1486] F2E2 E9,4C            HSTR 10,@FAC2
[1487] F2E4 FB              FEND
[1488] F2E5 A1,10,4A CAT3   DADD @FAC,@SCADD       Go to next field
[1489] F2E8 A3,10,00        DADD 19,@SCADD         Continue to last field
       F2EB 13
[1490] F2EC BF,14,00        DST  >28,@>8314        Set up screen addr
       F2EF 28
[1491] F2F0 D7,AF,10        DCEQ >4453,V@>100A     DSK?
       F2F3 0A,44,53
[1492] F2F6 52,FE           BR   CAT4              No, must be HARD
[1493] F2F8 06,F4,1B        CALL DISNUM            Display available DSK space
[1494] F2FB 05,F3,0F        B    CAT4A
[1495] F2FE 35,00,08 CAT4   MOVE 8,V*SCADD,@ARG    Get Available space *2
       F301 5C,B0,10
[1496] F304 31,00,08        MOVE 8,G@HALVE,@FAC    Get divisor
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0035
Rich E/A GROM
       F307 4A,F2,4D
[1497] F30A 0F,02           XML  ROUND
[1498] F30C 06,F4,21        CALL DISNU1            Display available HARD space
[1499]               * Display used space
[1500] F30F 35,00,08 CAT4A  MOVE 8,V*SCADD,@FAC    Get Available space
       F312 4A,B0,10
[1501] F315 A7,10,00        DSUB 9,@SCADD          Point to formatted space
       F318 09
[1502] F319 35,00,08        MOVE 8,V*SCADD,@ARG    Move it to ARG
       F31C 5C,B0,10
[1503] F31F 0F,07           XML  FSUB              Develop used value *2
[1504] F321 BF,14,00        DST  >38,@>8314        Set up screen addr
       F324 38
[1505] F325 D7,AF,10        DCEQ >4453,V@>100A     DSK?
       F328 0A,44,53
[1506] F32B 73,3C           BS   CAT4B             Yes, must be DISK
[1507] F32D 35,00,08        MOVE 8,@FAC,@ARG       Get Unused space *2
       F330 5C,4A
[1508] F332 31,00,08        MOVE 8,G@HALVE,@FAC    Get divisor
       F335 4A,F2,4D
[1509] F338 0F,09           XML  FDIV
[1510] F33A 0F,02           XML  ROUND
[1511] F33C 06,F4,21 CAT4B  CALL DISNU1            Display used space
[1512] F33F 00              RTN                    Return
[1513]               *
[1514]               * Display one file on screen
[1515]               *
[1516] F340 06,F4,3E FILNAM CALL DISSTR            Get string into FAC
[1517] F343 90,1E           INC  @COUNT            FILE COUNT +1
[1518] F345 8E,4B           CZ   @FAC1             Skip display if zero
[1519] F347 73,51           BS   CAT5              length
[1520] F349 08              FMT                    Put disk name on screen
[1521] F34A FE,17            ROW   23              .
[1522] F34C FF,02            COL   02              .
[1523] F34E E9,4C            HSTR 10,@FAC2         .
[1524] F350 FB              FEND                   .
[1525] F351 A1,10,4A CAT5   DADD @FAC,@SCADD       Go to next field
[1526] F354 A3,10,00        DADD 10,@SCADD         Continue another field
       F357 0A
[1527] F358 8F,B0,10        DCZ  V*SCADD           Time to get out if
[1528] F35B 74,16           BS   FILNA1            zero file size
[1529] F35D BF,14,02        DST  >2EA,@>8314       Set up screen address
       F360 EA
[1530] F361 06,F4,1B        CALL DISNUM            Display file length
[1531] F364 A7,10,00        DSUB 9,@SCADD          Back a field
       F367 09
[1532] F368 35,00,08        MOVE 8,V*SCADD,@FAC    Move it into FAC
       F36B 4A,B0,10
[1533] F36E 0F,12           XML  CFI               Convert it to an int.
[1534] F370 8E,4A           CZ   @FAC              Non-negative?
[1535] F372 73,7A           BS   CAT5A             YES! File not protected
[1536] F374 BC,A2,FE        ST   @TMP2,V@>2FE      Put a 'Y' on screen
       F377 02
[1537] F378 83,4A           DNEG @FAC              Make number positive
[1538] F37A 92,4B    CAT5A  DEC  @FAC1             Adjust for CASE
[1539] F37C 8A,4B           CASE @FAC1             Show file type
[1540] F37E 53,8A           BR   DF                .
[1541] F380 53,9A           BR   DV                .
[1542] F382 53,AA           BR   IF                .
[1543] F384 53,BA           BR   IV                .
[1544] F386 53,CA           BR   PR                .
[1545] F388 53,DA           BR   DI
[1546] F38A 08       DF     FMT
[1547] F38B FE,17            ROW   23
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0036
Rich E/A GROM
[1548] F38D FF,12            COL   18
[1549] F38F 06,44,69         HTEX 'Dis/Fix'
       F392 73,2F,46
       F395 69,78
[1550] F397 FB              FEND
[1551] F398 53,EC           BR   CAT6
[1552] F39A 08       DV     FMT
[1553] F39B FE,17            ROW   23
[1554] F39D FF,12            COL   18
[1555] F39F 06,44,69         HTEX 'Dis/Var'
       F3A2 73,2F,56
       F3A5 61,72
[1556] F3A7 FB              FEND
[1557] F3A8 53,EC           BR   CAT6
[1558] F3AA 08       IF     FMT
[1559] F3AB FE,17            ROW   23
[1560] F3AD FF,12            COL   18
[1561] F3AF 06,49,6E         HTEX 'Int/Fix'
       F3B2 74,2F,46
       F3B5 69,78
[1562] F3B7 FB              FEND
[1563] F3B8 53,EC           BR   CAT6
[1564] F3BA 08       IV     FMT
[1565] F3BB FE,17            ROW   23
[1566] F3BD FF,12            COL   18
[1567] F3BF 06,49,6E         HTEX 'Int/Var'
       F3C2 74,2F,56
       F3C5 61,72
[1568] F3C7 FB              FEND
[1569] F3C8 53,EC           BR   CAT6
[1570] F3CA 08       PR     FMT
[1571] F3CB FE,17            ROW   23
[1572] F3CD FF,12            COL   18
[1573] F3CF 06,50,72         HTEX 'Program'
       F3D2 6F,67,72
       F3D5 61,6D
[1574] F3D7 FB              FEND
[1575] F3D8 53,F7           BR   CAT7              Return
[1576] F3DA 08       DI     FMT
[1577] F3DB FE,17            ROW    23
[1578] F3DD FF,12            COL    18
[1579] F3DF 08,44,69         HTEX 'Directory'
       F3E2 72,65,63
       F3E5 74,6F,72
       F3E8 79
[1580] F3E9 FB              FEND
[1581] F3EA 53,F7           BR   CAT7
[1582] F3EC A3,10,00 CAT6   DADD 18,@SCADD         Advavce two fields
       F3EF 12
[1583] F3F0 BF,14,02        DST  >2F6,@>8314       Set up screen address
       F3F3 F6
[1584] F3F4 06,F4,1B        CALL DISNUM            Display record length
[1585] F3F7 35,00,1F CAT7   MOVE >1F,V@>02E0,V@0(@>8340)
       F3FA E0,00,40
       F3FD A2,E0
[1586] F3FF A3,40,00        DADD >20,@>8340
       F402 20
[1587]
[1588]               *
[1589]               * Scroll the screen
[1590]               *
[1591] F403 35,02,60 SCROLL MOVE >260,V@>A0,V@>80  Scroll screen
       F406 A0,80,A0
       F409 A0
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0037
Rich E/A GROM
[1592] F40A BE,A2,E0        ST   SPACE,V@>2E0      Clear last line
       F40D 20
[1593] F40E 35,00,1F        MOVE >1F,V@>2E0,V@>2E1
       F411 A2,E1,A2
       F414 E0
[1594] F415 00              RTN                    Return
[1595] F416 87,12    FILNA1 DCLR @>8312            Clear a byte
[1596] F418 8E,12           CZ   @>8312            Set COND bit
[1597] F41A 01              RTNC                   Return w/COND
[1598]               * Display number subroutine
[1599]               *  ENTER: Floating number in FAC for DISNU1
[1600]               *         Screen address in >8314
[1601]               *
[1602] F41B 35,00,08 DISNUM MOVE 8,V*SCADD,@FAC    Move FLP number to FAC
       F41E 4A,B0,10
[1603] F421 86,55    DISNU1 CLR  @FAC11            Indicate a free format
[1604] F423 06,00,14        CALL CNS               Convert FAC to a string
[1605] F426 BF,16,00        DST  7,@>8316          Right justify number
       F429 07
[1606] F42A A4,17,56        S    @FAC12,@>8317
[1607] F42D A1,14,16        DADD @>8316,@>8314
[1608] F430 BC,B0,14 DISNU2 ST   *FAC11,V*>8314    Put a char on the screen
       F433 90,55
[1609] F435 91,14           DINC @>8314            Increment screen addr.
[1610] F437 90,55           INC  @FAC11            Increment FAC addr.
[1611] F439 92,56           DEC  @FAC12            Decrement string length count
[1612] F43B 54,30           BR   DISNU2            Loop until done
[1613] F43D 00              RTN                    Return to caller
[1614]               *
[1615]               * Prepare a VDP string for FORMAT statement
[1616]               *  LEAVE: FAC has string length (word)
[1617]               *         FAC2  has string
[1618]               *         SCADD pointing to next string in record
[1619]               *
[1620] F43E BF,10,08 DISSTR DST  >0836,@SCADD      Get buffer address
       F441 36
[1621] F442 86,4A           CLR  @FAC              Clear MSB of FAC word
[1622] F444 BC,4B,B0        ST   V*SCADD,@FAC1     Store disk name length
       F447 10
[1623] F448 91,10           DINC @SCADD            Point to string
[1624] F44A BE,4C,20        ST   >20,@FAC2         Clear out string space
[1625] F44D 35,00,09        MOVE 9,@FAC2,@FAC3     .
