RespeQt 4.3 beta
149 replies to this topic
#51 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
  • Back off, man! I'm a scientist.
Posted Sun Feb 10, 2019 11:47 AM
That is very clear.
Thank you for this detailled explanation.
But I confirm that I can play the game (after loading map) with the 3 following ATX versions with RespeQt 4.3 under Windows 10
- Seven Cities of Gold, The (1984)(Electronic Arts)(US)(Side A)[!][grey disk].atx
- Seven Cities of Gold, The (1984)(Electronic Arts)(US)(Side A)[black disk].atx
- Seven Cities of Gold, The (1984)(Electronic Arts)(US)(Side A)[!][black disk with blue dot].atx
Maybe the settings is also important (not sure). I am using divisor 10 to be more compatible with Happy and Super Archiver.
Did you try RespeQt under Windows with Seven Cities of Gold ?
Anyone else experiencing problems with Seven Cities of Gold with RespeQt 4.3 ?
I tried all three of those versions above under Windows using the binaries posted in this thread in December. I have *not* tried them yet under Ubuntu, though I will later today. In my case. all three get to the animated title screen but freeze when I press START to play a game.
As for settings, I tried stock 1050 (no Happy or Archiver settings at all, since my real floppy does not work when I use my Happy 1050 in Happy mode). I was not adjusting POKEY divisor settings at all when trying ATX files, just stock 19.2 kbps (standard SIO disk speed). I tried different OS ROMs too - XL, XE and a copy of OS B padded out to 16K for use in my Ultimate 1MB board. Didn't make a difference for me. I can try adjusting POKEY divisor manually, and maybe tweak the default timing delay in the RespeQt options later this afternoon.
#52 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Feb 10, 2019 12:06 PM
The protection is based on timing. So I guess something is affecting the timing used to answer the Atari. I am using Lotharek's SIO2PC on a USB2 port on an old Dell computer.
It would be interesting to compare the log when you load SCoG and when I do the same on my configuration.
Maybe it will reveal something.
#53 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Sun Feb 10, 2019 3:22 PM
Tried today under Unbuntu - wow, worse performance with this title than under Windows. :( The game freezes right after the second log entry regarding phantom sectors. Even up to that point though, performance is very herky-jerky, with noticeably larger gaps between sector beeps than under Windows.
Back to Win10 however ... Still no success no matter what I try on this one. My log is below, under the spoiler tags. As you can see, nothing stands out. The last entry, setting the emulation speed, appears when I press START to load the game from the title screen.
Spoiler
I'll add that I have the drive set to defaults (No Happy or Archiver emulation, standard SIO speed, etc).
EDITED TO ADD FURTHER: Any of the same files will load on the same hardware (1088XEL) via my SDrive-MAX. So I dunno what's going on with RespeQt.
Edited by DrVenkman, Sun Feb 10, 2019 3:35 PM.
#54 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,761 posts
Posted Sun Feb 10, 2019 3:40 PM
try a different usb port... no problem on xp or win 81.1
Edited by _The Doctor__, Sun Feb 10, 2019 3:42 PM.
#55 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Sun Feb 10, 2019 4:10 PM
Made no difference, as it rarely does with modern hardware and up-to-date drivers.
No, rather the problem was something else, set as a default in this version of RespeQt evidently: "Trigger on falling edge"
I don't remember this setting in prior versions, but as soon as I unchecked it, loading SCoG started working as expected. Note that having this checked did not complicate or prevent loading of a number of other ATX files, but it did cripple loading of SCoG past the animated title screen. I haven't yet checked to see if unchecking the box will cause difficulties with other ATX files.
#56 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Feb 10, 2019 4:19 PM
Bravo !
I am happy that you have found the right settings.
It is also unchecked in my configuration and nearly all titles are loading.
Really strange that is was checked on your side...
#57 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Sun Feb 10, 2019 4:30 PM
Bravo !
Yeah, I have no idea. I certainly didn't check that box intentionally. I still have a copy of Joey's last release (r4) and the setting didn't even exist in that version.
#58 _The Doctor__ OFFLINE
_The Doctor__
  • 6,761 posts
Posted Sun Feb 10, 2019 5:18 PM
falling edge is the normal setting for serial, by unchecking that- one of the flow control modes will stop working and you will have advanced the timing on the other flow control lines.
if timings have been calculated with it unchecked well.....
Edited by _The Doctor__, Sun Feb 10, 2019 5:19 PM.
#59 Kyle22 OFFLINE
Kyle22
  • 4,033 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sun Feb 10, 2019 11:08 PM
I wish there was a sticky that had the latest binaries. WinXP32 in my case.
The latest and greatest gets difficult to find.
#60 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Wed Feb 13, 2019 2:10 PM
Here you go. I attached the binaries for Win32 and Mac.
These are a roll up of ebiguy's and my forks.
#61 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Thu Feb 14, 2019 1:56 AM
Also a Linux 64 bit build.
