What are the typical causes of up not working on dpad?
ninsei
Could be a dirty connection on the underside of the button (the carbon pad - just gently wipe it with IPA). More common if you've taken it to bits a few times previously is the carbon can wear off the ribbon edge where it plugs into the PCB. That can mean that one trace isn't making a connection when you plug it in. If that's the cause you either need a new flex ribbon assembly, or sometimes you can trim a tiny tiny piece off the edge of the ribbon which means when it is pushed back in it goes further into the socket.