       F450 4D,4C
[1626] F452 34,4A,4C        MOVE @FAC,V*SCADD,@FAC2 Move disk name into FAC
       F455 B0,10
[1627] F457 00              RTN
[1628]               ***********************************************************
[1629]               * ERRORS
[1630]               *
[1631] F458 06,E8,1A GE8A8  CALL  EASCRN
[1632] F45B 06,F5,F4        CALL  WENTER
[1633] F45E 40,86           BR    GE029
[1634] F460 06,E8,1A GE8B0  CALL  EASCRN
[1635] F463 06,F4,B2 GE8B3  CALL  GE8FC
[1636] F466 CA,22,08        CHE   >08,@CODE
[1637] F469 55,0E           BR    CHKERR
[1638] F46B A6,22,08        SUB   >08,@CODE
[1639] F46E C6,22,05        CH    >05,@CODE
[1640] F471 74,84           BS    GE8D4
[1641] F473 06,F5,61        CALL  CLSALL
[1642] F476 8A,22           CASE  @CODE
[1643] F478 54,C0           BR    GE90F
[1644] F47A 54,B9           BR    GE908
[1645] F47C 54,D9           BR    GE928
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0038
Rich E/A GROM
[1646] F47E 54,E0           BR    GE92F
[1647] F480 54,E7           BR    GE936
[1648] F482 54,EE           BR    GE93D
[1649] F484 DA,48,20 GE8D4  CLOG  >20,@FLAG
[1650] F487 49,C5           BR    GE767
[1651] F489 DA,49,01        CLOG  >01,@FLAG2
[1652] F48C 4A,0F           BR    LANDR
[1653] F48E 06,F5,7D        CALL  CLSPAB
[1654] F491 43,8D           BR    EDITOR
[1655] F493 06,F4,B2 GE8E3  CALL  GE8FC
[1656] F496 06,E8,1A        CALL  EASCRN
[1657] F499 D6,22,0F        CEQ   >0F,@CODE
[1658] F49C 54,A5           BR    GE8F5
[1659] F49E 06,F5,9D        CALL  ERRMSG
[1660] F4A1 F8,6E           DATA  ERRPNF  * ERROR PROGRAM NOT FOUND
[1661] F4A3 54,FA           BR    GE949
[1662] F4A5 06,F5,9D GE8F5  CALL  ERRMSG
[1663] F4A8 F8,04           DATA  ERRC
[1664] F4AA 40,86           BR    GE029
[1665] F4AC 06,F4,B2        CALL  GE8FC
[1666] F4AF 05,E0,86        B     GE029
[1667] F4B2 39,00,01 GE8FC  MOVE  1,G@VREGS,#1
       F4B5 01,F8,BE
[1668] F4B8 00       GE907  RTN
[1669] F4B9 06,F5,91 GE908  CALL  WRNMSG
[1670] F4BC F8,0F           DATA  CCRMSG  * WARNING CONTROL CHARACTERS REMOVED
[1671] F4BE 54,84           BR    GE8D4
[1672] F4C0 06,F5,9D GE90F  CALL  ERRMSG
[1673] F4C3 F7,C7           DATA  ERRMF   * ERROR MEMORY FULL
[1674] F4C5 54,84           BR    GE8D4
[1675] F4C7 06,F5,9D GE916  CALL  ERRMSG
[1676] F4CA F8,6E           DATA  ERRPNF  * ERROR PROGRAM NOT FOUND
[1677] F4CC 40,6F           BR    OLDEA
[1678] F4CE DA,48,08 GE91D  CLOG  >08,@FLAG
[1679] F4D1 54,D3           BR    GE9E2
[1680] F4D3 06,F5,9D GE9E2  CALL  ERRMSG
[1681] F4D6 F7,E2           DATA  ERRNME  * ERROR NO MEMORY EXPANSION
[1682] F4D8 0B              EXIT
[1683] F4D9 06,F5,9D GE928  CALL  ERRMSG
[1684] F4DC F8,29           DATA  ERRIT   * ERROR ILLEGAL TAG
[1685] F4DE 4A,0F           BR    LANDR
[1686] F4E0 06,F5,9D GE92F  CALL  ERRMSG
[1687] F4E3 F8,35           DATA  ERRCE   * CHECKSUM ERROR
[1688] F4E5 4A,0F           BR    LANDR
[1689] F4E7 06,F5,9D GE936  CALL  ERRMSG
[1690] F4EA F8,44           DATA  ERRDD   * ERROR DUPLICATE DEFINITION
[1691] F4EC 4A,0F           BR    LANDR
[1692] F4EE 06,F5,9D GE93D  CALL  ERRMSG
[1693] F4F1 F8,59           DATA  ERRUR   * ERROR UNRESOLVED REFERENCE
[1694] F4F3 4A,0F           BR    LANDR
[1695] F4F5 06,F5,9D GE944  CALL  ERRMSG
[1696] F4F8 F7,F6           DATA  ERRNTL  * ERROR NAME TO LONG
[1697] F4FA 8F,50    GE949  DCZ   @FAC6
[1698] F4FC 75,09           BS    GE958
[1699] F4FE BE,B0,4E        ST    SPACE,V*FAC4
       F501 20
[1700] F502 34,50,E0        MOVE  @FAC6,V*FAC4,V@1(@FAC4)
       F505 01,4E,B0
       F508 4E
[1701] F509 06,F6,06 GE958  CALL  CLRMSG
[1702] F50C 4A,85           BR    GE848
[1703] F50E 8E,44    CHKERR CZ    @>8344           * Check Search flag
[1704] F510 75,19           BS    CHKER2           * Yes, normal error
[1705] F512 90,44           INC   @>8344           * Drive # + 1
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0039
Rich E/A GROM
[1706] F514 CA,44,3A        CHE   58,@>8344        * Last drive?
[1707] F517 4C,53           BR    MYSRCH           * No, continue Search
[1708] F519 BC,4E,E0 CHKER2 ST    V@1(@PABPTR),@FAC4
       F51C 01,1C
[1709] F51E B2,4E,E0        AND   >E0,@FAC4
[1710] F521 E6,4E,05        SRL   >05,@FAC4
[1711] F524 B6,4E,30        OR    >30,@FAC4
[1712] F527 B2,E0,01        AND   >1F,V@1(@PABPTR)
       F52A 1C,1F
[1713] F52C D6,4E,35        CEQ   >35,@FAC4        Error Read past EOF
[1714] F52F 55,3E           BR    GE97A
[1715] F531 06,F5,61        CALL  CLSALL
[1716] F534 D6,47,01        CEQ   1,@LDFLAG
[1717] F537 43,8D           BR    EDITOR           EDITOR
[1718] F539 D6,47,02        CEQ   2,@LDFLAG
[1719] F53C 48,4F           BR    ASSEM            ASSEMBLER
[1720] F53E 06,F5,9D GE97A  CALL  ERRMSG
[1721] F541 F7,D3           DATA  ERRIOC         * I O ERROR CODE
[1722] F543 D6,47,01        CEQ   1,@LDFLAG
[1723] F546 63,8D           BS    EDITOR
[1724] F548 D6,47,02        CEQ   2,@LDFLAG
[1725] F54B 68,4F           BS    ASSEM
[1726] F54D 06,F5,61 GE97F  CALL  CLSALL
[1727] F550 DA,48,20        CLOG  >20,@FLAG
[1728] F553 40,6F           BR    OLDEA
[1729] F555 DA,49,01        CLOG  >01,@FLAG2
[1730] F558 4A,0F           BR    LANDR
[1731] F55A DA,49,08        CLOG  >08,@FLAG2
[1732] F55D 40,6F           BR    OLDEA
[1733] F55F 43,8D           BR    EDITOR
[1734] F561 06,F6,55 CLSALL CALL  P1000
[1735] F564 06,F5,7D        CALL  CLSPAB
[1736] F567 BF,1C,11        DST   >1100,@PABPTR
       F56A 00
[1737] F56B 06,F5,7D        CALL  CLSPAB
[1738] F56E BF,1C,12        DST   >1200,@PABPTR
       F571 00
[1739] F572 06,F5,7D        CALL  CLSPAB
[1740] F575 BF,1C,13        DST   >1300,@PABPTR
       F578 00
[1741] F579 06,F5,7D        CALL  CLSPAB
[1742] F57C 00              RTN
[1743] F57D BD,56,1C CLSPAB DST   @PABPTR,@VPAB
[1744] F580 A3,56,00        DADD  >0009,@VPAB
       F583 09
[1745] F584 BE,B0,1C        ST    >01,V*PABPTR
       F587 01
[1746] F588 06,00,10        CALL  DSRLNK
[1747] F58B 08              BYTE  >08
[1748] F58C 86,E0,09        CLR   V@>0009(@PABPTR)
       F58F 1C
[1749] F590 00              RTN
[1750] F591 06,F6,06 WRNMSG CALL  CLRMSG
[1751] F594 31,00,0B        MOVE  11,G@WARN,V@>02A2
       F597 A2,A2,F7
       F59A BC
[1752] F59B 55,A7           BR    GE9DA
[1753] F59D 06,F6,06 ERRMSG CALL  CLRMSG
[1754] F5A0 31,00,09        MOVE  9,G@ERROR,V@>02A2
       F5A3 A2,A2,F7
       F5A6 8A
[1755] F5A7 88,4A    GE9DA  FETCH @FAC
[1756] F5A9 88,4B           FETCH @FAC1
[1757] F5AB 86,4C           CLR   @FAC2
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0040
Rich E/A GROM
[1758] F5AD 33,00,01        MOVE  1,G@0(@FAC),@FAC3
       F5B0 4D,00,00
       F5B3 4A
[1759] F5B4 32,4C,A2        MOVE  @FAC2,G@1(@FAC),V@>02C2
       F5B7 C2,00,01
       F5BA 4A
[1760] F5BB D7,4A,F7        DCEQ  ERRIOC,@FAC
       F5BE D3
[1761] F5BF 55,C5           BR    GE9F8
[1762] F5C1 BC,A2,D2        ST    @FAC4,V@>02D2
       F5C4 4E
[1763] F5C5 D7,4A,F8 GE9F8  DCEQ  ERRC,@FAC
       F5C8 04
[1764] F5C9 55,F4           BR    WENTER
[1765] F5CB E7,22,00        DSRL  >0004,@CODE
       F5CE 04
[1766] F5CF E6,23,04        SRL   >04,@>8323
[1767] F5D2 C6,22,09        CH    >09,@CODE
[1768] F5D5 55,DF           BR    GEA12
[1769] F5D7 C6,22,0F        CH    >0F,@CODE
[1770] F5DA 75,F4           BS    WENTER
[1771] F5DC A2,22,07        ADD   >07,@CODE
[1772] F5DF C6,23,09 GEA12  CH    >09,@>8323
[1773] F5E2 55,EC           BR    GEA1F
[1774] F5E4 C6,23,0F        CH    >0F,@>8323
[1775] F5E7 75,F4           BS    WENTER
[1776] F5E9 A2,23,07        ADD   >07,@>8323
[1777] F5EC A3,22,30 GEA1F  DADD  >3030,@CODE
       F5EF 30
[1778] F5F0 BD,A2,D0        DST   @CODE,V@>02D0
       F5F3 22
[1779]               *  Wait for ENTER
[1780] F5F4 31,00,17 WENTER MOVE  23,G@PRESS,V@>02E2
       F5F7 A2,E2,F7
       F5FA A5
[1781] F5FB 03       GEA2E  SCAN
[1782] F5FC 55,FB           BR    GEA2E
[1783] F5FE D6,75,0D        CEQ   >0D,@KEY
[1784] F601 55,FB           BR    GEA2E
[1785] F603 05,E0,25        B     SETUP  cHANGED FROM RETURN
[1786]               ***************************************
[1787] F606 BE,A2,A0 CLRMSG ST    SPACE,V@>02A0
       F609 20
[1788] F60A 35,00,5F        MOVE  >005F,V@>02A0,V@>02A1
       F60D A2,A1,A2
       F610 A0
[1789] F611 00              RTN
[1790]               ********************************************
[1791]               *  CALL INIT
[1792]               *
[1793] F612 D7,8F,9D BINIT2 DCEQ  >A55A,@>2000
       F615 00,A5,5A
[1794] F618 76,4C           BS    GEBBD
[1795] F61A 06,E7,F3 BINIT3 CALL  EXPMEM
[1796] F61D 86,8F,9D        CLR   @>2000
       F620 00
[1797] F621 35,1F,FF        MOVE  8191,@>2000,@>2001 CLEAR MEMORY
       F624 8F,9D,01
       F627 8F,9D,00
[1798] F62A 31,00,08        MOVE  8,G@LOW1,@>2000
       F62D 8F,9D,00
       F630 F8,C4
[1799] F632 31,00,08        MOVE  8,G@LOW2,@>2024
       F635 8F,9D,24
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0041
Rich E/A GROM
       F638 F8,CC
[1800] F63A 31,05,7B        MOVE  1403,G@LOW3,@>20FA
       F63D 8F,9D,FA
       F640 F8,D4
[1801] F642 31,00,C8        MOVE  200,G@LOW4,@>3F38
       F645 8F,BC,38
       F648 FE,54
[1802] F64A 48,41           BR    CLRXOP
[1803] F64C 00       GEBBD  RTN
[1804]               *******************************
[1805] F64D 86,4A    CLRFAC CLR   @FAC
[1806] F64F 35,00,07        MOVE  7,@FAC,@FAC1
       F652 4B,4A
[1807] F654 00              RTN
[1808]               *******************************
[1809] F655 BF,1C,10 P1000  DST   >1000,@PABPTR
       F658 00
[1810] F659 00              RTN
[1811]               *******************************
[1812] F65A 06,E7,F3 DEVICE CALL  EXPMEM               Clear expansion memory
[1813] F65D 35,00,80        MOVE  128,V@>027F,V@>0280
       F660 A2,80,A2
       F663 7F
[1814] F664 BC,06,75        ST    @KEY,@TMP6           Save key
[1815] F667 08              FMT
[1816] F668 FE,10           ROW   16
[1817] F66A FF,02           COL   2
[1818] F66C 0B,53,65        HTEX  'Select DSK#.'
       F66F 6C,65,63
       F672 74,20,44
       F675 53,4B,23
       F678 2E
[1819] F679 FB              FEND
[1820] F67A 35,00,05        MOVE  5,V@>100F,V@>020E     EDIT1 or ASSM1
       F67D A2,0E,AF
       F680 10,0F
[1821] F682 03       DEV1   SCAN                        KEY?
[1822] F683 56,82           BR    DEV1                  No.
[1823] F685 D6,75,20        CEQ   SPACE,@KEY            SPACE BAR?
[1824] F688 76,9F           BS    DEV4                  Yes
[1825] F68A D6,75,0F        CEQ   BACK,@KEY             BACK?
