I've just got a Specter GCR :)
18 replies to this topic
#1 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Mon Feb 11, 2019 4:54 PM
I've just got a Specter GCR :) It didn't come with the MAC OS but it come with the ROMS. I'm new to the MAC world so I'm going to need some help! Thanks! :P  OK, the only disk drive's I have is the internal drive in my STE and other disk drive is in my dell laptop, how do I get the MAC OS on to real floppy disk's ? Thanks! Oh I my SatanDisk installed too, if that helps any.
Edited by walter_J64bit, Mon Feb 11, 2019 5:06 PM.
#2 Zogging Hell OFFLINE
Zogging Hell
    Moonsweeper
  • 434 posts
Posted Tue Feb 12, 2019 9:11 AM
This is the hard part, getting System 6 on the ST in the first place. I had to use an old mac to make the disks (one which was still new enough to get on the net or had a way like a CD drive to interface with a newer model that could, but old enough to have a compatible disk drive. The cheapest old macs for this are the early power pc ones prior to the original iMac. The iMac is the cut off point really, as at that point apple killed the floppy drive and like with the ST the USB replacements can't write the disks do to the non standard format. You really want to use a hard disk if you want to do anything productive, the Mac is really unpleasant to use with just floppies, it really is - copy small part of file - ask for system disk - insert original disk - insert system disk and so on... :) I think you should be able to get the disk images on Winworld (ironically)
So if you can't find a old mac then I seem to recall there were a few websites who would offer to write some disks for you (I would do it myself if you were on my side of the pond).
#3 remowilliams OFFLINE
remowilliams
  • 10,605 posts
Posted Tue Feb 12, 2019 9:39 AM
Now you're playing with power : )
I've put up the Spectre manual here if you need it:
https://www.scribd.c...ctre-GCR-Manual
#4 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Tue Feb 12, 2019 12:39 PM
I've seen the disk images you are talking abut but I'm sure what app to use. I'll check out the websites as a last resource. Thanks.
#5 Zogging Hell OFFLINE
Zogging Hell
    Moonsweeper
  • 434 posts
Posted Tue Feb 12, 2019 1:03 PM
It's been a while but I think the Mac can handle them natively with a program called 'disk copy' (depending on the image)
#6 Goochman OFFLINE
Goochman
  • 6,982 posts
  • Moongates to the Past
Posted Tue Feb 12, 2019 1:23 PM
The big piece missing with Spectre is a way to move binary files from the ST to the "Mac" side of thing.  There is a utility provided but it totally screw up binary file transfers.
It would be great is there was a program that allowed us to download .sit files on the pc - put them on ST disks and transfer them to the Mac partition on the ST hard drive.  There is no way to do this that I know of.  You need to have an old Mac that can write to the floppy and with Spectre GCR or a Discovery cart move it to the "ST Mac"
#7 remowilliams OFFLINE
remowilliams
  • 10,605 posts
Posted Tue Feb 12, 2019 1:31 PM
It's the same problem with getting files to any generic old Mac.  This can be worked around with conversions to/from MacBinary and HQX (BinHex 4) formats, this way the data and resource forks are encapsulated.  You of course need an appropriate (and version compatible) decoder on the Mac side.
#8 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Tue Feb 12, 2019 1:32 PM
You got the link to the websites who write the OS disks?
#9 Zogging Hell OFFLINE
Zogging Hell
    Moonsweeper
  • 434 posts
Posted Tue Feb 12, 2019 1:38 PM
These people do it apparently, I've never used them so can't comment on the service
https://rescuemyclassicmac.com/
#10 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Tue Feb 12, 2019 2:30 PM
His prices aren't bad. :thumbsup: :thumbsup:
#11 Forrest OFFLINE
Forrest
    Chopper Commander
  • 124 posts
Posted Tue Feb 12, 2019 3:02 PM
As others have said, you'll need a set of System 6.0.x system disks made on a real Macintosh. In the early 90's, I remember buying a set from an Apple dealer for $50! You should be able to get a set for less. You may try buying a set of disks from a local Apple User Group.
The Spectre GCR emulates a Mac Plus, and a good source of info is https://www.emaculat...mini_vmac_setup
This link describes setting up the Mac Plus/II emulator Mini vMac under Windows.
You should also get Stuffit Expander 4.0.1 on a Mac disk, so you'll have a method of expanding Mac programs with Spectre GCR.
Hopefully SatanDisk users can chime in if this works with Spectre GCR
On the author's Mini vMac website, he has a list of Disk Conversion services at https://www.gryphel....vert/index.html
I see there's one in NC
Edited by Forrest, Tue Feb 12, 2019 3:07 PM.
#12 hunter44102 OFFLINE
hunter44102
    Chopper Commander
  • 122 posts
Posted Tue Feb 12, 2019 3:33 PM
Well worst case you can go to Ebay. This guy has the 4 disks for 16 dollars including shipping
https://www.ebay.com...&frcectupt=true
#13 remowilliams OFFLINE
remowilliams
  • 10,605 posts
Posted Tue Feb 12, 2019 3:42 PM
It does, I have a HUGE 16MB card that's a Mac hard drive.   :D
#14 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Wed Feb 13, 2019 7:51 PM
I'm a hipster now? I've just order for the OS from this guy. :thumbsup: :thumbsup:
#15 eebuckeye OFFLINE
eebuckeye
  • 1,238 posts
Posted Wed Feb 13, 2019 7:57 PM
I have a Specter but have not used it yet.  Seems like you have to install the OS to a hard drive?  I have a Ultra Satan but not sure how to get it to work with Specter.
#16 remowilliams OFFLINE
remowilliams
  • 10,605 posts
Posted Wed Feb 13, 2019 8:13 PM
You don't need to but you'll be in a world of hurt (as Zogging Hell alluded to), if you don't.
The original manual I scanned and linked above covers HD installation.
#17 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Fri Feb 15, 2019 7:34 AM
OK, I've got a Discovery cart so I can use that to make back up's of MAC disks with it? That one app I haven't used yet with my Discovery cart. I'm going to reset my SH205/Megafile 20 with new partitions or just delete all on files partition D: so I can use Spectre GCR, anyway I've missed placed my drivers for my SatanDisk from ParanoidLittleMam.  :?
Edited by walter_J64bit, Fri Feb 15, 2019 7:43 AM.
#18 walter_J64bit OFFLINE
walter_J64bit
  • 5,201 posts
Posted Yesterday, 4:46 AM
Update, I'm waiting for my OS to come in. Now my internal drive in my STE has stopped working   :thumbsdown:  :thumbsdown:  but I do have a 1.44 drive that I can change the drive ID number to 0 so that's installed.  :thumbsup:  :thumbsup:  Right now I learning more about the Spectre GCR w/o an OS now I know how setup the my Spectre GCR to work with my SatanDisk and I think, I know how to use my Discovery cart to copy MAC/Magic Scan disk but with out my OS I cant tell just yet.  ;-)
Edited by walter_J64bit, Yesterday, 4:56 AM.
#19 MrMaddog OFFLINE
MrMaddog
    Dragonstomper
  • 893 posts
  • Not a 'gamer' but a video game player...
Posted Yesterday, 11:17 PM
...Power Without The Price :-D
Seriously, that's a very sweet setup to have back in the day.
Edited by MrMaddog, Yesterday, 11:18 PM.
