Pioneer4x4 Posted February 14, 2019 Share Posted February 14, 2019 Another project I had was controlling 3D glasses with an Atari 2600. I have working code but not sure which version was the one that actually worked, I need to test it on hardware. Basically some glasses (I started with the old crappy/tiny viewport) Sega 3D glasses, then I got a pair that came bundled with some video card or something. Let me 'splain, no, there is too much, let me sum up... The glasses have a mini 1/8" stereo jack on them with a common pin, and one pin for each LCD shutter. If I recall, you just apply 5v to a pin and ground the common, and that shutter goes dark. So to display 3D; Send power to 1 shutter, blocking that eye from seeing the screen. Display the image on the screen that the other eye should see. Remove power from 1st shutter, and apply to the other. Display the other image. I sent data out to the joystick port to turn pins on and off, and that actually controlled the 3D glasses directly. If I remember, no electrical components were used, only a wiring adapter from 9pin D-Sub to headphone jack. I can't even remember how exactly it worked in code, but this is one piece I found on my old HD. set romsize 4k set tv ntsc set smartbranching on dim frame = a dim rate=b rate=0 COLUPF = $06 main rightframe rem frame 1 frame=1 playfield: ................................ ........X.......X............... ........X.......X............... ........X.......X............... ........X.......X............... ........X.......X............... ........X.......X............... ........X.......X............... ................................ ................................ ................................ end for c=0 to rate drawscreen next c leftframe rem frame 2 frame=2 playfield: ................................ .....X.......X.................. .....X.......X.................. .....X.......X.................. .....X.......X.................. .....X.......X.................. .....X.......X.................. .....X.......X.................. ................................ ................................ ................................ end for c=0 to rate drawscreen next c goto main vblank SWCHA=frame SWACNT=%00000011 return 2 Quote Link to comment Share on other sites More sharing options...