[1826] F68D 76,9E           BS    DEV3                  Yes
[1827] F68F BC,A2,0C        ST    @KEY,V@>020C          Any other key SAVE
       F692 75
[1828] F693 BC,AF,10        ST    @KEY,V@>100D          Put into PAB
       F696 0D,75
[1829] F698 BC,75,06 DEVNO  ST    @TMP6,@KEY            Restore old key
[1830] F69B 06,EC,93 DEV2   CALL  PMSG                  PLEASE WAIT...
[1831] F69E 00       DEV3   RTN
[1832] F69F 08       DEV4   FMT
[1833] F6A0 FE,10           ROW   16
[1834] F6A2 FF,02           COL   2
[1835] F6A4 10,45,78        HTEX  'Example: WDS1.EA.'
       F6A7 61,6D,70
       F6AA 6C,65,3A
       F6AD 20,57,44
       F6B0 53,31,2E
       F6B3 45,41,2E
[1836] F6B6 FE,12           ROW   18
[1837] F6B8 FF,02           COL   2
[1838] F6BA 09,46,55        HTEX  'FULL PATH?'
       F6BD 4C,4C,20
       F6C0 50,41,54
       F6C3 48,3F
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0042
Rich E/A GROM
[1839] F6C5 FB              FEND
[1840] F6C6 35,00,05        MOVE  5,V@>100F,V@>0213     EDIT1 or ASSM1
       F6C9 A2,13,AF
       F6CC 10,0F
[1841] F6CE BF,20,02        DST   >0282,@CURADD
       F6D1 82
[1842] F6D2 86,44           CLR   @>8344                Clear search flag
[1843] F6D4 B6,48,04        OR    >04,@FLAG             Set return flag
[1844] F6D7 06,E6,C4        CALL  GETINP
[1845] F6DA BD,00,20        DST   @CURADD,@TMP
[1846] F6DD A6,01,82        SUB   >82,@TMP1
[1847] F6E0 BC,AF,10        ST    @TMP1,V@>1009
       F6E3 09,01
[1848] F6E5 34,00,AF        MOVE  @TMP,V@>0282,V@>100A
       F6E8 10,0A,A2
       F6EB 82
[1849] F6EC BE,48,20        ST    >20,@FLAG
[1850] F6EF 05,F6,98        B     DEVNO
[1851]               **********************************************************
[1852] F6F2 F6,F9    EADSR  DATA SEADSR
[1853] F6F4 E0,25           DATA SETUP
[1854] F6F6 02,45,41        STRI 'EA'
[1855] F6F9 F7,00    SEADSR DATA XBDSR
[1856] F6FB E0,25           DATA SETUP
[1857] F6FD 02,65,61        STRI 'ea'
[1858]               ************************************
[1859] F700 F7,07    XBDSR  DATA SXBDSR
[1860] F702 63,72           DATA RXB
[1861] F704 02,58,42        STRI 'XB'
[1862] F707 F7,0E    SXBDSR DATA BASIC
[1863] F709 63,72           DATA RXB
[1864] F70B 02,78,62        STRI 'xb'
[1865]               ************************************
[1866] F70E F7,18    BASIC  DATA SBASIC
[1867] F710 21,6F           DATA >216F
[1868] F712 05,42,41        STRI 'BASIC'
       F715 53,49,43
[1869] F718 00,00    SBASIC DATA >0000
[1870] F71A 21,6F           DATA >216F
[1871] F71C 05,62,61        STRI 'basic'
       F71F 73,69,63
[1872]               ***********************************************************
[1873] F722 0A,44,53 C1     STRI  'DSK1.EDIT1'
       F725 4B,31,2E
       F728 45,44,49
       F72B 54,31
[1874] F72D 0A,44,53 C2     STRI  'DSK1.ASSM1'
       F730 4B,31,2E
       F733 41,53,53
       F736 4D,31
[1875] F738 0B,44,53 C3     STRI  'DSK1.SOURCE'
       F73B 4B,31,2E
       F73E 53,4F,55
       F741 52,43,45
[1876] F744 0B,44,53 C4     STRI  'DSK1.OBJECT'
       F747 4B,31,2E
       F74A 4F,42,4A
       F74D 45,43,54
[1877] F750 09,44,53 C5     STRI  'DSK1.LIST'
       F753 4B,31,2E
       F756 4C,49,53
       F759 54
[1878] F75A 01,4C    C6     STRI  'L'
[1879] F75C 05,00,13 PAB    BYTE  >05,>00,>13,>80,>00,>00,>21,>00
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0043
Rich E/A GROM
       F75F 80,00,00
       F762 21,00
[1880] F764 00,0A    DLEN   BYTE  >00,>0A
[1881] F766 44,53,4B DDSK1  TEXT  'DSK1.'
       F769 31,2E
[1882] F76B 45,44,49 DEDIT1 TEXT  'EDIT1'
       F76E 54,31
[1883] F770 41,53,53 DASSM1 TEXT  'ASSM1'
       F773 4D,31
[1884] F775 55,54,49 DUTIL1 TEXT  'UTIL1'
       F778 4C,31
[1885] F77A 0D              BYTE  >0D
[1886] F77B 4C,4F,41 DLOAD  TEXT  'LOAD'
       F77E 44
[1887] F77F 0D              BYTE  >0D
[1888] F780 00,12,10 PAB80  BYTE  >00,>12,>10,>00,>50,>00,>00,>00,>00,>00
       F783 00,50,00
       F786 00,00,00
       F789 00
[1889] F78A 2A,20,45 ERROR  TEXT  '* ERROR *'
       F78D 52,52,4F
       F790 52,20,2A
[1890] F793 2A,20,37 OUTSCN TEXT  '* 72 NAMES SHOWN *'
       F796 32,20,4E
       F799 41,4D,45
       F79C 53,20,53
       F79F 48,4F,57
       F7A2 4E,20,2A
[1891] F7A5 50,72,65 PRESS  TEXT  'Press ENTER to continue'
       F7A8 73,73,20
       F7AB 45,4E,54
       F7AE 45,52,20
       F7B1 74,6F,20
       F7B4 63,6F,6E
       F7B7 74,69,6E
       F7BA 75,65
[1892] F7BC 2A,20,57 WARN   TEXT  '* WARNING *'
       F7BF 41,52,4E
       F7C2 49,4E,47
       F7C5 20,2A
[1893] F7C7 0B,4D,45 ERRMF  STRI  'MEMORY FULL'
       F7CA 4D,4F,52
       F7CD 59,20,46
       F7D0 55,4C,4C
[1894] F7D3 0E,49,2F ERRIOC STRI  'I/O ERROR CODE'
       F7D6 4F,20,45
       F7D9 52,52,4F
       F7DC 52,20,43
       F7DF 4F,44,45
[1895] F7E2 13,4E,4F ERRNME STRI  'NO MEMORY EXPANSION'
       F7E5 20,4D,45
       F7E8 4D,4F,52
       F7EB 59,20,45
       F7EE 58,50,41
       F7F1 4E,53,49
       F7F4 4F,4E
[1896] F7F6 0D,4E,41 ERRNTL STRI  'NAME TOO LONG'
       F7F9 4D,45,20
       F7FC 54,4F,4F
       F7FF 20,4C,4F
       F802 4E,47
[1897] F804 0A,45,52 ERRC   STRI  'ERROR CODE'
       F807 52,4F,52
       F80A 20,43,4F
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0044
Rich E/A GROM
       F80D 44,45
[1898] F80F 19,43,4F CCRMSG STRI  'CONTROL CHARACTER REMOVED'
       F812 4E,54,52
       F815 4F,4C,20
       F818 43,48,41
       F81B 52,41,43
       F81E 54,45,52
       F821 20,52,45
       F824 4D,4F,56
       F827 45,44
[1899] F829 0B,49,4C ERRIT  STRI  'ILLEGAL TAG'
       F82C 4C,45,47
       F82F 41,4C,20
       F832 54,41,47
[1900] F835 0E,43,48 ERRCE  STRI  'CHECKSUM ERROR'
       F838 45,43,4B
       F83B 53,55,4D
       F83E 20,45,52
       F841 52,4F,52
[1901] F844 14,44,55 ERRDD  STRI  'DUPLICATE DEFINITION'
       F847 50,4C,49
       F84A 43,41,54
       F84D 45,20,44
       F850 45,46,49
       F853 4E,49,54
       F856 49,4F,4E
[1902] F859 14,55,4E ERRUR  STRI  'UNRESOLVED REFERENCE'
       F85C 52,45,53
       F85F 4F,4C,56
       F862 45,44,20
       F865 52,45,46
       F868 45,52,45
       F86B 4E,43,45
[1903] F86E 11,50,52 ERRPNF STRI  'PROGRAM NOT FOUND'
       F871 4F,47,52
       F874 41,4D,20
       F877 4E,4F,54
       F87A 20,46,4F
       F87D 55,4E,44
[1904] F880 50,41,54 FPATH  TEXT  'PATH.NAME?'
       F883 48,2E,4E
       F886 41,4D,45
       F889 3F
[1905] F88A 50,6C,65 PLEASE TEXT  'Please wait ...'
       F88D 61,73,65
       F890 20,77,61
       F893 69,74,20
       F896 2E,2E,2E
[1906] F899 57,44,53 WDS1   TEXT  'WDS1.'
