Skunkboard from Sell My Retro
29 replies to this topic
#1 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Sat Feb 9, 2019 10:03 AM
I bought a Skunkboard from Sell My Retro a couple of months ago, and while I've been happy with it for the most part, there is one big issue I've had with it—sometimes other carts won't work in my Jaguar after I remove the Skunkboard.
I know that this Skunkboard isn't beveled, but it also appears to be thicker than other cartridge PCBs. I'm not sure if all Skunkboards are like this (I used to have a V2 Skunkboard, but I never had any issues with it).
Anyone else have experience with the Skunkboard off Sell My Retro? Have you had similar issues, and if so, did you find a way to resolve it? I'm really worried about permanently damaging the cart connector on my Jaguar. The only solution that I can think of would be to create a pass-through adapter of some kind (which is beyond my abilities).
#2 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 799 posts
Posted Sat Feb 9, 2019 10:10 AM
That sounds like something that should never be used again!
It sounds like it's straining the cart connector. Then when removed, the pins take a while to kinda spring back far enough to make contact on a regular cart.
Bad bad bad.
Send it back.
#3 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 388 posts
Posted Sat Feb 9, 2019 10:30 AM
If the edge isn't bevelled it'll take 2 minutes with an emery board to fix that
#4 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Sat Feb 9, 2019 10:37 AM
Bad bad bad.
Send it back.
Looks like I never should have sold my V2 Skunkboard. :(
Is it seriously this simple? The cart will still work fine? I thought about doing this, but I was afraid I'd just damage the Skunkboard.
#5 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 799 posts
Posted Sat Feb 9, 2019 10:40 AM
That ain't gonna fix the thickness.
#6 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 388 posts
Posted Sat Feb 9, 2019 10:45 AM
I've no complaints with how thick the skunkboard is, it'll be a standard 1.6mm
#7 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Sat Feb 9, 2019 10:51 AM
You know, I may be wrong about the thickness. It may just look thicker to me due to not having a beveled edge. After I figure out how to get it out of this 3D printed case, I'll compare it to a regular Jaguar cart.
EDIT:
Okay, forget what I said about the PCB thickness. I compared it to a Tempest cart, and both are 1.3 mm thick. I'm going to try beveling the edge, and hopefully that will fix everything.
Edited by chicgamer, Sat Feb 9, 2019 11:01 AM.
#8 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Sat Feb 9, 2019 1:31 PM
EDIT:
I managed to bevel mine with a Dremmel, didn't need to take it out the case either. Just be careful not to go too far and damage the gold fingers.
#9 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 799 posts
Posted Sat Feb 9, 2019 3:52 PM
Here's a spare in case you do.
#10 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Sun Feb 10, 2019 9:01 AM
Okay, I beveled the edge of the Skunkboard, and everything seems okay now. I think I did bend some pins when inserting the Skunkboard prior to beveling the connector, as I sometimes have to remove and reinsert Jaguar cartridges now for them to be recognized. Ugh.
So, yeah, anyone who buys this Skunkboard should definitely bevel the connector before ever using it. Not sure why the seller doesn't have this done. Does it add much to the cost of a PCB to have the connector beveled?
#11 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 388 posts
Posted Sun Feb 10, 2019 12:48 PM
They are bevelled, at least the later ones. They should have been done during manufacture, I have it done on all my boards.
#12 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Sun Feb 10, 2019 1:09 PM
I bought mine in December, and mine wasn't beveled. If the person selling these is doing it now, then good, I'm glad others won't have this issue.
#13 JagChris OFFLINE
JagChris
  • 3,645 posts
Posted Sun Feb 10, 2019 1:30 PM
Is it easy to bevel the edges? Could someone throw up a demo video?
#14 Stage_1_Boss ONLINE
Stage_1_Boss
    Dragonstomper
  • 928 posts
  • The key is in the skull.
