Loading an address with a variable offset
2 replies to this topic
#1 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Tue Jan 8, 2019 1:47 PM
If I want to create a pointer to data in a table with a variable offset into the data, what is the syntax?  Here is what doesn't work:
    lda #<enemy_bitmaps_1,y
    sta EnemyPtr
    lda #>enemy_bitmaps_1,y
    sta EnemyPtr+1
I have confirmed via the Stella debugger that I am loading the correct offset into Y, but it is not pulling the correct data when I try to use the pointer.  What am I doing wrong here?
#2 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,548 posts
  • Medieval Mayhem
Posted Tue Jan 8, 2019 3:00 PM
LDA - Immediate and Absolute,Y are two distinct address modes, they can't be used at the same time.  In a better compiler that would cause a compile time error, or at least a warning, but with dasm the Absolute,Y mode appears to have priority.
I suspect what you're after is covered in step 14 - add animation of my tutorial, though I used Absolute,X instead of Absolute,Y (either will work).
#3 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Tue Jan 8, 2019 5:12 PM
It was indeed!  Thank you muchly.  :-)
