Peekchar 7800basic help
7800basic peekchar
2 replies to this topic
#1 Dalta OFFLINE
Dalta
    Space Invader
  • 18 posts
Posted Sun Feb 17, 2019 12:13 AM
Hope it's ok that I create a new thread each time I need help, I figured it would help people in future search if they're stuck on something.
Anyway, I've created bullets for the player to shoot and now I'm trying to get the bullets to disappear when they hit a wall. I admit that I don't fully understand peekchar, but I get weird behaviour around line 29 in the below code.
Before I put in the peekchar code, the bullets shoot from the player in whatever direction they're moving, as expected, but when I put in those peekchar lines around line 29 below, I get behaviour I don't understand. The appearance or otherwise of the bullet seems to depend on the player's position when in theory, that shouldn't affect it at all. The bullets also only appear when the player is on a certain side of the screen, not when they are touching a certain character, which is what I thought peekchar does. In theory it should be the character underneath either the player or the bullet which affects behaviour, no? Everything works fine until I set what 'tempbx' and 'tempby' are for the peekchar function.
I put in a debug line which plots another face sprite which should match the same conditions as the bullet, but it appears at different times, seemingly random. On one run through the game crashed and plotted out a load of numbers at the top of the screen (this happened before during a different bug when I had mis-assigned a variable. I went through several times to make sure I hadn't done that this time and it doesn't look like it. It seems like there's something about peekchar that I don't understand.
I tried to create a gif to illustrate the issue but apparently it's not allowed.
My abridged code looks like the following:
 set collisionwrap on
 set doublewide on
 <assign variables>
 ; this next line is copied from Atarius Maximus's code
 dim screenram = $2200 : rem to $24EF (20*12=240 bytes)
 rem $24F0 to $27FF are free
 ;screen0map is the name of the map I made with alphachars
 memcpy screenram screen0map 240
 plotmap screenram 1 0 0 20 12
 savescreen
main
 pprevx=playerx: pprevy=playery
 <movement code>
 if joy0fire0 && btimer=0 then gosub bullInit
 ; *** Plotting and Moving Bullets
 if firecon>10 then firecon=firecon-1
 for x=0 to firecon
  ;giving variables to the bullets, in order to work in the if statement
  bx=bullx[x]: by=bully[x]
  ;check if the Bullet has hit a wall
  tempbx=bx/16:tempby=by/8 ;the bullets stop plotting for some reason after I enter this line
  tempchar2=peekchar(screenram,tempbx,tempby,20,12)
  if player_bullets[x]=1 && tempchar2=2 then player_bullets[x]=0
  if tempchar2=2 then plotsprite face1 0 0 50 ;this is a debug line, though has weird behaviour too
  ;if the bullet is active, plot it and move it depending on it's direction for the next frame
  if player_bullets[x]=1 then plotsprite bullet 0 bx by: bullx[x]=bullx[x]+bdr[x]: bully[x]=bully[x]+bdd[x]
  next
  <some other code to prevent player moving off screen>
 if btimer>0 then btimer=btimer-1
 plotsprite face1 0 playerx playery
 drawscreen
 goto main
bullInit ;gives initial bullet variables
 bullx[firecon]=playerx: bully[firecon]=playery ; sets initial bullet coords at the player's coords
 player_bullets[firecon]=1 ;this basically sets the bullet to be active
 bdd[firecon]=playery-pprevy ;this sets the up/down velocity of the bullet depending on the player's movement
 bdr[firecon]=playerx-pprevx ;the same as above for left/right
 firecon=firecon+1 ; firecon keeps track of how many bullets there are
 btimer=10 ;this prevents too many bullets being plotted too quickly
 return
;checks for collision when player moves down
checkmovedown
  tempx=(playerx+1)/8
  tempy=(playery+8)/16
  tempchar1=peekchar(screenram,tempx,tempy,20,12)
  if tempchar1=2 then return
  playery=playery+2:return
<other code for player collision detection>
 alphachars ' abcdefghijklmnopqrstuvwxyz!@#$%^&*()_+-=[]{}:";<>,.?/'
 alphadata screen0map tileset_blanks2
 'aaaaaa     aaaaaaaaa'
 '              aaaa  '
 '        aaaaaa      '
 '  aaaaa             '
 'aaaaaaaaaa      aaaa'
end
Thanks as always for any help.
#2 RevEng OFFLINE
RevEng
    Bit Player
  • 5,193 posts
Posted Sun Feb 17, 2019 3:19 AM
You've mixed up the X and Y division factors, for the sprite to character coordinate conversion.
Instead of "tempbx=bx/16:tempby=by/8" try "tempbx=bx/8:tempby=by/16"
#3 Dalta OFFLINE
Dalta
    Space Invader
  • 18 posts
Posted Mon Feb 18, 2019 1:28 AM
Thank you for your help, that wasn't actually the error, I was still getting weird behaviour after I fixed the problem you mentioned. But I moved the line bx=bullx[x]: by=bully[x] to go after the peekchar lines (here:
if tempchar2=2 then plotsprite face1 0 0 50)
and I got improved behaviour (though I don't understand why, it's like the latter lines above affected the assignment of bx and/or by). But anyway, I think I'm on to something here and I will pursue this for a while. If I need further help I will come back, thanks so much.
Also tagged with one or more of these keywords: 7800basic, peekchar
