LED Mod
LED Mod Atari 2600
9 replies to this topic
#1 Polish.Gasoline OFFLINE
Polish.Gasoline
    Space Invader
  • 21 posts
Posted Wed Dec 12, 2018 11:09 PM
Hi,
I am trying to build my first mod for my 2600.  It is an LED mod.  I am trying to purchase the parts (not much to them) and am curious what does the led have to be rated for the 2600.  All I know is the 2600 takes .5 A and 9 V.  What does that mean for the LED?  The wire is rated for 24 AWG right?
This was the site I was going to order off of.
https://canada.newar...arch?st=led red
Thanks in the future if anyone responds.
#2 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,514 posts
  • I am the one who knocks!
Posted Wed Dec 12, 2018 11:33 PM
Simple, tap into ground and 5V, calculate the rating for the LED resistor and solder.  There are calculators online for this.
#3 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,514 posts
Posted Wed Dec 12, 2018 11:34 PM
http://led.linear1.org/1led.wiz
#4 Hannacek OFFLINE
Hannacek
    Moonsweeper
  • 432 posts
Posted Thu Dec 13, 2018 12:15 PM
You probably just want to buy parts off Ebay or Amazon. Newark tends to charge too much for shipping if your order is too small.
You just need an led, and the right value resistor for 5 volts. Its a really simple circuit to light an led with 5 volts. You can find youtube videos and stuff online to show you how.
#5 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Thu Dec 13, 2018 1:01 PM
I use 330 ohm for a red led modern leds even the basic ones are quite bright
Edited by Osgeld, Thu Dec 13, 2018 1:03 PM.
#6 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,747 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Fri Dec 14, 2018 11:43 AM
Not as cheap a solution, but I've been trying to use 12v LEDs lately. Reason being is that they are designed for 12v but still work with only 5v. But they are much less brighter and more 'Normal' for power LEDs if you ask me. And with them only running on half the rated voltage, they should last quite a bit longer with less fade over time.
#7 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Sat Dec 15, 2018 8:19 AM
that's not how it works
#8 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,747 posts
Posted Sat Dec 15, 2018 9:39 AM
These already have current limiting resistors installed in the base with a securing nut for easy installation. Just like an RCA jack.
#9 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Sat Dec 15, 2018 12:16 PM
its the current that matters, so yes if a led is setup for X current at Y voltage with Z resistor then changing any of those values will result in more or less light being produced, but it probably wont effect lifespan as its a diode junction, its either on or its not (until you get into LED's that start producing measurable heat, or your letting too much current pass, which produces heat)
Edited by Osgeld, Sat Dec 15, 2018 12:17 PM.
#10 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,747 posts
Posted Sat Dec 15, 2018 12:44 PM
Makes sense. I figured since there was less voltage and likely less current that it might extend the normal life of the LED. It about half as bright as they would normally be at that voltage. But thank you for the correction!
Also tagged with one or more of these keywords: LED, Mod, Atari, 2600
