Lillapojkenpåön Posted December 14, 2018 Share Posted December 14, 2018 I noticed that this line.. if player2y < player1y && player1y < player2y + 24 then _wait outputs this assembly LDA player2y CMP player1y BCS .skipL01207 ; complex condition detected LDA player2y CLC ADC #24 PHA TSX PLA LDA player1y CMP 1,x if ((* - ._wait) < 127) && ((* - ._wait) > -128) bcc ._wait else bcs .20skip_wait jmp ._wait .20skip_wait endif .skipL01207 what does this do and why? PHA TSX PLA LDA player1y CMP 1,x Is that why you should use <= and >= instead? My wild guess is that there either isn't a smaller then or bigger then in assembly, that one of them also checks if equal to, so that part adds 1 to compensate for that? Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted December 14, 2018 Share Posted December 14, 2018 Have you tried experimenting with flipping the second condition around? Try: if player2y < player1y && player2y + 24 > player1y then _wait and look at the code that produces. what does this do and why? PHA TSX PLA LDA player1y CMP 1,x Is that why you should use <= and >= instead? My wild guess is that there either isn't a smaller then or bigger then in assembly, that one of them also checks if equal to, so that part adds 1 to compensate for that? The code puts a copy of A, which is the result of player2y+24), onto the stack. Then performs the comparison with player1y. PHA TSX PLA -- puts A on the stack and puts the stack pointer into X and then "pops" A from the stack... A still exists on the stack since pop only reads the value and moves the stack pointer without clearing that spot. CMP 1,x access that copy of A on the stack using the saved pointer which needs 1 added since the stack pointer always points at the next available spot and not the last value added. If TSX was moved outside of the PHA PLA then it would be CMP 0,x instead. To answer the other portion of your last question, < and >= are the simplest cases to handle in assembly (equal and not equal are also simple cases). For good information about doing comparisons in assembly: http://6502.org/tutorials/compare_instructions.html Hopefully I explained that clearly enough 1 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted December 14, 2018 Author Share Posted December 14, 2018 Thanks for the quick and detailed info! I will try changing it around next time I encounter it, I changed it to this which seems to work fine asm LDA player2y CMP player1y BCS .skipwait CLC ADC #24 CMP player1y bcs ._wait .skipwait end Quote Link to comment Share on other sites More sharing options...