       F89C 31,2E
[1907] F89E FF,FF,FF CURPAT BYTE  >FF,>FF,>FF,>FF,>FF,>FF,>FF,>FF
       F8A1 FF,FF,FF
       F8A4 FF,FF
[1908] F8A6 FF,FF,FF        BYTE  >FF,>FF,>FF,>FF,>FF,>FF,>FF,>FF
       F8A9 FF,FF,FF
       F8AC FF,FF
[1909] F8AE 00,10,18 DARROW DATA  >0010,>18FC,>1810,>0000 * RIGHT ARROW
       F8B1 FC,18,10
       F8B4 00,00
[1910] F8B6 00,20,60        DATA  >0020,>60FC,>6020,>0000 * LEFT ARROW
       F8B9 FC,60,20
       F8BC 00,00
[1911] F8BE E0,00,0E VREGS  BYTE  >E0,>00,>0E,>01,>06,>00
       F8C1 01,06,00
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0045
Rich E/A GROM
[1912]               ***********************************************************
[1913]               *
[1914]               *  Data for Initialization of
[1915]               *  Memory Expansion
[1916]               *
[1917] F8C4 A5,5A,21 LOW1  DATA  >A55A,>2128,>2398,>225A
       F8C7 28,23,98
       F8CA 22,5A
[1918] F8CC A0,00,FF LOW2  DATA  >A000,>FFD7,>2676,>3F38
       F8CF D7,26,76
       F8D2 3F,38
[1919] F8D4 00,64,20 LOW3  DATA  >0064,>2000,>2EAA,>2094
       F8D7 00,2E,AA
       F8DA 20,94
[1920] F8DC 21,C4,20       DATA  >21C4,>2094,>2196,>2094,>21DE,>2094,>21F4
       F8DF 94,21,96
       F8E2 20,94,21
       F8E5 DE,20,94
       F8E8 21,F4
[1921] F8EA 20,94,22       DATA  >2094,>2200,>2094,>220E,>2094,>221A,>2094,>2228
       F8ED 00,20,94
       F8F0 22,0E,20
       F8F3 94,22,1A
       F8F6 20,94,22
       F8F9 28
[1922] F8FA 20,9A,22       DATA  >209A,>22B2,>20DA,>23BA,>C80B,>2030,>D060
       F8FD B2,20,DA
       F900 23,BA,C8
       F903 0B,20,30
       F906 D0,60
[1923] F908 83,49,20       DATA  >8349,>2060,>20FC,>132A,>C020,>8350,>1311,>06A0
       F90B 60,20,FC
       F90E 13,2A,C0
       F911 20,83,50
       F914 13,11,06
       F917 A0
[1924] F918 26,46,10       DATA  >2646,>101E,>0281,>3F38,>1319,>C001,>0202
       F91B 1E,02,81
       F91E 3F,38,13
       F921 19,C0,01
       F924 02,02
[1925] F926 83,4A,8C       DATA  >834A,>8CB0,>1611,>8CB0,>160F,>8CB0,>160D,>C810
       F929 B0,16,11
       F92C 8C,B0,16
       F92F 0F,8C,B0
       F932 16,0D,C8
       F935 10
[1926] F936 20,22,02       DATA  >2022,>02E0,>20BA,>C020,>2022,>1309,>0690
       F939 E0,20,BA
       F93C C0,20,20
       F93F 22,13,09
       F942 06,90
[1927] F944 02,E0,83       DATA  >02E0,>83E0,>C2E0,>2030,>045B,>0221,>0008,>10E4
       F947 E0,C2,E0
       F94A 20,30,04
       F94D 5B,02,21
       F950 00,08,10
       F953 E4
[1928] F954 02,00,0F       DATA  >0200,>0F00,>D800,>8322,>02E0,>83E0,>0460
       F957 00,D8,00
       F95A 83,22,02
       F95D E0,83,E0
       F960 04,60
[1929] F962 00,CE,58       DATA  >00CE,>5820,>20FC,>8349,>02E0,>2094,>0380,>C83E
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0046
Rich E/A GROM
       F965 20,20,FC
       F968 83,49,02
       F96B E0,20,94
       F96E 03,80,C8
       F971 3E
[1930] F972 83,E2,02       DATA  >83E2,>02E0,>83E0,>C80B,>20AA,>C081,>0281
       F975 E0,83,E0
       F978 C8,0B,20
       F97B AA,C0,81
       F97E 02,81
[1931] F980 80,00,1B       DATA  >8000,>1B07,>09C1,>0A11,>0A42,>09B2,>A0A1,>0CFA
       F983 07,09,C1
       F986 0A,11,0A
       F989 42,09,B2
       F98C A0,A1,0C
       F98F FA
[1932] F990 C0,92,06       DATA  >C092,>0692,>02E0,>2094,>C80B,>83F6,>0380
       F993 92,02,E0
       F996 20,94,C8
       F999 0B,83,F6
       F99C 03,80
[1933] F99E D0,60,83       DATA  >D060,>8373,>0981,>C87E,>8304,>F820,>20FC,>8349
       F9A1 73,09,81
       F9A4 C8,7E,83
       F9A7 04,F8,20
       F9AA 20,FC,83
       F9AD 49
[1934] F9AE 02,E0,83       DATA  >02E0,>83E0,>C2E0,>2030,>045B,>02E0,>83E0
       F9B1 E0,C2,E0
       F9B4 20,30,04
       F9B7 5B,02,E0
       F9BA 83,E0
[1935] F9BC C8,0B,20       DATA  >C80B,>20AA,>06A0,>000E,>02E0,>2094,>C80B,>83F6
       F9BF AA,06,A0
       F9C2 00,0E,02
       F9C5 E0,20,94
       F9C8 C8,0B,83
       F9CB F6
[1936] F9CC 03,80,06       DATA  >0380,>06A0,>223A,>D82D,>0002,>8C00,>0380
       F9CF A0,22,3A
       F9D2 D8,2D,00
       F9D5 02,8C,00
       F9D8 03,80
[1937] F9DA 06,A0,22       DATA  >06A0,>223A,>D831,>8C00,>0602,>16FC,>0380,>06A0
       F9DD 3A,D8,31
       F9E0 8C,00,06
       F9E3 02,16,FC
       F9E6 03,80,06
       F9E9 A0
[1938] F9EA 22,40,DB       DATA  >2240,>DB60,>8800,>0002,>0380,>06A0,>2240
       F9ED 60,88,00
       F9F0 00,02,03
       F9F3 80,06,A0
       F9F6 22,40
[1939] F9F8 DC,60,88       DATA  >DC60,>8800,>0602,>16FC,>0380,>C05D,>D82D,>0001
       F9FB 00,06,02
       F9FE 16,FC,03
       FA01 80,C0,5D
       FA04 D8,2D,00
       FA07 01
[1940] FA08 8C,02,02       DATA  >8C02,>0261,>8000,>D801,>8C02,>0380,>0201
       FA0B 61,80,00
       FA0E D8,01,8C
       FA11 02,03,80
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0047
Rich E/A GROM
       FA14 02,01
[1941] FA16 40,00,10       DATA  >4000,>1001,>04C1,>C09D,>D820,>2099,>8C02,>E081
       FA19 01,04,C1
       FA1C C0,9D,D8
       FA1F 20,20,99
       FA22 8C,02,E0
       FA25 81
[1942] FA26 D8,02,8C       DATA  >D802,>8C02,>C06D,>0002,>C0AD,>0004,>045B
       FA29 02,C0,6D
       FA2C 00,02,C0
       FA2F AD,00,04
       FA32 04,5B
[1943] FA34 02,04,83       DATA  >0204,>834A,>C014,>C184,>04F6,>04F6,>C140,>1323
       FA37 4A,C0,14
       FA3A C1,84,04
       FA3D F6,04,F6
       FA40 C1,40,13
       FA43 23
[1944] FA44 07,40,02       DATA  >0740,>0203,>0040,>04F6,>04D6,>0280,>0064
       FA47 03,00,40
       FA4A 04,F6,04
       FA4D D6,02,80
       FA50 00,64
[1945] FA52 1A,13,02       DATA  >1A13,>0280,>2710,>1A08,>0583,>C040,>04C0,>3C20
       FA55 80,27,10
       FA58 1A,08,05
       FA5B 83,C0,40
       FA5E 04,C0,3C
       FA61 20
[1946] FA62 20,FA,D9       DATA  >20FA,>D920,>83E3,>0003,>0583,>C040,>04C0
       FA65 20,83,E3
       FA68 00,03,05
       FA6B 83,C0,40
       FA6E 04,C0
[1947] FA70 3C,20,20       DATA  >3C20,>20FA,>D920,>83E3,>0002,>D920,>83E1,>0001
       FA73 FA,D9,20
       FA76 83,E3,00
       FA79 02,D9,20
       FA7C 83,E1,00
       FA7F 01
[1948] FA80 D5,20,83       DATA  >D520,>83E7,>0545,>1101,>0514,>045B,>C17E
       FA83 E7,05,45
       FA86 11,01,05
       FA89 14,04,5B
       FA8C C1,7E
[1949] FA8E 53,E0,20       DATA  >53E0,>20FC,>C020,>8356,>C240,>0229,>FFF8,>0420
       FA91 FC,C0,20
       FA94 83,56,C2
       FA97 40,02,29
       FA9A FF,F8,04
       FA9D 20
[1950] FA9E 21,14,D0       DATA  >2114,>D0C1,>0983,>0704,>0202,>208C,>0580
       FAA1 C1,09,83
       FAA4 07,04,02
       FAA7 02,20,8C
       FAAA 05,80
[1951] FAAC 05,84,80       DATA  >0584,>80C4,>1306,>0420,>2114,>DC81,>9801,>20FE
       FAAF C4,13,06
       FAB2 04,20,21
       FAB5 14,DC,81
       FAB8 98,01,20
       FABB FE
[1952] FABC 16,F6,C1       DATA  >16F6,>C104,>1352,>0284,>0007,>154F,>04E0
       FABF 04,13,52
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0048
Rich E/A GROM
       FAC2 02,84,00
       FAC5 07,15,4F
       FAC8 04,E0
[1953] FACA 83,D0,C8       DATA  >83D0,>C804,>8354,>C804,>2036,>0584,>A804,>8356
       FACD 04,83,54
       FAD0 C8,04,20
       FAD3 36,05,84
       FAD6 A8,04,83
       FAD9 56
[1954] FADA C8,20,83       DATA  >C820,>8356,>2038,>02E0,>83E0,>04C1,>020C
       FADD 56,20,38
       FAE0 02,E0,83
       FAE3 E0,04,C1
       FAE6 02,0C
[1955] FAE8 0F,00,C3       DATA  >0F00,>C30C,>1301,>1E00,>022C,>0100,>04E0,>83D0
       FAEB 0C,13,01
       FAEE 1E,00,02
       FAF1 2C,01,00
       FAF4 04,E0,83
       FAF7 D0
[1956] FAF8 02,8C,20       DATA  >028C,>2000,>1332,>C80C,>83D0,>1D00,>0202
       FAFB 00,13,32
       FAFE C8,0C,83
       FB01 D0,1D,00
       FB04 02,02
[1957] FB06 40,00,98       DATA  >4000,>9812,>20FF,>16EE,>A0A0,>20A4,>1003,>C0A0
       FB09 12,20,FF
       FB0C 16,EE,A0
       FB0F A0,20,A4
       FB12 10,03,C0
       FB15 A0
[1958] FB16 83,D2,1D       DATA  >83D2,>1D00,>C092,>13E6,>C802,>83D2,>05C2
       FB19 00,C0,92
       FB1C 13,E6,C8
       FB1F 02,83,D2
       FB22 05,C2
[1959] FB24 C2,72,D1       DATA  >C272,>D160,>8355,>1309,>9C85,>16F2,>0985,>0206
       FB27 60,83,55
       FB2A 13,09,9C
       FB2D 85,16,F2
       FB30 09,85,02
       FB33 06
[1960] FB34 20,8C,9C       DATA  >208C,>9CB6,>16ED,>0605,>16FC,>0581,>C801
       FB37 B6,16,ED
       FB3A 06,05,16
       FB3D FC,05,81
       FB40 C8,01
[1961] FB42 20,3A,C8       DATA  >203A,>C809,>2034,>C80C,>2032,>0699,>10E2,>1E00
       FB45 09,20,34
       FB48 C8,0C,20
       FB4B 32,06,99
       FB4E 10,E2,1E
       FB51 00
[1962] FB52 02,E0,20       DATA  >02E0,>209A,>C009,>0420,>2114,>09D1,>1604
       FB55 9A,C0,09
       FB58 04,20,21
       FB5B 14,09,D1
       FB5E 16,04
[1963] FB60 03,80,02       DATA  >0380,>02E0,>209A,>04C1,>06C1,>D741,>F3E0,>20FC
       FB63 E0,20,9A
       FB66 04,C1,06
       FB69 C1,D7,41
       FB6C F3,E0,20
       FB6F FC
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0049
Rich E/A GROM
[1964] FB70 03,80,C8       DATA  >0380,>C80B,>2030,>02E0,>20BA,>0420,>2124
       FB73 0B,20,30
       FB76 02,E0,20
       FB79 BA,04,20
       FB7C 21,24
[1965] FB7E 02,E0,83       DATA  >02E0,>83E0,>1303,>C2E0,>2030,>045B,>D820,>20BA
       FB81 E0,13,03
       FB84 C2,E0,20
       FB87 30,04,5B
       FB8A D8,20,20
       FB8D BA
[1966] FB8E 83,22,04       DATA  >8322,>0460,>00CE,>04E0,>2022,>53E0,>20FC
       FB91 60,00,CE
       FB94 04,E0,20
       FB97 22,53,E0
       FB9A 20,FC
[1967] FB9C C0,20,83       DATA  >C020,>8356,>0420,>2120,>0008,>1332,>0220,>FFF7
       FB9F 56,04,20
       FBA2 21,20,00
       FBA5 08,13,32
       FBA8 02,20,FF
       FBAB F7
[1968] FBAC 02,01,02       DATA  >0201,>0200,>0420,>210C,>0580,>C800,>202E
       FBAF 00,04,20
       FBB2 21,0C,05
       FBB5 80,C8,00
       FBB8 20,2E
[1969] FBBA C1,E0,20       DATA  >C1E0,>2024,>C147,>04CC,>06A0,>25E0,>0283,>0001
