EA3 and EA5?
4 replies to this topic
#1 cbmeeks OFFLINE
cbmeeks
    Moonsweeper
  • 413 posts
Posted Thu Jan 24, 2019 9:59 AM
In my quest to learn more TI, I see the terms EA3 and EA5 mentioned (formats).
Would someone please explain to me what these are?  Or, point me to some reading material.
Thanks!
#2 TheBF ONLINE
TheBF
    Dragonstomper
  • 923 posts
Posted Thu Jan 24, 2019 10:13 AM
You could start here:  http://www.unige.ch/.../ea_mod.htm#EA5
The names are short for:
  •  Editor Assembler menu option 3
  •  Editor Assembler menu option 5
BTW, I love your sig.  :-D
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 322 posts
Posted Thu Jan 24, 2019 10:18 AM
EA3=EDITOR ASSEMBLER CARTRIDGE OPTION 3 LOAD AND RUN
object code(output from assembler)
EDITOR ASSEMBLER manual 15.2 page 238
EA5=EDITOR ASSEMBLER CARTRIDGE OPTION 5 RUN PROGRAM FILE
memory image format(raw dump of CPU memory containing program)
EDITOR ASSEMBLER manual 24.5 page 420
Edited by HOME AUTOMATION, Thu Jan 24, 2019 10:23 AM.
#4 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 818 posts
Posted Thu Jan 24, 2019 12:04 PM
An Editor/Assembler EA #3 file is a DIS/FIX 80 file.  Sometimes, these files are autostart, while other times, they will require a program name to launch.  I think "START" has been a common name, but not always.
An Editor/Assembler EA #5 file is a PROGRAM image file.  Typically, if you see filenames like UTIL1, UTIL2 on a disk, that is an indication they are to be run from EA#5 option.  They do not require a program name to run.  Also, if there are multiple files with an incremental character in the last place of the filename and are 32 (or 33) sectors in length depending upon your disk manager, that is also indicative they are an EA#5 program.
It should also be known that both Basic and Extended Basic programs also use a filetype of PROGRAM.  These programs will not be loadable under the Editor/Assembler module.
There is a program called IDENTIFILE that can do a directory of your files on your disk and give you a fair amount of information on how/where to use the individual file(s).
Beery
#5 adamantyr ONLINE
adamantyr
  • 1,451 posts
Posted Thu Jan 24, 2019 12:42 PM
In particular, the #3 files are designed to be loadable in any memory. So you pay for that flexibility with a larger file size and a slower load time.
#5 files are 100% compiled and static; you can't place them anywhere in memory except where they were compiled to be. They start with a small header that indicates where in memory the code begins.
To make maximum use of the RAM memory of the TI and load your program the most efficiently, option #5 files are the best.
SAMS loading is a more complex subject. Art Green's SAMS assembler/linker had the option to create relocatable code that could be loaded into any page of memory, but it was pretty complex to understand and I do most of my compiling work on the PC for speed rather than the TI.
I ended up writing my own loader for my CRPG, and compiling static binaries that get stored in one large binary file which is loaded and set in fixed pages. To load around 160k takes a little over a minute, so it's pretty fast all things considered.
