TiVi Development Thread
asm f18a editor tms9900
9 replies to this topic
#1 retroclouds OFFLINE
retroclouds
  • 1,681 posts
Posted Sat Dec 22, 2018 1:02 PM
I will be using this thread to document the development of a new programmer editor for the TI-99/4a called "TiVi".
(pronounced "TV" or "TeeVee")
As you might expect from its name, the editor is somewhat inspired by the unix editor "vi" and will also take elements of "tmux".
So what do I have in mind:
  • Designed from the ground up for 80 columns mode, specifically using the F18A but 9938 will be supported as well.
  • Designed from the ground up for using SAMS card, albeit 32K memory expansion should work as well
  • Programming language of choice is TMS9900 assembly language
  • The editor itself will run from cartridge space (multi-bank cartridge).
  • Uses my spectra2 library as foundation (been doing major changes in the last couple of months, not related to games)
  • Will have some "API" so that I can integrate with external programs and go back and forth between programs.
  • Would like to add some kind of mouse support. This will not be a GUI in the traditional sense.
    If you used tmux with a mouse before you know what I mean.
  • Possibility to have multiple editor panes open at once.
  • Should handle files with up to 65536 lines when using SAMS.
  • Undo functionality, well up to a certain extent that is.
  • Language awareness, e.g. behave differently based upon language (e.g. assembly, C, Basic, ...)
  • Internal text representation will be decoupled from what actually will be rendered on screen. Should make the editor more responsive when dealing with large files, allow split panes, etc.
  • Reconfigurable keymaps, possibility to swap between keymap with single key combination. Not everyone is into VI ;-)
This is the start of a large project and I don't expect to have a truely useful version anytime soon.
I expect this project to take multiple years, but you gotta start somewhere.
Now I've taken my mouth full, I will use this thread to keep myself motivated :-)
There aren't too many resources out there discussing the architecture of a text editor, so cross-linking here.
Threads on Atariage discussing topics -somewhat- related to TiVi:
Others:
Edited by retroclouds, Sat Jan 5, 2019 9:40 AM.
#2 mizapf ONLINE
mizapf
  • 3,474 posts
Posted Sat Dec 22, 2018 1:16 PM
As you might expect from its name, the editor is somewhat expired by the unix editor "vi" and will also take elements of "tmux".
inspired?
BTW, I'm dreaming of a "vig" (vi for Geneve) for decades already, but I would keep it to a subset of the vi features.
#3 retroclouds OFFLINE
retroclouds
  • 1,681 posts
Posted Sat Dec 22, 2018 1:18 PM
Here's a first little demo I recorded on js99er. The cursor is actually a sprite in 80 columns mode on the F18a.
I've been doing a few of these to check out if certain things will or will not work.
Edited by retroclouds, Sat Dec 22, 2018 1:20 PM.
#4 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Sat Dec 22, 2018 9:46 PM
Really looking forward to this. I've been using Preditor in 80col mode, but it's a bit slow and limited in memory.
#5 Opry99er ONLINE
Opry99er
  • 10,370 posts
Posted Wed Dec 26, 2018 12:03 AM
Cool!!!
#6 atrax27407 OFFLINE
atrax27407
  • 1,177 posts
Posted Wed Dec 26, 2018 9:01 AM
I use the F'WEB 80-col editors. With 192K of VRAM in my AVPC card, and cut and paste facility, I cab do just about anything I want with either text or A/L programming.
  • RXB likes this
#7 retroclouds OFFLINE
retroclouds
  • 1,681 posts
Posted Sat Jan 5, 2019 9:51 AM
Update: I will supported the 9938 as well. At least up to a certain extent. F18a is primary focus though.
Progress is good. I have most of the memory structures in place and they are working as expected.
  • fb - Frame buffer. This basically matches a rectangular window as part of the physical screen. This is basically where the text resides until enter is pressed or key up/down is used.
  • idx - The index. It's the link between the line numbers and editor buffer.
  • edb - The editor buffer. This is where the text resides after the line is "crunched" (packed). Currently it's a copy-on-write without compression, but might be going for RLE compression.
