Slow Progress
19 replies to this topic
#1 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Wed Jan 9, 2019 7:59 PM
I bought a Beige TI-99/4A from E-bay for <$30 (incl shipping).
I built the Composite cable adapter, and it didn't work. I figured the machine was just dead. Then I looked at another diagram and realized I was looking at the wrong end of the DIN plug and had the pins transposed. A quick bit of de/re-soldering and I had a picture (woo hoo!). Even better it is a 1981 OS (y'know... in case I find an Atari cartridge at Goodwill).
Now most of the keys don't work. The connection is (like everything in this machine) very clean. I kept hitting the "1" key until it started to work. The same "method" worked on a few other keys. Seems like this is caused by funk on the key contacts. Anybody know a less-complicated fix?
(pictures to follow - once I upload them from my phone).
#2 arcadeshopper OFFLINE
arcadeshopper
  • 4,068 posts
Posted Wed Jan 9, 2019 8:09 PM
depending on which keyboard you have.. if it's a mitsumi you are probably going to have to take it apart and do the "fix"  the instructions on this are in the FAQ https://atariage.com...irst/?p=3791726
#3 LASooner OFFLINE
LASooner
    Moonsweeper
  • 344 posts
Posted Wed Jan 9, 2019 11:58 PM
If any hardware builders are looking for a new projects, we need someone to take on a replacement keyboard like the Amiga guys are getting these days. A drop in keyboard circuit board to replace all the Mitsumi would be super.
#4 FDOS OFFLINE
FDOS
    Chopper Commander
  • 246 posts
Posted Thu Jan 10, 2019 12:15 PM
Just do the USB modification.  Works great.  I have two TI consoles with the F18A and USB, and I use them via a 4 port KVM (VGA/USB) to my wireless keyboard.  Which does not effect joystick operation when I have Caps Lock on, while the TI is selected. Nice :)
#5 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Thu Jan 10, 2019 4:47 PM
Pics!!!!
Start-up
Attached File  20190109_170827.jpg   53.21KB   1 downloads
After pressing any key
Attached File  20190109_170841.jpg   45.96KB   1 downloads
After pressing "1" for TI BASIC. Note, after tapping every key repeatedly, I found very few of them actually worked.
Attached File  20190109_171114.jpg   47.63KB   1 downloads
There is some forced perspective going on in these pics. The TV is actually a lot larger than it looks... it's just a few feet farther away than the 99.
Edited by ironnerd, Thu Jan 10, 2019 4:48 PM.
#6 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,865 posts
  • Technology Samurai
Posted Thu Jan 10, 2019 5:59 PM
How does that meet the requirements of a drop-in keyboard replacement?
#7 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 218 posts
Posted Thu Jan 10, 2019 6:42 PM
One way: JediMatt USB adaptor allows you to "drop in" a USB keyboard. I'm looking at portable USB keyboards that fit into the vacated rectangle.
On the other hand, a from-scratch keyboard PCB wouldn't need the USB adaptor. Any key layout could be translated to the 4A's matrix, using an Arduino Nano (maybe even an ATTiny) plus some lv165a, hct595.
#8 twoodland OFFLINE
twoodland
    Chopper Commander
  • 142 posts
Posted Thu Jan 10, 2019 8:23 PM
If your keyboard is a stackpole switch grid type, you might use Deoxit D5 contact cleaner to clean the contacts (just make sure the keyboard is completely dry before applying power to it.  Also, you could take the corner of a dollar bill and put it between the contacts, press down the switch closing the contacts onto the dollar bill and gently pull the dollar bill out.  A dollar bill is abrasive enough to clean but not too abrasive to damage the contacts.
Attached File  TISPKBBK.JPG   97.61KB   1 downloads
Attached File  TISPKBFT.JPG   138.14KB   1 downloads
Attached File  TISPKBSW.JPG   46.63KB   1 downloads
#9 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Fri Jan 11, 2019 6:05 AM
Thank-you, Twoodland. I guess I have a nice weekend project.
#10 Ksarul OFFLINE
Ksarul
  • 5,028 posts
Posted Fri Jan 11, 2019 7:09 AM
From the side, that looks suspiciously like a Mitsumi keyboard. If it is you really only have two options--perform the delicate repair procedure Arcadeshopper pointed to or replace the keyboard. The good news is that the rest of your machine looks to be operating fine, so that once the keyboard is in order, you'll have a really nice, working console.
#11 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Fri Jan 11, 2019 5:32 PM
'Tis a Mitsumi.
#12 matthew180 OFFLINE
matthew180
  • 2,594 posts
Posted Fri Jan 11, 2019 5:53 PM
Check for cold solder joints too.  In these keyboards the mechanical vibration of pushing a key translates directly to the PCB.
#13 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,495 posts
Posted Fri Jan 11, 2019 9:45 PM
'Tis a Mitsumi.
#14 Ksarul OFFLINE
Ksarul
  • 5,028 posts
Posted Sat Jan 12, 2019 1:25 PM
If you can find a food spare, that will probably be less painful than repairing the Mitsumi, but the process Arcadeshopper pointed to will often fix one, if you don't damage the wrong parts of the keyboard while repairing it. The membrane is a bit fragile. . .
#15 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Sun Jan 13, 2019 2:39 PM
"...will often fix one..."
Meh, what the heck... it was a $30 computer. I'm not out much more than my time if I can't get it working.
Don't think I'll do the same repair as this guy though...
https://www.youtube....h?v=4vWf284tloI
Edited by ironnerd, Sun Jan 13, 2019 2:44 PM.
#16 Charlie_ OFFLINE
Charlie_
  • 2,903 posts
Posted Sun Jan 13, 2019 3:07 PM
Yesterday I purchased a white plastic TI-99/4A at a digitalpress store here in NJ. The keyboard did not work, same as the OP here...
I returned it after reading this thread. I don't have the time to repair it. Plus I have two working metal units.
Do most of the plastic white units have this keyboard problem?
#17 Ksarul OFFLINE
Ksarul
  • 5,028 posts
Posted Sun Jan 13, 2019 5:58 PM
There were at least three different keyboards used with the beige units. Only one of them has the problems. The problem keyboards are relatively easy to identify too, as they have really sharp, squarish key tops. The other variants have a more rounded look to them due to the corners of the keys being a bit more curved. Once you see them side by side, you will never mistake one for the other again.
#18 arcadeshopper OFFLINE
arcadeshopper
  • 4,068 posts
Posted Sun Jan 13, 2019 10:14 PM
Also if you look in the bottom vents the solder points are obvious on the good keyboards and the all brown is also on the mitsumi
Sent from my LG-H872 using Tapatalk
#19 ironnerd OFFLINE
ironnerd
    Space Invader
  • 26 posts
Posted Mon Jan 14, 2019 5:03 PM
Now you guys tell me...
#20 arcadeshopper OFFLINE
arcadeshopper
  • 4,068 posts
Posted Mon Jan 14, 2019 6:11 PM
odds are they have mitsumi's especially if they are the 1983 models..but you should ALWAYS check the vents and see if you see the solder joints or the brown mitsumi board.. both are documented in the FAQ which is pinned at the top of this forum..
