Atari 2600 Jr high voltage after regulator
atari 2600 Jr
4 replies to this topic
#1 tr0x OFFLINE
tr0x
    Combat Commando
  • 3 posts
Posted Fri Dec 7, 2018 9:56 AM
Hi,
I recently acquired an Atari 2600 Jr (PAL), but it shows no signs of life: the led indicator remains unlit and no RF signal comes out of the console.
I opened it and found with a DMM that *after* the 7805 regulator there's the same high voltage of the external power supply, so I replaced the regulator but the voltage is still the same both at the input and output pins.
What can be wrong with it?
Thank you!
#2 Osgeld OFFLINE
Osgeld
  • 5,978 posts
Posted Fri Dec 7, 2018 10:33 AM
Is it getting ac or dc input (it needs to be dc)
#3 tr0x OFFLINE
tr0x
    Combat Commando
  • 3 posts
Posted Fri Dec 7, 2018 10:53 AM
DC power brick, that works with another 2600 Jr.
I also replaced all the electrolytics capacitors.
#4 Stephen Moss OFFLINE
Stephen Moss
  • 1,160 posts
Posted Mon Dec 10, 2018 2:25 AM
Sounds like there is no GND (0V) connection to the Regulator.
Try doing a continuity check from the power socket to the middle pin/metal tab of the regulator, if you get a reading of Zero or only a few ohms it is probably OK and the problem lies elsewhere, if you get a high or infinite resistance reading you will have to trace where the problem is. A bad solder joint on the regulators GND pad or crack between the regulator GND pad and the GND track would be the first places I would look, if it is not there then either check the continuity of the GND track from the power socket to the regulator a few inches at a time until you find the break or solder a piece of wire from the power socket to the regualtor.
#5 tr0x OFFLINE
tr0x
    Combat Commando
  • 3 posts
Posted Mon Dec 10, 2018 8:48 AM
Atari 2600 Jr motherboard, new power connector
new power connector
I checked and found that there isn't any connection between bottom and top layers at the jack power connector, maybe the via is corroded.
So I installed a new power connector with two wires soldered both on top and bottom pads of the pcb, and it works perfectly :)
Thank you very much!
Edited by tr0x, Mon Dec 10, 2018 8:48 AM.
Also tagged with one or more of these keywords: atari 2600 Jr