For each of these structures I have a support module. Here's ane extract:
* Frame buffer structure @ >2000
* Frame buffer itself    @ >3000 - >3fff
fb.top.ptr      equ  >2000          ; Pointer to frame buffer
fb.current      equ  fb.top.ptr+2   ; Pointer to current position in frame buffer
fb.topline      equ  fb.top.ptr+4   ; Top line in frame buffer (matching line X in editor buffer)
fb.row          equ  fb.top.ptr+6   ; Current line in frame buffer (offset 0 .. @fb.screenrows)
fb.row.length   equ  fb.top.ptr+8   ; Length of current row in frame buffer
fb.row.dirty    equ  fb.top.ptr+10  ; Current row dirty flag in frame buffer
fb.column       equ  fb.top.ptr+12  ; Current column in frame buffer
fb.colsline     equ  fb.top.ptr+14  ; Columns per row in frame buffer
fb.curshape     equ  fb.top.ptr+16  ; Cursor shape & colour
fb.curtoggle    equ  fb.top.ptr+18  ; Cursor shape toggle
fb.yxsave       equ  fb.top.ptr+20  ; Copy of WYX
fb.dirty        equ  fb.top.ptr+22  ; Frame buffer dirty flag
fb.screenrows   equ  fb.top.ptr+24  ; Number of rows on physical screen
fb.top          equ  >3000          ; Frame buffer low memory 2400 bytes (80x30)
;                    >200c-20ff     ; ** FREE **
* Editor buffer structure @ >2100
edb.top.ptr     equ  >2100          ; Pointer to editor buffer
edb.index.ptr   equ  >2102          ; Pointer to index
edb.lines       equ  >2104          ; Total lines in editor buffer
edb.dirty       equ  >2108          ; Editor buffer dirty flag (Text changed!)
edb.next_free   equ  >210a          ; Pointer to next free line
edb.top         equ  >a000          ; Editor buffer high memory 24576 bytes
;                    >2102-21ff     ; ** FREE **
* Index @ >2200 - >2fff
idx.top        equ  >2200           ; Top of index
And here's how on of the routines in the edb support module looks like. I'm using xas99 which allows a lot of flexibility in using labels. That helps a lot.  :)
* edb.line.pack
* Pack current line in framebuffer
*  bl   @edb.line.pack
* INPUT
* @fb.top       = Address of top row in frame buffer
* @fb.row       = Current row in frame buffer
* @fb.column    = Current column in frame buffer
* @fb.colsline  = Columns per line in frame buffer
* OUTPUT
* Register usage
* tmp0,tmp1,tmp2
* Memory usage
* rambuf   = Saved @fb.column
* rambuf+2 = Saved beginning of row
* rambuf+4 = Saved length of row
edb.line.pack:
        dect  stack
        mov   r11,*stack            ; Save return address
        ; Get values
        mov   @fb.column,@rambuf    ; Save @fb.column
        clr   @fb.column
        bl    @fb.calc_pointer      ; Beginning of row
        ; Prepare scan
        clr   tmp0                  ; Counter
        mov   @fb.current,tmp1      ; Get position
        mov   tmp1,@rambuf+2        ; Save beginning of row
        ; Scan line for >00 byte termination
edb.line.pack.scan:
        movb  *tmp1+,tmp2           ; Get char
        srl   tmp2,8                ; Right justify
        jeq   edb.line.pack.idx     ; Stop scan if >00 found
        inc   tmp0                  ; Increase string length
        jmp   edb.line.pack.scan    ; Next character
        ; Update index entry
edb.line.pack.idx:
        mov   tmp0,@rambuf+4        ; Save length of line
        mov   @fb.row,@parm1        ; Current row in Framebuffer
        ; Store line inline in index if length <= 2 characters
        ci    tmp0,2
        jgt   edb.line.pack.idx.normal
        mov   @rambuf+2,tmp1        ; Retrieve beginning of line
        mov   *tmp1,@parm2          ; Store word inline
        mov   tmp0,@parm3           ; Length of line
        bl    @idx.entry.update     ; Update index entry
        jmp   edb.line.pack.$$      ; Exit
        ; Update index and store line in editor buffer
edb.line.pack.idx.normal:
        mov   @edb.next_free,@parm2 ; Block where packed string will reside
        mov   @rambuf+4,tmp2        ; Number of bytes to copy
        mov   tmp0,@parm3           ; Set length of line
        ; Pack line from framebuffer to editor buffer
        mov   @rambuf,tmp0          ; Source for memory copy
        mov   @edb.next_free,tmp1   ; Destination for memory copy
        bl    @xpym2m               ; Copy memory block
        ; Update pointer to next free block
        a     @rambuf+4,@edb.next_free
        ; Exit
edb.line.pack.$$:
        mov   @rambuf,@fb.column    ; Retrieve @fb.column
        b     @poprt                ; Return to caller
#8 retroclouds OFFLINE
retroclouds
  • 1,681 posts
Posted Sat Jan 12, 2019 1:27 AM
I want to try out some more editors to see how they behave on the TI-99/4a.
Does Funnelweb work with 32k as well? Would it be possible to do a short video. Interested in seeing how responsive it is with the 192k vram. thx.
#9 atrax27407 OFFLINE
atrax27407
  • 1,177 posts
Posted Sat Jan 12, 2019 7:41 AM
The 80-col Funnelweb requires a v9938 (or v9958) with its additional VRAM to use all of the "extras". It will run in 40-columns with a 9918.
#10 TheBF OFFLINE
TheBF
    Dragonstomper
  • 853 posts
Posted Sat Jan 12, 2019 8:08 AM
Others:
These are great resources.  I am playing with an editor design myself.
Thanks!
Also tagged with one or more of these keywords: asm, f18a, editor, tms9900
