Converting data on tape to digital data
3 replies to this topic
#1 Stuart OFFLINE
Stuart
    Dragonstomper
  • 854 posts
Posted Mon Feb 25, 2019 4:36 PM
Is there a way to convert data saved on a tape to digital data? Specifically, getting the data from a tape image normally loaded using the MiniMem EasyBug L command. Part of the problem is not knowing where in memory that data is being loaded ...
#2 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 390 posts
Posted Mon Feb 25, 2019 6:08 PM
Win994a stores tapes as .bin type with a simple header... open a .TITape file with a hex editor. When desperate I use this method to transfer from MINIMEM to my FG99... Oddly enough I would normally use your transfer utility from the miscellaneous disk to move such a file from MAME to Win994a... but to do this you need to know the load address!
Minimem's S and L options use: Memory Image(Program file) Format... from assy one could write a short program to define a PAB and access the cassette DSR than examine from VDP buffer or transfer to CPU RAM...
You could easily butcher my CS14EVER program to do this...
CS14EVER.dsk
** CS1 IS MALFUNCTIONING **
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 390 posts
Posted Mon Feb 25, 2019 7:48 PM
I fooled around with this and got it to load the LINES program to >1100 in VDP RAM.
Observed from the V option in EASYBUG.
Attached File  READCS1.dsk   90KB   4 downloads
USE PROGRAM NAME: RUN
EDIT: Had forgotten to update the filenames. :|
Edited by HOME AUTOMATION, Tue Feb 26, 2019 5:03 AM.
#4 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 390 posts
Posted Wed Feb 27, 2019 1:25 AM
I noticed the use of EASYBUG's V option really doesn't work for reading this... I don't know why it seemed to work on the emu last night...
anyway I figured this out a little better...
This loads the tape data to v>1100...then copies the data to c>B000... then copies the first 768 bytes to the screen table...
QUIT... and use EASYBUG's "M" option to view c>B000...
tapes made by EASYBUG's "S" option have the load address as the first word... and the image length as the second word... followed by the image data. :)
Attached File  READCS1(V2.0).dsk   90KB   3 downloads
