PLATOTerm99 0.1 test release for TI-99/4A
36 replies to this topic
#1 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Tue Jan 15, 2019 4:18 PM
The initial 0.1 version of PLATOTerm99 for TI-99/4A machines has been released for TI RS232 (TMS9902) compatible users. Please test and report back any issues. RELEASED HERE: https://github.com/t...PLATOTERM99-0.1#irataonline #plato #platoterm #ti99 #ti994a
-Thom
#2 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Tue Jan 15, 2019 4:41 PM
What type of interface do we need? Can I dial in on my modem?
***EDIT***
Ahh, I see now. Must be via WiFi.
Edited by Opry99er, Tue Jan 15, 2019 4:44 PM.
#3 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Tue Jan 15, 2019 4:51 PM
***EDIT***
you COULD dial your modem to my bbs then dial out.. .. /go dialout, d16 password is PLATO
#4 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Tue Jan 15, 2019 4:53 PM
Indeed. :) And I likely will
#5 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Tue Jan 15, 2019 4:57 PM
If his program addresses the server directly, however, how would I do that?
I need to run Telco to get to your BBS, but then how would I run his Plato term emulator while Telco was running?
Or am I over-thinking this somehow.....
#6 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Tue Jan 15, 2019 5:08 PM
its a terminal.. just like telco, but it supports the plato protocol.. I'll mess with it when i get home and see what i can do, howerver if you reset your TI, and don't turn off the rs232 it will likely stay online while you load the terminal program..long as you are at the same baud rate and parity it will just pick up where the other left off..
SHOULD be able to just atdt (thekeep no) then login, type /go dialout etc..from platoterm
#7 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Tue Jan 15, 2019 5:10 PM
As an example, I run a Raspberry Pi, running tcpser, which is acting like a virtual modem, attached to a COM port, which I am running on ti994w...
Once I get my real console, it will be attached via a TI RS232 Interface sidecar, via port 1.
The copy of tcpser I am using is here:
http://github.com/tschak909/tcpser
-Thom
#8 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Tue Jan 15, 2019 5:41 PM
Really looking forward to trying this tonight!
#9 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Tue Jan 15, 2019 11:14 PM
tested on real hw.. doesn't seem to see the rs232 port correctly on a TI rs232 card .. fast term works fine to test the modem out first..  If I reset my wifimodem I see the text coming from it (with dropped characters..) at 1200 baud 8n1.. when i type in plato it doesn't seem to get to the modem.. likely emulation works a little differently than real hw.
#10 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Tue Jan 15, 2019 11:34 PM
urgh :(
-Thom
#11 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Tue Jan 15, 2019 11:37 PM
the initial comms parameters:
  rs232_setcontrol(RS232_CARD,RS232_9902A,RS232_CTRL_STOP_1|RS232_CTRL_NO_PARITY|RS232_CTRL_8_BIT);
  rs232_setbps(RS232_CARD,RS232_9902A,RS232_BPS_1200);
Tursi's code does not do any flow control...
-Thom
#12 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Wed Jan 16, 2019 12:30 AM
-Thom
shouldn't need it at 1200 baud..   you should be able to get up to about 2400 baud without flow control and even 19200 (TIMXT)  and with better comm routines up to 38400 without it.. (HDX does that)
#13 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Wed Jan 16, 2019 12:36 AM
Yup, this was just to start, I picked a safe value.
I have added a baud rate toggle to the most recent build.
This brings to question, how to best handle "settings" ...
Specifically:
* Toggle Baud Rate (300-38400 baud) (FCTN-0 in TTY mode, can't be done while in PLATO mode)
* Toggle PLATO/TTY mode (need to find an out of the way key that one won't trip over)
* Hang Up. (FCTN-9 in TTY mode, can't be done while in PLATO mode)
PLATO and TTY mode is an emergency switch of sorts, if for some reason it has gotten out of sync (normally, the host switches into PLATO mode) this could happen if for example, you launch platoterm while already connected to the host.
I am currently only allowing baud rate switching and Hang up in TTY mode.
I am trying to wrangle together some hardware, so I can do some testing here, because it's working just fine under ti994w. sigh.
-Thom
#14 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jan 16, 2019 1:37 AM
If PlatoTerm is able to buffer packets of incoming data before processing it, the burst speed increase could be substantial.  All depends how things are coded.  (re: 38400, TIMXT manages it by tricking the ROM interrupt service routine into bypassing the VDP handling in favor of the user interrupt to service the RS232, whereas HDX uses direct RS232 polling on a more controlled packet basis)
#15 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Wed Jan 16, 2019 10:21 AM
@insanemultitasker the ShowPLATO() routine accepts a buffer, and a length, so it is possible. I just need better RS232 routines.
