DSR error 0094 when I try to use COPY directive in E/A II
77 replies to this topic
#76 RXB OFFLINE
RXB
  • 3,457 posts
Posted Wed Jan 9, 2019 5:11 PM
I run Classic99 on a HP INTEL I5 with 8 Gig of RAM and Video on a GTX 1050TI with 4Gig of RAM.
Running 4 Classic99 at same time does not present even a problem as I also browse with Google and run TIDIR all at one time.
I even run VLC playing Songs in the background too.
Whenever I get a system lock up it is normally TIDIR if have to shut down that created the problem, first signs of issues is Classic99 starts to behave strangely.
(Like can not access a disk or a disk acts like it is write protected or says a file I am looking at is not on that disk?)
#77 Tursi OFFLINE
Tursi
  • 5,420 posts
  • HarmlessLion
Posted Thu Jan 10, 2019 1:04 PM
The version of TIDIR that I have doesn't release disk images that it has opened even if you switch to another disk, so that may be part of it.
#78 hhos OFFLINE
hhos
    Space Invader
  • 38 posts
Posted Tue Jan 15, 2019 2:35 PM
I finally got around to looking at this project, which I am calling the Clulow-Guion_32K upgrade, located http://www.mainbyte....32kconsole.html
WOW!  That was quite a project.  That's going to take some time to figure out.
Actually not that hard to figure out once you get the pin #'s on those piggy-backs straight.  I initially had almost half of them bass ackward .  Figuring out where the 2-input AND on U613, pin 13 for the wait state bypass defeat switch was a bit confusing, but I think I got it now.
Your mod has 64K RAM and only 32K is used?  Did they put some of the extra memory into that space, or do you still only have 256 bytes in the >8000 to >83FF address area?
It only has 256 bytes.  There may be enough unused logic gates in there now to implement a 1024 byte scratch pad, though.  There's certainly enough memory. ;)
There is no attempt to accelerate Video, Cart, or GROM access.  That, in part I think, would explain the lack of acceleration when running console BASIC, or XB.
When I'm certain of the placement of that AND gate I'll post a revised schematic.  And, if I can figure it out quickly, maybe a way to mod this mod for the 1024 byte Scratch PAD (not a high priority for me at the moment since the 32K expansion would be just as quick w/ this mod).
HH
Edited by hhos, Tue Jan 15, 2019 3:06 PM.
