2600 Static Modification Zener Diode
No replies to this topic
#1 mksmith OFFLINE
mksmith
    Chopper Commander
  • 133 posts
Posted Fri Dec 7, 2018 12:08 AM
Hi,
Moving onto my next change (previous issue here: http://atariage.com/...oystick-issue/)- the Zener Diode protection.
Looking through the Service Guide Atari offered a direct replacement part CA018263 replacing C236 and C237.  Now looking through the forums it is suggested to solder directly onto Pin 6 of the joystick and the opposite side to the nearest ground plane. This is obviously using potentially newer components (as noted at Console 5):
http://atariage.com/...here/?p=2138298
http://atariage.com/...etin/?p=3776501
https://console5.com...capacitors.html
Can someone please help confirm the actual parts no's and required configuration to make sure I get this one right?
Thanks!
Edited by mksmith, Fri Dec 7, 2018 12:09 AM.
