adamh9700 Posted January 17, 2019 Share Posted January 17, 2019 I recently purchased a Commodore 64, with a monitor and drive. The seller told me everything works, but it wouldn't work for me. When it's all plugged in and turned on, the screen just stays grey. Shows nothing, has no audio. All the chips are secure and everything is soldered properly. Can't understand why it won't work. Any advice? Quote Link to comment Share on other sites More sharing options...
adamh9700 Posted January 17, 2019 Author Share Posted January 17, 2019 Photos of the machine. 1 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 17, 2019 Share Posted January 17, 2019 What are the voltage readings from the power brick? Quote Link to comment Share on other sites More sharing options...
carlsson Posted January 17, 2019 Share Posted January 17, 2019 That monitor has two inputs: one on the back side for luma + chroma (more or less S-video) and one on the front for composite. Both inputs have their own mono audio. You probably have a toggle button on the front panel or in the back to select input source. Depending on whether your cable has two or three RCA connectors, use the matching input and try to toggle it. Quote Link to comment Share on other sites More sharing options...
