I can't figure out how to trigger musical score
2 replies to this topic
#1 Captain Spazer OFFLINE
Captain Spazer
    Chopper Commander
  • 110 posts
Posted Mon Feb 4, 2019 12:25 PM
I managed to compose a small victory tune, but I can't seem to trigger it correctly, I only get a buzzing noise, any thoughts?
Attached File  techdemo.bin   4KB   6 downloads
 rem Generated 04-02-2019 16:06:57 by Visual bB Version 1.0.0.568
 rem **********************************
 rem *<filename>                      *
 rem *<description>                   *
 rem *<author>                        *
 rem *<contact info>                  *
 rem *<license>                       *
   set smartbranching on
   dim duration=y
   dim rand16=z
 player1x = 100 : player1y = 80
 missile1x = 134 : missile1y = 80
 player0x = 10 : player0y = 80
 ballx = 109 : bally = 79
 ballheight = 2
   dim _P0_Left_Right = player0x.c
   dim _P0_Up_Down = player0y.d
   const pfscore = 1
 pfscore1 = 21
   rem  *  Volume off
   AUDV0=0
   AUDV1=0
   rem  *  Initialize duration and set up music
   duration = 1
   goto MusicSetup
dragonlevel
 pfscorecolor = $0E
 COLUPF = $DC
 COLUP0 = $1C
 scorecolor = $0E
 if g = 0 then playfield:
 ........................X.X.X...
 .......................X.X.X.X..
 ......................X.......X.
 XX..............................
 X...............................
 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
end
 rem little caveman walk animation
 if b = 5 then player0:
 %01000000
 %00100000
 %00011110
 %00011000
 %00111110
 %01000000
 %00011000
 %00011000
end
 if b = 10 then player0:
 %00000100
 %00001000
 %01111000
 %00011110
 %00011000
 %01100000
 %00011000
 %00011000
end
 rem dino idle
 if a = 0 then player1:
 %00011111
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001100
 %00001000
 %00001100
 %00111110
 %00111010
 %00001110
 %00000000
 %00000000
 %00000000
end
 rem dino eat
 if a = 1 then player1:
 %00011111
 %00001010
 %00001010
 %00001010
 %00001010
 %10101010
 %10101010
 %10101100
 %11111000
 %10110000
 %11100000
 %00000000
 %00000000
 %00000000
 %00000000
 %00000000
end
 rem dino looks away
 if a = 2 then player1:
 %00011111
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001100
 %00001000
 %00011000
 %00111110
 %00101110
 %00111000
 %00000000
 %00000000
 %00000000
end
 rem dizzy dino
 if h = 1 then player1:
 %00011111
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001010
 %00001100
 %00001000
 %00011000
 %00111110
 %00101110
 %00111000
 %00000000
 %00101000
 %00010000
end
 f = f+ 1
 if f = 60 then a = (rand&3)
 if f > 60 then f = 0
 NUSIZ1 = $37
 if b > 10 then b = 0
 drawscreen
 rem little caveman move
 if e = 0 && k = 0 && j < 2 && joy0right then _P0_Left_Right = _P0_Left_Right + 0.50 : b = b + 1 : d = 0
 if e = 0 && k = 0 && j < 2 && joy0left then _P0_Left_Right = _P0_Left_Right - 0.50 : b = b + 1 : d = 1
 if d = 0 then REFP0 = 0
 if d = 1 then REFP0 = 8
 rem throw axe
 if d = 0 && e = 0 && i = 0 && k = 0 && pfscore1 > 0 && joy0fire then e = 1 : pfscore1 = pfscore1/4
 if e = 1 then missile0x = player0x : missile0y = player0y : e = 2
 if e = 2 then missile0x = missile0x + 2 : missile0y = missile0y - 2
 if missile0y < 20 then missile0x = 200 : missile0y = 200 : e = 0 : d = 0
 if missile0x > 140 then missile0x = 200 : missile0y = 200 : e = 0 : d = 0
 rem dino is stunned if hit
 if collision(missile0,player1) then h = 1 : missile0x = 200 : missile0y = 200 : score = score + 30
 if h = 1 then i = i + 1
 if i = 60 then h = 0 : i = 0
 if h = 1 then COLUP1 = rand
 if h = 0 then COLUP1 = $C2
 rem steal the egg
 if collision(player0,ball) then j = 1
 if j = 1 then ballx = player0x : bally = player0y - 4
 if j = 1 && collision(ball,playfield) then j = 2
 if j = 2 then goto GetMusic
GotMusic
 rem dino eats player
 if a = 1 && collision(player0,player1) then k = 1
 if k = 1 then player0x = 119
 goto dragonlevel
   rem  *****************************************************
   rem  *  Music
GetMusic
   rem  *  Check for end of current note
   duration = duration - 1
   if duration>0 then GotMusic
   rem  *  Retrieve channel 0 data
   temp4 = sread(musicData)
   temp5 = sread(musicData)
   temp6 = sread(musicData)
   rem  *  Check for end of data
   if temp4=255 then duration = 1 : goto MusicSetup
   rem  *  Play channel 0
   AUDV0 = temp4
   AUDC0 = temp5
   AUDF0 = temp6
   rem  *  Retrieve channel 1 data
   rem  *  Play channel 1
   AUDV1 = temp4
   AUDC1 = temp5
   AUDF1 = temp6
   rem  *  Set duration
   duration = sread(musicData)
   goto GotMusic
   rem  *  Music Data Block
   rem  *  Format:
   rem  *  v,c,f (channel 0)
   rem  *  v,c,f (channel 1)
   rem  *  d
   rem  *
   rem  *  Explanation:
   rem  *  v - volume (0 to 15)
   rem  *  c - control [a.k.a. tone, voice, and distortion] (0 to 15)
   rem  *  f - frequency (0 to 31)
   rem  *  d - duration
MusicSetup
   sdata musicData = x
  8,4,27
  0,0,0
  15
  2,4,27
  0,0,0
  0,0,0
  9
  2,4,24
  0,0,0
  0,0,0
  9
  2,4,20
  0,0,0
  0,0,0
  9
  2,4,18
  0,0,0
  0,0,0
  11
  8,4,18
  0,0,0
  38
  2,4,18
  0,0,0
end
   goto GotMusic
Edited by Captain Spazer, Mon Feb 4, 2019 12:38 PM.
#2 Karl G ONLINE
Karl G
    Dragonstomper
  • 732 posts
Posted Mon Feb 4, 2019 1:17 PM
"sdata" requires two adjacent variables.  You only declare the first, but it also uses the one after it.  In your case, you declared it as using "x", so it used x and y.  You are also using y for your duration variable, so the pointer got corrupted.  I changed it to use "w", and your tune played fine.
   sdata musicData = w
#3 Captain Spazer OFFLINE
Captain Spazer
    Chopper Commander
  • 110 posts
Posted Mon Feb 4, 2019 3:32 PM
Ahh, thank you. Note to self, write things down!
