Harmont Cart and the RetroTINK Issue
6 replies to this topic
#1 StephenJ OFFLINE
StephenJ
    Moonsweeper
  • 364 posts
Posted Thu Dec 27, 2018 8:33 PM
I have three AV (S Video) modded Atari 2600's that I have tested with the RetroTINK 2X.
I've had no problem running cartridge games. However, running games from the Harmony Cart has had the same issues with all three systems.
Note: One of my 2600's has the Longhorn AV kit installed and the other two have the AV kits from Electronic Sentimentalities.
Some games stumbled at start-up...but then ran OK. Others won't run at all.
For those of you, who have a similar set-up, please consider trying to run [Fast Food], [Battlezone] and [Moon Patrol] from your Harmony Cart...and reply with your experience.
Hope everyone had a great Christmas!
StephenJ
Edited by StephenJ, Thu Dec 27, 2018 8:34 PM.
#2 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,749 posts
  • Medieval Mayhem
Posted Fri Dec 28, 2018 2:31 PM
Are you running the same game from cart & Harmony, or different games?
The number of scan lines output by the Atari is totally under program control. It should be 262 for an NTSC Atari, but games often output more or less, and are sometimes inconsistent such as sending 260 when showing the game select screen and 262 when showing the game itself. Old CRT TVs can handle an incorrect count, modern displays (and HDMI converters) expect 262 often will not work if the count is something else. The further from 262 the greater the chance it won't work.
http://www.digitpres...s_scanlines.htm
#3 StephenJ OFFLINE
StephenJ
    Moonsweeper
  • 364 posts
Posted Fri Dec 28, 2018 3:57 PM
Hi SpiceWare,
"...Are you running the same game from cart & Harmony..."
The only game that I have in cartridge form, that exhibits a problem with the RetroTINK, is Moon Patrol.
When turned on, the screen flutters and goes blank...until the fire button is pressed. Then it runs OK.
BTW: False alarm on Battlezone. I tried it again and it runs OK.
Thanks,
StephenJ
#4 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,749 posts
  • Medieval Mayhem
Posted Sun Dec 30, 2018 2:59 PM
You can use Stella to check scanline counts for games you're having problems with.  Use Developer Key ALT-L (Linux, Windows) or COMMAND-L (Mac) to Toggle frame stats which will add scanline count to the upper-left corner of the display.
Fast Food only outputs 257 scanlines, 5 too few:
Moon Patrol outputs 256 on the title screen
while it outputs 262 for the game screen, which is why you can see it after starting the game
#5 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Sun Dec 30, 2018 5:06 PM
Yep, these are bugs in the games themselves, and the reason it won't display anyway isn't due to any issue with the Harmony Cart but the apparent inability of the RetroTINK to display a non-standard frame.
I have hacked Fast Food to have the proper number scanlines. Moon Patrol isn't as easy to fix but I am talking a look.
#6 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Sun Dec 30, 2018 5:18 PM
Never mind, Moon Patrol wasn't that hard to fix either.
In either case let me know how these work.
#7 StephenJ OFFLINE
StephenJ
    Moonsweeper
  • 364 posts
Posted Sun Dec 30, 2018 6:30 PM
You just gotta love the AA community.
Many thanks SpiceWare and Batari!!
...and all the best in the New Year,
StephenJ
