corrupt graphics, odd flicker
8 replies to this topic
#1 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,627 posts
  • Medieval Mayhem
Posted Tue Jan 22, 2019 2:18 PM
After seeing the status update I decided to start in on the HSC.  Yesterday it did this but a power cycle cleared it up so I played a few rounds and submitted a score.
It's worse today and won't go away.  There's even a flicker in the blue background of the Select Game Option screen. Any suggestions?
Attached File  ColecoFlicker.m4v.zip   2.57MB   10 downloads
#2 Ikrananka ONLINE
Ikrananka
  • 2,946 posts
Posted Tue Jan 22, 2019 4:44 PM
Graphical glitches like this are almost always down to the power switch needing overhauled or one (or more) of the video RAM chips going/gone bad.  How are you with a soldering iron?
#3 Ikrananka ONLINE
Ikrananka
  • 2,946 posts
Posted Tue Jan 22, 2019 4:45 PM
Have you tried a different power supply?
#4 Kiwi OFFLINE
Kiwi
  • 1,658 posts
Posted Tue Jan 22, 2019 5:14 PM
My usual suggestions is to make sure that the power plug is plugged in firmly.  That power cord, keep other cords off of it. The VDP and the VRAM needed good 12 volt, and the VRAM needed good 5+ and 5- volt.  Power switch, slide it completely.  It also another bottleneck in term of power since it wears off and get dirty.  Replacing the slide switch with some else should decrease or eliminate power problems.
I brought the Canadian Power Supply since I didn't want to keep using my flakey USA and end up frying my awesome Colecovision.  So that fixed most of my power problem.  I haven't change the switch so I should do that.
#5 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,627 posts
  • Medieval Mayhem
Posted Tue Jan 22, 2019 5:51 PM
Thanks all!
Power plug was firmly plugged in - first thing I checked.
I moved the power switch on/off a bunch and that seems to have cleared up the problem, so seems likely the switch is dirty and needs to be overhauled. Found this PDF on how to do it.  My soldering skills are so-so, but should be good enough to tackle this.  I think I have some DeOxit, need to track it down.  Doubt I have dielectric grease, so will need to pick up some of that.
#6 Ikrananka ONLINE
Ikrananka
  • 2,946 posts
Posted Tue Jan 22, 2019 5:55 PM
That's the excellent pdf guide I followed with one of my CVs and haven't had a problem since.
Edited by Ikrananka, Tue Jan 22, 2019 5:55 PM.
#7 Kiwi OFFLINE
Kiwi
  • 1,658 posts
Posted Tue Jan 22, 2019 6:10 PM
Awesome! That should fix your power problem for good! Enjoy your working Colecovision. I do produce homebrew games for that system.
#8 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,627 posts
  • Medieval Mayhem
Posted Wed Jan 23, 2019 9:40 AM
I've had the Coleco for quite some time, but don't often play on it.  I do have a few homebrews for it - the smooth scrolling in Rally-X impressed me.
#9 Pixelboy OFFLINE
Pixelboy
  • 8,161 posts
Posted Wed Jan 23, 2019 11:46 AM
If that impressed you, CollectorVision's Burn Rubber will surely impress you even more! :)
