FastBasic 4.0 - Tenliners'19 release
basic compiler interpreter ide FastBasic
11 replies to this topic
#1 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Sun Feb 24, 2019 6:53 PM
Hi all!
To start the new year, and to provide a better Basic for all the new ten-liners, I'm releasing version 4.0 of FastBasic.
The major changes in this version are under the hood:
  • The interpreter has been changed from a stack-base virtual machine to a register plus stack, this makes the interpreter from 10% to 20% faster depending in the program. In the SIEVE.BAS benchmark, the Atari version is 13% faster and in the cross-compiler is 19% faster, but programs depending on fast PEEK and POKE should be much faster.
  • There is now a full test-suite to automatically catch regressions in the parser and interpreter, ensuring that bugs don't re-appear.
Also, there are some user visible changes:
  • There is now a command-line compiler "FBC.COM", this allows compiling large programs that don't fit in the full editor. Currently, "FBC" accepts the full floating-point syntax.
  • Added minimal support for Player/Missile graphics:
    • PMGRAPHICS (abbreviated PM.) statements setups P/M,
    • PMHMOVE (abbreviated PMH.) horizontal moving a a player/missile,
    • PMADR() returns the address of the given player/missile data.
  • Many small bugs fixed.
In this version the integer IDE is 8188 bytes in size (we still have 4 bytes less than 8K), and the floating-point IDE is 9405 bytes.
As always, full sources and binaries for Atari, Linux, Windows and MacOS are available over Github: https://github.com/d...tbasic/releases
#2 MrFish OFFLINE
MrFish
  • 5,471 posts
Posted Mon Feb 25, 2019 3:49 PM
Manual covers and Serious Computerist site updated for the new version.
FastBasic v4.0 - Native Atari
FastBasic v4.0 - Cross Compiler
Great new version. Thanks for all the hard work.
Edited by MrFish, Mon Feb 25, 2019 3:53 PM.
#3 funkheld OFFLINE
funkheld
    Moonsweeper
  • 375 posts
Posted Tue Mar 5, 2019 11:48 AM
hello thanks.
is wonderfull.
greeting
#4 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,721 posts
Posted Tue Mar 5, 2019 4:43 PM
I wonder what other tenliner releases we'll see...
#5 slx OFFLINE
slx
  • 1,789 posts
Posted Thu Mar 28, 2019 4:57 PM
Hi all!
Thank you very much for this great, amazing BASIC!
I have started a 10-Liner which probably won‘t be finished by Saturday.
May I ask two questions:
[li]Is there a way to enter graphics symbols as some of them are masked by commands?[/li]
[li]Would it be possible to add Action!-style direct-to-memory variables, ie assigning integer variables to memory locations?[/li]
Gesendet von iPhone mit Tapatalk
#6 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Thu Mar 28, 2019 7:38 PM
Hi!
I have started a 10-Liner which probably wont be finished by Saturday.
Yes, in the IDE simply press ESC before the key you want to enter.
It is possible, but probably would need an special syntax to differentiate from standard variables, to avoid confusion in the parser, and would make the IDE a lot bigger.
I'm thinking on a syntax like:
 DIM @SdlSt = 560, @Color0 byte = $2c4
 @SdlSt = $1234   ' Equivalent to DPOKE 560, $1234
 @Color0 = 27     ' Equivalent to POKE $2C4, 27
Note that currently the cross-compiler already supports using standard Atari symbols with "@" at front, like " poke @CRSINH, 0 ".
  • slx likes this
#7 slx OFFLINE
slx
  • 1,789 posts
Posted Fri Mar 29, 2019 12:58 AM
Sounds great, didn‘t try the cross-compiler so far. IDE bloat would be a detriment, though, and differentiating between bytes and words would probably bloat it even more. Probably mostly a tenliners feature as it is much shorter ;)
#8 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 205 posts
Posted Sat Mar 30, 2019 7:00 PM
Hi dmsc,
First of all thank you for improving FastBasic. I see that now it is super enhanced with the first version that I tested.
I already overcome all the Basic of atari for its speed, but I have the doubt I will have overcome the ACTION! language?
regards
#9 slx OFFLINE
slx
  • 1,789 posts
Posted Sun Mar 31, 2019 12:32 AM
Hi dmsc,
regards
It probably wont, but while Action! gives you more control and flexibility it also requires more code/work/knowledge for e.g. P/M graphics and has more possibilities to get bitten by sloppy code.
#10 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Mon Apr 1, 2019 10:01 PM
Hi ascrnet!
Hi dmsc,
regards
Current FastBasic is a (very-fast) interpreter, so it is slower than a true compiler like Action. Remember that my goal with FastBasic is a *small* language.
But there is nothing preventing to write a compiler for FastBasic, as the language is already designed to allow easy compilation, I just need a lot of time :P .
Currently, those are my long-term projects for FastBasic:
- Parameters to PROC/EXEC;
- A simple way to call M/L procedures;
- Support for byte and word memory variables (the "@" syntax above);
- An optimizing compiler to 6502.
And last:
- Convince developers to help me in expanding FastBasic - I'm just waiting for pull requests ;)
Edited by dmsc, Mon Apr 1, 2019 10:03 PM.
#11 slx OFFLINE
slx
  • 1,789 posts
Posted Tue Apr 2, 2019 12:21 AM
Sounds great, what kind of help are you looking for? (Most probably beyond my simple ML abilities but maybe theres something low-grade assemblers can contribute as well.
#12 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Tue Apr 2, 2019 7:25 PM
Hi!
Well, you can (IMHO in order of difficulty):
- Add examples and review the documentation. Recently 777ismyname helped me by reviewing all the manual, you can see his work at: https://github.com/d...6c36df40558ae3a
- Add test to the testsuite at https://github.com/d...testsuite/tests, you add a ".bas" file with a test and a ".chk" file with the expected output, see https://github.com/d...ts/testproc.chk and https://github.com/d...ts/testproc.bas . Currently, not all functions are tested.
- Add issues for missing or wanted features.
- Help with optimizing!. there are probably still many simple ways to remove a few bytes, current git version is 86 bytes shorter than v4.0, and fixes a pair of bugs. See https://github.com/d...a7748c9975197c1for a simple size optimization in the parser.
- Proposing new statements or functions. See https://github.com/d...d642829cf29dcb5for what is needed to add a simple statement - this only adds a parser script, or see https://github.com/d...d642829cf29dcb5 for how to add a statement with a new assembly language procedure.
Have fun!
  • NRV likes this
Also tagged with one or more of these keywords: basic, compiler, interpreter, ide, FastBasic
