Using the RS232 DSR
17 replies to this topic
#1 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Thu Jan 17, 2019 12:27 PM
I have some questions,
Apparently the NanoPEB v2 uses a 16550 for its UART, which means the 9902 routines will not work, understandable...
but the RS232 devices have a DSR...
How can i use this from TI GCC?
If I use this, how bad is the overhead? Will this impact overall performance? Understanding on this subject seems a bit thin, so I really need input. I am trying to make PLATOTerm work on as many TI systems as possible (even possibly going as far as rewriting it in GPL so it can run on unexpanded 16K consoles, but I digress...)
thoughts?
-Thom
#2 FarmerPotato ONLINE
FarmerPotato
    Moonsweeper
  • 257 posts
Posted Thu Jan 17, 2019 2:35 PM
thoughts?
-Thom
I am not up to speed with TI GCC yet (I only followed it for the shift left / shift right bug fix, that bit you hard too). Access to the DSR ROM is a DSRLNK call with a PAB structure.
Essentially the code can be the same as disk access via DSRLNK, just with "RS232.BA=2400.DA=8.PA=N" instead of "DSK1.SOMEFILE". Other than that, read/write flags and record parameters work according to TI's standard DSR behavior. Which was the good side of the whole DSR specification.
But calling the DSR  is going to get you only so far. A bunch of us (myself included) started BBS software using BASIC to call the DSR and as soon as possible went to direct assembly access to the 9902 for character i.o.
On the input side, a DSR call will block, waiting for N characters or a carriage return, then miss chars between calls. The output direction should be ok.
(In my opinion, TI fixed all the problems with their DSR spec in the 1983 HexBus RS232 peripheral and it was usable from Basic. I found it quite versatile on the CC-40 Enhanced Basic with just OPEN, LINPUT and PRINT and I guess we would have seen some kid write a whole BBS in Extended Basic II on the 99/8, if TI had not killed it.)
I am game for locating the 16550 character i/o routines in the NanoPEB ROM, if Fred Kaal did not already reverse engineer them.
#3 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 816 posts
Posted Thu Jan 17, 2019 3:07 PM
A quick question or two as this was the first time I heard anything used the 16550 UART on the TI.
1. Is V2 still available for purchase new, or just Ebay resellers?
2. Who made it and wrote the DSR?
3. Are there many in existence?
4. Was there any terminal emulator software written for it or was it mainly for printer interface?
5. Is the V1 still available?
Trying to understand the history as this was not a device I had followed.
Beery
#4 arcadeshopper ONLINE
arcadeshopper
  • 4,178 posts
Posted Thu Jan 17, 2019 3:18 PM
Beery
1- no he stopped making them as they were incompatible, if you have one you are one of the few
2- jamie, dude that made the nanopeb/cf7
3- eh.. that's a question for him.. i can ask him
4- CFHDXS is the only program that I know of that works with it (Fred Kaal)
5- the v1 is being sold.. i have 4 on arcadeshopper available now..
If it were me, I'd ignore the v2.. there's just not enough to bother. 9902 code for the TI/cc/myarc/other rs232 cards should work fine with all of them with the exception of the nanopeb which requires enabling the port before it will work..see tim
Greg
#5 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Thu Jan 17, 2019 3:25 PM
How are you supposed to enable the port?
-Thom
#6 arcadeshopper ONLINE
arcadeshopper
  • 4,178 posts
Posted Thu Jan 17, 2019 3:27 PM
-Thom
Tim discusses this in the TIMXT thread but I assume accessing the DSR and enabling it.. even if you are reading it directly
Greg
#7 FarmerPotato ONLINE
FarmerPotato
    Moonsweeper
  • 257 posts
Posted Thu Jan 17, 2019 3:29 PM
See:
-Thom
    LI R12,>1300
    SBO 0 page in the dsr rom
* example. do your port 1 serial stuff now as usual
    LI R12,>1340
    TB  3
    LI R12,>1300
    SBZ 0 page out the dsr rom
It is still >1300 right?
Other points from that thread summarized:
The nanoPEB v1 (9902) addresses the serial port as “RS232”, “RS232/1” and “SIO”.  For some reason Jaime left out the “SIO” reference in some (all?) of the recent v1 releases.  The nanoPEB v2 (16550) addresses the serial port as “COM1”, with none of the other monikers.
...lee
v1 with a 9902: requires the DSR to be paged in during RS232 operations by setting bit 0 at >1300. TI RS232 doesn't need it.
v2 with a 16550: these only have a COM device in the DSR.
I agree with Greg - unless you only have the v2 right now... just ignore them. I think I have a v2.
Edited by FarmerPotato, Thu Jan 17, 2019 3:30 PM.
#8 arcadeshopper ONLINE
arcadeshopper
  • 4,178 posts
Posted Thu Jan 17, 2019 3:31 PM
See:
    LI R12,>1300
    LI R12,>1340
    TB  3
    LI R12,>1300
it says on your ti colorbar screen.. nanopeb Vx
#9 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Thu Jan 17, 2019 3:33 PM
// RS232 code for the TI-99/4A by Tursi
// You can copy this file and use it at will ;)
#include "rs232.h"
// turns off the card and the card LED
void rs232raw_activateCard(int card) {
    __asm__ (
        "mov %0,r12\n\tsbo 0\n\rsbo 7" : : "r"(card) : "r12"
-Thom
#10 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Thu Jan 17, 2019 6:05 PM
#include "rs232.h"
    __asm__ (
-Thom
The comment is misleading; this code is for enabling/activating the RS232 port.  Replace SBO with SBZ to disable/deactivate the card.
