Atari Bank Switching for Dummies
Bank Switching
9 replies to this topic
#1 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,931 posts
  • Always left from right here!
Posted Tue Dec 11, 2018 2:57 AM
Atari's bank switching (F8, F6, F4) is pretty straight forward. Nevertheless it can become quite complicated if you want to switch between banks a lot. Therefore I wrote myself some macros, which make things much easier.
Here is the basic version, just to get the idea:
; TJ's Atari standard bankswitching macros, here tailored for F4 (adapt for F8 or F6)
BANK_SIZE = $1000
; Use at the start of each bank, required by JMP_LBL macro
  MAC START_BANK ; bank number
BANK_NUM    SET {1}
BANK_ORG    SET $8000 + BANK_NUM*BANK_SIZE
BANK_RORG   SET $1000 + BANK_NUM*BANK_SIZE*2
    SEG     code
    ORG     BANK_ORG, $55
    RORG    BANK_RORG
    ECHO    "Start of bank", [BANK_NUM]d, ", ORG", BANK_ORG, ", RORG", BANK_RORG
; verify start addresses:
START{1} = (START & $fff) | BANK_RORG
    ; optional Space for RAM+
;    DS.B    $100, "#"
  ENDM
; a convenience macro, put at the end of every bank
  MAC END_BANK
   RORG $ff4
    ds      8, 0 ;
    .word   (START & $fff) | BANK_RORG  ; RESET
    .word   0                           ; BRK (unused)
  ENDM
; Insert code for executing the bankswitch,
; should be put at the very end of each bank, right before the hotspots
  MAC SWITCH_BANK
    ORG     BANK_ORG + $ff4 - BANKSWITCH_SIZE
    RORG    BANK_RORG + $ff4 - BANKSWITCH_SIZE
SwitchBank  = (. & $fff) | $1000
    pha
    txa
    pha
    lda     $fff4,y
    rts
BANKSWITCH_SIZE = ((. & $fff) | $1000) - SwitchBank
  ENDM
; Define a label which can be used by JMP_LBL macro
;Example:
;    DEF_LBL Foo
  MAC DEF_LBL ; address
{1}
{1}_BANK    = BANK_NUM
  ENDM
; Jump to a label in other or same bank. The assembler will take care if the
; code has to bankswitch or not.
; Example:
;    JMP_LBL Foo
  MAC JMP_LBL ; address
   IF {1}_BANK != BANK_NUM      ; convenience IF :)
    ldy     #{1}_BANK
    lda     #>({1}-1)
    ldx     #<({1}-1)
    jmp     SwitchBank          ; always at the same address in each bank
   ELSE
    jmp     {1}
   ENDIF
  ENDM
So if you put these macros into your code and use DEF_LBL to define the labels you want to call, you can jump with JMP_LBL to these labels without having to care for bankswitching.
Disadvantages:
  • a bit slower than dedicated bank switching code
  • uses A, X and Y registers, so you cannot transfer parameters (but with more code this can be reduced to one register).
BTW: This could be adapted to JSR calls to, but I never really needed those.
Edited by Thomas Jentzsch, Tue Dec 11, 2018 11:28 AM.
#2 Karl G OFFLINE
Karl G
    Dragonstomper
  • 722 posts
Posted Tue Dec 11, 2018 11:38 AM
Thank you for sharing these!
#3 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 360 posts
Posted Sun Dec 23, 2018 2:59 PM
Well I started out understanding none of this and now I think I understand about half of it.  Anybody care to check or correct my comments?
BANK_SIZE = $1000	;j Define a constant,(4K bank size here)
  MAC START_BANK ; bank number. j example: start each bank with with argument
					;j START_BANK 1, START_BANK 2, etc
BANK_NUM    SET {1}	;j Transfer the START_BANK argument to BANK_NUM
BANK_ORG    SET $8000 + BANK_NUM*BANK_SIZE ;j $8000 skips over the first potential 8
					;j (4K) banks then sets the start address (ORiGin) of the
					;j bank that was set in the argument.
BANK_RORG   SET $1000 + BANK_NUM*BANK_SIZE*2 ;j ??? If bank 2, for example, BANK_RORG
					;j would be $5000.  Why?
    SEG     code		;j Start the code segment
    ORG     BANK_ORG, $55	;j Put $55 at the start of a bank?
    RORG    BANK_RORG		;j Put the relocatable code in the calculated location?
    ECHO    "Start of bank", [BANK_NUM]d, ", ORG", BANK_ORG, ", RORG", BANK_RORG ;j print stuff
START{1} = (START & $fff) | BANK_RORG ;j Define START of the bank as this location
					;j with the left nibble stripped off and replaced with the
					;j left nibble of BANK_RORG?
