Atari Lynx II -- What's that smell?
pop smell atari lynx lynx ii lynx 2 power
6 replies to this topic
#1 TechCowboy OFFLINE
TechCowboy
    Space Invader
  • 26 posts
Posted Mon Dec 31, 2018 8:11 PM
I had just done a McWill update and everything was working great.
It ran fine for a few hours and a few on/off cycles, then I couldn't turn the Lynx on.
I assumed the MOSFET has failed, ordered a couple, put it in and then POP, TP18 blew up real good!
Perhaps I didn't purchase the right MOSFET, or just a coincidence?
This is the MOSFET I ordered from Digikey:
NDT2955CT-ND   NDT2955 MOSFET P-CH 60V 2.5A SOT-223-4
Assuming nothing else blew and I have the right part, I've heard there was a zener diode I should be replacing as well, but I don't know which one or it's value.
I, of course, need to replace TP18 -- what part is that?
Thanks in advance to you all.
lynxii
Album: Lynx_II
1 images
0 comments
#2 Stephen Moss OFFLINE
Stephen Moss
  • 1,128 posts
Posted Tue Jan 1, 2019 4:29 AM
Anything labled TP is a test point- a hole/pad on the PCB provided for the convenient measurement of key voltages/signals in the circuit and so cannot blow up. From the image it looks like a transistor, possibly labled Q8, but being at home this week I cannot check as both my Lynx II and circuit diagram are at work.
The MOSFET/Zenner and equivalent replacements have been discussed here many times, a search of the forum should provide the answer you need.
#3 Lynxman OFFLINE
Lynxman
    Moonsweeper
  • 429 posts
Posted Tue Jan 1, 2019 4:48 PM
I hope nothing else damaged...
You should install a 5V Mod to avoid such issues...
#4 necrocia OFFLINE
necrocia
    Moonsweeper
  • 286 posts
Posted Wed Jan 2, 2019 12:00 AM
Are you talking about this? http://atariage.com/...erac-connector/
I tried to look for a definitive guide on how to do a 5V mod, but couldn't find it, can you share please?
#5 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,870 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Wed Jan 2, 2019 12:50 PM
Look like Q8 is what went out. The Diode is directly above where it is labeled as D13 in your pic.
I always advise that before installing the McWill on your Lynx that you always go and replace the parts that come in this kit to be sure the power regulation is good for a long while more:
https://console5.com...power-jack.html
#6 Lynxman OFFLINE
Lynxman
    Moonsweeper
  • 429 posts
Posted Wed Jan 2, 2019 5:46 PM
http://atariage.com/...-regulator-mod/
#7 necrocia OFFLINE
necrocia
    Moonsweeper
  • 286 posts
Posted Fri Jan 4, 2019 6:17 PM
Thanks. There's a lot of discussion on that thread but no final step by step guide on how to do it. Looks like different people took slightly different approaches. I might have to write up a guide at some point after trying it out myself.
Also tagged with one or more of these keywords: pop, smell, atari, lynx, lynx ii, lynx 2, power
