AUTOBAUD DETECTION FOR 9902
8 replies to this topic
#1 TheBF OFFLINE
TheBF
    Dragonstomper
  • 853 posts
Posted Fri Dec 14, 2018 5:38 PM
I found this code in an old book from TI circa 1981.
I thought the gang here might find it interesting.  Apologies.  I have not assembled it and the tabs are all wrong but it's a neat idea.
It appears to work by measuring the time between mark and space in the signal and then looking up the rate interval for that measurement in the table.
Smart people at TI in 1981.
Minor edits per Stuart's comments
* autobaud for 9902
* Software Development, Texas Instruments 1981
           LI      R12,BASE
           SBO     31
           LI      R1,6200
           LDCR    R1,8
           SBZ     13
           CLR     R3
* wait for start bit
SBAUD      TB      15
           JEQ     SBAUD
* wait until rin goes back to space condition
SBAUD1     INC     R3
           TB      15
           JNE     SBAUD1
* FIND THE BAUD RATE
           LI      R4,BAUDTB-2
SBAUD2     INCT    R4
           C       R3 *R4+
           JH      SBAUD2
* baud rate found - set recieve and transmit data interval
* read a char and throw it away
           LDCR *R4,12
SBAUD3     TB   21
           JNE SBAUD3
           SBZ 18
BAUDTB     DATA >0007,>001A     * 19200
           DATA >000E,>0034     *  9600
           DATA >001D,>0068     *  4800
           DATA >003B,>00D0     *  2400
           DATA >0075,>01A0     *  1200
           DATA >00EA,>0340     *   600
           DATA >0246,>04D0     *   300
           DATA >7FFF,>0638     *   110
Edited by TheBF, Sat Dec 15, 2018 10:02 AM.
#2 TheBF OFFLINE
TheBF
    Dragonstomper
  • 853 posts
Posted Fri Dec 14, 2018 5:52 PM
I just discovered that you don't have to turn on the RS232 CARD to access the 9902 chips!
The CRU address can be set to >1340 and you can read and write the 9902 bits and send and receive data just fine.
Does anyone know of a downside if you are not using the DSR code?
#3 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,316 posts
Posted Fri Dec 14, 2018 7:14 PM
The nanoPEB devices require you to turn on the card, causing incompatibility with any programs that used the "feature" you describe.
The creator did not want to fix this difference which, in my opinion, is a mistake and has created a few headaches.
No downside so long as you roll your own code.
#4 Stuart OFFLINE
Stuart
    Dragonstomper
  • 817 posts
Posted Sat Dec 15, 2018 9:37 AM
Tiny little typo in the listing:
LI R4,BAUDTB=2    should be   LI R4,BAUDTB-2 (minus 2, not equals 2)
Note that the values in the Baud rate table are for no-wait state memory. The values in the first column will need recalculating if the code is run from memory with wait states. The Baud rates, from the top to the bottom of the table, are 19200, 9600, 4800, 2400, 1200, 600, 300, 110 Baud.
#5 TheBF OFFLINE
TheBF
    Dragonstomper
  • 853 posts
Posted Sat Dec 15, 2018 10:06 AM
Thanks Stuart,
Any thoughts on the multiple that we should use for those times in column 1?
I suppose I could just load the code and hit it with a known BPS rate and look at R3.
I need to write this up in RPN assembler and try it.
#6 Stuart OFFLINE
Stuart
    Dragonstomper
  • 817 posts
Posted Sat Dec 15, 2018 10:48 AM
Values best established by experimentation I think.  ;-)  Probably best to make sure interrupts are off as well, just in case.
#7 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 534 posts
Posted Sat Dec 15, 2018 2:41 PM
This was a common feature back then. I remember first learning about it in school, 1982 or something. Not with the same UART, but using a similar principle. It was common to send the character 'A', due to its bit pattern.
#8 Swim OFFLINE
Swim
    Chopper Commander
  • 152 posts
Posted Tue Dec 18, 2018 6:47 AM
I seem to recall baud rate parsing is done in the console ROMs? Parsing wait state and clock speed? Correct? I think user atrax27407, Hummingbird EPROMs, has ROMs with wait state and clock speed options available.
#9 atrax27407 OFFLINE
atrax27407
  • 1,177 posts
Posted Tue Dec 18, 2018 8:19 AM
Here are the baud rate calculations:
  • Attached File  Scan.pdf   174.65KB   16 downloads
