Wanted Replacement PAL Chip CorComp FDC 1985 rev A U12
Pal Chip U12 PLS153AN
41 replies to this topic
#1 TI998owner OFFLINE
TI998owner
    Space Invader
  • 46 posts
Posted Tue Feb 26, 2019 11:06 PM
Hi Group,
Need a little help. This evening , had one of my CorComp
Floppy Disk Controllers fail . Short across main
5 volt Regulator. Tested, replaced the regulator. Found
That the short started in U12 the second PAL chip on the
Board.
The chip has FDC-U12 on the label. The chip is a PLS153AN
Printed on the chip itself.
Does anyone have replacement PAL Chip Available ? Or does anyone
Have the correct iNFO to program a replacement PAL
For this CorComp FDC ?
Thanks in advance for any help or Info getting this repaired.
TI998owner Lee
#2 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Tue Feb 26, 2019 11:24 PM
Good luck on finding the code necessary to program a PAL for any CorComp card. They tended to set the fuses to prevent reading the chips out. If someone had the equations, it would be possible to recreate the necessary JEDEC file, but so far as I know, that data never made it into the wild either. . .
#3 atrax27407 ONLINE
atrax27407
  • 1,237 posts
Posted Wed Feb 27, 2019 7:59 AM
Ksarul and I have been talking sporadically for the past several years about setting up a "PAL Repository" for TI peripherals. Between the two of us, we have a handful of PAL JEDEC files. However, there are a bunch of them missing - notably Myarc and CorComp cards. What is needed is folks with the time (and talent) to trace the PAL inputs and outputs to come up with the necessary equations to reproduce the PALs. That is a daunting task. I have the code to do a large number of EPROMs for DSRs and could probably reproduce the PALs if I had the JEDEC files. There are several of us in the community that could do so. Maybe a group effort and a repository on Atariage?
#4 RickyDean ONLINE
RickyDean
  • 1,082 posts
Posted Wed Feb 27, 2019 8:28 AM
I remember seeing PAL equations in the TI DSDD Disk Controller package, I believe, how close to this model would Myarc and Corcomp stay?
#5 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 494 posts
Posted Wed Feb 27, 2019 8:34 AM
Very far... The CorComp floppy disk controller is significantly different, to start with the electronic design that is very very poor. The worst of the FDC controllers for TI-99/4A.
Satellize the PAL chips is quite easy, this board has no buffers... A shame.
Edited by fabrice montupet, Wed Feb 27, 2019 8:43 AM.
#6 RickyDean ONLINE
RickyDean
  • 1,082 posts
Posted Wed Feb 27, 2019 10:21 AM
Is it possible to use the datasheet for the particular disk controller chip, then look at other existing systems that either do have a documented disk controller using the same chip or just looking at what ic's match and what doesn't on a comparable board and by deduction recreate the jedec or a small smd board that could replace it? Just a thought. Like my Foundation z80 card uses the same chip for it's drive access,
#7 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 494 posts
Posted Wed Feb 27, 2019 10:41 AM
The CorComp FDC is based on the TMS9901 and WD2793 controllers  couple not the Foundation Z80 card or TI and WHT controllers, and there is no schematics around.  Without the jedec files or finding non protected PAL chips, the solution could be to study the two ROM chips and make a long work of retro engineering.
Not sure that someone will get on a such project.
Edited by fabrice montupet, Wed Feb 27, 2019 10:42 AM.
#8 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 494 posts
Posted Wed Feb 27, 2019 1:40 PM
Ooops! Typo error. I wanted to say "Myarc controller" and not WHT one.
I forgot to say that there are different revisions of the CorComp FDC, the REV A that has a WD1773 FDC controller and a later revision that has a WD2793. The PAL chips containt is specific for each revision.
Note that the PLS153AN PAL can be replaced by 12L6.
#9 RickyDean ONLINE
RickyDean
  • 1,082 posts
Posted Wed Feb 27, 2019 2:40 PM
" later revision that has a WD2793. The PAL chips containt is specific for each revision."
