Help in converting EA5 Files to a .bin
9 replies to this topic
#1 atrax27407 ONLINE
atrax27407
  • 1,202 posts
Posted Sat Feb 2, 2019 2:14 PM
I have a couple of EA5 files that I would like to convert to a .bin file to burn into an EPROM. Any ideas how to do it? The files are attached.
#2 adamantyr OFFLINE
adamantyr
  • 1,448 posts
Posted Sat Feb 2, 2019 4:29 PM
You can do it by hand with a hex editor, if you use TI99Dir to extract the file to a PC file and strip off the 128 byte header at the start.
#3 Fritz442 OFFLINE
Fritz442
    Chopper Commander
  • 220 posts
Posted Sat Feb 2, 2019 4:36 PM
I'm not the best at it but try this.
#4 chue ONLINE
chue
    Moonsweeper
  • 332 posts
Posted Sat Feb 2, 2019 5:30 PM
I had to add a "9" to the filename to get it to run in Classic 99:
MunchManBeta3_9.bin
#5 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Sat Feb 2, 2019 7:34 PM
Yes--early on, inverted images ended with a 3 and non-inverted images ended with an 8. This led to some confusion, as he chips for both types had a 3 in them. The current standarf is to use a 9 to indicate inverted files on a 73LS379-type board, and an 8 for non-inverted files on a 74LS378-type board. The 8 files will also work on a 74LS377-type board without modification.
#6 Tursi OFFLINE
Tursi
  • 5,486 posts
  • HarmlessLion
Posted Sun Feb 3, 2019 12:48 AM
The filename is also only important if you ask Classic99 to autodetect, instead of specifying the cartridge type in the INI.
#7 atrax27407 ONLINE
atrax27407
  • 1,202 posts
Posted Tue Feb 5, 2019 8:31 AM
A lot of modern laptops don't have a Scroll Lock key on the keyboard.That is something that is needed if you are going to use Classic99 to covert EA5 files to .bin files. There is a work-around. In Windows 7 and higher, type "osk" (without the quotes) in the search bar and an on board system keyboard will appear which allows you to turn off/on the scroll lock by selecting the appropriate key.
#8 Asmusr OFFLINE
Asmusr
  • 3,033 posts
Posted Tue Feb 5, 2019 9:58 AM
I don't think you need to press Scroll Lock in Classic99 any longer.
#9 Tursi OFFLINE
Tursi
  • 5,486 posts
  • HarmlessLion
Posted Tue Feb 5, 2019 6:46 PM
Not for a while now... the scroll lock function is replaced by the debugger window merely being open.
#10 Fritz442 OFFLINE
Fritz442
    Chopper Commander
  • 220 posts
Posted Tue Feb 5, 2019 6:49 PM
Kool, I did not know this  :)
