Help! Weirdness and insanity!
20 replies to this topic
#1 Opry99er ONLINE
Opry99er
  • 10,679 posts
Posted Sun Mar 3, 2019 11:12 AM
Quick rundown:
At the CTIUG meeting, we had an issue with a PBox or card or something.
We were able to read and write to disks just fine, and we initialized and formatted a couple of disks.
On our third initialization attempt, the system refused to format a disk. It still reads and writes just fine, but it will not initialize. We tried multiple 32k cards, multiple disks, and 3 different disk managers. We also swapped drives.
We can read previously formatted disks, AND write to them--just cannot format/initialize.
What in the good hell would cause this?
Consoles tried:
Modified console (Vic Steerup)
Unmodified console (Ron Klein)
32k tried:
32k onboard a RAMDisk
Standard TI 32k
Drives tried:
Two separate 5.25" TEAC half height double sided drives
Disk managers tried;
MENU Disk manager (on RAMDisk)
DM1000 (on FinalGROM)
TI standard Disk Manager 2 cartridge
DM1000 (on XB2.7 cart)
Floppies tried:
4 different brands, all known to work on other systems.
#2 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Sun Mar 3, 2019 11:24 AM
The only thing that I don't see listed is a different floppy controller. The floppy controller sounds like the culprit. Also just for giggles I would try the floppy controller in a different slot in the PEB
#3 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 494 posts
Posted Sun Mar 3, 2019 11:50 AM
Track 0 dead?
#4 Opry99er ONLINE
Opry99er
  • 10,679 posts
Posted Sun Mar 3, 2019 11:51 AM
I was thinking floppy controller as well... Thinking though, why would it be able to read and write, but not initialize a disk?
Weird!
We will try moving the disk controller to another slot. That's a good idea.
#5 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 494 posts
Posted Sun Mar 3, 2019 12:07 PM
Maybe your controller can't access to track 0, this track is accessed during the format operation.
#6 Opry99er ONLINE
Opry99er
  • 10,679 posts
Posted Sun Mar 3, 2019 12:08 PM
Interesting... wonder what would cause that, fabrice? I need to look at the schematic I suppose
#7 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Sun Mar 3, 2019 12:59 PM
I just tried moving the controller.  That did not seem to help.  I am still able to read and write disks without issue, just can't initialize them.  Such a strange issue!  What part(s) in the controller could fail and still allow most functions to work?
Thanks everyone for your help so far.  Really appreciate it!
#8 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 390 posts
Posted Sun Mar 3, 2019 1:10 PM
Sometimes drives fail in a manner that causes physical damage to the disks! Particularly the to the inner or outer tracks, this can permutate the results when diagnosing other problems, if unnoticed.
#9 Lee Stewart OFFLINE
Lee Stewart
  • 3,947 posts
Posted Sun Mar 3, 2019 6:37 PM
As long as you use only 90 KiB diskettes in the system, you could try FORMAT-DISK and/or DISK-HEAD with TI Forth to see whether sectors 0 – 3 can be written.  See Chapter 5 of the TI Forth Instruction Manual (2nd LES Edition) in the TI-99/4A development resources thread.
...lee
#10 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Sun Mar 3, 2019 6:55 PM
I've seen specific drives act this way. It is likely a cap gone bad on the drive or controller.. after this many years..
people have complained they cant format the disks i sell on the pushbang drives for instance, but replacing them solves the problem
Greg
#11 sparkdrummer OFFLINE
sparkdrummer
  • 1,073 posts
  • Status? I don't need no stinkin' status!
Posted Sun Mar 3, 2019 7:41 PM
If you have one of the disks you formatted before things went flakey I would VERIFY that disk to see if all sectors check ok. I then would check that same disk in another system. Possibilitys I thought of were head alignment went south or motor speed if off. Another possibility is see how free the head moves on the rails.
#12 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Mon Mar 4, 2019 7:01 AM
If this FDC card has socketed IC's, take each one out and test it on a Mini Pro or some similar device to see if there are problems there. You haven't stated a controller brand so at this time I am assuming a TI controller, so unless there has been mods done in the past, I would say that all the IC's are soldered straight to the board, which will make it much harder to diagnose. I just got two Foundation Memory cards functional again last week by testing and finding some bad IC's, due to age and storage.
#13 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Mon Mar 4, 2019 7:08 AM
I appreciate everyone's suggestions so far.  As an FYI, this issue is being experienced with 2 identical TEAC drives.  I only have a cable that supports the use of a single floppy drive, but swapping drives (for testing) produces the same results.  Disks can be read and written to, just not formatted.  If I write to a disk in one drive, it can be read back without issue on the other drive.  I am looking for one more 5.25" drive to add to the test.
Thanks!
#14 FarmerPotato OFFLINE
FarmerPotato
    Moonsweeper
  • 310 posts
Posted Mon Mar 4, 2019 9:46 AM
Quick rundown:
I looked for IO Error 43 in the TI disk DSR source code. I did not find it yet.
It means Illegal Operation on Seek/Rewind/Restore.
Some guesses:
1. I wonder what is the expected error when you enable Protect Disk (the anti-copy protection flag, letter P on sector 0)
2. There was an error trying to move the head to a particular track (but this should be a 6 not a 3)
Maybe it is a power supply issue. Try a different Pbox? Drives draw the most power when spinning and seeking.
#15 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Mon Mar 4, 2019 10:07 AM
are both drives powered up? if so try with just one powered and the other completely unplugged
#16 atrax27407 OFFLINE
atrax27407
  • 1,237 posts
Posted Mon Mar 4, 2019 10:20 AM
Have you checked the cable for continuity?
#17 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Tue Mar 5, 2019 5:34 AM
I need to check that tonight after work.
#18 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Tue Mar 5, 2019 5:35 AM
No I have not.  Is there a pin specifically related to the disk initialize process?  I needed a dual floppy cable and planned to order a new one from ArcadeShopper soon.
#19 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Tue Mar 5, 2019 5:37 AM
Yes, it is a TI controller.  I'm looking for any working loaner to see if it helps with the issue.
#20 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Some guesses:
Power supply has been mentioned twice.  I do have access to an empty (spare) PEB and will be trying that out as well.
#21 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 60 posts
Posted Tue Mar 5, 2019 5:39 AM
...lee
Hi Lee.  I'm interested in this test.  I've never used Forth, but will look for it and see what happens.  Thank you!