Yes, I have two of the WD2793 version and the side car version with the WD1773 chip inside. As a side note, and the reason I brought it up, was the Foundation Z80 card has the WD2793, built into it, and the circuitry seems to be close, at least from a reasonable perspective. I was going to play around with some  WD2797 and  WD3765 IC's to see if a home built controller on a protoboard is feasible.
#10 Astharot OFFLINE
Astharot
    Star Raider
  • 84 posts
  • Married
Posted Sat Mar 2, 2019 4:39 PM
I found a old explain create by paolo bagnaresi how built pal chip for myarc floppy controller.. i enclosed dump of floppy. Hope is usefully for community..
#11 Astharot OFFLINE
Astharot
    Star Raider
  • 84 posts
  • Married
Posted Sat Mar 2, 2019 5:54 PM
i Found the PAL file jed for myarc fdc controller and rs232 .. also this seem my memory no fault was work by Paolo Bagnaresi.. .. maybe is possible using this file rebuild a fdc myarc controller.. hope ;-)
#12 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,389 posts
Posted Sat Mar 2, 2019 8:42 PM
Nice find.  Paolo wrote a lot of information about the Myarc disk controller.  I have seen documentation that explains the memory layout, but never his Myarc FDC disassembled EPROM.  :(
#13 Astharot OFFLINE
Astharot
    Star Raider
  • 84 posts
  • Married
Posted Sun Mar 3, 2019 3:34 AM
Here i post a dump of disk full of information on myarc fdc controller with assembly source wrote by Paolo Bagnaresi.. i built this floppy take this info from many disk that i have .. at moment is all that i found.. :-)
#14 acadiel OFFLINE
acadiel
  • 1,499 posts
  • www.hexbus.com
Posted Mon Mar 4, 2019 7:46 AM
It’s amazing what people have floating around in their drives :-)
#15 RickyDean ONLINE
RickyDean
  • 1,082 posts
Posted Thu Mar 7, 2019 7:18 AM
Does anyone here, have or know where I could either get 1. A finished product, 2. The plans to build a product, 3. the place to mail two PAL's, for a PAL dumper?
I have been reading at sites like this, http://www.techno-junk.org/and believe the capability to read my PAL's on the CC disk drive already exist.
I blew one of my new CC a couple of months ago, as was stated in a previous post in another topic, some time back, The 9901 was blown and the bottom PAL was damaged on this device.
#16 Stuart OFFLINE
Stuart
    Dragonstomper
  • 854 posts
Posted Thu Mar 7, 2019 11:20 AM
Ricky, sent you a PM.
#17 helocast OFFLINE
helocast
    Chopper Commander
  • 189 posts
Posted Thu Mar 7, 2019 2:10 PM
You're welcome to what I have.
It isn't a 100% solution because I'm still working equations and double-checking my work.
Doug
#18 Stuart OFFLINE
Stuart
    Dragonstomper
  • 854 posts
Posted Fri Mar 8, 2019 2:51 AM
Doug
Great work Doug! Have you done a schematic as well as the board layout?
#19 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Fri Mar 8, 2019 10:41 AM
If he hasn't I will, as this is one of the only floppy disk controllers we don't have good schematics for yet. The only one left after this would be the Atronic controller. . .
#20 helocast OFFLINE
helocast
    Chopper Commander
  • 189 posts
Posted Fri Mar 8, 2019 12:07 PM
Thanks, it's on my list after brute force PAL reading and the ugly K-map minimization to get a JEDEC "equivalent".
Sorry, just trying to prioritize for the community.
Doug
EDIT: Just got the BOM done + "reader" layout I'm going to try ... wish there was more I could do to prevent any possible damage like adding buffers to inputs.
Edited by helocast, Fri Mar 8, 2019 12:40 PM.