;    DS.B    $100, "#"
  ENDM
  MAC END_BANK
   RORG $ff4
    ds      8, 0 ;j Put zeros in the last 8 bytes for the hot spots before the
			; reset and break vectors
  ENDM
  MAC SWITCH_BANK
    ORG     BANK_ORG + $ff4 - BANKSWITCH_SIZE ;j Calculate where the hot spots
											;j go in each bank
    RORG    BANK_RORG + $ff4 - BANKSWITCH_SIZE ;j Calculate where the hot spots
											;j go in the moveable code?
SwitchBank  = (. & $fff) | $1000 ;j take this location and replace the left
								;j nibble with a 1?
    pha		;j MAC JMP_LBL jumps to here. The accumulator was loaded with one
    txa		;j nibble and x was loaded with the other.  Move it to the accumulator
    pha		;j so it can be pushed on the stack.  Setting up a return address.
    lda     $fff4,y	;j Load the accumulator with one of the hot spots, causing
			;j a bankswitch.
    rts		;j The bankswitch occurred, so this executes in the new bank
			;j The rts is to an address that was calculated in JMP_LBL
BANKSWITCH_SIZE = ((. & $fff) | $1000) - SwitchBank ;j Calculates the size of the
			;j SwitchBank code. Then take this address and limit it to a range of
			;j	%00001111 11111111 to
			;j	%00011111 11111111 .... Why the limit?
  ENDM
;Example:
;    DEF_LBL Foo	;j Insert this in the place where you want to be able to jump to.
  MAC DEF_LBL ; address	;j Figure out where we are.
{1}			;j Argument is Foo. Labels the code?
{1}_BANK    = BANK_NUM	;j Foo_BANK is the bank number we are currently in.
  ENDM
; Example:
;    JMP_LBL Foo
   IF {1}_BANK != BANK_NUM      ; convenience IF :) ;j If Foo_BANK is not current bank
    ldy     #{1}_BANK		;j Load y with the hot spot offset
    lda     #>({1}-1)		;j Load MSB of Foo's address
    ldx     #<({1}-1)		;j Load LSB of Foo's address
   ELSE		;j If we're already in the same bank
    jmp     {1}	;j then just jump Foo
   ENDIF
  ENDM
#4 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,931 posts
Posted Mon Dec 24, 2018 2:23 AM
					;j START_BANK 1, START_BANK 2, etc TJ: for F4 you should start with 0, else the following variables will overrun
					;j would be $5000.  Why? TJ: Because we need an odd first nibble here
    ORG     BANK_ORG, $55	;j Put $55 at the start of a bank? TJ: This is the address of the bank in the ROM. These can be anything, but they must be consecutive overall. $55 is just redefining the default fill value for unused areas
    RORG    BANK_RORG		;j Put the relocatable code in the calculated location? TJ: The origin used by the code in this bank. Different origins per bank make debugging easier.
					;j left nibble of BANK_RORG? TJ: Startup address of the bank, this code just verifies that all banks use the place in their logical address space
;    DS.B    $100, "#"
  ENDM
  MAC END_BANK
   RORG $ff4
  ENDM
  MAC SWITCH_BANK
											;j go in each bank
											;j go in the moveable code? TJ: You have to update ORG and ROGR in pairs when using bankswitching, because they are different.
								;j nibble with a 1? TJ: Just like START, this puts all bank switch code at the same spot in address space for each bank
			;j a bankswitch.
			;j	%00011111 11111111 .... Why the limit? TJ: The limit comes from the 4K address space we are using.
  ENDM
;Example:
{1}			;j Argument is Foo. Labels the code? TJ: Yes, required to have an address
  ENDM
; Example:
;    JMP_LBL Foo
   ENDIF
  ENDM
My comments above (TJ...)
#5 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 360 posts
Posted Sun Dec 30, 2018 9:01 AM
Thanks A lot! I think I understand enough of it to use it now
#6 KevKelley OFFLINE
KevKelley
    Chopper Commander
  • 136 posts
  • Lots of hobbies, little time, loads of fun.
Posted Tue Jan 1, 2019 8:33 AM
Curious. I am still learning but Is there a method of getting the same amount pf space without bankswitching?
#7 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,931 posts
Posted Tue Jan 1, 2019 8:38 AM
Sorry, I don't get your question.
#8 KevKelley OFFLINE
KevKelley
    Chopper Commander
  • 136 posts
Posted Fri Jan 4, 2019 1:14 AM
Sorry. I was wondering if information can only be accessed in 4k increments or is there a way to have more without bankswitching?
Not sure if I am fully understanding it or not or if my question makes much sense at all...
#9 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,931 posts
Posted Fri Jan 4, 2019 1:17 AM
The Atari can only access up to 4K ROM without bankswitching. If you need more ROM space you need bankswitching.
#10 KevKelley OFFLINE
KevKelley
    Chopper Commander
  • 136 posts
Posted Fri Jan 4, 2019 10:19 AM
Okay. Thanks. That's what I thought from all the reading but wasn't sure if I missed anything.
Also tagged with one or more of these keywords: Bank Switching
