Saturn Troubles
Saturn controller
10 replies to this topic
#1 Inky OFFLINE
Inky
    Gobs of money!
  • 25,909 posts
  • Meh
Posted Mon Jan 28, 2019 7:53 PM
Not sure where else to post this, so I'l put it here...
I have a Sega Saturn that was given to me. No controllers, cables, games, anything.  I've been trying to get it working to no avail.  I have an AV cable and a power cord and a controller.  When I power the device on, the left direction on the controller doesn't work. I've replaced the carbon pads inside, as well as the controller board in the Saturn to no avail.  I don't have any other accessories.Any ideas?
#2 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Tue Jan 29, 2019 7:30 AM
Any chance there's a problem with the plastic D-pad part? Does the controller work on another Saturn? If so, that would seemingly narrow the issue down to the controller port.
Quick fix is a replacement: https://www.ebay.com...AN/143073309360
But you could probably first inspect the board and make sure that there aren't any cold/cracked solder joints and maybe resurrect it quickly.
#3 Inky OFFLINE
Inky
    Gobs of money!
  • 25,909 posts
  • Meh
Posted Tue Jan 29, 2019 7:42 AM
I've replaced that board. I currently don't know of any other Saturn owners in my area, to where I can do more testing.
Ironically, that Ebay auction you linked to is where I bought my board from.
#4 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Tue Jan 29, 2019 7:46 AM
OK I misunderstood. I thought you replaced the innards of the controller.
edit: and in that case, another controller looks like the only viable test.
Edited by derFunkenstein, Tue Jan 29, 2019 7:53 AM.
#5 Inky OFFLINE
Inky
    Gobs of money!
  • 25,909 posts
  • Meh
Posted Tue Jan 29, 2019 11:26 AM
Can I control the system functions if I plug the controller into the second port?
#6 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Tue Jan 29, 2019 3:22 PM
I just tried it on my US model 2 and it works fine with port 2. I can press Start at the boot screen and if there's no disc in it'll take me to the player. All functions work as expected through controller port 2.
#7 Inky OFFLINE
Inky
    Gobs of money!
  • 25,909 posts
  • Meh
Posted Tue Jan 29, 2019 10:09 PM
OK.  I just tried my controller in port 2, and still no left movement.
This is weird, because I swore that when I tested it at MGC last year that it didn't matter which controller was being used, it still wouldn't move to the left.
I have another controller on the way.
#8 DragonGrafx-16 ONLINE
DragonGrafx-16
    Moonsweeper
  • 420 posts
Posted Tue Jan 29, 2019 10:13 PM
Buy another controller and move on. There's even going to be some brand new ones soon.
#9 power OFFLINE
power
    Chopper Commander
  • 188 posts
Posted Tue Jan 29, 2019 11:27 PM
tried cleaning the connector (controller and console end)?
#10 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Wed Jan 30, 2019 8:28 AM
I agree with this. Definitely try cleaning the board. I had two SNES controllers where the Start button barely worked, I really had to jam on it. Took them apart and there was some sort of dark substance on them. Took a toothbrush to it and cleaned it up with some Isopropyl alcohol and it worked good as new.
#11 Inky OFFLINE
Inky
    Gobs of money!
  • 25,909 posts
  • Meh
Posted Thu Jan 31, 2019 10:41 PM
I used contact cleaner inside the controller and in the Saturn..  Didn't think about the connector...
Also tagged with one or more of these keywords: Saturn, controller
