whitbyterry Posted December 28, 2018 Share Posted December 28, 2018 I received the portable device for Christmas and tried to insert an SD card into the slot. When I put it in, there's no 'stop' when I insert it like a laptop and no catch/lock like a camera has. In fact, I was able to insert it all the way to the point where it was impossible to get it back out without a small screwdriver to apply some gentle pressure. Is this normal? Is the unit defective? I formatted the card and created a Games folder with bin files from a zip linked here. Regardless of where I insert the card, it isn't recognized. The card is a HC one 4GB which I think might not work. I can order a new older 4GB, non-HD, but they are $20 and seems like a waste if my unit is defective. Any thoughts? Is the insertion process normal for these? Should I just get a non-HC card and I'll likely be fine? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Megadragon15 Posted December 28, 2018 Share Posted December 28, 2018 You are supposed to push it in until it clicks. To get it out, push it in again and it will spring out. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted December 29, 2018 Share Posted December 29, 2018 It only goes all the way in one way. As I recall, it should go in with the "teeth" facing the screen. Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted December 29, 2018 Share Posted December 29, 2018 Insert the card with the contacts facing up. Quote Link to comment Share on other sites More sharing options...
