256 color CLUT
16 replies to this topic
#1 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Thu Feb 7, 2019 8:17 PM
I am currently working on a boxing game project. Unlike my prior releases I want to take advantage of 8 bit color sprites and use 1 256 color CLUT for all of the characters. I understand that if I wish to use text in this project I will need to convert the text object into either a 16 bit or 8 bit sprite as well. That is not an issue and should be simple enough. As I understand it once you set up the game to use 8 bit graphics theres no longer the option to use 4 bit as the 16 CLUTS of 16 colors are all used up to make up the 256 color pallette. What I want to know is can't I just put a graphic containing 256 color squares and add that to the assets file then assign that graphic with all the squares in it a CLUT number in the .bas (clut 0?)? Then all of my 8 bit sprites should also be set to CLUT 0 in the object list or no_CLUT? I would think it would need to be 0 in order to call upon the 256 colors I chose. Also lets say I did do the graphic of the 256 colored sqaures, I still want black to be the transparent color, does a little black sqaure need to be in all 4 corners of said graphic for it to recognize this as the default transparency color?
I'm a little confused about this and any help anyone could give would be much appreciated.
Thanks in advance
Attached File  received_2266888333330732.png   747.38KB   1 downloads
Edited by WAVE 1 GAMES, Thu Feb 7, 2019 8:19 PM.
#2 swapd0 ONLINE
swapd0
    Moonsweeper
  • 390 posts
Posted Fri Feb 8, 2019 3:56 AM
You can mix 16bits with 1,2,4,8 bits CLUT graphics, you just need to be a clever to sort the colour palette to have some nice colours on each palette (for lower bits graphics).
#3 ggn OFFLINE
ggn
  • 1,463 posts
Posted Fri Feb 8, 2019 2:40 PM
Check out this post where I tried to explain graphically what happens. In general you can think of 256 colours as 16 palettes of 16 colours each. So for example if you assign the particle/text layer to use CLUT (palette) 15 then you need to make sure that the last 16 colours (240-255) have the colour indexes of the font you're going to use.
Try a 256 colour tool like Grafx2 or Pro Motion that have palette editing features so you can see what's happening.
#4 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Tue Feb 19, 2019 3:30 PM
I’m curious about this boxing project you are working on. What will the game mechanics be like? Will you be doing a third-person, Punch Out style game or something more akin to James ‘Buster’ Douglas Knock Out Boxing for Sega Genesis?
#5 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Tue Feb 19, 2019 9:15 PM
Im curious about this boxing project you are working on. What will the game mechanics be like? Will you be doing a third-person, Punch Out style game or something more akin to James Buster Douglas Knock Out Boxing for Sega Genesis?
It will be Super Punch Out style and hopefully have a working combo system similar to Killer Instinct arcade. Getting the 256 color pallette to work the way I want is a very important key to this games success. If done right the 10 characters that will be in the game will look better and have way more frames of animation than the characters in my JagZombies game.
This will likely be the ONLY game I work on or release this year.
Attached File  FB_IMG_1550018254379.jpg   73.61KB   0 downloads
Edited by WAVE 1 GAMES, Tue Feb 19, 2019 9:26 PM.
#6 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Wed Feb 20, 2019 11:53 AM
Nice! Just remember that a game like Punch Out focuses on the characters and their personalities. A project like this will require good animation and different fighting styles to differentiate the boxers.
Edit: Just some friendly advice.
Edited by ColecoGamer, Wed Feb 20, 2019 11:56 AM.
#7 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Wed Feb 20, 2019 12:29 PM
Here is a tad more info on the project. The 10 PLANNED characters are listed below. These are the characters planned. It may turn out that not all will make it to the final cut but there will definitely not be any more added to the list.
Skylar (custom edited sprites)
Bentley Bear. (Sprites from custom 3d model)
JagZombies Male Zombie
Alien Xenomorph knockoff. ( knock of due to copywrite)
Predator knockoff character (knock off due to copywrite)
JagZombies Female Zombie
Blizzard (sprites from custom 3d model)
Jagmania Man (custom 3d model of Jagmania character)
JagZombies BATLORD
Jeffrey Johnson (Myself digitally captured MK style)
#8 Shawn OFFLINE
Shawn
    As Above
  • 18,873 posts
  • So Below
Posted Wed Feb 20, 2019 12:51 PM
FYI, "copywrite" isn't a word.
#9 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Wed Feb 20, 2019 1:20 PM
Yes, you may want to change it to its proper spelling, which is copyright.
Otherwise, you have a unique lineup of fighters. This game could actually be popular, as long as you work out the bugs and spend enough time on the characters.
Looking forward to seeing some footage.
Edited by ColecoGamer, Wed Feb 20, 2019 1:20 PM.
#10 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Wed Feb 20, 2019 2:20 PM
Oops
#11 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Sat Feb 23, 2019 11:18 PM
#12 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Sun Mar 10, 2019 2:33 PM
Looking good! Any idea when you’ll have a preview that shows the game in action on actual Jaguar hardware?
#13 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Fri Mar 15, 2019 11:03 AM
Still no updates on this project?
#14 danwinslow OFFLINE
danwinslow
  • 2,574 posts
Posted Fri Mar 15, 2019 11:46 AM
In 5 days? Some of these threads are lucky to get an update in 5 months.
#15 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Fri Mar 15, 2019 3:41 PM
Just about a week ago on his Youtube page, he was telling someone that he would have something to show soon. Oh well...
Attached File  58DDE5A6-BBC7-4E7A-97AE-3FB032CF5A00.png   2.28MB   1 downloads
Edited by ColecoGamer, Fri Mar 15, 2019 3:55 PM.
#16 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,102 posts
Posted Fri Mar 15, 2019 5:29 PM
I haven't posted yet because what I have isn't ready to be seen. I assure you this is not a Vladr project but a WAVE 1 GAMES project and I will have preview videos soon and a physical release some time this year.
#17 ColecoGamer OFFLINE
ColecoGamer
    Dragonstomper
  • 574 posts
Posted Sun Mar 17, 2019 1:22 AM
I’m just interested in your project. While I will admit that I am not fimiliar with all your games, I do know about Ants, Fast Food Holiday Edition and JagZombies.
Reply to this topic
