65XE/130XE Cartridge Port Extender - 90 degree
89 replies to this topic
#1 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 429 posts
Posted Mon Feb 25, 2019 6:14 PM
I recall there being a 90 degree cartridge port extender for the XE models, but have been unsuccessful in finding it. I am aware of the dual switching cartridge port extender, but am just looking for a single port unit. Was there ever one designed?
#2 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,703 posts
Posted Mon Feb 25, 2019 10:03 PM
your probably thinking about the supra or icd eci/pbi cards with cartridge connector(s) on them depending on which version you would buy.
I posted some pictures of them not long ago...
Edited by _The Doctor__, Mon Feb 25, 2019 10:04 PM.
#3 Nezgar ONLINE
Nezgar
  • 1,807 posts
Posted Tue Feb 26, 2019 12:03 PM
Here's a picture of the ECI to PBI adapter for the MIO from the 1990 ICD Catalog.
Good luck finding one nowadays though. I lost mine, but I was able to use dropcheck's adapter to get my MIO working with a 130XE again. But only 1 cart port works at a time, so can't use say SDX and an R-Time 8, 1 in each slot simultaniously like the ICD one.
#4 manterola ONLINE
manterola
    Moonsweeper
  • 341 posts
Posted Tue Feb 26, 2019 1:20 PM
It might be very easy to re create one, since it looks like a PCB and one edge connector, that it, right?.. or I am wrong?
Maybe someone can upload the design to oshpark.... Or is it too much to ask?
I'd do it but my kicad skills are very limited.
#5 Sikor ONLINE
Sikor
  • 1,471 posts
Posted Tue Feb 26, 2019 3:12 PM
https://www.bitsofth...-port-expansion
#6 Mathy OFFLINE
Mathy
  • 2,924 posts
Posted Tue Feb 26, 2019 6:54 PM
Hello manterola
It is.  Well, it's a PCB with two connectors on it.  I bought one years ago from ICD.  If somebody wants to recreate it, I'd add some solder points for the unused pins on either side.
Sincerely
Mathy
#7 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 429 posts
Posted Tue Feb 26, 2019 9:46 PM
At this rate might try to create a cartridge with 90 degree connector port since no one has released one. just a thought
#8 Curt Vendel OFFLINE
Curt Vendel
  • 4,899 posts
Posted Tue Feb 26, 2019 10:33 PM
Single one is from Supra Corporation
#9 Curt Vendel OFFLINE
Curt Vendel
  • 4,899 posts
Posted Tue Feb 26, 2019 10:37 PM
Should be very straight forward to make. Here is front & back to help
#10 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Tue Feb 26, 2019 11:58 PM
the feet are missing they keep the pcb level and keeps things firm for cartridge insertion
#11 AtariGeezer ONLINE
AtariGeezer
  • 2,896 posts
Posted Wed Feb 27, 2019 12:31 AM
Mine for the MIO didn't have feet either...
http://atariage.com/...62#entry3243230
#12 Nezgar ONLINE
Nezgar
  • 1,807 posts
Posted Wed Feb 27, 2019 1:59 AM
My MIO ECItoPBI had two big rubber feet. Need to get some like that for the adapter I have from Dropcheck. That board doesn't appear available on her website anymore.
http://atariage.com/...re-order-offer/
But there is this one now:
https://www.bitsofth...e-adapter-board
#13 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 6:28 AM
is it the same, or modified? interchangeable? need more convenient way of getting at the information. sifting through pictures/schematics to see how they do or don't match up isn't an at a glance affair.
Edited by _The Doctor__, Wed Feb 27, 2019 6:31 AM.
#14 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Wed Feb 27, 2019 6:55 AM
The 1090XLR ECI2PBI is not actually a standard converter.  It was meant to be used with the 1090XLR since it doesn't have all the standard 130XE/800XL signals where they are supposed to be.
I can work up a bog standard single RA cart 130XE extension. All it will do is put the cart connector at RA to the original orientation.  If you want the full pass thru connections now you start getting into the possibility of bus contention depending on what's connected to the 'second' cart connector.  What has been shown in previous posts is a ECI2PBI converter.  Completely different animal.  But that can be done as well.  Give me a few hours.
Edited by Dropcheck, Wed Feb 27, 2019 7:04 AM.
#15 Nezgar ONLINE
Nezgar
  • 1,807 posts
Posted Wed Feb 27, 2019 7:09 AM
Thanks for the clarification.
As far as I know, with ICD's ECI2PBI with 2 cart connectors, only the RTime8 could be plugged in at the same time as another cart. Anything else would have to go on top of say, spartados X which could switch them on and off.