       FBBD 24,C1,47
       FBC0 04,CC,06
       FBC3 A0,25,E0
       FBC6 02,83,00
       FBC9 01
[1970] FBCA 16,24,05       DATA  >1624,>058C,>04C3,>1023,>0283,>0046,>161E
       FBCD 8C,04,C3
       FBD0 10,23,02
       FBD3 83,00,46
       FBD6 16,1E
[1971] FBD8 04,C2,06       DATA  >04C2,>06A0,>262E,>0283,>003A,>16F7,>C020,>202E
       FBDB A0,26,2E
       FBDE 02,83,00
       FBE1 3A,16,F7
       FBE4 C0,20,20
       FBE7 2E
[1972] FBE8 06,00,02       DATA  >0600,>0201,>0100,>0420,>210C,>06A0,>25E0
       FBEB 01,01,00
       FBEE 04,20,21
       FBF1 0C,06,A0
       FBF4 25,E0
[1973] FBF6 C0,20,20       DATA  >C020,>2022,>1307,>06A0,>2646,>1005,>CB4E,>0016
       FBF9 22,13,07
       FBFC 06,A0,26
       FBFF 46,10,05
       FC02 CB,4E,00
       FC05 16
[1974] FC06 C3,A0,20       DATA  >C3A0,>2022,>0380,>D740,>F3E0,>20FC,>0380
       FC09 22,03,80
       FC0C D7,40,F3
       FC0F E0,20,FC
       FC12 03,80
[1975] FC14 06,A0,25       DATA  >06A0,>25C2,>04C4,>D123,>2662,>0974,>C808,>202C
       FC17 C2,04,C4
       FC1A D1,23,26
       FC1D 62,09,74
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0050
Rich E/A GROM
       FC20 C8,08,20
       FC23 2C
[1976] FC24 06,A0,25       DATA  >06A0,>2594,>0464,>23F8,>0580,>0240,>FFFE
       FC27 94,04,64
       FC2A 23,F8,05
       FC2D 80,02,40
       FC30 FF,FE
[1977] FC32 C1,20,20       DATA  >C120,>2024,>A100,>1808,>8804,>2026,>1B05,>C160
       FC35 24,A1,00
       FC38 18,08,88
       FC3B 04,20,26
       FC3E 1B,05,C1
       FC41 60
[1978] FC42 20,24,C8       DATA  >2024,>C804,>2024,>100A,>C120,>2028,>A100
       FC45 04,20,24
       FC48 10,0A,C1
       FC4B 20,20,28
       FC4E A1,00
[1979] FC50 88,04,20       DATA  >8804,>202A,>140C,>C160,>2028,>C804,>2028,>C1C5
       FC53 2A,14,0C
       FC56 C1,60,20
       FC59 28,C8,04
       FC5C 20,28,C1
       FC5F C5
[1980] FC60 02,09,00       DATA  >0209,>0008,>06A0,>262E,>0609,>16FC,>10B6
       FC63 08,06,A0
       FC66 26,2E,06
       FC69 09,16,FC
       FC6C 10,B6
[1981] FC6E 02,00,08       DATA  >0200,>0800,>10CC,>A005,>C800,>2022,>10AF,>A800
       FC71 00,10,CC
       FC74 A0,05,C8
       FC77 00,20,22
       FC7A 10,AF,A8
       FC7D 00
[1982] FC7E 20,2C,13       DATA  >202C,>13AC,>0200,>0B00,>10C2,>A005,>C1C0
       FC81 AC,02,00
       FC84 0B,00,10
       FC87 C2,A0,05
       FC8A C1,C0
[1983] FC8C 10,A6,A0       DATA  >10A6,>A005,>DDC0,>DDE0,>20DB,>10A1,>A005,>06A0
       FC8F 05,DD,C0
       FC92 DD,E0,20
       FC95 DB,10,A1
       FC98 A0,05,06
       FC9B A0
[1984] FC9C 25,66,C0       DATA  >2566,>C000,>1316,>0226,>FFF8,>8106,>1B02
       FC9F 00,13,16
       FCA2 02,26,FF
       FCA5 F8,81,06
       FCA8 1B,02
[1985] FCAA 05,14,10       DATA  >0514,>1096,>8594,>16F8,>89A4,>0002,>0002,>16F4
       FCAD 96,85,94
       FCB0 16,F8,89
       FCB3 A4,00,02
       FCB6 00,02,16
       FCB9 F4
[1986] FCBA 89,A4,00       DATA  >89A4,>0004,>0004,>16F0,>C0E6,>0006,>C250
       FCBD 04,00,04
       FCC0 16,F0,C0
       FCC3 E6,00,06
       FCC6 C2,50
[1987] FCC8 C4,03,C0       DATA  >C403,>C009,>16FC,>0224,>0008,>C804,>202A,>10EA
       FCCB 09,16,FC
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0051
Rich E/A GROM
       FCCE 02,24,00
       FCD1 08,C8,04
       FCD4 20,2A,10
       FCD7 EA
[1988] FCD8 A0,05,06       DATA  >A005,>06A0,>2566,>0226,>FFF8,>8106,>13E3
       FCDB A0,25,66
       FCDE 02,26,FF
       FCE1 F8,81,06
       FCE4 13,E3
[1989] FCE6 C2,96,15       DATA  >C296,>1501,>050A,>8294,>16F7,>89A4,>0002,>0002
       FCE9 01,05,0A
       FCEC 82,94,16
       FCEF F7,89,A4
       FCF2 00,02,00
       FCF5 02
[1990] FCF6 16,F3,89       DATA  >16F3,>89A4,>0004,>0004,>16EF,>C296,>1516
       FCF9 A4,00,04
       FCFC 00,04,16
       FCFF EF,C2,96
       FD02 15,16
[1991] FD04 C0,E6,00       DATA  >C0E6,>0006,>C253,>C4C0,>C0C9,>16FC,>C246,>6244
       FD07 06,C2,53
       FD0A C4,C0,C0
       FD0D C9,16,FC
       FD10 C2,46,62
       FD13 44
[1992] FD14 C2,86,02       DATA  >C286,>022A,>0008,>C0C6,>0643,>064A,>C693
       FD17 2A,00,08
       FD1A C0,C6,06
       FD1D 43,06,4A
       FD20 C6,93
[1993] FD22 06,49,16       DATA  >0649,>16FB,>0224,>0008,>C804,>202A,>10D9,>CB44
       FD25 FB,02,24
       FD28 00,08,C8
       FD2B 04,20,2A
       FD2E 10,D9,CB
       FD31 44
[1994] FD32 00,02,02       DATA  >0002,>0200,>0C00,>0460,>2432,>0460,>2494
       FD35 00,0C,00
       FD38 04,60,24
       FD3B 32,04,60
       FD3E 24,94
[1995] FD40 C2,8B,02       DATA  >C28B,>0209,>0006,>C1A0,>202A,>0226,>FFF8,>C106
       FD43 09,00,06
       FD46 C1,A0,20
       FD49 2A,02,26
       FD4C FF,F8,C1
       FD4F 06
[1996] FD50 88,06,20       DATA  >8806,>2028,>1AF3,>C806,>202A,>06A0,>262E
       FD53 28,1A,F3
       FD56 C8,06,20
       FD59 2A,06,A0
       FD5C 26,2E
[1997] FD5E DD,A0,20       DATA  >DDA0,>20E1,>0609,>16FA,>C580,>0206,>4000,>045A
       FD61 E1,06,09
       FD64 16,FA,C5
       FD67 80,02,06
       FD6A 40,00,04
       FD6D 5A
[1998] FD6E C2,8B,04       DATA  >C28B,>04C0,>C30C,>1308,>06A0,>262E,>D020
       FD71 C0,C3,0C
       FD74 13,08,06
       FD77 A0,26,2E
       FD7A D0,20
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0052
Rich E/A GROM
[1999] FD7C 20,E1,06       DATA  >20E1,>06A0,>262E,>A003,>045A,>0209,>0004,>06A0
       FD7F A0,26,2E
       FD82 A0,03,04
       FD85 5A,02,09
       FD88 00,04,06
       FD8B A0
[2000] FD8C 26,2E,06       DATA  >262E,>06A0,>25C2,>0A40,>A003,>0609,>16F8
       FD8F A0,25,C2
       FD92 0A,40,A0
       FD95 03,06,09
       FD98 16,F8
[2001] FD9A 04,5A,02       DATA  >045A,>0223,>FFD0,>0283,>000A,>1A05,>0223,>FFF9
       FD9D 23,FF,D0
       FDA0 02,83,00
       FDA3 0A,1A,05
       FDA6 02,23,FF
       FDA9 F9
[2002] FDAA 02,83,00       DATA  >0283,>0019,>1B01,>045B,>0200,>0A00,>0460
       FDAD 19,1B,01
       FDB0 04,5B,02
       FDB3 00,0A,00
       FDB6 04,60
[2003] FDB8 24,32,02       DATA  >2432,>02E0,>83E0,>0200,>2032,>C330,>C270,>C830
       FDBB E0,83,E0
       FDBE 02,00,20
       FDC1 32,C3,30
       FDC4 C2,70,C8
       FDC7 30
[2004] FDC8 83,54,C8       DATA  >8354,>C830,>8356,>C050,>1D00,>9820,>4000
       FDCB 30,83,56
       FDCE C0,50,1D
       FDD1 00,98,20
       FDD4 40,00
[2005] FDD6 20,FF,16       DATA  >20FF,>161D,>0699,>101B,>1E00,>02E0,>20DA,>C020
       FDD9 1D,06,99
       FDDC 10,1B,1E
       FDDF 00,02,E0
       FDE2 20,DA,C0
       FDE5 20
[2006] FDE6 20,2E,02       DATA  >202E,>0201,>20DB,>0202,>0004,>0420,>2118
       FDE9 01,20,DB
       FDEC 02,02,00
       FDEF 04,04,20
       FDF2 21,18
[2007] FDF4 70,00,09       DATA  >7000,>0950,>1610,>0982,>C001,>0201,>203C,>0420
       FDF7 50,16,10
       FDFA 09,82,C0
       FDFD 01,02,01
       FE00 20,3C,04
       FE03 20
[2008] FE04 21,18,04       DATA  >2118,>04C8,>0602,>11D7,>D0F1,>0983,>A203
       FE07 C8,06,02
       FE0A 11,D7,D0
       FE0D F1,09,83
       FE10 A2,03
[2009] FE12 04,5B,02       DATA  >045B,>02E0,>20DA,>04C0,>06C0,>0460,>2432,>0201
       FE15 E0,20,DA
       FE18 04,C0,06
       FE1B C0,04,60
       FE1E 24,32,02
       FE21 01
[2010] FE22 3F,40,02       DATA  >3F40,>0221,>FFF8,>C011,>1105,>8060,>202A
       FE25 21,FF,F8
       FE28 C0,11,11
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0053
Rich E/A GROM
       FE2B 05,80,60
       FE2E 20,2A
[2011] FE30 16,F9,05       DATA  >16F9,>05CB,>045B,>0200,>0D00,>045B,>2D52,>5163
       FE33 CB,04,5B
       FE36 02,00,0D
       FE39 00,04,5B
       FE3C 2D,52,51
       FE3F 63
[2012] FE40 64,83,84       DATA  >6483,>8455,>045C,>5B5F,>5EF0,>F003,>F0F0
       FE43 55,04,5C
       FE46 5B,5F,5E
       FE49 F0,F0,03
       FE4C F0,F0
[2013] FE4E 47,00,00       DATA  >4700,>00C8,>3F38
       FE51 C8,3F,38
[2014] FE54 55,54,4C LOW4  DATA  >5554,>4C54,>4142,>2022,>5041,>4420,>2020,>8300
       FE57 54,41,42
       FE5A 20,22,50
       FE5D 41,44,20
       FE60 20,20,83
       FE63 00
[2015] FE64 47,50,4C       DATA  >4750,>4C57,>5320,>83E0,>534F,>554E,>4420
       FE67 57,53,20
       FE6A 83,E0,53
       FE6D 4F,55,4E
       FE70 44,20
[2016] FE72 84,00,56       DATA  >8400,>5644,>5052,>4420,>8800,>5644,>5053,>5441
       FE75 44,50,52
       FE78 44,20,88
       FE7B 00,56,44
       FE7E 50,53,54
       FE81 41
[2017] FE82 88,02,56       DATA  >8802,>5644,>5057,>4420,>8C00,>5644,>5057
       FE85 44,50,57
       FE88 44,20,8C
       FE8B 00,56,44
       FE8E 50,57
[2018] FE90 41,20,8C       DATA  >4120,>8C02,>5350,>4348,>5244,>9000,>5350,>4348
       FE93 02,53,50
       FE96 43,48,52
       FE99 44,90,00
       FE9C 53,50,43
       FE9F 48
[2019] FEA0 57,54,94       DATA  >5754,>9400,>4752,>4D52,>4420,>9800,>4752
       FEA3 00,47,52
       FEA6 4D,52,44
       FEA9 20,98,00
       FEAC 47,52
[2020] FEAE 4D,52,41       DATA  >4D52,>4120,>9802,>4752,>4D57,>4420,>9C00,>4752
       FEB1 20,98,02
       FEB4 47,52,4D
       FEB7 57,44,20
       FEBA 9C,00,47
       FEBD 52
[2021] FEBE 4D,57,41       DATA  >4D57,>4120,>9C02,>5343,>414E,>2020,>000E
       FEC1 20,9C,02
       FEC4 53,43,41
       FEC7 4E,20,20
       FECA 00,0E
[2022] FECC 58,4D,4C       DATA  >584D,>4C4C,>4E4B,>2104,>4B53,>4341,>4E20,>2108
       FECF 4C,4E,4B
       FED2 21,04,4B
       FED5 53,43,41
       FED8 4E,20,21
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0054
Rich E/A GROM
       FEDB 08
[2023] FEDC 56,53,42       DATA  >5653,>4257,>2020,>210C,>564D,>4257,>2020
       FEDF 57,20,20
       FEE2 21,0C,56
       FEE5 4D,42,57
       FEE8 20,20
[2024] FEEA 21,10,56       DATA  >2110,>5653,>4252,>2020,>2114,>564D,>4252,>2020
       FEED 53,42,52
       FEF0 20,20,21
       FEF3 14,56,4D
       FEF6 42,52,20
       FEF9 20
[2025] FEFA 21,18,56       DATA  >2118,>5657,>5452,>2020,>211C,>4453,>524C