#62 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sat Feb 16, 2019 3:47 AM
Hi JoSch,
I merged your pull request.
Great work on printer !
I will try some day the 1020 plotter emulation. I had one back in the days...
I have a layout issue with your printer widget.
I am not using D9-DO so I hide them. When hidden the display of P3: and P4: overrides the drives D1-D8.
I would suggest an option to hide also P3-P4 (which will be rarely used IMHO) so that the right side (D9-DO and P3-P4) fully disappears.
Do you think you can add this option ?
#63 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Sat Feb 16, 2019 7:56 AM
Hi JoSch,
Can you or someone build some Win64 binaries and post them? I'd love to give this a try this weekend. :)
#64 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Mon Feb 18, 2019 2:35 AM
Hi JoSch,
I will look into it.
@All: How should I deal with such an option to hide the right column?
1.) Should the left column just expand to the existing windows size?
or
2.) Should the window width be halved?
#65 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Mon Feb 18, 2019 4:26 AM
or
I vote for 1)
#66 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Mon Feb 18, 2019 3:33 PM
@ebiguy: I pushed the change for the printer widgets. They now hide and show with D9-DO.
@all: Poll is still open ;-)
#67 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Mon Feb 18, 2019 4:30 PM
Hi Josch,
I merged your work. Thank you for fixing this issue so quickly.
After compiling, i tried this new version.
My current setting is D9-DO hidden. When I try to show D9-DO, it resizes my window and when I hide again D9-D0, it resizes the window to a different size than the original size...
I really don't like when the application changes my settings. The size I gave to the window IS a setting as it is kept from one session to the next one.
Changing the window size is definetely not a UI best practice. IMHO, there is no choice here.
Try to activate different panels in the File Explorer, the remaining parts extend to fit the window size.
#68 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Tue Feb 19, 2019 1:59 AM
Hi ebiguy.
I didn't change the window size behaviour. The code was there before and it changes the minimum width size.
If one comments the two lines the shown left column extends over the while window width, when the right column is hidden.
I was waiting for the others chiming in. Perhaps we can make that configurable.
BTW, when I was at it, I again looked at the native menu bar issue on macOS. I solved that, and it will be configurable. When I have checked, that my code works on Windows and Linux, I will push it to ebiguy and provide some binaries.
Edited by JoSch, Tue Feb 19, 2019 1:59 AM.
#69 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Tue Feb 19, 2019 8:24 AM
If anyone manages to compile the 4.3 branch in Raspbian, let us know please. The “internal compiler error” I get is infuriatingly vague.
#70 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Tue Feb 19, 2019 1:24 PM
So, I made binaries for Win32 and Mac.
Attached File  RespeQt_mac.zip   25.95MB   11 downloads
Attached File  RespeQt_win32.zip   853.61KB   22 downloads
@DrVenkman: I have to get out my RaspberryPi and try to build it. Stay tuned.
#71 cpforbes OFFLINE
cpforbes
    Combat Commando
  • 6 posts
Posted Wed Feb 20, 2019 1:55 AM
I was able to build ebiguy's develop branch (0277736) on my Pi 3 B. I updated the OS with apt-get dist-upgrade before building, but g++ was not updated.
$ g++ --version
g++ (Raspbian 6.3.0-18+rpi1+deb9u1) 6.3.0 20170516
$ uname -a
Linux pi3 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
Attached is the result, I have not had a chance to test it with my Atari
Attached File  RespeQt-r4.3-0277736-RPi.gz   877.03KB   12 downloads.
#72 JoSch ONLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Wed Feb 20, 2019 1:00 PM
I also could compile RespeQt on a RPi 1. The screenshot shows RespeQt run remotely on the RPi
#73 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Wed Feb 20, 2019 5:28 PM
$ g++ --version
$ uname -a
attachicon.gifRespeQt-r4.3-0277736-RPi.gz.
Interesting. I have the same g++ version installed on my PiZeroW, though my kernel is older. Just did a sudo apt-get update and now sudo apt-get dist-upgrade  Once all that's done I'll try to compile it again. Otherwise I'll try the binaries you compiled and see if they work. I *really* hope they do. Although I have a Pi 3 B and 3B+ in the house, both are being used full-time for other tasks. This PiZeroW has worked flawlessly for prior versions of RespeQt until now.
#74 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Wed Feb 20, 2019 6:05 PM
Okay, now after cloning ebiguy's develop branch to my desktop and running qmake, I get a new error, no doubt related to the printer support. I seem to be missing svg support in my Qt installation. Off to go try to figure that one out …  Ah, I need to install the Qt5 SVG dev tools. Okay, that's fixed.
Now to see if the make process works.
Edited by DrVenkman, Wed Feb 20, 2019 6:40 PM.
#75 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Wed Feb 20, 2019 6:19 PM
Rats, still fails on the PiZeroW. I might remote into one of my other Pi's here in the house and see if it's just a limitation of the ZeroW - maybe it ran out of memory or something during compilation?
Reply to this topic
