DPC+ simple custom kernel help needed
17 replies to this topic
#1 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Thu Jan 10, 2019 11:44 PM
I'm trying to make a very simple kernel that only draws playfield, playfieldcolor and backgroundcolor that I can jump to when needed.
I thought it would be very simple and that the playfield, playfieldcolors and backgroundcolors you had set in bB would have all the fetchers and pointers ready to just add for example this before the kernel
     LDA #255
     STA DF6FRACINC
     LDA DF6FRACDATA ; priming read (first value will be read twice)
and this in the kernel to draw your bgcolors
     lda #<DF6FRACDATA
     sta COLUBK
but that didn't work, do you have to set the fetchers or something every frame to?
DF?LOW
DF?HI
DF?FRACLOW
DF?FRACHI
#2 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Fri Jan 11, 2019 12:55 AM
It makes sense that you have to reset the pointer, I guess you do that like this, it works atleast.
     lda #<BKCOLS
     sta DF6FRACLOW
     lda #(>BKCOLS) & $0F
     sta DF6FRACHI
 LDA #128 ;255 resulted in single line, weird, I have DF6FRACINC=255 in the bB loop, is the bB kernel 2 lines?
 STA DF6FRACINC
Edited by Lillapojkenpćön, Fri Jan 11, 2019 1:05 AM.
#3 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Fri Jan 11, 2019 8:07 AM
If someone wants to help me with the playfield that would be awesome.
dffraclow2
     .byte <PF1L
     .byte <PF2L
     .byte <PF1R
     .byte <PF2R
     .byte <PFCOLS
     .byte <NUSIZREFP
     .byte <BKCOLS
     .byte <P1HMP
dffrachi2
     .byte (>PF1L) & $0F
     .byte (>PF2L) & $0F
     .byte (>PF1R) & $0F
     .byte (>PF2R) & $0F
     .byte (>PFCOLS) & $0F
     .byte (>NUSIZREFP) & $0F
     .byte (>BKCOLS) & $0F
     .byte (>P1HMP) & $0F
VerticalBlank:
     ldx #7
setloopfrac2
     lda dffraclow2,x
     sta DF0FRACLOW,x
     lda dffrachi2,x
     sta DF0FRACHI,x
     dex
     bpl setloopfrac2
                LDA #128  ; 255 and 2lk might be better
                STA DF6FRACINC
                STA DF4FRACINC
                LDA DF4FRACDATA ; priming read (first value will be read twice)
                LDA #64 ; 128 and 2lk might be better
                STA DF0FRACINC
                LDA DF0FRACDATA ; priming read (first value will be read twice)
                STA DF1FRACINC
                LDA DF1FRACDATA ; priming read (first value will be read twice)
                STA DF2FRACINC
                LDA DF2FRACDATA ; priming read (first value will be read twice)
                STA DF3FRACINC
                LDA DF3FRACDATA ; priming read (first value will be read twice)
 ;The Kernel is the section of code that draws the screen.
Kernel:
        sta WSYNC       ; Wait for SYNC (halts CPU until end of scanline)
        lda INTIM       ; check the timer
        bne Kernel      ; Branch if its Not Equal to 0
    ; turn on the display
        sta VBLANK
    ; draw the screen
       ; ldx #96        ; for 2lk
        ldx #192        ; Load X with 192
     lda #0
     sta FASTFETCH
KernelLoop:
     lda #<DF6FRACDATA
     sta COLUBK
     lda #<DF0FRACDATA
     sta PF1
     lda #<DF1FRACDATA
     sta PF2
     lda #<DF2FRACDATA
     sta PF1
     lda #<DF3FRACDATA
     sta PF2
     lda #<DF4FRACDATA
     sta COLUPF
        dex             ; DEcrement X by 1
        bne KernelLoop  ; Branch if Not Equal to 0
OverScan:
     ldx #255
     stx FASTFETCH
#4 iesposta OFFLINE
iesposta
  • 3,876 posts
  • Retro-gaming w/my VCS
Posted Fri Jan 11, 2019 9:10 AM
In batari Basic just write code using playfield, playfieldcolor and backgroundcolor.
