sio2sd error init card
8 replies to this topic
#1 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Fri Dec 7, 2018 5:43 AM
Hi, you're sorry my English.
I built a sio2sd, using an atmega 32a, I programmed the atmega 32a with the last available file.
but if I start the sio2sd it gives me error no sd / mmc card and after a few minutes it gives me error init card.
I have programmed the atmega 32a without setting the fuses that are written on the website, because if I imposed the merges atmega stops.
does sio2sd not see the sd card for a programming or hardware problem?
I tried sd card from 1gb and 4gb card and following a guide on youtube
thank you so much.
#2 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 451 posts
Posted Fri Dec 7, 2018 1:00 PM
I have no crystal ball available, to see the unknown.
If I have to guess, I would suspect the SD card reader,
it's connection, or the SPI bus or something like that.
But sorry, it's just a guess - and even with photos...
no chance to help.
Stefan
#3 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Sat Dec 8, 2018 12:11 AM
sd card works, 3.3 regulator works, i changed 3 atmega 32a.
the slopes welter all :(
#4 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,930 posts
Posted Sat Dec 8, 2018 12:18 AM
touch up all solder connection. re-program atmega make sure security brown out fuse bits are set.
last thing is other chip and transistor, make sure sd card slot is not damaged, is clear, and not dirty..
#5 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Sat Dec 8, 2018 12:59 AM
I changed the controller and the 74hcxxxx but still error.
I have programmed the atmega without setting the fused bits, because if I set the fused bits as written on the site of the sio2sd the atmega crashes, I already tried two atmega that are now blocked. I have programmed without setting the merged bits.
I prepare the sd card with atari folder and Sio2sd.xex files
How should I set the merges?
I program with avrdude and the command is this:
sudo avrdude -c usbasp -p m32 -u -U flash:w:sio2sd_all_v3.0rc5.bin
and this is the command I used to set the fuses
sudo avrdude -c usbasp -p m32 -u -U lfuse:w:0x3F:m -U hfuse:w:0xC3:m flash:w:sio2sd_all_v3.1rc2.bin
I have 3 atmega, 2 blocked and one mounted on the sio2sd, how can I do to recover the two locked at'mega, so to do other tests?
thank you
#6 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Sat Dec 8, 2018 1:08 AM
I give the atari and the sio2sd from no sd / mmc card. and remains locked even if I press the keys nothing changes.
when error init card appears, I can enter the sio2sd configuration
#7 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Sat Dec 8, 2018 2:59 AM
I changed pcb, sd docking, 3.3v regulator, capacitance resistances and 75hxxx but it is always error.
I think problem of fuse atmega :(
#8 pancioalbe OFFLINE
pancioalbe
    Combat Commando
  • 6 posts
Posted Sat Dec 8, 2018 3:47 AM
samy@samy-Lenovo-Ideapad-110-15AST:~$ sudo avrdude -c usbasp -p m32 -u -U lfuse:w:0x3F:m -U hfuse:w:0xC3:m flash:w:sio2sd_all_v3.1rc2.bin
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9502 (probably m32)
avrdude: reading input file "0x3F"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x3F:
avrdude: load data lfuse data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xC3"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xC3:
avrdude: load data hfuse data from input file 0xC3:
avrdude: input file 0xC3 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude done.  Thank you.
 workkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk ::::::::::)))))))))))))))))))))
I do not know why but it works after giving this command once again
thank you very much for the answers
#9 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sun Dec 9, 2018 1:41 AM
Try different sd card or older sio2sd firmware. The newest firmware gave me same issues.
Some cards are refused.
