Two Bruce Lee sequels
199 replies to this topic
#151 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Mon Mar 18, 2019 4:22 PM
Let's see:
; ANOTHER DLIST, LOOKS THE THE MAIN GAME DLIST
L0EF1    .BYTE $70,$70,$40
L0EF4    .BYTE $20
L0EF5    .BYTE $20
L0EF6    .BYTE $10,$00
         .BYTE $C2      LMS+DLI+ ANTIC 2
         .WORD L78D5
         .BYTE $90
L0EFC    .BYTE $05,$05,$05,$05,$05,$05,$05,$05,$05,$05,$05
         .BYTE $41
         .WORD L0EF1
; GAME OVER DISPLAY LIST
LF0A     .BYTE $70,$70,$70
         .BYTE $47
         .WORD L7905
         .BYTE $07
L0F11    .BYTE $07,$07,$07,$07,$07,$07,$07,$07,$07,$07,$41,$0A,$0F
; GAME TITLE DISPLAY LIST
L0F1E    .BYTE $70,$70,$70,$50,$F0   BLANK LINES
         .BYTE $46   MODE 6 PLUS LMS
         .WORD L78A5
         .BYTE $70,$70   COUPLE BLANK LINES
         .BYTE $47   MODE 7 PLUS LMS
         .WORD L78B9
         .BYTE $70,$70,$06,$70,$70,$02
         .BYTE $70,$02,$70,$02
         .BYTE $41    JMP TO TOP
         .WORD L0F1E
;  MAP DLI TABLE
;  F38 IS LSB, F4C IS MSB
;  EG. $0214 IS FIRST ENTRY
;  EACH BIT CAUSES $80 TO BE ADDED TO THE DLIST CODE
;  SO $05 BECOMES $85 ETC.
L0F38    .BYTE $14,$14,$14,$12,$00,$00,$00,$00,$00,$00,$01,$00,$01,$20,$01,$C0
         .BYTE $41,$01,$00,$40
L0F4C    .BYTE $02,$02,$02,$02,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$02
         .BYTE $00,$00,$00,$00
haha, yes, Courier New is the answer. Thanks fantomas.
#152 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Sun Mar 24, 2019 9:28 AM
Level editor progress
#153 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Sun Mar 24, 2019 9:29 AM
Screen editor is almost done. I’ll be posting it later today/tomorrow.
Some limitations:
For now you must load character sets and maps one at a time.
You must edit the individual map files and because it doesn’t load executables yet.
You must put the generated files back in to the assembly file and re-assemble the game.
There are bugs I’m sure, they’ll be fixed as found or reported.
There are some planned fixes for the next version:
Display DLI colors on the screen
Fix tile graphics to display properly
Load the executable file and edit it directly
A tile editor with color so we can actually make our own tiles.
And of course bug fixes
Right now there is a lot of hard coded stuff but that will get changed once the executable is loading properly. However there is a problem with editing the executable directly and I’ve mentioned it before: If you make or edit a screen whose final RLE is larger than the original the program will not run properly.
Also since the source code is not completely relocatable for now, this will also be a problem for editing the individual files. If the RLE is smaller no problem, the file can be padded out with zeros. If the RLE is larger then the original, then it won’t compile. Once code is all relocatable or at least certain portions, that problem will go away.
Thanks for your patience and enjoy.
Edit: Forgot to mention - Use the files in Fantomas' incbin.zip for loading the fonts and maps.
Edited by Ute, Sun Mar 24, 2019 9:32 AM.
#154 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Sun Mar 24, 2019 9:33 AM
And here is my own example of a quick, half-assed attempt at creating a level from scratch.
#155 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,581 posts
Posted Sun Mar 24, 2019 10:40 AM
Looks good to me Ute...
  • Ute likes this
#156 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Sun Mar 24, 2019 10:07 PM
Thanks Paul.  :)
#157 TheNameOfTheGame OFFLINE
TheNameOfTheGame
    Dragonstomper
  • 700 posts
Posted Mon Mar 25, 2019 9:58 AM
Fantastic, the level editor is shaping up nicely.
Thanks for all the work you guys are doing!
  • Ute likes this
#158 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Mon Mar 25, 2019 3:41 PM
Here is Level Editor beta 0.0.1
Found an issue last night with levels 4,5,7,10,13,17,18. I put a hack fix in for most of the levels. The only one not editable at this point are 5 and 17(Fantomas' map5.rle and map17.rle)
Technically 5 and 17 are editable they just wont assemble correctly.
Working as much as I can on this right now, but you know.......life. :)
#159 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Mon Mar 25, 2019 3:51 PM
So what are the odds I can port the editor? It’s not C++ I hope.
#160 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Mon Mar 25, 2019 8:05 PM
It's written in C#, very similar to Java. A direct translation would be challenging.