       FEFD 57,54,52
       FF00 20,20,21
       FF03 1C,44,53
       FF06 52,4C
[2026] FF08 4E,4B,21       DATA  >4E4B,>2120,>4C4F,>4144,>4552,>2124,>4750,>4C4C
       FF0B 20,4C,4F
       FF0E 41,44,45
       FF11 52,21,24
       FF14 47,50,4C
       FF17 4C
[2027] FF18 4E,4B,21       DATA ,>4E4B,>2100
       FF1B 00
[2028]               ***********************************************************
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0055
Rich E/A GROM
Symbol Table #1 (New,alpha)
0001 AID        835C ARG        835D ARG1       835E ARG2       8360 ARG4
8362 ARG6       EF2F ARROW1     EF48 ARROW2     EF4F ARROW3     EF1B ARROWS
E84F ASSEM      000F BACK       EF95 BACK0      EFBE BACK1      EFCE BACK3
F70E BASIC      000E BEGIN      EFD1 BEGIN0     EFE6 BEGIN1     EFF6 BEGIN2
EFFF BEGIN3     001C BERR       0038 BGETSS     F612 BINIT2     F61A BINIT3
E659 BLDPAB     E68A BLNKBU     F722 C1         F72D C2         F738 C3
F744 C4         F750 C5         F75A C6         F2E5 CAT3       F2FE CAT4
F30F CAT4A      F33C CAT4B      F351 CAT5       F37A CAT5A      F3EC CAT6
F3F7 CAT7       F244 CATDAT     F80F CCRMSG     F519 CHKER2     F50E CHKERR
8318 CHRCUR     0023 CIF        0002 CLEAR      E69F CLOSE      F229 CLRBUF
E079 CLREA      F64D CLRFAC     F606 CLRMSG     ED67 CLRREA     E841 CLRXOP
F561 CLSALL     F57D CLSPAB     8322 CODE       077F COLOR      E36E CONDEU
E372 CONDEV     E380 CONDST     E22E CONFIG     E2E6 CONFIH     E318 CONFIJ
E326 CONFIK     E342 CONFIL     E35F CONFLP     831E COUNT      8320 CURADD
F89E CURPAT     F8AE DARROW     F770 DASSM1     F766 DDSK1      F76B DEDIT1
F682 DEV1       F69B DEV2       F69E DEV3       F69F DEV4       F65A DEVICE
F698 DEVNO      F38A DF         F14D DF80       F3DA DI         EEB4 DIREC2
EEC2 DIREC3     EDC9 DIRECT     F421 DISNU1     F430 DISNU2     F41B DISNUM
F43E DISSTR     F19E DKEY       F764 DLEN       F77B DLOAD      EDCE DMENU
E6A3 DOIO       F11E DORF80     0010 DSRLNK     0012 DSRRET     F775 DUTIL1
F39A DV         F6F2 EADSR      E81A EASCRN     E38D EDITOR     E507 EINPUT
E50A EMOPT1     E51D EMOPT2     8326 ENDLN      000D ENTER      F07D ENTER0
F098 ENTER1     F0A7 ENTER2     F080 ENTR       8354 ERCODE     F804 ERRC
F835 ERRCE      F844 ERRDD      F7D3 ERRIOC     F829 ERRIT      F7C7 ERRMF
F59D ERRMSG     F7E2 ERRNME     F7F6 ERRNTL     F78A ERROR      F86E ERRPNF
F859 ERRUR      E7F3 EXPMEM     834A FAC        834B FAC1       8355 FAC11
8356 FAC12      834C FAC2       834D FAC3       834E FAC4       834F FAC5
8350 FAC6       8351 FAC7       8352 FAC8       8353 FAC9       F01E FCTNUP
F416 FILNA1     F340 FILNAM     8348 FLAG       8349 FLAG2      F218 FLSCR
EB0B FNDDON     EABB FNDLNK     EAC1 FNDLP      EADE FNDSHO     F880 FPATH
EDA6 GDDSK      EDBA GDDSKN     EDC2 GDWDS      E086 GE029      E092 GE056
E0D6 GE116      E3E9 GE19B      E43A GE1E2      E43C GE1E4      E469 GE1F6
E485 GE1FC      E4B6 GE22C      E4C1 GE235      E4C3 GE237      E4CE GE23B
E526 GE272      E532 GE27B      E53A GE283      E553 GE29C      E56A GE2B3
E56C GE2B5      E57B GE2C4      E590 GE2D9      E5C2 GE30A      E5DA GE322
E5E3 GE32B      E5FB GE344      E616 GE35F      E618 GE361      E61E GE367
E637 GE380      E644 GE38D      E689 GE3CF      E6CF GE415      E6E5 GE42B
E6E8 GE42E      E6F6 GE43C      E700 GE446      E706 GE44C      E72F GE456
E739 GE460      E75A GE46B      E75F GE470      E76B GE47C      E774 GE485
E788 GE499      E79A GE4AB      E7C2 GE4D3      E7CC GE4DD      E7F0 GE501
E7F2 GE503      EC5A GE597      EC69 GE5A6      ECAC GE5E5      ECCC GE605
E89D GE654      E8A8 GE687      E991 GE736      E9B3 GE756      E9C5 GE767
E9E1 GE784      E9EB GE7A2      E9F0 GE7A7      E9FA GE7B1      EA09 GE7C0
EA40 GE7F2      EA65 GE816      EA70 GE821      EA75 GE826      EA85 GE848
EBC8 GE883      EBD3 GE88E      F458 GE8A8      F460 GE8B0      F463 GE8B3
F484 GE8D4      F493 GE8E3      F4A5 GE8F5      F4B2 GE8FC      F4B8 GE907
F4B9 GE908      F4C0 GE90F      F4C7 GE916      F4CE GE91D      F4D9 GE928
F4E0 GE92F      F4E7 GE936      F4EE GE93D      F4F5 GE944      F4FA GE949
F509 GE958      F53E GE97A      F54D GE97F      F5A7 GE9DA      F4D3 GE9E2
F5C5 GE9F8      F5DF GEA12      F5EC GEA1F      F5FB GEA2E      F64C GEBBD
E656 GETALL     E6C4 GETINP     E6F7 GETKEY     F192 GLESS      F19C GLESS2
F1B1 GMORE      F24D HALVE      F3AA IF         8379 ITIMER     F3BA IV
8374 KBNO       8375 KEY        EA0F LANDR      8347 LDFLAG     F154 LEAASM
F1DB LGLES2     F1D1 LGLESS     F1C2 LKEY       EC75 LODPGM     EC82 LODUSR
F1DD LOKKEY     F8C4 LOW1       F8CC LOW2       F8D4 LOW3       FE54 LOW4
ED9E LPAB       F1C5 LUPKEY     E010 MENU       E0CB MMENU      E33D MMMENU
EAFA MORSCN     E0E0 MSCRN      E1AA MYEAXB     EC53 MYSRCH     EF86 NAID
E814 NESCRN     E082 NEWEA      E19F NEWSCN     EC4C NO1KEY     F0C1 NODIR
EC16 NOEABF     EF5E NOKEY      ED96 NPAB       E1B4 NSCAN      E1C3 NSCAN1
E1CB NSCAN2     E1DA NSCAN3     E1E2 NSCAN4     E1F1 NSCAN5     E1F9 NSCAN6
E208 NSCAN7     E210 NSCAN8     EF57 OKKEY      E06F OLDEA      ED75 ONEKEY
F793 OUTSCN     F655 P1000      F75C PAB        F780 PAB80      E67D PABNAM
831C PABPTR     EC9B PGMLOD     F88A PLEASE     EC93 PMSG       F0FA PORVI
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0056
Rich E/A GROM
F3CA PR         F7A5 PRESS      EBE8 PRGRM      000C PROCD      E713 PSCANX
F1EA RDKEY      0006 REDO       F1FD RGMORE     F1E7 RKEY       F20E ROKKEY
0002 ROUND      E1A7 RTRXB      EA83 RUN        EB12 RUN00      EB40 RUN01
EB60 RUN02      EB74 RUN03      EB94 RUN04      EB9B RUN05      EBA6 RUN06
EB4A RUNDN      EB6A RUNLT      EB7E RUNRT      EB36 RUNUP      6372 RXB
F718 SBASIC     8310 SCADD      8311 SCADE      F255 SCREEN     F403 SCROLL
F6F9 SEADSR     E025 SETUP      E06C SOLDEA     0020 SPACE      8324 STLN
8373 SUBSTK     F707 SXBDSR     8316 TEMP       8317 TEMP1      8300 TMP
8301 TMP1       8302 TMP2       8303 TMP3       8304 TMP4       8306 TMP6
8307 TMP7       8308 TMP8       EF03 TSTKE2     EF0A TSTKE3     EF0E TSTKE4
EF11 TSTKE5     EEF6 TSTKEY     ED95 TWOKEY     F186 UPKEY      E833 USSCRN
837D VCHAR      E5B8 VFILE      8356 VPAB       F8BE VREGS      836E VSTACK
E6B8 VZERO      EF83 WAID       F7BC WARN       F899 WDS1       F5F4 WENTER
F591 WRNMSG     ECE0 XBAGN      F700 XBDSR      ECDB XBINP      ED13 XBINP1
ED4B XBINP2     ED5D XBINP3     F160 XBPGM      8342 XTOKEN     EF78 YAID
E9E8 YESNO
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0057
Rich E/A GROM
Symbol Table #2 (New,value)
0001 AID        0002 CLEAR      0002 ROUND      0006 REDO       000C PROCD
000D ENTER      000E BEGIN      000F BACK       0010 DSRLNK     0012 DSRRET
001C BERR       0020 SPACE      0023 CIF        0038 BGETSS     077F COLOR
6372 RXB        8300 TMP        8301 TMP1       8302 TMP2       8303 TMP3
8304 TMP4       8306 TMP6       8307 TMP7       8308 TMP8       8310 SCADD
8311 SCADE      8316 TEMP       8317 TEMP1      8318 CHRCUR     831C PABPTR
831E COUNT      8320 CURADD     8322 CODE       8324 STLN       8326 ENDLN
8342 XTOKEN     8347 LDFLAG     8348 FLAG       8349 FLAG2      834A FAC
834B FAC1       834C FAC2       834D FAC3       834E FAC4       834F FAC5
8350 FAC6       8351 FAC7       8352 FAC8       8353 FAC9       8354 ERCODE
8355 FAC11      8356 FAC12      8356 VPAB       835C ARG        835D ARG1
835E ARG2       8360 ARG4       8362 ARG6       836E VSTACK     8373 SUBSTK
8374 KBNO       8375 KEY        8379 ITIMER     837D VCHAR      E010 MENU
E025 SETUP      E06C SOLDEA     E06F OLDEA      E079 CLREA      E082 NEWEA
E086 GE029      E092 GE056      E0CB MMENU      E0D6 GE116      E0E0 MSCRN
E19F NEWSCN     E1A7 RTRXB      E1AA MYEAXB     E1B4 NSCAN      E1C3 NSCAN1
E208 NSCAN7     E210 NSCAN8     E22E CONFIG     E2E6 CONFIH     E318 CONFIJ
E326 CONFIK     E33D MMMENU     E342 CONFIL     E35F CONFLP     E36E CONDEU
E372 CONDEV     E380 CONDST     E38D EDITOR     E3E9 GE19B      E43A GE1E2
E43C GE1E4      E469 GE1F6      E485 GE1FC      E4B6 GE22C      E4C1 GE235
E4C3 GE237      E4CE GE23B      E507 EINPUT     E50A EMOPT1     E51D EMOPT2
E56C GE2B5      E57B GE2C4      E590 GE2D9      E5B8 VFILE      E5C2 GE30A
E5DA GE322      E5E3 GE32B      E5FB GE344      E616 GE35F      E618 GE361
E61E GE367      E637 GE380      E644 GE38D      E656 GETALL     E659 BLDPAB
E67D PABNAM     E689 GE3CF      E68A BLNKBU     E69F CLOSE      E6A3 DOIO
E6B8 VZERO      E6C4 GETINP     E6CF GE415      E6E5 GE42B      E6E8 GE42E
E6F6 GE43C      E6F7 GETKEY     E700 GE446      E706 GE44C      E713 PSCANX
E72F GE456      E739 GE460      E75A GE46B      E75F GE470      E76B GE47C
E774 GE485      E788 GE499      E79A GE4AB      E7C2 GE4D3      E7CC GE4DD
E7F0 GE501      E7F2 GE503      E7F3 EXPMEM     E814 NESCRN     E81A EASCRN
E833 USSCRN     E841 CLRXOP     E84F ASSEM      E89D GE654      E8A8 GE687
E991 GE736      E9B3 GE756      E9C5 GE767      E9E1 GE784      E9E8 YESNO
E9EB GE7A2      E9F0 GE7A7      E9FA GE7B1      EA09 GE7C0      EA0F LANDR
EA40 GE7F2      EA65 GE816      EA70 GE821      EA75 GE826      EA83 RUN
EA85 GE848      EABB FNDLNK     EAC1 FNDLP      EADE FNDSHO     EAFA MORSCN
EB0B FNDDON     EB12 RUN00      EB36 RUNUP      EB40 RUN01      EB4A RUNDN
EB60 RUN02      EB6A RUNLT      EB74 RUN03      EB7E RUNRT      EB94 RUN04
EB9B RUN05      EBA6 RUN06      EBC8 GE883      EBD3 GE88E      EBE8 PRGRM
EC16 NOEABF     EC4C NO1KEY     EC53 MYSRCH     EC5A GE597      EC69 GE5A6
EC75 LODPGM     EC82 LODUSR     EC93 PMSG       EC9B PGMLOD     ECAC GE5E5
ECCC GE605      ECDB XBINP      ECE0 XBAGN      ED13 XBINP1     ED4B XBINP2
ED5D XBINP3     ED67 CLRREA     ED75 ONEKEY     ED95 TWOKEY     ED96 NPAB
