HDTV question
6 replies to this topic
#1 Atariboy OFFLINE
Atariboy
  • 7,698 posts
  • River Raider
Posted Mon Feb 11, 2019 11:11 PM
Been thinking about getting a new tv, but I'm confused with one of the models I'm looking at.
It's advertised as having a component input (A rarity these days). Yet when looking at the picture of the television inputs, I see what appears to be two RCA jacks. One is for L/R audio and the other is a shared composite/component input.
I'm not confused by the composite/component sharing of this port since I know that's been common in recent years as manufacturers seek to cut cost yet retain compatibility with analog sources. What I'm confused about is that there's just a single input for component.
Are there adapters for this sort of thing? The online manual doesn't provide any clarification on how you're supposed to connect component video with three RCA style plugs to just a single port video input on the tv.
Edited by Atariboy, Mon Feb 11, 2019 11:13 PM.
#2 Tanooki OFFLINE
Tanooki
  • 5,749 posts
Posted Mon Feb 11, 2019 11:46 PM
Got a picture to clear this up?
The TVs here, the component/composite are shared.  So the back of the TV will have like 5 jacks in a row, you have your RED/WHITE for the audio channels, then the 3 others (reddish, bluish, greenish) and usually the green or blue is marked also as bypass for the traditional RCA yellow port.  Sucks if you want to use either feature, fine if you don't.
#3 supercoupe91 OFFLINE
supercoupe91
    Chopper Commander
  • 118 posts
Posted Mon Feb 11, 2019 11:52 PM
Some come with a 3.5 mm jack for av inputs and then include an adapter.
#4 Atariboy OFFLINE
Atariboy
  • 7,698 posts
  • River Raider
Posted Tue Feb 12, 2019 12:48 AM
#5 Austin OFFLINE
Austin
  • 12,928 posts
Posted Tue Feb 12, 2019 4:19 AM
Those look like 1/8 inch jacks, not RCA ports. My guess is there's probably an adapter that comes with the TV or one you need to buy separately.
#6 TDIRunner OFFLINE
TDIRunner
    Moonsweeper
  • 255 posts
Posted Tue Feb 12, 2019 3:54 PM
Yeah, those look like 1/8 jacks.  That means all 3 component connections are in that single input.  I've never seen a 1/8 component jack before, but I'm certain they must exist for this to work.  That is an extreme cost cutting measure there, but I guess it's better than nothing.  This is a sign that component is probably only one generation of TVs from completely disappearing.
  • jhd likes this
#7 Bilnick OFFLINE
Bilnick
    Dragonstomper
  • 606 posts
Posted Tue Feb 12, 2019 8:14 PM
https://www.amazon.c...mponent adapter
If it is a Samsung, it might use this adapter