Posted Sun Feb 10, 2019 1:34 PM
I also have that same skunkboard, it's looking like mine isn't beveled either, but for me it's usually the skunkboard itself that has connection issues and my other carts seem alright.  I probably shouldn't be plugging this into the JagCD like I have been lol
#15 jjona5 OFFLINE
jjona5
    Space Invader
  • 22 posts
Posted Sun Feb 10, 2019 5:20 PM
I just got mine in the mail a few days ago and it is beveled.
#16 mqark OFFLINE
mqark
    Space Invader
  • 41 posts
Posted Mon Feb 11, 2019 3:59 AM
How much should I be selling my Skunkboard for, what's the going price?
#17 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,755 posts
  • reBOOTed
Posted Mon Feb 11, 2019 4:52 AM
Less than 72 GBP, which is what they are new.
#18 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 388 posts
Posted Mon Feb 11, 2019 7:22 AM
Some of the older original ones may get slightly more, but for the collectors only.
#19 mqark OFFLINE
mqark
    Space Invader
  • 41 posts
Posted Mon Feb 11, 2019 7:37 AM
Oof! Sure I paid closer to 120 pounds! (might be misremembering). I believe it came from GoatStore.
Anyhoo, it's doing nothing. If someone wants it, please let me know. I can't see any reason why 65 pounds shouldn't be a reasonable price.
I'll have to check the version. I'd swap it for a Harmony encore cart...
#20 chicgamer OFFLINE
chicgamer
    Dragonstomper
  • 553 posts
Posted Mon Feb 11, 2019 11:21 AM
Yes, it's easy to do. The hardest part for me was getting the 3D printed case to come apart. :) The board extends a bit below the connectors, so you just have to file that part down a bit. I did it in a matter of minutes using a small file.
If I remember correctly, the carts were being sold on the Goat Store for $130 to $140 (at least, that's what I remember about the "ghost" version). I missed out on it, but I ended up buying a V2 later for $200 (people were marking them up, of course, since they were no longer being produced). Fortunately, I was able to sell mine for the same price I bought it. Since someone is producing Skunkboards again, the price has gone back down.
#21 JagChris OFFLINE
JagChris
  • 3,645 posts
Posted Mon Feb 11, 2019 12:41 PM
So basically just knock down the corners of the the connector board?
Fair enough.
#22 joeyaage OFFLINE
joeyaage
    Star Raider
  • 64 posts
Posted Wed Feb 13, 2019 3:23 AM
I bought a skunkboard from sell my retro (back in August 2018, I think). I am also paranoid about it stretching my jag's cart connector. The board does look thicker than standard jaguar cartridges. Perhaps I have 1.6mm and the standard jag's are 1.3mm. However, it did come already bevelled. I plugged it into my CD unit originally but quickly decided to take it out after reading about thick PCB's.
I havn't had my CD unit plugged in since because of this.
I understand that the cartridge connector pins on the jag can be coaxed back into position if really necessary.
Luckily I have had no problems using standard jag cartridges after using the skunkboard (no more than I usually get). I was quite worried about this but feel a little more confident now.
It has to be said that it is a bit of a nightmare. I wish that proper sized PCB's were used so there was no issue.
I make sure that I don't leave the jag with skunkboard plugged in, just in case.
Skunkboards are awesome! It is good to see your own code running on the Jaguar.
#23 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 799 posts
Posted Wed Feb 13, 2019 7:57 AM
Just wait for the Jag SD from SainT.
That's what I be doing!
#24 42bs OFFLINE
42bs
    Moonsweeper
  • 303 posts
Posted Thu Feb 14, 2019 12:40 PM
Not sure, will it have USB connection to the PC? If you have to remove the card from Jaguar, plug into PC, write game, remove from PC, re-plug into Jaguar and then boot, well this will do for a hello world, but nothing else.
Good for me is: BJL ROM (which makes a register dump) + SkunkBoard. Best would be if the SkunkBoard would have a RAM to store the "ROM" instead.
#25 Greenious OFFLINE
Greenious
    Chopper Commander
  • 232 posts
  • -= Elite =-
Posted Fri Feb 15, 2019 7:24 PM
Well, I would have preferred a real cartridge shell for my skunk, but other than that I'm as happy as can be with it.