#21 mizapf ONLINE
mizapf
  • 3,560 posts
Posted Fri Mar 8, 2019 2:50 PM
Once we have the schematics, it will be quite simple to add the Corcomp controller emulation to MAME.
#22 Stuart OFFLINE
Stuart
    Dragonstomper
  • 854 posts
Posted Fri Mar 8, 2019 3:43 PM
Doug
Doug, what are your thoughts behind your design for the PAL 'reader'? Going to try reading it in something like an EPROM programmer? I'm a little confused over what seems like rather complicated connections ...
#23 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Fri Mar 8, 2019 5:26 PM
The problem is that CorComp blew the read fuses, so the only way to really generate the right truth table is to run through all of the possible inputs and look to see what comes out. . .this is pretty much the same problem we have with all third-party cards/cartridges that use PALs.
#24 helocast OFFLINE
helocast
    Chopper Commander
  • 189 posts
Posted Mon Mar 11, 2019 7:46 PM
Nothing overly complicated and I modified it down once again in implementation to reduce the file size/permutations for somebody that wants to pick up the project from here.
My methodology here was to use both a TL866II+ and GQ 4x4 programmer (for redundancy, both set to slowest "read" setting possible) in a "27C020 (256Kx8bit EPROM) device mode" using address lines A0-A11 as PAL inputs and D7-D2 as PAL outputs (see reader jpg).
By using the 12 LSbits of the 18 programmer outputs one has to analyze only the first 4096 lines of each bin file. In similar fashion, by using the arbitrary 6 MSbits of the data bytes I weeded out the two unused bits by anding with 00111111 (see reader jpg).
It isn't a final solution:
- no logic minimization of raw PAL outputs
- no PAL output equations, hence no JEDEC fuse programming file
- no schematic like everybody wants
Takeaways:
- PAL FDCU6 logic is the more complex/active of the two based on byte changes in the output file I analyzed (two inputs are from self outputs, three inputs are from outputs of other PAL FDCU12).
  This is a poor man's feedback and introduces more logic delays, unlike a registered GAL which provides internal feedback into the input logic.
- PAL FDCU12 logic seems minimal based on byte changes in the output file I analyzed OR I have a malfunctioning FDCU12 chip as well. ¯\_(ツ)_/¯
- I have concerns that FDCU12 is using a clocked signal as a logic input (similar to a registered GAL). It is quite possible the original creator constructed a flip flop(s) out of internal combinatorial logic to further muddy the equations.
- A final thought, it may be possible to use the process I used with BOTH PALs interconnected per schematic to get a combined output (except one would have 1 extra "bit" output to deal with) for a new design using a small CPLD or even the more commonly available PALCE22V10.
- I don't have the software tools nor the time right now to minimize the outputs into equations.
Attached ZIP file contents:
PAL12L6-FDCU6            BIN file          Reader output raw
PAL12L6-FDCU12 BIN file Reader output raw
FDCU6 TXT file Reader output reduced. Bytes AND'd w/ 00111111
FDCU12 TXT file Reader output reduced. Bytes ANDed w/ 00111111
8Kx8 ROM DevID-06A0_Bank1 BIN file Not sure if original or MG EPROMS
8Kx8 ROM DevID-D1E4_Bank2 BIN file Not sure if original or MG EPROMS
reader JPG file Methodology used to extract PALs content to BIN
Corcomp_FDC-REVA PCB file ExpressPCB 7.8.0 design from physical PCB
PAL12L6 FDCU6 worksheet JPG file Fuse/input worksheet
PAL12L6 FDCU12 worksheet JPG file Fuse/input worksheet
PEBcontacts JPG file PEB I/O pinout
PAL12L6NC PDF file National Semiconductor Datasheet
Edited by helocast, Mon Mar 11, 2019 7:52 PM.
#25 atrax27407 ONLINE
atrax27407
  • 1,237 posts
Posted Mon Mar 11, 2019 9:49 PM
FYI - the EPROMs are the standard CorComp EPROMs. They are not the MG upgrades.
