52K Atari 800 - did anyone else do this ?
30 replies to this topic
#1 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 61 posts
Posted Wed Feb 13, 2019 8:46 AM
When I first got my Atari 800 in the 80's, I used it to develop some games + Utility software.
I realised there was a 4K hole in the system that could be used to put debugging software etc.
I rarely played Computer Chess, so that cartridge got the chop.
Also nothing used the right side cartridge slot.
I found a 4K RAM chip with the the same pinout as the ROM, did a little rewire of the cartridge and the 800 motherboard cartridge slot
to enable writing to the RAM.
It worked a treat, obviously couldn't use it with Basic.
At a later date I did make a 'Cartridge' for the Chess ROM.
See attached photo's
#2 Stephen OFFLINE
Stephen
  • 7,542 posts
  • A8 Gear Head
Posted Wed Feb 13, 2019 9:17 AM
Wow - that's really cool.
#3 Forrest ONLINE
Forrest
    Chopper Commander
  • 140 posts
Posted Wed Feb 13, 2019 9:32 AM
That's interesting. What is the address range for the extra 4K?
#4 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 61 posts
Posted Wed Feb 13, 2019 9:57 AM
Sits in the hole above 48K to the start of ROM at 52K, no paging needed, just extra RAM.
$C000 to $CFFF
#5 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,199 posts
Posted Wed Feb 13, 2019 1:05 PM
Cool. That would be nice for my 800... and charge 499,- for it to keep in 1970s price range ;)
#6 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 231 posts
Posted Wed Feb 13, 2019 1:13 PM
https://youtu.be/bV-rhtet4Ow?t=6
#7 slx OFFLINE
slx
  • 1,749 posts
Posted Wed Feb 13, 2019 1:54 PM
$C000 to $CFFF
Very nice. Could you explain what changes to the motherboard are required?
#8 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 61 posts
Posted Wed Feb 13, 2019 3:38 PM
I will take the case off and have a look, maybe photo, was done back in the 80's and I been round the golfish bowl many times since  :D
#9 ClausB OFFLINE
ClausB
  • 1,592 posts
Posted Wed Feb 13, 2019 9:17 PM
Nice one. Which SRAM chip did you use? In the day, most were 2K or 8K bytes.
I did something similar, but with DRAM instead. It filled that 4K hole with RAM and also replaced the OS ROM with RAM:
http://atariage.com/...0-64k-atari-800
#10 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 61 posts
Posted Thu Feb 14, 2019 4:02 AM
Just followed your link, really cool topic, can you imagine people doing this sort of thing these days
#11 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 61 posts
Posted Thu Feb 14, 2019 5:03 AM
Unfortunately I couldn't take the 800 apart, there are some 'flexible' retainers on the bottom plate of the shielding and the've gone a bit hard,
didn't want to break them, sorry.
I did open the Cart, see photo's, I had forgotten what I did to make it work, wish I still had the diagrams.
As you can see it's 2x2K RAM chips HM6116P, there is also a 7404 (Hex inverter) and a 7400 (Quad Nand) used to provide the correct
logic for the RAM, you can also see that I had to add an extra contact to the edge connector (right side of the underneath) and cut a few tracks.
#12 Kyle22 OFFLINE
Kyle22
  • 3,896 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Thu Feb 14, 2019 7:28 PM
Incognito has a 52K mode. Are there any programs that require (or are enhanced by) it?
#13 Nezgar OFFLINE
Nezgar
  • 1,687 posts
Posted Fri Feb 15, 2019 12:10 AM
I believe I read SynFile will recognize it, along with additional Axlon RAM up to something like 192K. Maybe SynCalc or VisiCalc too then.
#14 Curt Vendel OFFLINE
Curt Vendel
  • 4,868 posts
Posted Fri Feb 15, 2019 12:40 AM
Never did that, but I used to get 52k when I used DOS XL 2.1 and with a Newell OS board that had 4k of memory on it, when I enabled my Bit-3 for some reason I always wound up with more memory.  I have the system back up again, I'll try to recreate it, but that extra 4k was a God send back then, especially with my BBS software, I was using Basic XL's delete command to delete lines of code as a section was run and then load in parts of the software from a Ramdisk to allow me to have a bigger BBS program within the 52k of space.
#15 BillC OFFLINE
BillC
  • 1,905 posts
Posted Fri Feb 15, 2019 1:07 AM
Synfile+ works with the Mosaic 64K upgrade in the 400, don't know if it only uses a single 4K(52K) bank or all 4(full 64K).