I also need, very much need, routines to drive the 16550 on the NanoPEB v2.. seriously, who the @#(%@# puts an unsupported (in the scope of TI 99/4A, I am familiar with the 16550) UART on a peripheral and doesn't provide example code to drive it?!
-Thom
Edited by tschak909, Wed Jan 16, 2019 10:21 AM.
#16 jedimatt42 OFFLINE
jedimatt42
  • 1,850 posts
Posted Wed Jan 16, 2019 11:18 AM
Hobbyists, building stuff for themselves and sharing it with the community.
-M@
#17 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Wed Jan 16, 2019 11:34 AM
Yes, but the serial port is pretty much useless at the moment.
Is there an RS232 DSR that can be used on the card?
-Thom
Edited by tschak909, Wed Jan 16, 2019 11:37 AM.
#18 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Wed Jan 16, 2019 11:38 AM
As mentioned in another thread, I think... Fred Kaal produced a program called CFHDXS1 which was designed to allow access to that serial port.  I use his program regularly for transferring files to/from the TI.
The source may be out there, and (if not) he might be willing to share it with you.
#19 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Wed Jan 16, 2019 11:41 AM
Yeah, I've pinged him to see what can be done. I will support the NanoPEB v2, as it is one of the few extant RS232 solutions out there... the TIPI version is also coming very soon (in the next day or two)
-Thom
#20 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Wed Jan 16, 2019 1:09 PM
-Thom
sure is.
#21 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Sat Feb 9, 2019 12:52 AM
I have been steadily implementing PLATOTERM. While there are still issues with the RS232 version (it doesn't seem to work outside of TI994W), the TIPI version has been working quite well, and is currently reachable via entering PI.HTTP://TI99.IRATA.ONLINE/PLATOas a filename to CALL TIPI() (or other E/A5 loader), or by using one of your URIx shortcuts (e.g. URI1.PLATO).
I have just implemented basic color support, which adds color decoding for the 8 basic PLATO colors:
* Black
* White
* Red
* Green
* Blue
* Cyan
* Magenta
* Yellow
all on black background.
Attached File  01-notes.PNG   60.28KB   1 downloads
Attached File  02-notes2.PNG   55.87KB   1 downloads
Attached File  03-avatar-title.PNG   89.29KB   1 downloads
Attached File  04-avatar-ingame.PNG   53.92KB   1 downloads
Attached File  05-moria-title.PNG   77.6KB   1 downloads
Due to the quirks of the TMS9918 GRAPHICS II mode, I am not able to successfully add support for background color support. If I can work out a reliable integer-only way to scale down to 0.008 (to scale RGB values down), I will add support for mapping all of the other possible colors to the closest VDP match (again, no background colors, because then any color clash will become _VERY_ apparent.)
Stuff I am still working on:
* Character Set loading (compiler bugs in relation to unsigned char data types are causing the charset loading code to not work 100% correctly, am trying to work around it)
* Keyboard mapping (This is _HARD_... I still have a suggested mapping from arcadeshopper to try and work through), I really want to get this to be as least awkward as possible....
* Preferences (save baud rate, possibly phone book and maybe color/mono toggles)
* Get RS232 working on real hardware.
Once these are knocked out, I will consider the TI99 version of PLATOTerm feature complete.
-Thom
#22 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Sat Feb 9, 2019 2:42 AM
The RS232 support is the biggie... I'm itching to log on with my real hardware!
#23 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Sat Feb 9, 2019 10:25 AM
I need help to debug the routines. I have posted a thread in the tech thread to try and help get to the bottom of this.
Also, @Opry99er, it really is worth it to put together a TIPI. I am using it to do real hardware testing, and it works fantastically. :)
-Thom
#24 Opry99er ONLINE
Opry99er
  • 10,587 posts
Posted Sat Feb 9, 2019 1:05 PM
You know, I know what you're saying makes perfect sense... I know the TIPI is awesome, and it is revolutionary and it changes the way you "TI" by doing all kinds of stuff way faster and more efficiently.
I have to be honest though... I don't know if I want that kind of convenience. Sounds stupid, I know.... but if I had TIPI, I likely wouldn't have spent 2 hours last night taking a disk controller card apart to swap out EPROMs.... I likely wouldn't be making serial transfer videos or focusing on the best way to catalog floppies to a parallel printer.... These are the things I love to do... and I fear that my TI time would shift to CHATTI and playing 2P games on the TIPI server.... I know there's an amazing new world out there, I just don't know if I'm ready for it.
And maybe I'm completely wrong.... but I am just not ready to go there yet. Too much legacy stuff still to do before I need a new experience. :D
#25 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Sun Feb 10, 2019 10:33 PM
Meanwhile, a mouse attached to a #RaspberryPi attached to a #tipi which allows a #ti994a to use a mouse under #platoterm to select items on #irataonline. #plato 9899509d425ceb8e09241c014624e1d5.jpg
Sent from my SM-G920F using Tapatalk