ED9E LPAB       EDA6 GDDSK      EDBA GDDSKN     EDC2 GDWDS      EDC9 DIRECT
EDCE DMENU      EEB4 DIREC2     EEC2 DIREC3     EEF6 TSTKEY     EF03 TSTKE2
EF0A TSTKE3     EF0E TSTKE4     EF11 TSTKE5     EF1B ARROWS     EF2F ARROW1
EF48 ARROW2     EF4F ARROW3     EF57 OKKEY      EF5E NOKEY      EF78 YAID
EF83 WAID       EF86 NAID       EF95 BACK0      EFBE BACK1      EFCE BACK3
EFD1 BEGIN0     EFE6 BEGIN1     EFF6 BEGIN2     EFFF BEGIN3     F01E FCTNUP
F07D ENTER0     F080 ENTR       F098 ENTER1     F0A7 ENTER2     F0C1 NODIR
F0FA PORVI      F11E DORF80     F14D DF80       F154 LEAASM     F160 XBPGM
F186 UPKEY      F192 GLESS      F19C GLESS2     F19E DKEY       F1B1 GMORE
F1C2 LKEY       F1C5 LUPKEY     F1D1 LGLESS     F1DB LGLES2     F1DD LOKKEY
F1E7 RKEY       F1EA RDKEY      F1FD RGMORE     F20E ROKKEY     F218 FLSCR
F229 CLRBUF     F244 CATDAT     F24D HALVE      F255 SCREEN     F2E5 CAT3
F2FE CAT4       F30F CAT4A      F33C CAT4B      F340 FILNAM     F351 CAT5
F37A CAT5A      F38A DF         F39A DV         F3AA IF         F3BA IV
F3CA PR         F3DA DI         F3EC CAT6       F3F7 CAT7       F403 SCROLL
F416 FILNA1     F41B DISNUM     F421 DISNU1     F430 DISNU2     F43E DISSTR
F458 GE8A8      F460 GE8B0      F463 GE8B3      F484 GE8D4      F493 GE8E3
F4A5 GE8F5      F4B2 GE8FC      F4B8 GE907      F4B9 GE908      F4C0 GE90F
F4C7 GE916      F4CE GE91D      F4D3 GE9E2      F4D9 GE928      F4E0 GE92F
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0058
Rich E/A GROM
F4E7 GE936      F4EE GE93D      F4F5 GE944      F4FA GE949      F509 GE958
F50E CHKERR     F519 CHKER2     F53E GE97A      F54D GE97F      F561 CLSALL
F57D CLSPAB     F591 WRNMSG     F59D ERRMSG     F5A7 GE9DA      F5C5 GE9F8
F5DF GEA12      F5EC GEA1F      F5F4 WENTER     F5FB GEA2E      F606 CLRMSG
F612 BINIT2     F61A BINIT3     F64C GEBBD      F64D CLRFAC     F655 P1000
F65A DEVICE     F682 DEV1       F698 DEVNO      F69B DEV2       F69E DEV3
F69F DEV4       F6F2 EADSR      F6F9 SEADSR     F700 XBDSR      F707 SXBDSR
F70E BASIC      F718 SBASIC     F722 C1         F72D C2         F738 C3
F744 C4         F750 C5         F75A C6         F75C PAB        F764 DLEN
F766 DDSK1      F76B DEDIT1     F770 DASSM1     F775 DUTIL1     F77B DLOAD
F780 PAB80      F78A ERROR      F793 OUTSCN     F7A5 PRESS      F7BC WARN
F7C7 ERRMF      F7D3 ERRIOC     F7E2 ERRNME     F7F6 ERRNTL     F804 ERRC
F80F CCRMSG     F829 ERRIT      F835 ERRCE      F844 ERRDD      F859 ERRUR
F86E ERRPNF     F880 FPATH      F88A PLEASE     F899 WDS1       F89E CURPAT
F8AE DARROW     F8BE VREGS      F8C4 LOW1       F8CC LOW2       F8D4 LOW3
FE54 LOW4
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0059
Rich E/A GROM
Symbol Table #4 (Def,alpha)
0034 ACCTON     835C ARG        0032 ATN        0036 BADTON     003B BITREV
0012 CFI        0014 CNS        002C COS        0010 CSN        8372 DATSTK
0001 DIVZER     0003 ERRIOV     0006 ERRLOG     0005 ERRNIP     0002 ERRSNN
0004 ERRSQR     0028 EXP        834A FAC        0006 FADD       000A FCOMP
0009 FDIV       0008 FMUL       836C FPERAD     0007 FSUB       0038 GETSPACE
0022 INT        0010 LINK       0018 LOCASE     002A LOG        8370 MEMSIZ
003D NAMLNK     8300 PAD        0024 PWR        0012 RETURN     000B SADD
000F SCOMP      000E SDIV       8375 SGN        002E SIN        000D SMUL
8400 SOUND      0026 SQR        000C SSUB       837C STATUS     0016 STCASE
8373 SUBSTK     0030 TAN        0007 TRIGER     004A UPCASE     836E VSPTR
0001 WRNOV      837F XPT        837E YPT
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0060
Rich E/A GROM
Symbol Table #8 (Def,value)
0001 DIVZER     0001 WRNOV      0002 ERRSNN     0003 ERRIOV     0004 ERRSQR
0005 ERRNIP     0006 ERRLOG     0006 FADD       0007 FSUB       0007 TRIGER
0008 FMUL       0009 FDIV       000A FCOMP      000B SADD       000C SSUB
000D SMUL       000E SDIV       000F SCOMP      0010 CSN        0010 LINK
0012 CFI        0012 RETURN     0014 CNS        0016 STCASE     0018 LOCASE
0022 INT        0024 PWR        0026 SQR        0028 EXP        002A LOG
002C COS        002E SIN        0030 TAN        0032 ATN        0034 ACCTON
0036 BADTON     0038 GETSPACE   003B BITREV     003D NAMLNK     004A UPCASE
8300 PAD        834A FAC        835C ARG        836C FPERAD     836E VSPTR
8370 MEMSIZ     8372 DATSTK     8373 SUBSTK     8375 SGN        837C STATUS
837E YPT        837F XPT        8400 SOUND
#31 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Dec 12, 2018 1:14 PM
Mind you that is Rich Editor Assembler GPL Source Code, but REA is based on the same exact Editor Assembler GPL Source Code created by Texas Instruments.
I did not change buffer locations or did I remove any.
I could post that also but like I said the buffers are the same and that was your question.
Edited by RXB, Wed Dec 12, 2018 1:19 PM.
#32 hhos OFFLINE
hhos
    Space Invader
  • 38 posts
Posted Wed Dec 12, 2018 4:24 PM
Wow, RXB.  That's a lot of code to splash onto the board at once.  Tragically, it is mostly wasted on me, :idea: though it has given me an idea of how to find, and handle, my problem.  I do not know the GPL language at all.  I just know that it is slow, like all interpreted languages tend to be.  I used to program in DBASE III/dBXL quite often, but when I got what I wanted I put it all through the Quicksilver compiler in order to speed it up.  Everybody, PLEASE DO NOT START TALKING ABOUT DBASE LANGUAGES IN HERE NOW! :mad:
Can you go back and edit that post so that it is a Spoiler Tag?  As Tursi did here:
http://atariage.com/...s/#entry3421682
That way anybody who is interested in looking at it may, all others are not inconvenienced by having to scroll down through screens of code.  If you decide to post that other Editor Assembler GPL Source Code you might want to make it an attachment.
Thanks,
HH
#33 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Dec 12, 2018 6:56 PM
Tursi posted this:
Language   First Pass    Optimized
Assembly       17 sec         5 sec
TurboForth    48 sec        29 sec
Compiled XB  51 sec        37 sec
FbForth         70 sec        58 sec
GPL
80 sec       none yet
ABASIC
490 sec       none yet
XB
2000 sec       none yet
Hmm GPL is not that bad it was close to FbForth and Compiled XB and NOT OPTIMIZED for speed in test.
Also I posted entire code maybe you would learn something about GPL the language that runs the TI and most cartridges.
Edited by RXB, Wed Dec 12, 2018 6:57 PM.
#34 hhos OFFLINE
hhos
    Space Invader
  • 38 posts
Posted Fri Dec 14, 2018 2:48 AM
GCC           15 sec         5 sec
CAMEL99 DTC   49 sec        27 sec
CAMEL99 ITC   55 sec        29 sec
FbForth       70 sec        26 sec
GPL           80 sec       none yet
ABASIC       490 sec       none yet
XB          2000 sec       none yet
UCSD Pascal 7300 sec       273 sec
What's your point here?  GPL is running, at best, 21.25% of the unoptimized assembly language speed.  That's kind of like saying that my car can make 45 MPH, so it's ready for the Indy500, isn't it?  And that's ignoring the optimized speed difference of both GCC and ASM.  Sixteen times the speed of GPL is a pretty good case for disposing of GPL in favor of the much faster ASM, or if you wish, GCC which would be a much larger binary.  GPL was only necessary when we only had 256 bytes of directly addressable memory.  RAM is much cheaper now.  You can buy two 32K SRAM for less than $10.  I have at least a dozen that I cannibalized from an older PC.  It's time to drop GPL, replace the ROMs that have tied this console to slow GROMs, and GRAMs.
Would we have to re-write the ROM ourselves?  Yes, let's do that.  Then we could cut away grounds and +5V inputs on the interrupt lines and have the 16 levels this CPU was designed for.  There would no longer be a need to constantly poll the VDP chip to see when the vertical interrupt has occurred, because we could use the interrupt to almost instantly respond to it.  There is also a timer in one of the chips (9901?, I think?) that looks like it could be very useful, if we could use it without the performance penalty imposed by the current, 40 year old, inadequate-off-the-shelf, system.  There are a great many reasons why the TI99 lost to the Commodore PET, and the lack of speed was only one of them.
This thread's focus is done. I haven't found the answer to EA II's inability to do COPY on my machine, but RAG is doing fine.  RXB, if you wish to continue to beat this dead horse, please start a thread of your own.
Sincerely,
HH
#35 RXB OFFLINE
RXB
  • 3,457 posts
Posted Fri Dec 14, 2018 9:01 AM
I found this excerpt in the documentation that FarmerPotato sent me to:
The cartridge also uses the VDP area to store PABs for file access, and to load the file
themselves.
PAB for Editor, Assembler, edited/printed file, assembly source file, loaded file: >1000-1018
PAB for assembly object file, printer: >1100-1118
PAB for assembly list file: >1200-1218
PAB for file copied during assembly (?): >1300
Assembly source file, edited/printed file: >1080-10CF
Assembly code file data, printer data: >1180-11CF
Assembly list file data: >1280-12CF
Program files (Editor, Assembler, user-defined): >1380-157F
It IDs RXB's addresses as PAB locations in VDP, all except the >1400 one.  I don't think the E/A II that I'm using will accept the cassette as a source or destination, so I'm calling that one invalid. The rest were just misidentified a buffers.  Perhaps the original E/A did accept the cassette, but my one attempt to use my copy of E/A didn't turn out so well, so I won't be trying that again too terribly soon. ;-)   I'll have to rebuild my disk based E/A disk A from an image file first before I do that.
