AtariNesSega Posted March 4, 2019 Share Posted March 4, 2019 My controller goes up down an left an when I take it apart I can turn the little knob inside an it will go right when I put it back together it wont help needed? Quote Link to comment Share on other sites More sharing options...
AtariNesSega Posted March 4, 2019 Author Share Posted March 4, 2019 Bump Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 4, 2019 Share Posted March 4, 2019 Well, you need to test with other controllers to see if this is a consistent issue. Reason being there are two adjustments to be had for this. There is a potentiometer inside the 5200 to the lower left of the power switch that can be turned to adjust this. But...the controllers themselves also have their own calibration that should be performed on while NOT connected to the controller port to get to a starting point before making adjustements to the console itself. If you find that only this one controller has the issue, then it is the controller and you wouldn't want to adjust the 5200's controller calibration and make other controllers suddenly out of calibration and not work either? Quote Link to comment Share on other sites More sharing options...
bohoki Posted March 4, 2019 Share Posted March 4, 2019 what i would do is with the controller apart pop in missile command and make sure the lefty righty pot arm is in the 6 oclock position when the crosshairs are centered sometimes its hard to get the actuator plate to grab the pot arm when reassembling Quote Link to comment Share on other sites More sharing options...