A single cart port would satisfy modern needs, dual would let a classic R-time 8 coexist without stacking...
#16 manterola ONLINE
manterola
    Moonsweeper
  • 341 posts
Posted Wed Feb 27, 2019 8:06 AM
Yep. There are different animals, but I guess that when you need right angle cartridge adapter it doesn't hurt and it is actually cool to have also a PCI available for the XE
#17 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 8:07 AM
My recommendation is  the 2 cart port version, the rtime8 never leaves the slot it is in, my spartados x cart in the other slot can be switched off, or a side/avg can still be running on top of the switch off sparta cart, you can have other switched carts in on the rtime8 and still access the drives on the avg/side. I have different version of sdx and switches on the carts and oss carts, it just works in the straight up two cart port version. It really take up no more space, you don't have to use both if you don't want, but it is more convenient, it prevents stress on connectors from stacking too high... you can see your monitor instead of carts. It only changes price by 2 dollars give or take to have both.
My dream is a combined eci2pbi with two slots including eci headers,  a switch on port two allowing the selection of normal straight thru connect(like icd/supra), a cart off but pass thru for side/avg/rtime8 position, including the ability to shut off one connector or the other completely when needed.
maybe a run of the simple 2 connector adapter since it might be all of approximate 10.00 dollars give or take (depends on aggregate of parts at the time plus labor etc.) and a run of a complex adapter like I described...
I don't think I could handle not having the adapter on my daily driver, it's been in use since supra and icd first offered them... I wish Atari kept two cart ports on all machines since the 800 first had them that way, enhancing the function of the ports perhaps with a keyed auto selection switch built into the cart case interlock style...
Edited by _The Doctor__, Wed Feb 27, 2019 8:16 AM.
#18 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Wed Feb 27, 2019 9:44 AM
On the Supra single RA cart ECI2PBI has anyone traced ECIBottom pin 3 and ECITop pin A & C to its none/connection to the PBI side?
I'm talking about the secondary connector the 2x7.
Edited by Dropcheck, Wed Feb 27, 2019 9:46 AM.
#19 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 10:21 AM
if I remember correctly pin 3 eci goes to 38 pbi. just click the picture curt uploaded make it big and see if I am correct
eci 7 goes to pbi 47 and pbi 48 and are all tied together on the supra but on the icd rev 1 eci 7 goes to pbi 48 only
Edited by _The Doctor__, Wed Feb 27, 2019 11:20 AM.
#20 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 11:59 AM
is the question about pin 3 because the Decoder in out is not labeled perfectly on some stuff floating around the internet? DO and DI are sort of interchangeable in that respect... they should have just labelled it DIO instead of external decoder out on some of the sheets and DIXX on others...
#21 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 12:33 PM
in any event I'd buy a 2 cart/eci port eci2pbi that might follow... as a premium choice
switch positions
A cart 1 on cart 2 off
B cart 1 on car 2 on
C cart 1 off cart 2 on
another switch to allow pass thru on disabled or off cart so the ide/sd.whatever device can still operate.
I do this current using super spartados x switch and oss multi carts as my switchers... would be nice to do it with most other carts.
else a two cart supra icd combined clone would do it for me on the cheap choice..
#22 _The Doctor__ OFFLINE
_The Doctor__
  • 6,703 posts
Posted Wed Feb 27, 2019 1:27 PM
halt/ready.... is rattling around in my head....  I am not sure but think C went to 36 on some devices...  I bet Curt has something to correlate that with the expansion/pbi/buffer information somewhere.
#23 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Wed Feb 27, 2019 5:57 PM
switch positions
On a XE/XL you can't have two carts enabled at the same time. The only exception that I know of, and it's not really an exception because the R8 is not a true cart is the SDX and R8 carts. Any other cart stacked on the SDX cart is switched on/off by telling the SDX cart to run the cart or by exiting back to SpartaDOS if the stacked cart will allow it.
Do you really mean a horizontal stacked SDX cart rather than a vertical stacked SDX cart?
I'm assuming you mean a 130XE since I don't know of 800XL ide/sd devices that operate using the same cartridge connector.  Most of them already have a pass thru connector.  Not understanding what you mean here.
#24 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Wed Feb 27, 2019 6:02 PM
The original poster requested a source for a RA cartridge connector.  I am assuming the poster is using a 130XE machine.
Here's a possible option.  It contains a complete RA 130XE Cartridge and ECI port and adds the PBI converter.  If the PBI converter is not needed then it can be left off the design.
#25 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Wed Feb 27, 2019 6:04 PM
One might also use a SIDE cart only for the CF adapter (with the ROM switched off) alongside another cart, which isn't normally possible.
