Project: Building a Better NES Arcade Stick
NES Nintendo Advantage Arcade stick Sanwa suzo happ controller mod modding
10 replies to this topic
#1 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
  • Cannot be classified as a planet
Posted Sun Feb 24, 2019 12:44 AM
I'm so...SO happy right now. I've had this project on the backburner for over half a year, and tonight I finally got around to modding & wiring the components and mounting everything on a "test control panel".
I'm happy to report: I've successfully modded an NES-04 controller into an arcade stick. Tested it with Contra, and it works perfectly.
Sanwa joystick, Suzo-Happ buttons, Cherry microswitches, if anyone's curious.
I'll update this thread from time to time with updates on the control panel/body design and build.
Edited by HeadcolorsTV, Sun Feb 24, 2019 12:45 AM.
#2 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Wed Mar 6, 2019 4:59 PM
Here's a peek at the top piece.
#3 CMR OFFLINE
CMR
    Space Invader
  • 45 posts
Posted Wed Mar 6, 2019 7:23 PM
Nice looking stick.  Someday I'm going to get a few of my own built.  Someday......
#4 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Wed Mar 6, 2019 10:26 PM
Just got done with the control panel decal design, ready to send to my "vinyl girl".
#5 wongojack OFFLINE
wongojack
  • 3,309 posts
Posted Thu Mar 7, 2019 12:00 AM
Cool!  Did you use some sort of diagram to help you pick up the buttons and directions on the board and chip, or did you just figure it all out through trial and error?
#6 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Thu Mar 7, 2019 2:32 PM
I was actually fortunate enough to get it correct on the very first try, thanks to my slightly unorthodox technique of coloring traces with sharpies.
Yes, you read that right. It works, and is PCB-safe. Doing this, I was able to easily determine the correct/optimal locations to add solder joints and sever traces.
#7 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Sat Mar 9, 2019 11:15 AM
Got the lower body assembled, planed and evened-out. Then I pre-installed the catches for hole location. I'll be removing the metal parts, disassembling the body, and applying clear lacquer to the inner sides of each piece. I think the next step will be to apply the cushioning to the bottom piece.
#8 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Mon Mar 18, 2019 2:00 PM
Bottom is cushioned, plexiglass overlay is cut and ready, and the frame is ready for the paint to go on.
Realized my connection for vinyl doesn't do one-piece prints, so I'm looking to simply send the ai file to FedEx Office or similar, and cut the holes myself.
#9 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Thu Mar 21, 2019 8:51 PM
Okay everybody...
I'm so excited for the final outcome of this project that I'm STRONGLY considering making more to order if anyone's interested. And I've taken the time, while waiting for the clear coat to harden over the week, to design a few more CPOs, and offer options.
The stick should be 100% done and ready to show off some time this weekend. We'll see. Fingers crossed.
PM me if you'd be interested in owning one of these.
#10 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Sun Mar 24, 2019 9:22 PM
And here it is.
More to come later. And yes, it works. :)
#11 HeadcolorsTV OFFLINE
HeadcolorsTV
    Star Raider
  • 68 posts
Posted Thu Mar 28, 2019 11:06 PM
While I'm thinking about it, I might as well list the full features of this stick:
Hardwood body
Sanwa joystick, 4lb tension spring, upgraded actuator
Suzo-Happ concave buttons
24 AWG wire throughout
Hinges for swing-open access from the top
Catches (1 heavy-duty magnetic in front, 2 mechanical for the sides) under the control panel for secure closing.
Automotive paint & clearcoat exterior, buffed and polished
T-molding trim
Clear lacquer interior
Cushioned bottom (faux velour, foam padding) for lap comfort
Plexiglass overlay protector
Decal designed in Illustrator, printed on matte adhesive stock
Also tagged with one or more of these keywords: NES, Nintendo, Advantage, Arcade, stick, Sanwa, suzo happ, controller, mod, modding
