Ramdisk driver for MyDos4.53/4 and Sys-Check 2 512K RAM
Ramdisk MyDos Sys-Check 512K
1 reply to this topic
#1 E474 OFFLINE
E474
    Chopper Commander
  • 190 posts
Posted Mon Feb 4, 2019 5:34 PM
Hi,
   Following on from http://atariage.com/...eck-2-512k-ram/
   I have tried out various configurations of MyDos and the RamDisk drivers together with a Sys-Check 2 card, and have managed to get it to work as a 512K Ramdisk.
   I ended up using MyDos 4.53/4, as this is supported by dir2atr (MyDos 4.55 isn't supported by dir2atr).
   I used the MYRD2 ramdisk driver, which is part of MYRD.ARC (written by Lee Barnes).
   I've attached a working ATR that should be good for anyone to use with a Sys-Check 2 card (I followed the instructions in the Ramdisk readme, and wrote the Dos files back to disk after booting with the Ramdisk driver).
   The files on the disk are:
DOS.SYS, DUP.SYS - MyDos versions
MD.ARC - Compressed Disk Communicator image of MyDos
MYRD.ARC - sources and ramdisk drivers
DISKCOMM3.EXE - disk communicator 3 by Bob Puff
MYRD2.AR0 - the Ramdisk driver that works with SysCheck 2 for 512K Ramdisk
UNARC.COM - super-unarc by Bob Puff
   Thanks to all that helped, I got all the files from http://mathyvannisselroy.nl/mydos.htm - I've just combined them into a single ATR for ease of use.
   Hope this helps.
#2 E474 OFFLINE
E474
    Chopper Commander
  • 190 posts
Posted Wed Feb 6, 2019 8:31 PM
Hi,
   One thing I forgot to mention is that the data in the Ramdrive is preserved after a cold-start - so a run at address E477 or similar won't destroy the contents of the Ramdrive if the MyDos disk is rebooted and the Ramdrive driver reloaded.
Also tagged with one or more of these keywords: Ramdisk, MyDos, Sys-Check, 512K