If using VisualbB uncheck "clean up" or remove temporary files.
bB outputs 2 .asm files you can study, along with .sym and .lst text files.
Lots of bB DPC+ use a 2 line kernel, however the Players are 1 line kernel, playfield is 1 line kernel.
color is every other line change for playfield and background I am not sure if that is due to the 2 line kernel parts or not?
#5 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Fri Jan 11, 2019 10:07 AM
That's what I usually do, but that doesn't help much with the kernel, the kernel has this for playfield
     lda #<DF0FRACDATA
     sta PF1 ; (PF1L)
     lda #<DF1FRACDATA
     sta PF2 ; 31 (PF2L)
     lda #<DF2FRACDATA ;45
     sta PF2 ; 48
    lda #<DF3FRACDATA ;53
     sta PF1 ; 56
While the documentation has this
; then in the kernel read the Fractional Data Fetchers and update the playfield
; LDA DF0FRACDATA
; STA PF0
; LDA PF1FRACDATA
; STA PF1
; ... repeat for Data Fetchers 2-5, putting them in PF2, PF0, PF1 and PF2
It doesn't match, also believe there's some crucial timing to consider when you update playfield, I will try again tomorrow, would just like some tips or something :)
#6 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Fri Jan 11, 2019 12:32 PM
The second assembly, when compiling a file, called bB.asm Has more native code than the first one.
Is this for bB or pure assembly game?
Im not clear what you need to do, but it is probably awesome!
The Titlescreen Kernel is an example of an independent Kernel. Any shared variables restored when returning to bB. It doesnt use data and graphics from the bB code.
In bB when you call drawscreen the compiled code chooses from around 12 canned kernels depending on what has been set and programmed. These canned kernels are include from bBs includes folder.
Study those text files to find the kernels.
#7 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Fri Jan 11, 2019 10:45 PM
It's assembly for bB, my thought was that there are a couple occasions in my game where there's nothing going on, only the playfield and background is being drawn, where I wish I could have text, like when you kill the boss and your points are being counted, would be cool if I could write "bonus points" or something using the players.
It would be absolutely impossible to modify the existing bB kernels to do that, but what if you jumped to a inline assembly custom kernel that does only that? Might work?
#8 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Sat Jan 12, 2019 7:37 AM
It's not perfect but you can jump between the regular and custom kernel with joy0fire and joy1fire
Attached File  custom_kernel.bas   12.92KB   20 downloads
#9 mksmith OFFLINE
mksmith
    Space Invader
  • 39 posts
Posted Sat Jan 12, 2019 7:50 AM
I would love some sort of ability to write to the screen. Change of level, game over messages etc would be awesome!
#10 Karl G OFFLINE
Karl G
    Dragonstomper
  • 655 posts
Posted Sat Jan 12, 2019 8:21 AM
attachicon.gifcustom_kernel.bas
Hitting fire doesn't seem to do anything.
#11 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Sat Jan 12, 2019 8:26 AM
Me too! I will try and look at how it's done in the titlescreen kernel, if RevEng or someone wants to make it happen in two seconds they are more then welcome to :)
Haha good, then it works!
#12 Karl G OFFLINE
Karl G
    Dragonstomper
  • 655 posts
Posted Sat Jan 12, 2019 8:36 AM
How could you tell if it wasn't working, then?   :P
I guess I figured that your custom kernel would do something different!