From this it would seem that the >1300 location is the one that isn't working for me when I try to COPY in an external file.  There is also this:
>3580 +-------------------------+
      |        (free)           |
>35D2 +-------------------------+ <--- @>8370
      | File buffers (4 files)  |
>37D8 +-------------------------+ <--- @>8370
      | File buffers (3 files)  |
>3FFF +-------------------------+ VR0=0, VR1=E0, VR7=F5
It looks like there is at least the possibility that E/A will only reserve 3 buffers.  All of which must be dedicated to a specific purpose, whether I use them or not?  Apparently so.  So how do I instruct the assembler to reserve 4 buffers?  Or, are there different versions of the E/A that only allocate 3 buffers?  I am using the E/A II that I downloaded for use with my FlashROM99, so I'm assuming it is a later version, but does it always only provide for 3 buffers?
Thanks to all for the help so far,
HH
I did remove Wafer Tape access in the EA Cart for REA.
I mean how many people use that????
#36 RXB OFFLINE
RXB
  • 3,457 posts
Posted Fri Dec 14, 2018 9:21 AM
TI shoulda woulda coulda....
Pretty invalid arguments.
Not hard to look in a rear view mirror 40 years later, pretty freaking tough to read the future like a seer.
#37 hhos OFFLINE
hhos
    Space Invader
  • 38 posts
Posted Tue Jan 1, 2019 1:40 AM
Not many, I imagine.  But, I don't intend to leave them out just because they don't have the resources that I have.  This guy didn't get a lot of help from any of your community way back in 2011:
http://atariage.com/...p/#entry2414652
Of course, it does look like he didn't give you much time to do so, though.  He decided to send his Disk Manager to his friend before the day was over.  But a cassette/WAV solution would have gotten him going pretty quickly.  From what I've seen, it may even be possible to send the audio over a quiet telephone line.  Has anybody ever tried that?
A cassette based diagnostic program or a formatter might have helped this guy get an answer in less than the month it took:
http://atariage.com/...-2#entry2997349
I was in need of a cassette/WAV file based solution for formatting a few disks just a few weeks ago:
http://atariage.com/...p/#entry4158260
I didn't get a Disk Manager with my PEB.  Fortunately, I went looking through all the stuff I had bought years ago for a TI99/4A, and found a FlashROM99.  Then it was easy, but if I hadn't found that, who knows how long I would have been working on just getting a floppy formatted?  Until I did, I didn't even know if the floppy drive, or the PEB, worked!
We are members of a community that could shrink rapidly.  The numbers are what drives much of the development that has happened for the TI99, progress that will hopefully continue into the future.  Ignoring the plight of any curiosity seeker (me), collector (me again), I-couldn't-afford-one-then-but-I-got-one-now (not me, didn't want one back then), etc. doesn't help increase our numbers.
That's your argument, not mine.  I can look back, and I remember a co-worker telling me about how slow the TI99 was.  I saw one at a party later on.  I might have been the only one there that was interested. ;-)   I had a CoCo1 and a TRS-80 Model 1. The TI99/4A didn't impress me.  This thing was running on a clock that was more than 3 times the clock in my CoCo (.895 MHz), and almost 70% faster than that of my Model 1 (1.79 MHz?).  And it was crawling!!!  I said, "What a piece of s__t!"  Yes, I said it out loud.  I'm much more diplomatic these days, though.  I use emoticons. :lol:
It doesn't take a crystal ball to see the future when you're looking at that kind of evidence.
But now, 36 years later?, party was in '82 maybe '83?, :ponder:...  I think the TI99/4A has far more potential than has been tapped.  After looking it over, I'm wondering if some of the engineers might have thrown a couple of curves around their upper management, making it possible to perhaps double its speed, with a few simple mods.  Thierry Nouspikel experimented with several wait state eliminations.
http://www.unige.ch/...l/ti99/wait.htm
I'll start with those, but AFAIK he didn't go as far as I am looking to go with it.  There's a lot of stuff on his web site that I haven't looked at yet, though. :sad:
I'm going to modify one, or more, of the units I have (20+ TI99/4A's? and one PEB), just to see what this box could have been if it had been targeted at a different marketplace, or conversely, what it never could have been.  Several mods don't even seem to be that difficult, especially since Thierry has done a good deal of heavy lifting for me. ;-)
HH
#38 Ksarul OFFLINE
Ksarul
  • 5,023 posts
Posted Tue Jan 1, 2019 8:42 PM
I will read the trail of your adventuring through the system hardware with great interest. It is (said with no malice at all) hard-headed folks like you that found such wonderful tricks as the Playground hack that allowed Assembly programs to launch from console BASIC, the bank-switching techniques that allow the huge cartridges used today, the graphics enhancements of the F18A, and numerous other hardware and software enhancements that weren't even a gleam in the eye of the engineers who originally designed the system.
Have much fun on your journey--and please document all of it, as I am sure the results will help one or more of us solve a seemingly-intractable problem when we least expect it to.  :)
  • RXB likes this
#39 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Jan 2, 2019 3:27 AM
HH
The Wafer Tape section was only a few lines of code and would never work with Cassette Tapes as they are not even remotely similar.
People constantly claim they Shoulda Coulda Woulda with no proof ever of these claims at the time.
It always take place years later like they thought of it then....but never did anything about it. (Hard to believe as a fact.)
Nice the people come up with new ideas like you posted, but I want proof of some of these claims they thought of them back then.
#40 senior_falcon OFFLINE
senior_falcon
  • 1,328 posts
Posted Wed Jan 2, 2019 7:16 AM
Many years ago I installed 32K on the 16 bit bus which has no wait states, plus a switch so I could restore the wait states if needed. As you would guess, there is a noticeable improvement in speed. An assembly program running totally on slow ram including the workspace would run in about 60% of the time when running on the fast RAM. Not twice as fast, but a nice speed increase. Of course in the real world, most assembly programs already put the workspace in the fast scratchpad ram. With the workspace already on fast ram, putting the program into fast ram does not lead to such a dramatic increase. It might run in around 75% of the time. Not earth shattering, but still a decent speed increase.
XB is a different story. Because so much of BASIC and XB is written in GPL, the fast ram has virtually no effect on execution time. Now if the XB ROMS were in fast ram then you might see some improvement-somewhere on the order of 10% faster depending on the program.
#41 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 212 posts
Posted Wed Jan 2, 2019 11:43 AM
Or if all of the GROM in the console and XB cartridge were moved into a zero wait state GRAM device. GROM address setup takes nearly 10 microseconds during which the GROM asserts the HOLD signal (READY low). I was still surprised when I measured this on my scope recently, though Tursi had done a comprehensive bus timing document earlier this year (I skipped the sections on GROM.)
#42 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Jan 2, 2019 3:33 PM
GROM only runs from Scratch Pad memory in the OS as does the XB ROMs also.
Yes the RAM is slower in the TI design and yes on the 16 bit bus would be much better design.
I disagree on speed when running XB programs on the 16 bit bus versus normal 32K you can see a marked difference in speed on two TI side by side.
Many years ago we put two side by side and the 16 bit bus was running considerably faster.
Prescan alone was much much faster due to 16 bit bus scanning the program before running was way faster after typing RUN.
#43 senior_falcon OFFLINE
senior_falcon
  • 1,328 posts
Posted Wed Jan 2, 2019 4:07 PM
Define "considerably faster" and "much faster".  Do you mean 10% or more, or would 1% be much faster to you? I don't remember it being 1% faster.
#44 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Jan 2, 2019 5:10 PM
So you are saying XB programs residing in 16 bit RAM vs normal RAM would only be 1% faster....you have any proof it would be that slow?
By the way PRESCAN is done by XB ROMs not GPL GROM!
Edited by RXB, Wed Jan 2, 2019 5:14 PM.
#45 senior_falcon OFFLINE
senior_falcon
  • 1,328 posts
Posted Wed Jan 2, 2019 5:47 PM
I think 1% at most. I have used a stopwatch to test this and the results are almost identical, just like the difference when the program is in VDP vs in CPU ram.
I'm sure a slight difference could be measured over a long period, but my short attention span gives out after a minute or so.
I figured PRESCAN (and garbage collection) are in the ROMs because they are a lot snappier in XB than they are in BASIC.
"GROM only runs from Scratch Pad memory in the OS as does the XB ROMs also."
I don't know what you are trying to say. Cartridge rom space is from >6000 to >7FFF, which is definitely not in the scratch pad, nor is it on the 16 bit bus.
#46 RXB OFFLINE
RXB
  • 3,457 posts
Posted Thu Jan 3, 2019 2:47 AM
Sorry I meant the GROM and XB ROMS Registers and many variables run from Scratch pad in the TI OS and in XB.
Yes I know about the XB ROMs but they do use Scratch Pad mostly.
Also unlike Basic that runs Programs from VDP only, XB stores and runs from RAM or VDP depending on if you have a 32K or not, thus 16 bit no wait state would be a increase in speed.
We can argue about the amount of speed, but putting Basic and XB in same box is both inaccurate and unfair entirely.
#47 senior_falcon OFFLINE
senior_falcon
  • 1,328 posts
Posted Thu Jan 3, 2019 7:14 AM
You are aware, of course, that Extended BASIC uses the VDP RAM for programs when there is no 32K expansion. Everyone knows how slow VDP access is compared to direct memory access. Yet when you compare the same XB program running from VDP vs runnining from 32K you will be hard pressed to see a difference. (Typically less than 1% faster) How is this comparison inaccurate and unfair?
The whole point of this speed discussion is to answer HHOS who wondered how much faster the TI would run XB  if there were no wait states when accessing the 32K memory. I was merely saying that you wouldn't notice any significant difference. (In Extended BASIC)
Perhaps an XB program exists that is "considerably faster" and "much faster" when running on the 16 bit bus vs the 8 bit bus.  But I doubt it.
Edited by senior_falcon, Thu Jan 3, 2019 9:14 AM.
#48 RXB OFFLINE
RXB
  • 3,457 posts
Posted Thu Jan 3, 2019 4:04 PM
I am pretty sure you ran tests that were based on things you did not know at that time.
Like the larger the program the slower TI Basic gets as it uses VDP for EVERYTHING,  Program, Strings, and Numeric Variables.
Exactly the opposite of XB that when you hit 13K the Program is moved to RAM and only Strings and temporary variables are in VDP.
Everything else is in RAM including Line Number Table, Number Variables and the XB Program.
This is also just ignoring XB ROMs entirely too.
Like I said I am very sure you ran dinky program tests so everything you did still 100% ran from only VDP in both XB and TI Basic, thus your belief is based on faulty tests.
But then when test results are based on faulty unknowns you get faulty results conclusions.
Edited by RXB, Thu Jan 3, 2019 4:05 PM.
#49 senior_falcon OFFLINE
senior_falcon
  • 1,328 posts
Posted Thu Jan 3, 2019 5:03 PM
"TI BASIC uses VDP for everything." Well now, I guess that's something that we both can agree on. So what? Why do you keep bringing up TI BASIC when the discussion was about XB?
"Exactly the opposite of XB that when you hit 13K the Program is moved to RAM and only Strings and temporary variables are in VDP."
This is total B.S. It doesn't matter how big the XB program is; if you have 32K then that is where the program is kept. Don't believe me? Type NEW then type SIZE. Now type in a one line program, say 10 FOR I=1 TO 10::NEXT I.  Then type SIZE again. Stack space is the same; program space is smaller.  What does this tell you about where the program is contained?
"Like I said I am very sure you ran dinky program tests so everything you did still 100% ran from only VDP in both XB and TI Basic, thus your belief is based on faulty tests."
You may be "very sure", but the fact of the matter is that I ran large programs as well. And by the way, this was testing the speed differences running the same program in XB using no 32K, using 32K on the 8 bit bus, and using 32K on the 16 bit bus. Virtually no difference in speed
"But then when test results are based on faulty unknowns you get faulty results conclusions."
Well once again there is something we can agree on. Of course in this case you are the one operating with faulty unknowns.
At no point have you answered my question about what would constitute "considerably faster" and "much faster". Since you are so sure of yourself here is a challenge for you: post an XB a program that runs noticeably faster when running on the 16 bit data bus compared to the 8 bit data bus. I don't think you can.
#50 RXB OFFLINE
RXB
  • 3,457 posts
Posted Thu Jan 3, 2019 8:15 PM
Ok but I still think you pulled 1% out of your butt.
