The Persistent RAM Cartridge
9 replies to this topic
#1 Nezgar ONLINE
Nezgar
  • 1,822 posts
Posted Sun Jan 20, 2019 10:05 PM
I have a gem here readers may be interested in - The "Persistent RAM" cartridge by Intra-Tech Computer Products. There appears to be literally no information about it online. Only a single entry on AtariMania with a picture and no other information. Probably considered 'Rarity 10'. :grin:  There is only two mentions of it on all of the AtariAge forums, in cart lists with no information, and 'no ROM dump' - which I thought was funny (since it's RAM).
It operates passively in the "RAM" mode, and you can load up any standard cartridge based code into the 8K or 16K address space, and flipping the switch to the "ROM" position 'locks it in' to static battery-backed RAM and then operates as an 8K or 16K ROM cartridge.  IE - Load the 8K Track & Field, or 16K Pitfall II, flip it to ROM, and when you turn the computer off, and back on again, and instantly you're back in the game as if it is a real ROM cart.
I can see this would have been invaluable for a software developer working on a cartridge title! As long as there is a valid Cart init/entry point intact, it would work. Most XEX games that originated from Cart dumps that leave the original code in the $A000-$BFFF (8K) or $8000-$BFFF (16K) range should work. XEX loaders often have extra initialization code placed elsewhere in RAM, that obviously gets discarded.
I used this as a kid to load games off of tape or disk, and then keep it as a 'virtual cartridge' for instant load the next time. It was neat to be able to change up which 1 game was on it.
The original battery was a 3V lithium cell soldered directly to the PCB, but I replaced it with a ginormous CR123A battery ages ago and attached it externally with hot glue which was long since dead. I just replaced it with a new CR2032 cell holder recently after ordering 4 different types to see what would fit inside the cart shell, since I really didn't want to solder a battery directly to the PCB, which I think was the original configuration... well I got one to fit, and confirmed it still works!
The PCB appears to consists of just 2 8K SRAM chips, and some simple logic chips, a diode to protect against reverse battery polarity, and a capacitor. The solder work was originally really messy, and looked like a lot of old (acid based?) flux was left, indicating quick work. I spent an evening cleaning it all up with isopropyl alcohol, and reflowing solder. After first replacing the battery, I did have some strange issues with the computer not booting up occasionally, but that all seems to have cleared up after time, maybe from corrupt RAM in the cartridge memory space.
I've taken some pictures of the internals as well, lifting up my battery holder so all of the PCB is visible.
My dad who acquired it originally back in the day thinks it was created by a local hardware guru in the Vancouver, BC (Canada) area he knew, but pretty hard to confirm nowadays... may be the same guy that created clone Happy PCB's he had some of, one of which I still have.
I tested a bunch of XEX titles on it last night, there's a lot of stuff that doesn't work (Probably not originated from a cartridge release), but here is a small list of ones I found that do work:
8K:
  • Atari Assembler Editor
  • Atari PILOT
  • Atari Centipede 81 or 82
  • Demon Attack
  • Activision MegaMania
16K
  • Atari Centipede
  • Activision Decathlon
  • Defender
  • Diamond Mine
  • Atari Dig Dug
  • Donkey Kong Jr
  • Atari Football
  • Matterhorn
  • Miner 2049er
  • Ms Pac Man
Maybe someone with experience in PCB design would be interested in replicating it. Maybe others would be interested in acquiring those replicas. Looks like only a few pretty cheap components.
Curious to hear if anyone else out there knows any additional history about this cart, and thoughts on it's workings / design!
Cheers,
Ryan
#2 Tinman OFFLINE
Tinman
    Moonsweeper
  • 258 posts
Posted Sun Jan 20, 2019 10:10 PM
Neat!
#3 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Mon Jan 21, 2019 12:48 AM
Thanks for sharing, and the pics.
It's listed on Pitfall Jones' site, and you can see a picture by click the link for it.
No information there though. He really just wanted to make record of as many
carts as possible. A lot of the pictures on his site were obtained from members
here on AtariAge. So it's quite possible the picture original appeared in the
thread he started here, asking for pictures of carts. I'm not sure if there might
be information there or not.
I could find it, but I gotta sleep now... Zzzz...
#4 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Mon Jan 21, 2019 1:08 AM
OK, one more bit of information here: AA member AtariGeezer mentions having one. Maybe he has some info to share about it.
[Edit: That was back in 2016, posted here -> Rarest A8 Carts (Post #25)]
Edited by MrFish, Mon Jan 21, 2019 1:11 AM.
#5 Wrathchild OFFLINE
Wrathchild
  • 2,188 posts
Posted Mon Jan 21, 2019 5:56 AM
The S/XEGS RAMCART 128KB by C.P.U. seems an evolution of such a device
#6 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,181 posts
Posted Mon Jan 21, 2019 8:00 AM
It looks to me like The!Cart supersedes persistent Ram cart and Ramcart these days...
#7 Nezgar ONLINE
Nezgar
  • 1,822 posts
Posted Mon Jan 21, 2019 9:41 AM
Interesting read! I never knew about this one. More complicated, but the pictures don't look like that much more component wise.
Haha, I agree -- I was not trying to imply that this could compete in any way to a modern flash cart ;-)
But for a fun 8K or 16K novelty... 2x6264 static rams, 74LS04N, 2 switches, and a 3V lithium cell are pretty cheap common components available today.
#8 Nezgar ONLINE
Nezgar
  • 1,822 posts
Posted Mon Jan 21, 2019 9:54 AM
supposedly AtariMax uses the exact same Solakian type mold shells:
http://atariage.com/...info/?p=2964166
(if new ones were to be made)
#9 E474 OFFLINE
E474
    Chopper Commander
  • 211 posts
Posted Mon Jan 21, 2019 10:04 AM
Hi,
   The S/XEGS RAMCART 128KB looks like a fun project, although it isn't as highly specced as alternatives such as The Cart!. etc., it had a build cost of 8 euros at the time, so I wonder what it would cost now to produce?
#10 E474 OFFLINE
E474
    Chopper Commander
  • 211 posts
Posted Mon Jan 21, 2019 10:36 AM
Hi,
  Could the S/XEGS Ramcart 128KB be used to hold a version of SpartaDOS X, and would it be difficult to up the memory to say, 256KB, and have the cartridge act as a writable disk/file system which also holds SpartaDOS X?