#13 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Sun Jan 13, 2019 8:04 PM
I tried merging it with your bBsplash Mr. G, do you think there's any chance there's enough time for this in the LogoLoop?
     lda #<DF6FRACDATA
     sta COLUBK
     lda #<DF0FRACDATA ;PF1L
     sta PF1
     lda #<DF1FRACDATA ;PF2L
     sta PF2
     lda #<DF4FRACDATA
     sta COLUPF
     lda #<DF2FRACDATA ;PF1R
     sta PF2
     lda #<DF3FRACDATA ;PF2R
     sta PF1
; Fast Fetch Mode
; Fast Fetch Mode enables the fastest way to read DPC+ registers.  Normal
; reads use LDA Absolute addressing (LDA DF0DATA) which takes 4 cycles to
; process.  Fast Fetch Mode intercepts LDA Immediate addressing (LDA #<DF0DATA)
; which takes only 2 cycles!  Only immediate values < $28 are intercepted
; set Fast Fetch Mode
; LDA #0
; STA FASTFETCH
; then use immediate mode to read the registers, takes just 5 cycles to update
; any TIA register
; LDA #<DF0DATA
; STA GRP0
; when done, turn off Fast Fetch Mode using any non-zero value
; LDA #$FF
; STA FASTFETCH
; NOTE: if you forget to turn off FASTFETCH mode, then code like this will not
;       work as you expect
; LDA #0 ; returns a RANDOM NUMBER, not 0.
; STA COLUPF
FASTFETCH     DS 1    ; $58
Maybe it would even be possible to use DF5FRACDATA and DF7FRACDATA for the first  GRP0 and GRP1 then turn off fastfetch?
I think they will reset to what they usually do when you return to the bB kernel.
Or load the values after the logo has been drawn, and update before on the next scanline?
I'm not gonna get any further then this right now so I hope someone picks up the ball.
Attached File  custom_kernel2.bas   24.18KB   5 downloads
#14 Karl G OFFLINE
Karl G
    Dragonstomper
  • 655 posts
Posted Mon Jan 14, 2019 2:32 PM
My experience with DPC+ and fastfetch is very limited. I guess it would save you 18 cycles due to the loads being 2 cycles instead of 5, and you are trying to add 30. It probably wouldn't be enough, and also the timing matters, too - you aren't going to be able to break-up a 48-pixel routine in the middle by loading the right half of your playfield and have it still work.
#15 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Tue Jan 15, 2019 12:10 AM
Ok, well I can still do exactly what I wanted now thanks to your splashscreen!
Requesting a standalone 96 pixel kernel from Mr. Karl G  :) I would do it but I can't decipher the titlescreen kernel whatsoever!
Ooohh I can picture a nice NES style titlescreen  :thumbsup:
Attached File  custom_kernel3.bas   16.01KB   6 downloads
Attached File  custom_kernel3.bas.bin   32KB   5 downloads
#16 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Tue Jan 15, 2019 7:39 AM
I wanted score and pfscore in my custom kernel to so I'm gosub'ing to the allready existing scorekernel to save space.
Had to modify the DPCplus_kernel slightly so it either returns or returns otherbank depending on what's in temp5
It's very close to working, only the scoredigits aren't showing (or being colored?) until after atleast one bB drawscreen has been called.
Just replace the following line at the very bottom of includes/DPCplus_kernel.asm
     rts
With this..
     lda temp5
     cmp #255
     beq _return_otherbank
     rts
_return_otherbank
     JMP BS_return
and SAVE (just restore it later)
 What is it that I am missing?
 Jump to the custom kernel with joy0fire
Attached File  custom_kernel5.bas   16.87KB   1 downloads
Attached File  custom_kernel5.bas.bin   32KB   4 downloads
Edited by Lillapojkenpćön, Tue Jan 15, 2019 8:12 AM.
#17 Karl G OFFLINE
Karl G
    Dragonstomper
  • 655 posts
Posted Tue Jan 15, 2019 11:07 AM
I don't really want to make other standalone kernels - if something more than a simple single-color 48-pixel splash screen is needed, I suggest using the actual Titlescreen kernel. It's a bit of work, but it's well-documented and worth the effort.
#18 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Tue Jan 15, 2019 1:27 PM
I didn't expect you to  :)  I allready got the 96 pixels working, must be my new add medicine.
