Can I use a simple EEPROM for a cartridge?
2 replies to this topic
#1 cbmeeks OFFLINE
cbmeeks
    Moonsweeper
  • 355 posts
Posted Wed Dec 19, 2018 3:00 PM
Lets say I have a stack of 8K and 32K EEPROMS.
If I match the pinouts, can I make my own CV carts or do I need some other logic in between?
Which brings me to my second question, how are /8000, /A000, etc. used on the CV? Would my cartridge have to set those somehow like with pull up/down resistors?
Im learning more about the CV hardware so please excuse my ignorance.
Thanks.
#2 ChildOfCv OFFLINE
ChildOfCv
    Star Raider
  • 94 posts
Posted Thu Dec 20, 2018 6:21 PM
/8000 through /E000 are individually-decoded addresses representing A15-A13.  If any of them are on, that means A15 is high.  A14 and A13 decode as one of the other lines.  So if you were to use a single 32K EEPROM, it needs to activate based on ANY of those select lines going low.
#3 ChildOfCv OFFLINE
ChildOfCv
    Star Raider
  • 94 posts
Posted Fri Dec 21, 2018 2:52 AM
And to answer your first question, you can connect the data and address lines directly.  Only chip select needs special logic to go active when one of those 4 decoded lines goes active (low).
