tripletopper Posted January 10, 2019 Share Posted January 10, 2019 Hello, I was wondering. I can hire a joystick builder to wire a joystick. I’m just trying to find out what is the better route. My fight stick his separate wires for each Joystick Direction, button ground, voltage and a miscellaneous "other wire", like what the Xbox 360 needs. and then gets sent into a Brook fight board. (It actually has 11 buttons and 4 directions, it’s easier to go down than up.) Thanks to the fact that the brook stick is easily removable with a DB25, I was wondering if either the Atari 7800 or the 2600 Booster grip is as simple as wiring discrete buttons to pins, meaning a pin representing a direction, button, ground or voltage is straight wired from the DB25 discrete to a pin on the DB9. I know the basic 2600, Astrocade, Master System, and Neo Geo are simple one pin = one function hookups. I understand I could have a straight-wire hookup to do those systems. I understand systems as early Intellivision and Colecovision had "coded" joystick signals, so those are hard without PCB knowledge unless you hack an existing PCB. The 7800 and the 2600 booster grip are two weird beasts. Atari 7800 has buttons that split to 2 pins and one pin that is a combination of 2 buttons. Is that as easy as a simple wiring job with no coding and no PCB, or do you need some sort of "OR circuit" to make the 2600 button work. I don’t know if an Or circuit is as simple as wiring it, or if it needs intelligence. My joystick guy is charging $2 a 2-way pin hookup. With 4 directions, 2 buttons, a ground and a voltage, that should come to $16. That would be cheaper than a Edladdin Genesis->7800 adapter, and I don’t have to split up my shipment between myself for the 7800 and my joystick maker for the Colecovision. But I don’t know if uilding a discrete 7800 adpater would work. Also the 2600 booster grip has digital buttons actuating an analog paddle signal. Is that a simple wiring function too, or does THAT need some circuitry for it to work to convert a joystick signa to a paddle (assuming they are different I hear it’s an analog voltage between zero electricity and the maximum allowed electricity, [i won’t pretend to throw around words I don’t understand] so if it’s as simple as actuating a maximum, it’s just like taking the dimmer switch away from a circuit: it becomes a simple on/off circuit.) I also notice the pins are similar in a 2600 booster grip and a 7800. Can one device work for both? Or is it better to make 2 separate ones. Quote Link to comment Share on other sites More sharing options...
+slx Posted January 11, 2019 Share Posted January 11, 2019 The booster grip seems to use straight wiring according to this: http://arcarc.xmission.com/Web%20Archives/Deathskull%20%28May-2006%29/games/tech/2600cont.html The CX24 of the 7800 is not straight but uses resistors to allow both buttons to be used interchangeably on the 2600 and separately on the 7800: http://atariage.com/forums/topic/255244-diy-atari-7800-stick-guide/ Quote Link to comment Share on other sites More sharing options...
tripletopper Posted January 20, 2019 Author Share Posted January 20, 2019 So my instincts are right. Analog paddles are actuated in an all or nothing manner, so you’re just changing the dimmer dial to an on/off switch. I didn’t know if there was an easy "OR circuit", but it looks too complex where I can’t explain it to my joystick hacker. I’ll just either pad-hack a 7800 controller, or (probably cheaper) pad hack a Genesis controller I was getting pad hacked anyway, and just buy the Genesis->7800 adapter form Edladdin. The cost of a 7800 pad + labor to hook up the 7800 + Genesis > the cost of an Edladdin controller adapter plus a Genesis hack. The Pad-hacked Genesis pad can also be used in a Genesis->INTV adapter from @7800fan, if he actually responds in his Gen->INTV forum. Quote Link to comment Share on other sites More sharing options...
