atari_aaron Posted June 15, 2003 Share Posted June 15, 2003 I've read through the sizes.txt file on The Dig. I understand that to switch banks using the F4 method I should call something like: LDA $1FF5 or LDX $1FF5 But I'm not clear on how the ASM file is to be structured so that each bank has an address of $1000 to $1FF3. I've looked through Paul Slocum's Marble Maze code found at: http://www.biglist.com/lists/stella/archiv...7/msg00018.html That code seems fairly straight forward. However, what is not clear to me is how the code included files are structured: marbank2.asm marbank3.asm marbank4.asm Would the code in each of these includes look something like this: processor 6502 include vcs.h org $1000 Bank1 = $1FF4 Start ;...some code here... LDA Bank1; call to send the processor back to the first bank ;.... org $1FF3 .word Start .word Start Would the references to Start even be needed? Also are there some other DASM commands required like SEG and RORG? Or should the ORG's be pointing to a different address, something like this: org $2000 org $2FF3 If you don't have time to write about F4/F6/F8 bankswitching I understand, but would you be able to post some simple files that myself and others could browse in an attempt to understand the method on our own? Any help you can provide is appreciated. Thanks, Aaron Link to comment Share on other sites More sharing options...
+Andrew Davie Posted June 15, 2003 Share Posted June 15, 2003 If you don't have time to write about F4/F6/F8 bankswitching I understand, but would you be able to post some simple files that myself and others could browse in an attempt to understand the method on our own? Any help you can provide is appreciated. These sorts of questions are best asked on the [stella] mailing list. This forum is designed to be a beginner's tutorial on programming the '2600 - and as such will not deal with such issues as bankswitching until much later in the piece. I'd prefer to keep the forum on-target and discuss the lessons presented to date, rather than divert on wild tangents. Link to comment Share on other sites More sharing options...
atari_aaron Posted June 15, 2003 Author Share Posted June 15, 2003 Sorry, I posted the same message to the Stella mailing list. Aaron Link to comment Share on other sites More sharing options...
CPUWIZ Posted June 15, 2003 Share Posted June 15, 2003 These sorts of questions are best asked on the [stella] mailing list. This forum is designed to be a beginner's tutorial on programming the '2600 - and as such will not deal with such issues as bankswitching until much later in the piece. I'd prefer to keep the forum on-target and discuss the lessons presented to date, rather than divert on wild tangents. Or you could just move the message into the programming forum instead. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
