Black screen, no beep with boyfriend's TI
81 replies to this topic
#26 retiredqwest OFFLINE
retiredqwest
    Space Invader
  • 11 posts
Posted Tue Jan 22, 2019 8:43 PM
There's something wrong with the TI itself. Great. I'll be in town, tomorrow, and I'll be passing by Walmart, so I can pick up a balun of the type you mentioned, if they have one. If not, there's a Lowes next door, so we can try that. Fortunately, the TV does have a coaxil port, just don't know which setting on the thing we'd need to put it on to test it out (probably cable).
Good Luck on finding a balun locally..... As far as the input setting on the TV it probably says Antenna, Cable, or TV, etc. On the Modulator set that to modulator and the channel to 3 or 4. You'll also have to set the TV to channel to 3 or 4.
If you already knew this... just thought I'd cover it anyway.
#27 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 8:16 AM
Ours say TV, so...we'll just have to see.
#28 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 4:50 PM
Okay, we found an old analog TV, and a balun to plug it in. Tried it with both cables, got black screen, no sound. We're at a loss, now, as to what's wrong,
#29 AwkwardPotato OFFLINE
AwkwardPotato
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 5:25 PM
The one time I've ever had a black screen and no sound (as opposed to the normal cacophony) was due to a power supply issue (the internal PSU, not the transformer). It was a pretty easy fix: the contacts in the switch were oxidized and needed to be sanded. When/if you're able to open the computer, check the voltages from the power supply. They're labeled on the board silkscreen.
#30 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 5:39 PM
That's possible; the light comes on red on the TI, but the light on the RF box doesn't come on when it's on and working, so...
#31 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 7:43 PM
We did get a cheap multimeter that we can use to test the voltage, so that should be no problem. I'll see if I can talk my boyfriend into getting to it tomorrow.
#32 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Jan 23, 2019 8:09 PM
https://translate.go...ecomputerti994a
I found this French link to a TI-99 site that seems to have schematics for the 4A, but I dunno if that's different from the American ones. Anyone familiar with it? It seems to have what we need to test out the various parts of it.
#33 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Thu Jan 24, 2019 7:04 AM
That is Fabrice's site, he is a regular on these forums and a quite brilliant man. His schematics should be spot on.
#34 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 12:07 PM
https://imgur.com/a/xdSdGXY
Here's what the power board looks like, right now. We dunno if it's damaged or not. Thoughts?
#35 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Thu Jan 24, 2019 1:04 PM
Look at post 29 from AwkwardPotato.
#36 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 1:49 PM
We don't know how to test the voltage, sadly, but we may have found something; when trying to clean the back of the circuit board, we found that one of the traces right near where the switch is (right next to where the red line connects to the circuit board) is corroded to almost nothing. We're thinking that's the issue, but we don't have the tools with us to get it fixed. We may have to take it down to my boyfriend's dad and have him reconnect it with some solder or something.
Edited by xabin, Thu Jan 24, 2019 2:13 PM.
#37 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Thu Jan 24, 2019 3:37 PM
He would be able to test the voltages then wouldn't he?
#38 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 3:41 PM
Yeah, but he lives about a half-hour away from us. Right now, we are stuck with no way of proceeding until we get someone more knowledgeable with electronics to help out.
Also, RickyDean, please don't treat us like idiots; we're trying our hardest to get this fixed, but we have no real clue what we're doing, besides turning it on to see what works, and cleaning the boards of corrosion.
Edited by xabin, Thu Jan 24, 2019 3:42 PM.
#39 arcadeshopper ONLINE
arcadeshopper
  • 4,286 posts
Posted Thu Jan 24, 2019 3:45 PM
I have working power supply boards at arcadeshopper.com
Greg
#40 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 3:48 PM
Greg
Thanks. We're going to try and see if we can't fix the one we have, but if not, we'll look into getting one from your store.
#41 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Thu Jan 24, 2019 3:59 PM
I am so sorry I came across like that, I am at work and peer though here from time to time. Please forgive me if I offended you, I definitely don't believe you are idiots, sorry.
#42 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 4:02 PM
It's fine, we're just learning about this.
After cleaning the power board, we did notice two changes: the light, when the power is off but not unplugged, will still be on but dim, and when it is on, we get a more fuzzy signal than pure black, with the fuzz being reddish in color.
#43 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Thu Jan 24, 2019 6:05 PM
I didn't see the reply as offensive. Perhaps it's the vacuum of text-based-communication that sometimes causes confusion.
To the OP--- it sounds like you've got some stuff fried in there. We used to have people around who would take your computer and fix it up... but I don't know of anyone offering console repair services right now. I know this particular one is special to you guys, but as a consideration, these computers are usually less than $40 on eBay. Might be worth buying a good one and parting it out to fix your boyfriend's... or perhaps put his on display and use the second machine.
That is--if you are unsuccessful in your restoration efforts.
Just food for thought.
#44 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 6:28 PM
That is a possibility. We'll just have to see.
#45 AwkwardPotato OFFLINE
AwkwardPotato
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 8:23 PM
The PSU is in pretty rough shape but I wouldn't write it off as unrepairable. If the LED is on when the computer is off but plugged in, I'd definitely assume a switch issue since the anode of the diode is connected directly to the switch (and it's not surprising given the condition of the surrounding area). The corroded traces can be patched with wire. As others have stated already though, a new PSU isn't too expensive if you can't get that one fixed.
Edited by AwkwardPotato, Thu Jan 24, 2019 8:24 PM.
#46 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Thu Jan 24, 2019 9:02 PM
We fixed that problem, while I was testing out how to use the multimeter to read the circuits; there was still a lot of residue on the PSU from where we scrubbed it, so another dry scrubbing took care of that. But yeah, with near no knowledge of how to diagnose let alone fix this, we're going to wait until we can get back with my boyfriend's dad and see what he can do with it. If he can't fix it, we may have to buy a new PSU, as you guys suggested.
Edited by xabin, Thu Jan 24, 2019 9:05 PM.
#47 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Tue Mar 12, 2019 4:01 PM
We managed to find this item, here, that we think will work, but we're tight on money, right now. I'm hoping I can get the money to buy it, by the end of the month, if it hasn't been sold out, by then.  https://www.ebay.com...353.m1438.l2649
#48 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Wed Mar 13, 2019 5:28 PM
That will work--just make sure your board has the four prong white connector (at the edge of the board next to the end of the huge black capacitor). Some boards have a short cable with a connector there instead. The boards are electrically compatible, but you'd need to build an adapter to connect one that doesn't match--and the parts for the connectors on that adapter cable are difficult (but not impossible) to find.
#49 xabin OFFLINE
xabin
    Star Raider
  • 61 posts
Posted Wed Mar 13, 2019 6:08 PM
I'm pretty sure it does have that, it's been a little while since we cracked it open to see, but I'm pretty sure I remember it having that.
A funny little anecdote from today: my boyfriend and I went to one of our local used game shops, and noticed that they had an Atari 800 computer. So, I asked them how far back of computer tech they are able to sell and fix (they do fixes, too). When we mentioned that we had a TI-99, one of the store owners said his dad had one, and they'll take a look at it, once we get the power board for it.
#50 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Wed Mar 13, 2019 6:40 PM
That is really good news!