For the nanopeb you MUST enable the card before accessing it.  Be sure you are not using a routine that turns the card off after use, which may lull you into thinking the card is on when it really isn't.  For simplicity, just assume that the other RS232 cards also require you to enable them, and you'll be good to go.
Edit: After turning on the card, read the byte at 0x4000.  It should be 0xAA when the card is on.  this will at least tell you if the routine to enable the card is working as expected.  Sometimes it is the simple things that trip us up in CRU land.
Edited by InsaneMultitasker, Thu Jan 17, 2019 6:44 PM.
#11 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Thu Jan 17, 2019 8:14 PM
@insanemultitasker - do the rs232raw_ routines here, look okay?
https://github.com/tursilion/libti99
-Thom
#12 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Thu Jan 17, 2019 8:51 PM
Sorry, I don't have the bandwidth to look through all that code.  If you share all of the specific routines/function names you are calling, I or some of the others here can probably double-check the routines for the right activation sequence.   That said, if you call the activatecard routine before your read/write calls and deactivate after, seems to me you'd probably have success...
#13 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Thu Jan 17, 2019 9:28 PM
ok, just wanted to make sure.
Does anyone have a TI BASIC program that I can type in to quickly get a terminal to test my RS232 sidecar?
-Thom
#14 FarmerPotato ONLINE
FarmerPotato
    Moonsweeper
  • 257 posts
Posted Fri Jan 18, 2019 12:12 AM
10 OPEN #1:"RS232.BA=2400.PA=N.DA=8",UPDATE
20 INPUT #1:A$
30 NL$=CHR$(13)&CHR$(10)
40 PRINT #1:"HELLO SAILOR"&NL$
50 CLOSE #1
eliminate 20 if its not getting anywhere and put in a 50 GOTO 40
or try
10 OPEN #1:"RS232.BA=2400.PA=N.DA=8",UPDATE,DISPLAY,VARIABLE 1
This is from memory, I syntax checked it on my NanoPEB v1, but I can't find a DB9 serial cable.
You can substitute your baud rate in BA=2400 but I figure why not start slow.
Likewise PA=E.DA=7 would be 7 bits even parity . The TI RS232 checks two letters so you can write
10 OPEN #1:"RS232.BAUDRATE=2400.PARITY=N.DATABITS=8",UPDATE,DISPLAY,VARIABLE 1
but nobody does that.
Just for fun
10 OPEN #1:"RS232.BANANA=2400.PARTY=N.DANCE=8",UPDATE
#15 tschak909 OFFLINE
tschak909
  • 3,088 posts
Posted Fri Jan 18, 2019 12:31 AM
ok good, seems to work :) too bad you can't check if there is something in the buffer via the standard I/O routines..would make it easy to write a dirt simple terminal program"
-Thom
#16 FarmerPotato ONLINE
FarmerPotato
    Moonsweeper
  • 257 posts
Posted Fri Jan 18, 2019 12:51 AM
FYI, to access the other port, change RS232 to RS232/2.
I checked my (1 year old) nanoPEB v1 and found these devices in the DSR ROM (devices on same line are aliases)
RS232, RS232/1
RS232/2
PIO,  PIO/1
PIO/2
RS232/3
nanoPEB dsr
4000 aa01
4002 0000
4004 4010 power up list
4006 0000
4008 4016 dsr list
400a 0000
400c 406c interrupt
* power up header
4010 0000
4012 40f2
4014 0000
* dsr headers
4016 4020 link to next
4018 4164 address
401a 0552 name: 'RS232'
401c 5332
401e 3332
4020 402c link to next
4022 4164 address
4024 0752 name: 'RS232/1'
4026 5332
4028 3332
402a 2f31
402c 4038 link to next
402e 416a address
4030 0752 name: 'RS232/2'
4032 5332
4034 3332
4036 2f32
4038 4040 link to next
403a 4154 address
403c 0350 name: 'PIO'
403e 494f
4040 404a link to next
4042 4154 address
4044 0550 name: 'PIO/1'
4046 494f
4048 2f31
404a 4054
404c 415a
404e 0550 name: 'PIO/2'
4050 494f
4052 2f32
4054 4060
4056 4176
4058 0752 name: 'RS232/3'
405a 5332
405c 3332
405e 2f33
#17 F.G. Kaal OFFLINE
F.G. Kaal
    Space Invader
  • 46 posts
Posted Tue Feb 12, 2019 11:56 AM
No sorry, I don't own a NanoPeb V2, I only have a V1. I have used a 16550 for one of my early DIY HDX devices though. If somebody has a nanoPeb ROM dump I can have a look.
Fred ;-)
#18 arcadeshopper ONLINE
arcadeshopper
  • 4,178 posts
Posted Tue Feb 12, 2019 12:02 PM
I wonder if Custodio just patched your code himself then.
Greg