#16 DjayBee ONLINE
DjayBee
    Moonsweeper
  • 349 posts
Posted Fri Feb 15, 2019 9:10 AM
SynCalc and VisiCalc do
#17 David_P OFFLINE
David_P
    Dragonstomper
  • 931 posts
Posted Fri Feb 15, 2019 3:55 PM
I believe with the Bit3 you're no longer using system RAM for the display, and thus get more free memory..
#18 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,107 posts
Posted Fri Feb 15, 2019 6:26 PM
I never had a chance to try with a 52K machine, but both Alternate Reality games used all available memory (The City upto 64K, Dungeon 128K) so it's possible they may use 52K Atari memory too. The Dungeon lets you know how much it finds, The City does not. Who knows, maybe The Dungeon would even look for Axlon expanded memory...maybe even The City. I wonder has anyone ever tried with them? If not, I will, eventually, I'm doing a 16K-to-48K-to-62K (Port B) mod to one of my 16K 800 boards now, and plan on doing a 48/52K mod and Axlon mod to the other two afterward.
Edited by Gunstar, Fri Feb 15, 2019 6:27 PM.
#19 Kyle22 OFFLINE
Kyle22
  • 3,896 posts
Posted Fri Feb 15, 2019 7:29 PM
I would think it provides 52K. PORTB is not used for OS ROM control. It is used for joyport 3/4 on a 400.
I wish my Incognito had usable ports 3 and 4. (or 2 &3 if you start with zero).
Edit: provides, not uses. (sometimes being a perfectionist is frustrating).
Edited by Kyle22, Fri Feb 15, 2019 7:30 PM.
#20 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,107 posts
Posted Fri Feb 15, 2019 8:15 PM
The 48/52K mod board I'm planning, I think I will make it so it also uses all 64K with 4, 4K banks like the Mosiac. (Claus B's schematics are being used on all boards)
Edited by Gunstar, Fri Feb 15, 2019 8:17 PM.
#21 Kyle22 OFFLINE
Kyle22
  • 3,896 posts
Posted Fri Feb 15, 2019 8:23 PM
Is this on a 400/800? Do you mean LINEAR 64K from $0000-$FFFF?
Where is the hardware and OS gonna live? Are there bankswitch registers? How does it work?
#22 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,107 posts
Posted Fri Feb 15, 2019 8:46 PM
The 800 compatible upgrade I'm talking about doing to a board, I referred too as the 48/52K, I'm talking about using all 64K (any 400/800 board that is at least 48K actually use 8x64K drams and so 64K memory is there, but Atari's and some other 48K boards just ignore it unless modified.) like the Mosiac bank switches to the same continuous 48+4K memory. Similar to how the Mosiac 64K board works, but I actually don't know if it's 100% compatible with the Mosiac board. It's one of Claus's designs. so it doesn't touch the OS locations. ($C000-$D000)?? I may be mis-reading my self-edited, abbreviated memory map...I'm just teaching myself all this stuff lately, usually I just build the upgrades, I hadn't really started learning the 6502 and Atari memory map until recently, I still have to use reference constantly. I have Mapping the Atari, but this chart in 'How to program your Atari in 6502 Machine language' (A Hofacker paperback) was the easiest to find since I read the book a couple weeks ago.
Edited by Gunstar, Fri Feb 15, 2019 9:13 PM.
#23 Kyle22 OFFLINE
Kyle22
  • 3,896 posts
Posted Fri Feb 15, 2019 8:54 PM
You'll have 52K then. You are only enabling RAM at the $C000 area. IIRC, there is a bug with clearing the screen that may affect this region.
#24 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,107 posts
Posted Fri Feb 15, 2019 9:16 PM
Yes, 52K seen by the 6502, but 64K dram on the board with three other 4K banks to bank switch in and out between $C000-$D000, Like the Mosiac 64K board.
Edited by Gunstar, Fri Feb 15, 2019 9:17 PM.
#25 Nezgar OFFLINE
Nezgar
  • 1,687 posts
Posted Fri Feb 15, 2019 10:07 PM
Only if there is RAM above MEMTOP. If the OS initializes E: with a default 52K MEMTOP, the bugged writes will go to the ROM region past $D000. But if you plan to do mosaic style banking, I presume memtop has be forced back to 48K to prevent banking out the screen RAM.. Which presents the risk of an E: screen clear wiping out some bytes into $C000.
Soution being what the 'run from RAM' init routines Atari BASIC, ASM/ED, etc hackers did - set memtop to the next lower 4KB boundary, ie 44K, and reinitialize E: there...
Edit: or fix the bloody bug in the ROM, David Small integrator style :)
