Omega-TI Posted December 26, 2018 Share Posted December 26, 2018 I'm looking for a Windows editor for TI text files in TIFILES format. Does one already exist? Basically when I'm viewing files on my TIPI over the network, I'd like to be able to simply click on a specific file and have it load up in an editor ready to go, instead of having to load a program and then go through a bunch of convoluted steps to see it, let alone edit it. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 26, 2018 Share Posted December 26, 2018 I'm looking for a Windows editor for TI text files in TIFILES format. Does one already exist? Basically when I'm viewing files on my TIPI over the network, I'd like to be able to simply click on a specific file and have it load up in an editor ready to go, instead of having to load a program and then go through a bunch of convoluted steps to see it, let alone edit it. There is no way to do this in Windows when a file does not have an extension, which is the case for nearly all TI files. Even when there is a filename with a dot in it, it does not imply an extension in the conventional DOS/Windows sense. ...lee 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 26, 2018 Author Share Posted December 26, 2018 There is no way to do this in Windows when a file does not have an extension, which is the case for nearly all TI files. Even when there is a filename with a dot in it, it does not imply an extension in the conventional DOS/Windows sense. ...lee True enough, but it would be relatively easy to click one extra button when Windows asks "How do you want to open this file?" All we would have to do is get the editor into the list. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 26, 2018 Share Posted December 26, 2018 I'm looking for a Windows editor for TI text files in TIFILES format. Does one already exist? Basically when I'm viewing files on my TIPI over the network, I'd like to be able to simply click on a specific file and have it load up in an editor ready to go, instead of having to load a program and then go through a bunch of convoluted steps to see it, let alone edit it. Classic99 map the TIPI drive to a drive letter then make that a dsk in classic99.. use your editor of choice.. Greg Sent from my LG-H872 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 26, 2018 Author Share Posted December 26, 2018 Classic99 map the TIPI drive to a drive letter then make that a dsk in classic99.. use your editor of choice.. Yeah, that works, but to be honest, I've got too much much crap on my TIPI and I was looking for a "Lazy Man's Way" of going through all the folders and clutter for deletion or editing. Thanks though. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 26, 2018 Share Posted December 26, 2018 Tidir works for viewing and deleting. Most of the time. Sent from my LG-H872 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted December 26, 2018 Share Posted December 26, 2018 Can't you just use Fred's or Michael's programs? That's how I look at most of my files for folder review. As for extensions, it is easy enough to add ".TI" or something of your choice to the filename. Will that trip up the TI DSR/TIPI? I don't know. Once upon a time Heatwave and Reef BBS added an extension to all downloaded TI files to simplify PC file management. I abandoned that at some point and now only follow the convention with my own files, as I prefer to know it is a TI FILE and I like being able to sort/search/mark based on extension. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 26, 2018 Share Posted December 26, 2018 Using TIImageTool means you have to work with a disk image as storage, so I am not sure whether Omega has it in his desired work chain. if you have a TIFILES file in the PC file system you would first have to import it into a disk image. Every now and then I consider to add an editing function in TIImageTool so that you can change files and save again. It seems easy, given that I already have an editor inside. However, I'll have to implement a rollback function first: Until now, you can only add a new file to an image, or you can read a file from the image. If you could change it, I'd first have to delete the file, then add it again, and hope that the new version has enough space on the image. 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 26, 2018 Author Share Posted December 26, 2018 I'm surprised in all the years that NOTEPAD has been part of Windows, no one has tweaked it to read TIFILES format DV80 or DF80 files, or at the very least added a new extension format to LibreWriter. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 26, 2018 Share Posted December 26, 2018 The question is which TIFILES should be considered editable. DV80 is likely, then maybe also DF80 (if not compressed object code), what about DF128? The bad thing (in this context) is that we have so many file formats, where PC operating systems typically only have an unstructured byte stream. 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 26, 2018 Author Share Posted December 26, 2018 The question is which TIFILES should be considered editable. DV80 is likely, then maybe also DF80 (if not compressed object code), what about DF128? The bad thing (in this context) is that we have so many file formats, where PC operating systems typically only have an unstructured byte stream. Agreed. I would say 'for sure' on the DV80 TI-Writer format, with and without the formatting codes at the end of the file. Probably DF80 as well. In my case personal case as a TIPI user it would be nice to be able to edit a 4A/DOS batch file on the PC. For other people having the extra memory on a PC might be beneficial for editing large text files that are too big for the TI or some of the programs on the TI to handle. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 27, 2018 Author Share Posted December 27, 2018 Can't you just use Fred's or Michael's programs? That's how I look at most of my files for folder review. Yes, for everything on the TI, I've been using << Fred Kaal's new Editor >> as it's an awesome program, but truth be told, I find maintenance easier via the PC. Since I install new stuff via the the PC/TIPI WiFi link anyway, having a PC-side editor would sure make life easier. Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted December 27, 2018 Share Posted December 27, 2018 But it's ...so much fun to edit in notepad and than have to PASTE into MAME or Classic99. ...At least it's an option! Ha! 1 Quote Link to comment Share on other sites More sharing options...
