Apple II+ with clone Saturn RAM card that causes bad video
1 reply to this topic
#1 electronizer OFFLINE
electronizer
    Chopper Commander
  • 118 posts
Posted Thu Feb 28, 2019 7:50 PM
I recently got an Apple II+ with a clone of the Saturn 128 memory card installed. I have it connected via composite video out to a modern LCD TV. With the memory card installed, there is a lot of red and blue color bleed around text on the screen, and a bunch of vertical blue dashed lines that are continually pulsating. Without the memory card, the text is crystal clear. Interestingly, whenever I load a program on disk, the bad text and vertical lines clear up while the disk drive is running, then come back.
Bad:
Attached File  5984D52B-1C44-4594-8ACA-3B9913CB134B.jpeg   580.2KB   1 downloads
Good (while disk is running):
Attached File  34326460-D4B9-4CDC-8C49-8093A43B2540.jpeg   991.96KB   1 downloads
Is there any way to fix this? Should I find an official Apple 64k upgrade card and replace the clone Saturn card? Do I even need a memory upgrade? Im guessing yes because a lot of the games Id want to play probably require 64k.
#2 Aunty Entity OFFLINE
Aunty Entity
    Star Raider
  • 67 posts
Posted Fri Mar 1, 2019 2:20 AM
Power issue, if it comes good while accessing the Floppy??
Reply to this topic