You would be ok memory wise, but displaying everything on screen would be the challenge. ANTIC mode 4 might be they way to go since they maps would only take have the screen and you could utilize the other half for character tiles, color sets, DLI info, etc.
As far as actual implementation, editing it natively would offer the advantage of loading native character sets and screen resolutions.
Definitely possible, but a lot would be from scratch.
#161 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Mon Mar 25, 2019 9:41 PM
Well I only asked because I'm looking into Envisions, so I figure that's half the job done if I can get it working as a file loaded from DOS.
#162 tjlazer OFFLINE
tjlazer
  • 2,148 posts
  • Retro Atari Addict
Posted Wed Mar 27, 2019 10:30 AM
Amazing work, would be amazing to get this ported to the A8!
#163 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,581 posts
Posted Wed Mar 27, 2019 12:02 PM
That is the hope and the guys are doing a wonderful job of all pitching in...
Something WILL come out of this, I'm sure..
It started as a little "what if" with me, I pushed a little but the pick up from others has been amazing...
A big thanks to Dmx for being a great sport in helping us via his C64 version code and other files and suggestions, just proves the coders CAN work together . And of course a big thanks to Ute, Alfred and folk like Jose etc for the work so far and just idea's being swapped..
#164 dmx OFFLINE
dmx
    Combat Commando
  • 6 posts
Posted Wed Mar 27, 2019 2:43 PM
My pleasure to help. Looks like this is shaping up nicely, looking forward to playing it :)
#165 fantômas OFFLINE
fantômas
    Space Invader
  • 17 posts
Posted Wed Mar 27, 2019 3:44 PM
Hi, I play with the editor and with the code.
The engine adapts very well to a new map even if you have to pay attention to colors
bc3.png .
2 fonts on screen, 5 dlis.
  • Attached File  bl3.xex   40.6KB   30 downloads
#166 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Wed Mar 27, 2019 3:57 PM
I would like to echo what Mclaneinc has said, big thanks to everyone who has pitched in.
And don't forget Fantomas - He has done A LOT of disassembly and we've been working on the level editor together :)
Edited by Ute, Wed Mar 27, 2019 4:00 PM.
#167 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Wed Mar 27, 2019 4:28 PM
Yeah, I think we really have to hand it to fantomas, his efforts on this have simply been outstanding.
#168 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Wed Mar 27, 2019 5:35 PM
Level Editor Version 0.0.2 is available at Sourceforge.
Fixes temporary extra byte hack and RLE re-encoding issues.
#169 shoestring OFFLINE
shoestring
    Dragonstomper
  • 578 posts
Posted Wed Mar 27, 2019 5:44 PM
This is gonna be great!
#170 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,581 posts
Posted Thu Mar 28, 2019 3:06 AM
Oops, my apologies Fantomas, you were not side tracked deliberately :)
Thank you for your time and dedication as well..Fantastic work there....
I wish I had more to offer the project other than good will, my coding skills are pretty rubbish these days and I was just a hobby coder back then but looking at the talent being shown here on this I can say its looking great people. At the end of the day I will be more than happy if this leads to a game and anything else. Anyone thinking of music and FX as yet, too early?
The dedication shown by you guys make's me smile and the fact it all hopefully will lead to a game to be enjoyed by others is amazing...Can't thank you all enough..
  • Ute likes this
#171 fantômas OFFLINE
fantômas
    Space Invader
  • 17 posts
Posted Fri Mar 29, 2019 9:19 AM
Do not worry. It does not matter. What matters is Bruce Lee!  ;)
Some of Dmc's maps are superb, I think.
  • Attached File  Fury.xex   29.29KB   40 downloads
#172 Ute OFFLINE
Ute
    Star Raider
  • 84 posts
Posted Sun Mar 31, 2019 3:22 PM
Latest update. Now supports full color screen editing. Drop down shows DLI colors being used. Source and Binary for editor uploaded to Sourceforge: https://sourceforge....ci/master/tree/
EDIT: Colors were based on NTSC screens
Edited by Ute, Sun Mar 31, 2019 3:24 PM.
#173 Stephen OFFLINE
Stephen
  • 7,600 posts
  • A8 Gear Head
Posted Sun Mar 31, 2019 3:30 PM
Fantastic work!
  • Ute likes this
#174 Philsan OFFLINE
Philsan
  • 3,860 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Mon Apr 1, 2019 9:43 AM
Thank you very much!
  • Ute likes this
#175 TheNameOfTheGame OFFLINE
TheNameOfTheGame
    Dragonstomper
  • 700 posts
Posted Mon Apr 1, 2019 9:44 AM
Wow!  Brilliant Ute!
  • Ute likes this
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
